Hector T.
Grésille
Hector T.
Combiné avec mes Truthear Nova, j´ai enfin la puissance nécessaire pour écouter mes musiques pleinement.
Les bass sont...
Hector T.
Bien mais gros
Le connecteur fonctionne correctement, mais ma coque (Apple) bloque un peu la connexion et je dois forcer pour le brancher...
Customers reviews - There are 19052 reviews.
Michael M.
BURSON AUDIO V7 CLASSIC PRO Dual OPA (Pair) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
Opams musical fidelity trivista dac
Perfect packing, quick delivery, great product. I very am blessed with the sound after the upgrade
Michael M.
Opams upgrade in musical fidelity trivista DAC
Perfect packing, quick delivery, great product. I am
Sandu T.
TOPPING D90 III DISCRETE Balanced Discrete DAC Bluetooth 5.1 32bit 768kHz DSD512 Black The D90 III Discrete balanced DAC from Topping is the parallel to the D90III using a 100% discrete digital/analogue conversion module. Here, conversion is performed by a PSRM...
Super !
Super DAC, looks identical, but they don't do the same thing :) It sounds very good, it's worth it! This company has made me a fan forever. Bravo to the engineers! With love from Romania!
Marian Serban T.
Price/Quality acceptable
First I want to thank Audiophonics for the excellent customer care service and for the fast shipping.
Be aware of the dimensions, (I wasn't) they are quite small, the nut, the grover and the existed piece for soldering the wire are not usable ... they contain iron (easy magnetized), the rest seems to be ok, made from brass with no magnetic properties, as in title price/quality acceptable
Matthias L.
Dac complètement incroyable
Je rejoins absolument le premier avis !!
Comment vous dire, j'ai voulu le comparer... J'ai donc écouté sur du matos meilleur que le mien les propositions en magasins à Paris (j'ai quand même un ampli Cambridge, des enceintes B&W détaillées) et constat dingue :
Son meilleur selon mon humble avis que les Dacs EverSolo même le meilleur modèle (son décharné à côté), Atoll même celui à deux mille euros quelque chose, ibasso meilleur, j'ai poussé la comparaison avec un Dac élitiste un Dac Moon à 2800 euros: il y avait évidence qu'Ibasso le survolait en terme de fidélité et de dynamisme, malgré tout le boniment du vendeur (c'est le seul l'ibasso qui permet d'entendre réellement de manière réaliste de la pluie tomber sur "the road to hell" de Chris Rea et je connais le morceau depuis 20 ans
Armin w.
Italian premium? Well ...
... this case is called premium, but the 10 mm front plate is horribly manufactured. I don't expect high end, but simple and well made parts.
The round edges of the front are very sloppy shaped. My aunt could do this better with her nail file. Looks like a missused second hand front plate. Also the anodizing looks dirty at the edges.
At the end, it seems that the corners were rounded after anodizing(!) and on the backside of the front are plenty of CNC cuts that make no sense at all.
So unusable, bad quality factory parts gets modified and sold as DIY case?
This is not premium at all, then don't call it premium. Call it saved from the trash parts.
Very dissapointing.
jean-luc s.
bonne surprise
dernière étape,monter les 12ax7 sur mon DAC PRIMALUNA ,encore un gap;des basses plus profondes mais bien maitrisées ,des .((voix très présentes (saxo plus chaleureux).6 tubes changés de mème marque et au final un son ample, clair ,immersif,détaillé,bref une belle évolution.voir mes commentaires sur tubes 12au7 et5ar4 GENALEX GOLD LION.envoi très bien emballé et rapide.
jean-luc s.
bonne surprise
après avoir changer les tubes 5ar4 de mon DAC PRIMALUNA ,j'ai monté les 12au7 et là les aigus sont plus clairs et l'ensemble est plus dynamique.voir la suite sur GENALEX GOLD LION 12ax7.
jean-luc s.
bonne surprise
le remplacement de ces tube sur mon DAC PRIMALUNA m'apporte profondeur et élargissement de la scène sonore.ce petit plus m'immerge encore plus dans la musique.les attaques de note sont plus franches,bon choix.
Hugo Darien O.
