Jochen M.
Tout n'est pas parfait
Richard M.
Bernard g.
Excellente Interface
Customers reviews - There are 19551 reviews.
Damianos D.
Simple and versatile with high quality parts
I use this buffer combined with two Mundorf mcaps, a 10K ALPS blue pot (I know that a 50K pot is recommended but I has this pot already), and a 50VA toroidal transformer to drive an Audiophonics HPA-S250NC power amplifier. It is placed between the amplifier and an old Parasound 1100/HD DAC. Great improvement in dynamics, bass extension and imaging, against a passive pot used before. Highly recommended.
Francis C.
AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752 The Audiophonics PSU S4-HP power supply module has been designed to provide a clean DC voltage supply to an amplifier or other audio circuit. Its particularly rigorous design,...
Utilisée pour alimenter une carte mère sous Daphile (CPU de 10w de TDP).
Dimensionner impérativement le radiateur en fonction de la consommation, stabilité parfaite du voltage de sortie. A l'écoute, très supérieure aux cartes avec régulateur LT1083, différence de prix importante mais justifiée.
Roberto D.
I replaced the original op amp of my dac x-duoo xd05 plus, it added a more spacious and dynamic sound, now is a bit less warm but clear and natural, very pleasant. Good purchase and good service, I received the package in a few days
JF B.
DAYTON AUDIO H812 Horn for compression chamber 800 Hz Dayton Audio horns are designed to operate smoothly until the lowest possible crossover frequency. whIt maintains consistent and predictable dispersion throughout the intended...
Super association avec la compression D250T-8
Résultat vraiment très bon.
JF B.
Super association avec le pavillon H812
Rendu au delà de mes attentes.
Po Marn K.
Great upgrade
Replaced the unbranded 3.5 mm connectors for my Hifiman Arya headphones on my custom made headphone cable. the spaciousness and smoother high frequencies were immediately noticeable. Worthwhile upgrade
Jerome L.
Connecteur de qualité ! Mais ATTENTION : la phase est inversée sur ce connecteur allemand ! Heureusement que j'ai un conditionneur de courant qui me l'a indiqué lors du branchement. Donc, j'ai dû mettre la phase à la place du neutre sur ce connecteur pour corriger le problème. Sinon, tout est OK et rien à dire ormis ça.
Jerome L.
Connecteur IEC de qualité. Monté sur un câble X-60 de la même marque, le résultat est à la hauteur.
Jerome L.
Gaine associée à un câble X-60 de la même marque, le rendu est parfait.
Jerome L.
VIABLUE FILTER 18 Filtering Ferrite Reducer Ø18.5mm to Ø17.5mm Viablue Ferrite Reducers eliminate high-frequency electromagnetic interference (EMI) and the noise it induces within your audio cables. This is essential for designing high...
Ferrites de qualité associées à un câble X-60 de la même marque. Rien à redire, c'est du bon.
Jerome L.
Ce câble (tout comme la marque) est de qualité exemplaire ! Le X-60 alimente du lourd matos comme il se doit. Certaines autres marques populaires devraient plutôt prendre exemple et s'écraser. Le seul câble secteur qui a une vraie répercussion sur la qualité sonore de mon matériel Hi-Fi. La matériel respire ! Monté avec les fiches secteur Viablue (attention à l'inversion de phase sur ces connecteurs allemands !!!) ainsi que leur gaine noire, ce câble est parfait en tous points. Je vous le recommande.
yves p.
Adjustable Soldering Iron 70W 480°C Ø6.4mm This adjustable soldering iron offers a power of 70W allowing it to rise up to a temperature of 480°C. It can reach 350°C in just 8 seconds.
mieux que Weller !!!
impressionnant très rapide on va voir la tenue des pannes avec de la brasure ROHS bonne tenue en main . il est mieux que la petite station Weller dont les pannes ne tienne pas le coup
Laurent F.
Très bon connecteur
Déjà acheté dans la même marque et avec les mêmes caractéristiques des connecteurs coudés schuko, ce connecteur IEC coudé présente les mêmes qualités. La prise est de grande qualité et s'insère sans le moindre flottement dans l'appareil. Les câbles tiennent parfaitement bien dans le boitier qui est réglable dans son orientation. Tout simplement, un très bon produit.
Clément E.
Une petite merveille
Un excellent DAC, avec une légère tendance chaleureuse mais une résolution et un niveau de détails très impressionnants ! Loin devant ma Sound BlasterX G6.
Point postif, le DAC peut être alimenté avec un cordon USB DC fourni, ou avec une alimentation secteur non fournie. Le fait d'avoir le choix est très appréciable car cela permet d'utiliser le DAC en semi-nomade sans avoir de prise secteur à disposition.
