TINYSINE TSA8802B Stereo Amplifier Module
The TinySine TSA8802B amplifier module combines the functions of a stereo Class D amplifier, a DAC / DSP and incorporates an AudioB I2S Bluetooth receiver supporting high-resolution aptX and aptX Low Latency codecs. It is capable of delivering up to 2x88W of power at 4Ω. To achieve this, it uses TPA3221 amplifier chips. DAC / DSP signal processing is carried out by an ADAU1701 chip, enabling tone adjustment for each channel. In addition to Bluetooth reception, a stereo RCA input is also available. This module also supports TWS, enabling several modules to be connected together.
Reference : 20743
59,91 €tax incl.
49,92 € tax excl.
Shipping date: 01-12-2026.
TinySine TSA8802B Class D Stereo Amplifier Module TPA3221 DAC DSP ADAU1701 Bluetooth 2x88W 4 Ohm
TinySine TSA8802B : Front view
The ADAU1701 DSP chip has a preloaded program for adjusting gain, bass, midrange and treble in the Sigma Studio DSP program/interface. A debug port is available for Sigma Studio. To access advanced features, users can program the TSA8802B module via TinySine's USBi programmer. Advanced features available include EQ, crossover, bass enhancement, multi-band dynamic processing, delay compensation and more.
The TSA8802B amplifier module is powered by 12V-30V DC and is capable of driving passive loudspeakers with an impedance of 2Ω, 4Ω or 8Ω.
TinySine TSA8802B overview
TinySine TSA8802B : Descriptive diagram of the different components
1External LED port
2DC power input
3RCA input
4Output 2x100W
5DSP input/output
6External button port
7Potentiometer port
8DSP programming port
Product typeAmplifier module
Amplification typeClass D
Channels2
Output power2x 112W @ 3Ω, 10% THD+N
2x 105W @ 4Ω, 10% THD+N
2x 100W @ 3Ω, 1% THD+N
2x 88W @ 4Ω, 1% THD+N
InputsBluetooth
1x Stereo RCA
OutputScrew terminals
Bluetooth version5.1
Supported Bluetooth codecsaptX, aptX Low Latency, SBC, AAC
TWS support
I2S sampling rate48kHz
Amplification chipsTPA3221
DSP chipADAU1701
Total harmonic distortion more noise (THD+N)0.02% @ 1W
Signal-to-noise ratio (SNR)108dB @ A-wt, gain=18dB
Dynamic range109dB @ A-wt, gain=18dB
Minimum load impedance3-4Ω
Gain18dB
24dB
30dB
34dB
Efficiency90% @ 100W, 4Ω
Input impedance48kΩ @ 18dB
24kΩ @ 24dB
12kΩ @ 30dB
7.7kΩ @ 34dB
ProtectionsOver voltage
Under voltage
Over current
Over heat
Supply voltage10-30V DC (power supply sold separately)
Dimensions135 x 92 x 35mm
Package1x TinySine TSA8802B
1x Bluetooth antenna
Channel2 (Stereo)
Amplifier chipTPA3221
Power (W)88
TINYSINE TSA8802B Class D Stereo Amplifier Module TPA3221 DAC DSP ADAU1701 Bluetooth 2x88W 4 Ohm
The TinySine TSA8802B amplifier module combines the functions of a stereo Class D amplifier, a DAC / DSP and incorporates an AudioB I2S Bluetooth...