FX-AUDIO FX03 DAC USB ES9028Q2M 32bit 384kHz DSD256 Black This small, affordable FX-Audio FX03 DAC offers great quality. It incorporates an ESS Technology ES9028Q2M DAC chip and a SA9137L USB interface, enabling it to decode up to PCM...
for the price is 5 stars
this is the cheapest dsd256 dac i know it sounds very good for the price, what you miss is litle details in the sound and you shuold have a warm amp if possible, because, this dac is litle on the bright side.
Antoine C.
Cache bien son jeu...
Contrairement aux équivalents fabriqués par Furutech ou WBT, Mundorf n'a pas misé sur le design ou le raffinement : aucun "sex appeal" ici.
Ressemblent à des connecteurs génériques, "pas cher".
En revanche tout l'intérêt de ces Mundorf MConnect réside dans la qualité sonore.
Utilisés sur un vieux Madrigal double mono, le résultat est très musical avec une présentation naturelle. La scene sonore offre un très bon focus et les plans sont assez bien séparés.
Pour une finition plaquée Or, c'est au dessus de la moyenne.
La connection est faite sans soudure dans mon cas, j'ai serti des cosses à oeillet Mundorf, les écrous permettent un serrage et un contact parfaits.
On peut faire passer du courant comme avec une batterie de camion : idéal pour les gros bloc mono qui drivent des enceintes avec un rendement faible.
Pour ceux qui hésitent, ne vous y trompez pas... ce n'est pas par hasard que ce fabricant et ce modèle en particulier soient utilisés par MAGICO, SOULUTION, PILIUM pour équiper leurs produits.
Une fois montés ils seront invisibles de toute façon, c'est le résultat qui compte et le résultat est là !
Antoine C.
Impressionnant mais...
Qualité de fabrication irréprochable.
La tension des lames optimise le contact, il est assez difficile à brancher la première fois.
La quantité d'information que ce connecteur permet de révéler est bluffante, surtout avec un composant numérique.
Le contrôle du Grave est fabuleux et même si il apparait moins présent sa présentation reste dynamique, rapide et très tendue : vivante !
Le medium est beaucoup moins fluide qu'avec des connecteurs plaqués or ou rhodium.
L'aigu offre une quantité de détail bluffante à la première écoute, avec beaucoup d'extension mais à la longue cela ne sera pas toujours confortable.
Une prise qui amène beaucoup de transparence et de réalisme mais qui selon le câble utilisé et le composant associé pourra s'avérer être difficile à intégrer.
Jorma Design équipe certains de leurs cables secteur avec ce modèle.
Selon le type de musique et les goûts de chacun il pourra faire des merveilles ou introduire un déséquilibre évident dans le registre.
Un chose est certaine le C-004 ne pourra s'inviter que dans des systèmes très haut de gamme : cette prise ne pardonne rien.
Antoine C.
Belle qualité Made in Japan
Très belle qualité de fabrication, meilleure que le milieu de gamme Furutech.
Sonorité douce intéressante pour des configurations dont les aigus sont mis en avant.
Offre une belle densité dans la présentation et surtout un fluidité et une musicalité difficiles à battre.
La contrepartie est le manque de transparence et de contrôle sur l'ensemble du registre.
Hessel L.
Very good amplifier for the money
It’s a massive difference compared to the Onkyo receiver I had previously. Much more detail and dynamic range driving some B&W CDM7 SE’s. Very happy with the amp, especially at this price point.
Grégoire B.
FOSI AUDIO BOX X3 MM Phono Preamplifier with Tubes 2xGE5654 Stereo Bluetooth 5.0 Black With its BOX X3 tube preamplifier, big brother to the BOX X2, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound...
trés bon matériel
Très bon petit préampli phono - Sonne nettement mieux que celui de l'ampli AKAI - Les fonctions Bluetooth et line son des ajouts très intéressants - Les tubes fournis sont très corrects mais le remplacement par des SOVTEK change complétement la donne. Le son est extrêmement clair et précis, notamment en utilisant les réglages grave et aigus afin d'adapter à son gout ou au rendu de ses enceintes.
alric M.