Le contrôle de volume est appréciable également, mais malheureusement uniquement via la télécommande dont les piles ne sont pas fournies.
Les trois entrées numérique permettent aussi de pouvoir basculer facilement entre plusieurs appareils (USB, Toslink, Coaxial) le tout sans avoir besoin de driver.
Je recommande chaudement ce petit DAC !
Francois P.
Parfait avec des Dali Ikon7 MK2
Je les utilise avec des contrepointes Elecaudio SD40 et j'avoue que c'est un plus. Les basses sont plus précises et cela me donne l'impression qu'il y a plus de relief dans la musique. Les enceintes sont des Dali Ikon7 MK2 avec un ampli Cambridge. Très content de mon achat.
Yngve I.
VIBORG UA201 Male USB-A 2.0 Connector Gold 24k Plated Ø8.5mm This USB-A 2.0 male Viborg UA201 connector will allow you to design high quality USB cables. Its contacts are made of a 24k gold-plated copper alloy, ensuring very good...
One of the best after market available!
Yngve I.
VIBORG UB201 Male USB-B 2.0 Connector Gold 24k Plated Ø8.5mm This USB-B 2.0 male Viborg UB201 connector will allow you to design high quality USB cables. Its contacts are made of a 24k gold-plated copper alloy, ensuring very good...
Really high quality
Easy fitting and nice looking and most important it does not affect sound quality, since i broke my Shunyata usb plug it got me worried but i can recommend viborg products. Top notch
Eric R.
Manque de sensibilité
Un très bon son mais hélas pas suffisamment sensible pour exploiter la puissance avec le seul réglage de volume d'un téléphone mobile, livré sans notice et sans le connecteur d'entée ligne
Rotaru M.
good
Exceptional quality but for the time in which it was delivered it does not deserve even a star (it was delivered after 100 days from when it was ordered and paid)
Guillaume B.
Bon matos
C'est bien fait, et ça remplace avantageusement des embases d'origines en laiton ou bronze plaqué or.
Gilles D.
Amélioration à coût modéré
Excellent rapport qualité-prix pour ces condensateurs de découplage, recommandés par Tony Gee de "humblehomemadehifi". Précision, détails et nuances en progrès, sur condensateurs et haut-parleurs, de moyenne comme de haut de gamme.
Gilles D.
Classique indispensable
Classique mais indispensable pour des connexions de qualité, sur nouvelles enceintes comme sur de vieux modèles aux borniers sous-dimensionnés.
Yvan S.
Un connecteur de bonne valeur
J'ai acheté ce produit pensant que la qualité état bien supérieur à la moyenne.
Je ne suis pas déçu, ce produit est excellent et le son l'est de même, beaucoup de détails et une large scène sonore qui se dimensionne bien au delà des enceintes.
Par contre... comme le dit Audiophonics, il est précisé que la bague se sertit à l'aide d'une pince spéciale mais vu le prix de la dîtes pince, plus de 200 EUR, je trouve cela exagéré !!
J'ai donc serti la prise avec une autre pince, bien moins adapté mais au final je m'en moque car je ne regarde le câble derrière mon DAC :-)
Yvan S.
Une valeur sûre
Ce produit est excellent, les pattes sont larges et le plastique très dur. Le serrage peut être fort, le plastique résiste bien à la pression.
Un connecteur efficace.
Laurent P.
DD DJ44C Adapter Female Balanced Jack 4.4mm to Male Single-Ended Jack 3.5mm Gold Plated This adapter consists of a female balanced Jack 4.4mm connector and a male single-ended Jack 3.5mm connector.  It benefits from a very nice quality design with a robust CNC...
article bien reçu,conforme a la description, envoi rapide,parfait
Gilbert L.
ALPS 16 50KBX2 Potentiomètre Stéréo Axe Méplat
Conforme à ma commande mise en service fonctionne très bien
délai de livraison correcte
John P.
Top quality product
I ordered this dac for my secondary hi-fi system. In my first system i have a cambridge audio dacmagic dac which costs 200$. I really could not tell any difference between these two dacs which i compared side by side listening to them for about an hour. For the price of 25$ it is a steal. I will order another one for my computer. And i want to say something for the store, audiophonics shipped it the same day i made the payment and i received it only a week after the order, the packaging was perfect. Thank you very much audiophonics.
Laurent f.
fait bien leur boulot
changer dans un ampli lampe parce que les autres était fatigués
très satisfait du produit
Francesco R.
Hexagon Socket Countersunk Head Screw M3x8mm 10.9 Steel Black (x10) These hexagon socket head screws are in M3x8mm format. Made of 10.9 steel, they guarantee a high durability.
Ils ne sont pas noirs.
Ils ne sont pas noirs, ils sont gris.
Près des surfaces noires, elles sont beaucoup plus légères
Stéphane P.
Surprisingly good
I was almost convinced that the arguments about clean digital signal and clock drift were valid only for very end system and with well trained listernes. But i must admit that it improved even on a rudimentary system : a toppling Mx3 as DAC and amplifier (currently replacing my denon 1500 that m m trying to get repaired) and my Triangle Lyrr from around 2000. The gigh are sharped and more defined, for the bass i hear much more harmonic and details (that also exist without) just appear more obviously. Last the dynamic of the sound is much larger.
So of course for 20 euros it is a bargain.
Yet there are issues, 1) the first it that the device is delivered with spacers but those are not to be used since they prevent the Pi to fit in bargain box. So i lost quite some time before i became 100% that the problem were the spacer. Once i had removed them everythinh actually fitted almost perfectly. The second is that with the bargain boxing (the one that ost a few euros) it is impossible to plus the Toslink connector. I know that this connector is aymetric (i have been using those for 20 years) and i have 3 optical cable at home, all a bit different. None fits. If i remove the boxing i can plus a Toslink connector but i need to psuh super hard, and to unplug i need to pull so hard that i m afraid to break the Pi-card.
Note i bought this device to use it with the SPDIF connector so i don't mind to much, but honnestly it is improper.
WONDOM AA-JA32472 JAB2-30 V2 Class D Stereo Amplifier Module Bluetooth 5.0 DSP 2x30W 8 Ohm Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use.
Un bon ampli
Ampli suffisamment puissant pour alimenter un boombox, aucun souffle et plutôt musical. Très simple d’ajouter un potentiomètre, interrupteur, Haut- parleurs, Leds, batterie sans soudure grâce aux nombreuses connections .
ETI BP-20C Binding Post Gold Plated Pure Copper Ø19mm (Pair) The ETI BP-20C are very high performance terminal blocks at contained prices. Made of 1100 Series Hardened Copper conductor with 102% IAC (conductivity index), these terminals...
rapport qualité prix au top
utilisé sur des enceintes Hepta contender hollandaise.. j remplacer les bornier laiton mastroquet par ses borniers hp ..grave tenu et profond et bc plus articulé.. medium plus précis vivant et naturel et les aigus sont filant doux et très riches. plaisirs de mes oreilles .facile a monter .soit soudé ou visé.je les ai dabort visé..et soudé..pas de difference.. pour mes enceintes. alors a vous de choisir.. n oublié pas de protéger vos fils si soudé par de la gaine thermo. et un truc enlever les cosses des câbles internes sa piétine la qualité sur l ensemble des signaux musicaux.. a un point.. j ai d'ailleurs enlevé toutes les cosses et soudé directement les fils sur les plat des hp.. pour les enlever au cas ou.. il suffit de desouder. et d enlever la soudure avec l outil adéquate.. que du bonheur.. prochaine étape.. les filtres. et le câblage en occ de chez oayde.. des explorer et du fils nu argent pour les graves.. je donnerais des news une fois le travail fait..et rodé ;-) vive audiophonics pour leurs matos de dy.. mon porte feuille etant limité.. ont prend vraiment du plaisirs a faire sois même le travail.. avec le temps mon savoir faire vos bien le temps passé ;-) et les conseil des technicien sont bon. ses bornier sont recommander sans modération.. et si besoin du cuivre pl argent les klei sont le meilleures choix pour les petite bourses.. et les grande.. écoutée sur un ampli purify et400 d audiophonics vendu ici le resultat et excellent..
Emmanuel T.
Bon investissement ! :)
Franchement j'ai l'impression que le son est plus "global" et dense qu'avant (j'avais une multiprise Naim depuis quasiment 20 ans).
J'ai été surpris de voir que le grave est plus profond et impactant et l'aigu plus fluide, plus doux, plus présent et mieux intégré au médium.
Bref la musique est plus tactile, plus incarnée et plus réelle.
Emmanuel T.
nvestissement
Franchement j'ai l'impression que le son est plus "global" et dense qu'avant.
J'ai été surpris de voir que le grave est plus profond et impactant et l'aigu plus fluide, plus doux, plus présent.
Philippe S.
ELECTRO HARMONIX EL34 Amplification Tubes (Matched Quad) The Electro Harmonix EL34 tubes contribute to offering a sound reproduction of great musicality and richness. These are perfect models to replace unsuccessful units on vintage...