LHY AUDIO LPS-A6 230V Linear Power Supply Module for EverSolo DMP-A6 The LPS-A6 linear power supply module developed by LHY Audio has been specially designed to improve the power supply stage of the EverSolo DMP-A6 and DMP-A6 Master Edition...
génial
Monter hier dans un eversolo dmp6 master édition , montage en 15mn plus in pluay , qualité top packagé complet gant outil. Vidéo sur le net facilement trouvable , pas besoin de mettre de rondelle pour isoler c'est idem que montage origine , attention quand vous basculer le couvercle en avant la fiche pour l'écran et le bouton son très fragile et peuvent casser ( mettre quelque chose pour tenir le capot une fois basculer en avant ) bien éteindre l'appareil et appuyer 20/30s sur le bouton pour vider le courant avant remplacement des alim. Sinon c'est net ! Le gain et immédiat ! Aération de la scène sonore , spacialisation , gain en dynamique , basse plus franche et nerveuse le son et beaucoup plus large et aérien. On gagne un peut en détail . Le gain et a la hauteur de l'investissement . Je ne peut que recommander , je suis encore en rodage mais sur mon système le gain fut aussi haut que lors de l'ajout d'un conditionneur sur l'installation . Je recommande chaudement de plus vous protéger votre système cette alim a un fusible que celle d'origine n'a pas . Pour 250e vous aller améliorer votre matériel et le retour a l'origine n'est plus possible ! Merci Audiophonics pour le vois bien protéger .
alric M.
excellentissime !!!!
Alors que dire ! J'ai eu plusieurs dac notamment sabre , et wolfson , et puis après avoir éplucher forum , vidéo youtube ect j'ai longuement esiter en un smsl en double dac sabre pro et celui ci . Celui ci étant dans la ligne de mon double wolfson je cherchais du charnel du détail de aéré , ce sac et tous simplement une pure tuerie , après avoir eu le retour de plusieurs youtubeur sur ce modèle seul le gustard x26 et un peut supérieur mais également des centaines d'euros plus cher . Pour en revenir à celui ci finition top , mettre le profil sur nos pour ne pas avoir le sur échantillonnage . Privilégiez la parte USB qui est tous bonnement fabuleuse , le coaxial sonne vraiment très bien ! La télécommande et un peut cheap ( si on cherche du chichi ) sinon laisser le dac allumer il a une fonction pour le laisser en veille ce qui baisse ça consommation et il reste a température pour être optimal , l'écran ce met en veille au bou de 5mn pour éviter le marquage de l'écran OLED . Sinon encore une fois la qualité de son et prodigieuse . J'ai eu des sacs a 1500/2000e et celui ci est vraiment hors de tous , une société qui est spécifique dans ce domaine trop peux connu du grand public leur produit mériterait d'être plus connu , petit défaut d'affichage 2 mois après mais le sav formidable ma remplacer la machine . Ce n'étais rien de grave une ligne de pixel HS . Le matériel lui marchait formidablement bien. A savoir que entre la première heure et 1/2 semaine après il sonne encore mieux , lors du passage au sav je me suis retrouvée sur le double dac de mon eversolo dmp6 master édition ( qui est un bon produit ) mais bordel ... A des années lumières ce singxer . Perso je ne changerai pour rien au monde . ( Chez moi le eversolo dmp6 master édition en USB sur le singxer et le singxer en xlr sur mon audia flight fl3s ) et vraiment le mariage et merveilleux . Ce dac coûte une somme mais vois ne serrez pas déçu . L'intérieur et très très bien construit ça transpire la qualité .
alric M.
Ce câble et très bien pour le prix la finition et exemplaire la spacialisation et excellente les basses sont dégraisser , les médiums aéré les aigus très détaillé j'ai adorer ce câble il tiens la comparaison avec des câbles a 2/3x sont prix je l'ai remplacer par un wireworld série 8 qui pour le double du prix de celui ci ma apporté un peut plus de dynamique. A comparer ce câble et formidable et nul besoin d'investir plus surtout pour avoir un faible gain.
alric M.
Très bon produit plus petit en vrai quand photo mais font largement le travail , mi sous mon dac et mon lecteur réseau prix imbattables
alric M.
AUDIOPHONICS WIRE Interconnect Cable Stereo XLR OFC Copper Gold Plated 75cm (Pair) The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire XLR cable features a...
Bon produit bien fini , léger gain comparer a mes Real câble 128 qui était plutôt déjà très bien fini , j'ai légèrement gagner en spacialisation , des basses légèrement plus sèches et moin dominante. Rapport qualité prix imbattables je recommande
Didier f.
SHANLING M1 PLUS DAP Digital Music Player DAC ES9069Q Bluetooth 5.2 LDAC 32bit 768kHz DSD512 Black Shanling's M1 Plus is a technical and aesthetic evolution of the M1S high-fidelity digital music player. This Plus version benefits from an improved digital/analogue conversion...
Déçu...
J'ai déjà son "petit" frère le M1s.
Je pensais évoluer vers un baladeur légèrement plus performant et encore plus intuitif en terme de navigation, et bien pas du tout.
Je n'ai entendu aucune différence sonore, pas moins bien mais pas non plus mieux.
En ce qui concerne la navigation le M1s est plus logique, vous permettant de revenir en arrière lorsque vous êtes sur un morceau de musique en faisant glisser votre doigt vers la droite, ce qui n'est pas le cas du M1 plus.
La définition des écritures est également mieux détourer sur le M1s.
Ce n'est certainement pas un mauvais produit mais je ne comprends pas ce que shanling a voulu faire en sortant ce baladeur.
Seul la prise en main sera peut-être plus intéressante pour certains d'entre vous au vu de son gabarit.
Daniel D.
Super qualité/prix
Ces schuko Viborg sont à mon sens meilleur que les viborg cuivre or argent (qui sont quand même pas mal du tout). Elle sont plus rapide avec image plus profonde et un meilleur rendu des voix, et oui il me semble aussi avec des basses plus chaleureuses. Elles pèchent un peu sur la séparation pas aussi précises que d'autres prises et par le fait d'avoir un rendu légèrement étheré mais pas montant. A mon sens à utiliser avec parcimonie sinon on perd en musicalité. Sur un système avec 8 prises je n'en ai actuellement que 2.
Daniel D.
Super prises IEC
J'ai acheté 4 de ces IEC Oyaide pour équipement de différents appareils. Je confirme les qualités décrites dans les différents commentaires à savoir neutre, rapide, meilleur perception des voix et très belle scène sonore (bien ouverte avec une meilleure séparation des voix). Sur mon système elle ont eu l'effet décrit ci-dessus sur la source, le préampli et la barette multiprise, avec probablement des effets cumulés. Par contre elles n'ont pas du tout matchés avec mes blocs mono Aesthetix (message sonore trop desséché, l'écoute devient raide). J'ai donc réinstallé les prises IEC Iego 8085 pour leur côté chaleureux et mélodieux. Toutes ces oyaide 004 sont associées en shucko avec d'autres marques pour mixer les sonorités.
Fabrizio P.
DAC BEA1
Ottimo prodotto, costruito bene, molto utili e rare le uscite digitali, per un prodotto di questo livello di prezzo. Spedizione veloce e ottimo imballo. Venditore consigliato.
Željko J.
Mr
I have recently bought case 4U 300 mm front 4mm black.
Arrived today.
Excellent package and prerfect product.
Highly recommended, positive experience.
Would suggest to add assembly instructions to package.
Regards, Željko
Luis Enrique G.
OUTSTANDIG
Absolutely wonderful. Gives you all the details, colors, atmosphere and space you can dream at third cost of those very renamed brands. I am absolutely sold with this cable. My system is quite high level (CH Precision A1.5 + Holoaudio May DAC + Marten Mingus speakers), able to give all posible details of any record, and with this cable I can hear so many much more now than with my previous so famous super expensive Audioquest cable, that I can't believe it.
It takes about 60 hours of use to break through. In the beginning sounds very detailed, but constrained, a little Metallic, but after those 60-70 hours, its spacious, open, dynamic, brilliant, powerful, detailed, harmonic....
For this price, it's impossible to find a better speaker cable, anywhere, any brand.
Rqp imbattable
Installé sur mon ampli , ce câble est neutre, et transparent. Alimente parfaitement mon ampli 3e audio. Également très bon pour les sources.
Daniel M.
Choisi pour alimenter les "basses" de mes enceintes en bi-amplification.
Belle amélioration du rendu, musicalité accrue.
Juste la couleur grise, pas très gai. Je vais les peindre en blanc.
Pierre B.
AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home...
Excellent ampli
Utilisé sur 5 canaux avec mes enceintes LCR Kef LS50 Meta, R2 et 2 bass shakers BST-300ex.