Bonne sonorité générale
Agréable sonorité générale.
J'espère qu'ils seront plus fiable que le haut de gamme PSVANE.
En tout cas ils sont bien moins chers
Jean B.
Bon câble trop cher
Rien à lui reprocher sur la plan fonctionnel, il fait bien le job, mais à plus de 3€ le mètre c'est vraiment trop cher payé pour ce que c'est! Mauvaise impression d'avoir été pris en otage par l'exclusivité du distributeur...
Mariano S.
Perfect product
Two months delay delivery
Peter D.
Produit répondant parfaitement à mes besoins, reçu plus rapidement que prévu.
Jean S.
Armature Hécate
Mon 2eme exemplaire.
Quand on aime...
Yngve I.
Unbeatable
For the money spent per tube I've yet to find better. Not quite up to par with genalex gold lion but very close, but a clear step up from JJ
Excellent chargeur pour s’affranchir de l’alimentation secteur
Très bon rapport qualité/prix , très facile à connecter à l’ampli JAB 2. J‘ai testé l’autonomie pendant 4 heures et aucun problème. A recommander pour rendre un boombox complètement autonome.
Hendrik W.
ETI BP-20C as replacement on class-d power amp
Used the binding post to replace in purifi class-d power amp in combination with elacaudio HP-25occ cable. Love the combination. Most pronounced was making the sound more natural and fluid.
Hendrik W.
HP-25occ in power amp very good
Used the cable to replace in purifi class-d power amp in combination with eto bp-20c binding post. Love the combination. Most pronounced was making the sound more natural and fluid.
christophe b.
câble révélateur et musical
très satisfait de ce câble joueur et musical: il est précis et généreux pour donner vie à tous les instruments et autres petits sons ou effets sonores, la scène est bien étalée et les voix sont mises en valeur avec réalisme. Le rythme n'est pas en reste puisque ce câble apporte également de la dynamique.
Hendrik W.
Love the sparkos ss3602
The sparkos replaced the opa627 which replaced the lm4562. To my ears the lm4562 is very unpleasant (boring, dull, small soundstage).
With ss3602 the sound is fluid, impulsive, natural and sound is coming loose from speakers and showing wide soundstage. Used in purify class-d power amp.
Hendrik W.
HPA-S400ET - Got it to swing
First weeks not too happy with the amp. I knew the LM4562 was not my taste and planned to swap it anyway. Changed it to OPA627 I had lying around and it improved, but not as much as expected. Next adjustment was swapping to Sparkos SS3602. This was good step forward in frequency response and soundstage nice and fluid only after changing internal cables and binding post. Signal cable changed to single core silver plated and screened occ cable (not sure about brand, got it ‘donated’). The binding posts were changed to eti bp-20c. The internal speaker cable was changed to elacaudio hp-25occ (non-twisted). I first tried untwisting the original cable to check whether or not audible noise would occur, this was not the case. Now the sound is very fluid with broad and high soundstage.
I believe in original state the amp is OK-ish and for me an item to sell again (for me max 2 stars then). It is a keeper after the changes. Rather minus 1 star because of the many changes required.
Frederic F.
super appareil complet et de qualité à petit prix
J'utilise le dp3 uniquement en lecteur de fichiers stockés sur un disque dur branché au port usb de l'appareil.
Aussi bien avec la télécommande et le petit écran, ou bien avec l’application Hiby sur mon smartphone, qui me donne accès aux dossiers contenus dans le disque dur.
Simple et efficace.
Concernant le dac intégré, il est vraiment pas mal, très détaillé, beaucoup de relief, scène large mais j'utilise malgré tout mon dac externe Musical Fidelity v-dac2 qui offre un petit plus niveau réalisme et naturel.
La section ampli casque est vraiment bonne aussi, sans atteindre le niveau d'immersion et de sensualité de mon ensemble v-dac2 + ampli bravo audio mk1 à tube .
davide b.
It is sufficent listening to
It is a little dac but with a great power and a detailled sound: warm and worth of be part of your hifi.
Pierre P.
excellent produit
Résultats excellents en pcm comme en dsd, supérieurs au module LJ CM que je possède aussi.
J'ai eu un souci avec le DSD qui ne passait pas. Audiophonics a oublié d'indiquer le driver à charger pour windows. Problème réglé avec le SAV.
Pour son prix, ce module est étonnant.
Je le recommande fortement.
Pierre
davide b.
Wonderful!
It is a dac not expensive which has a warm and detailled sound. The remote control completes the product.