Un seul souci a déploré : l'appareil était allumé en permanence, même « éteint ».
Après un bref échange, le SAV conclu qu'un relais était collé. Ampli expédié le lundi et récupéré le samedi, sans frais. Aucun problème depuis.
Giorgio B.
AUDIOPHONICS PULSAR Male USB-A to Male USB-B Cable Silver / Gold Plated 1.5m The Audiophonics Pulsar USB cable, thanks to a precise and meticulous design, using high-end materials, ensures a stable and clean signal transmission for high quality sound...
Mon meilleur câble usb
J'ai eu des câbles de bases, des audioquest, un câble usb diy acheter sur leboncoin, mais celui la c'est le meilleur.
En terme de qualité audio c'est meilleur qu'un câble de base c'est sûre, et je n'entend pas de différence avec des câbles plus chère.
Et en plus de sa c'est un tank, une qualité de fabrication irréprochable a mes yeux.
Giorgio B.
PANGEA PREMIER SE BALANCED XLR Modulation Cable Balanced 0.6m (Pair) PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first...
Un régale
Ce cable est bien meilleur qu'une paire de RCA Atlas Element, c'est ma seul référence.
Je vous le conseille
Puis suivant les topologie de préampli/ampli c'est conseiller de passer sur du XLR.
Il offre Plus de dynamique
Un fond beacoup plus silencieux - j'entend plus aucun bruit parasite en fond.
J'entend tout les échos et réverbération des enregistrement.
Pour "juste un cable XLR" c'est beacoup d'apport en qualité audio.
Giorgio B.
Bon cable robuste
Il fait bien son travail en apportant une meilleur qualité audio qu'un cable d'origine de base.
Attention son blindage est un peu rigide, donc c'est un avantage au niveau solidité, mais si vous essayer de le mettre entre un équipement audio et un mur il se pliera difficilement, mais c'est faisable
David R.
Utilisés pour faire des pieds de platine vinyle réglables en hauteur.
Pieds sympas, bien finis, permettent un montage par le haut ou le bas, possible d'intervertir le sens de montage (le tout avec une visserie M4, pour du M6 il faudra les modifier)
Seul bémol, les parties noires ne sont pas en caoutchouc mais faites dans un plastique souple, donc non amortissant (flexible mais dur). Cependant, l'effet anti-glisse est bon.
Didier T.
Une leçon de musique... et de vie...
La vie nous réserve parfois des surprises qui nous prennent de court.
Disons-le, le cénacle audiophile raffole de tics de langages audiophiles bien à lui pour qualifier telle ou telle caractéristique ou ressenti,
Ca permet de passer pour un spécialiste, expert d'écoute... de matériel, habitude également mienne depuis plus de 30 ans.
Jusqu'à aujourd'hui et la magistrale leçon que Ludic m'a donné rendant ces expressions risibles ou grotesques, c'est selon.
Quel que soit le style retranscrit, le musicien que je suis s'est subitement retrouvé face aux couleurs habituelles des contrebasses, voix, pianos, guitares (mon instrument de prédilection), électriques ou non, et j'en passe, dont les textures coulent spontanément avec une majesté toute aérienne.
Toute conjecture à l'égard du Silenos, tout décorticage de ses qualités et toute envie de comparaison volent en éclats.
Moi non plus je ne comprends pas trop et pour moi aussi ce sera très vraisemblablement le dernier.
Siniša B.
Great upgrade for LPS
Significantly better quality compared to the original cables that came with the LPS. The sound is a bit more spacious and open. The quality and design are perfect—definitely not snake oil.
Dominique L.
Très bon câble pour mon système.
Comme beaucoup d'entre nous, j'ai plusieurs fois changé les câbles HP de ma chaine. Sans marque, Monster Cable, Sommer, câble téléphone diy, Leroy Merlin, Viard, Van Den Hull. Il y avait toujours quelque chose qui au fil du temps me rebutait : platitude, mollesse, pas de grave, trop de grave, trop d'aigus etc ... Le VDH Clearwater ,était le plus aéré, avec du relief et la meilleure image. C'est ce que je recherche, mais, malheureusement, le Van Den Hull est trop montant (argent/cuivre ?) dans mon système ou plutôt il renforce ce coté scintillant et fatiguant du tweeter.
Le Mogami 3082 a les qualités de scène sonore, de transparence du Van den Hull sans avoir ce haut medium et ces aigus qui parfois me vrillaient les tympans. Pour l'instant, je ne vois rien à lui reprocher, au contraire ! Et puis, le prix est une autre de ses qualités.
Ah si, un petit défaut : il faut un peu bricoler avant de l'utiliser car la tresse autour de l'âme centrale doit être protégée afin de servir de " neutre ".
Matt H.
Expensive but worth it
I have just replaced the moulded IEC’s on a pair of PS Audio Premier sc cables feeding my active speakers and also the IEC and mains plug on a Wireworld Electra 5.2 that feeds my balanced transformer, feeding my source equipment.
Really impressed with the build quality and solid grip the IEC has when plugged in.
Nice uplift in sound quality and quieter mains supply allowing more detail through. Timing seems to have improved along with a more 3D soundstage.
Roland L.
FOSI AUDIO V1.0G Class D Stereo Amplifier TPA3116 2x50W 4 Ohm This small Fosi Audio V1.0G integrated amplifier is an affordable, high-quality Class D stereo amplifier. It incorporates a TI TPA3116D2 amplifier chip enabling it to develop...
Fosi audio V1.0G
Étonnant ce petit ampli, il est vraiment très musical, très équilibré, il est même fourni avec son alim secteur ! Super rapport qualité prix
Roland L.
MEAN WELL LRS-150-36 SMPS Switching Mode Power Supply Module 36V 4.3A 150W This Mean Well LRS-150-36 SMPS switching power supply is capable of delivering 36V and 4.3A for a power output of 150W. Its low-profile 1U form...
Très bonne alimentation.
Liam O.
EVERSOLO DMP-A6 MASTER EDITION UPGRADE 4TO Streamer 2xES9038Q2M WiFi DLNA AirPlay 2 Roon Bluetooth aptX HD 32bit 768kHz DSD512 Eversolo presents with its DMP-A6 MASTER EDITION a streamer as powerful as it is intuitive and stylish. It will allow you to stream your music with ease while enjoying excellent...
Excellent Service.
I learned of Audiophonics while watching a Youtube video about Eversolo streamers/dacs. It was mentioned that Audiophonics, who have a comprehensive workshop, would implement upgrades to the units to customers requirements. I ordered the Eversolo DMP-A6 Master Edition with the linear power supply, 4TB SSD and external cd/writer. My order was dealt with very expeditiously and arrived safely by courier.
The Eversolo installed without problems and I am very happy indeed with the sound. The Company responds to queries by return and I would be happy to deal with them again.
Liam.
J'ai entendu parler d'Audiophonics en regardant une vidéo Youtube sur les streamers/dacs Eversolo. Il a été mentionné qu'Audiophonics, qui dispose d'un atelier complet, mettrait en œuvre des mises à niveau des unités selon les exigences des clients. J'ai commandé l'Eversolo DMP-A6 Master Edition avec l'alimentation linéaire, un SSD de 4 To et un CD/graveur externe. Ma commande a été traitée très rapidement et est arrivée en toute sécurité par courrier. L'Eversolo s'est installé sans problème et je suis vraiment très content du son. La société répond aux questions par retour et je serais heureux de les traiter à nouveau.
Liam.
Robert v.
Great value CD-player upgrade!
Audiophonics did a fantastic job again with this DigiRescue Reclocker. I have the reclocker connected to a quite 'regular' 1990s Sony cd-player that has a Toslink output, and I power it with Audiophonics' 5V linear powersupply, on which I still had an unused USB 5V out. I use the "Canare by Audiophonics" digital coax cable to connect it to my DAC's s/pdif in, and a glass-based Toslink cable between the cd-player and the DigiRecue.
Before getting the Digirescue, I was not able to hear a difference between the cd-player's internal DAC and my external DAC. I am happy to report this is no longer the case now!
This device feels very well built, with metal housing and nice sturdy RCA connections. The reclocker has not only increased clarity and precision as advertised, but I can also clearly notice better dynamics and imaging. Overall, I experience more presence and enjoy my CD's more now. One thing to note in my setup, is that the bass not only gained presence, but also somehow feels significantly louder. That could/should be just due to either perceptual change as a result from better clarity and dynamics, or perhaps my smaller room size now more prominently interacting with these frequencies from the former. Either way, it's not on a level that's disturbing me but it was unanticipated and interesting.
Toslink to Coax conversion/ port choice is fully automatic, so you can tuck this small device also in difficult to reach spaces, should you want to.
The web-shopping experience has room for improvement: it is not cool that the product suddenly increased by 6 Euros in price during shopping/looking around. I wish that the advertised product price would be what you see the first time, and the web-store leaves out the marketing trickery.
Patrick R.
Protège bien
C’est sûrement un très bon produit mais je n’avais pas compris qu’il faut absolument l’utiliser en complément du desoxidant d100 (pas gold)
Patrick R.
Belles qualités
Montée sur un TCS31avec une IEC 50 NCF. Le résultat est un câble vraiment exceptionnel, sur mon DAC. Mise en remplacement d’une shucko Charlin. Il y a une petite amélioration en terme de contrôle: grave encore mieux tenu, équilibre général.
Arnaud B.
Ces pointes sont très bien usinées.
Un conseil sur le sens de positionnement de la pointe vers le haut ou vers le bas aurait été judicieux, il faut fait des essais e faire confiance à ses oreilles ce qui n est pas plus mal .
Arnaud B.
Ce câble haut parleur transmet le signal de façon équilibrée, sans coloration.
Il est utilisé en câblage interne dans les enceintes Revival Atalante 3, enceintes.
Je conseille ce produit Van Den Hul sans restriction
Étonnant !
Essayé sur des colonnes 2,5 voies 6 ohms 92db, en simple utilisation et strap basses aigus.
C' est un excellent midrange ! Il ne se suffit pas à lui seul mais peut être dans une composition plus complexe de câble en apportant des qualités de bas, haut medium indéniables!
De la précision, dynamique, finesse et beauté du son. Excellentissime !!
Fasi I.
DAC Module MS8413 SPDIF Coaxial Optical 24bit 192kHz This small, affordable DAC module is equipped with an MS8413 digital-to-analog conversion chip and supports PCM audio streams up to 24bit 192kHz. On the input side, the module...
I love it
an excellent value for money small module with outstanding sound. it can even drive a Hifiman HE400se with pleasant dynamics, albeit relatively quietly :)
Hocine H.
Belle boîte
Achetez uniquement pour le caisson et les embases, j'ai retiré le filtre, bypassé l'interrupteur et le fusible à réarmement et changé tout le câblage interne.
J'ai recâblé avec du OYAIDE EE / F-S2.0 V2 de3.3mm² et intégré un fitre SCHAFFNER protégé. Le résultat est au-delà de mes espérances tant la qualité est améliorée, mais comme toujours, la qualité du son est subjective pour chacun.
Je l'avais testé stock et j'ai été très déçu par rapport à ce que j'avais avant et ne regrette pas le tweak de ce distributeur.
Il revient au final plus cher de 160 euros, ce qui monte son coup à 400 euros avec le filtre et le câble, mais surpasse largement des distributeurs plus onéreux que j'ai pu posséder. Il faut aussi avoir envie de bricoler et il n'y a rien de compliqué, la grande difficulté réside dans le retrait des cosses sur l'interrupteur et le fusible car VIBORG a eu la bonne idée de les souder. Et pour finir, en suface il parait bien fini et propre, mais une fois démonté beaucoup de surprises sur la pietre qualité des éléments utilisés apparaissent, surtout dans un distributeur secteur ; bref tout est propre maintenant et ne m'en separerais pas de sitôt.
Même sans modification il vaut son prix, sauf le filtre qui est juste bon à jeter.
Bruno C.
THINHYA JA 310
utilisé avec une sortie optique toslink sur un ampli : son impeccable. L'appareil est bien fini , il fait bien son job. Il y a un petit afficheur bien visible indiquant piste et temps écoulé, situé sous le couvercle. L'objet est compact. Le bruit de rotation est très léger. C'est du made in China ( le prix !) , avec une notice uniquement en chinois. Pour info, le bouton on est celui du volume qu'il faut enfoncer. Il faut ajouter une alimentation , mais audiophonics le précise bien.
Alain V.
Quelle claque !
Vraiment impressionné par cet ampli, quelle puissance, que de détails, magnifiques spatialisation et tout cela à un prix mini. Enorme merci à David Aubert pour le précieux conseil !
