Comme je l'écris...
Rachid C.
J'en rachète, donc très bon produit.
Rachid C.
Petit mais costaud
Petit ampli, 2x50W, DSP. Très versatile. Rapport qualité/prix des plus intéressant. Je l'ai acheté pour expérimenter avec...
Customers reviews - There are 19539 reviews.
GEORGES V.
Aluminium Graduated Knob D Shaft 38x33mm Ø6mm This Aluminium knob is graduated from 1 to 12. It is fixed with a hexagon socket screw integrated on the flat axis of a potentiometer. Its long grip ensures ideal ergonomics.
Sens de lecture des chiffres inversé
Les chiffres défilent correctement de 1 à 12 en tournant le bouton de la gauche vers la droite MAIS on les chiffres sont à l'envers si on les lis en haut du bouton ! EN FAIT IL FAUT QUE l'index soit sous le bouton et non au dessus. Curieux non ?
Patrick G.
smsl m8a v3
Bonjour,au vu de la similitude des composants avec khamas tone board,j'ai voulu essayé ce DAC,le comparer au sanskrit 10° anniiv(que j'ai achete sur ce site ily a qqs mois).
Whaou!!quel bon en avant,quel naturel.....Superbe...Merci Audiophonics!
Patrick V.
Nice sounding versatile DAC board
I use this board inside the appropriate case (sold seperately), together with two displays and a RPi4.
Pros:
Nice sound quality
Versatile inputs
Volume control with almost no sound degrade.
Remote control signals are also passed to the Pi.
Cons:
No graceful shutdown of Raspberry Pi when pressing the off button on the case or on the remote control.
Volume is not remembered when completely powered of (plug pulled).
I would give it a full 5 star review if it also had a graceful shutdown function for the Pi. For my purpose this is needed for I am not using a Pi with a readonly OS and need to store settings on the SD card just before closing down. Now when pressing the Off button the power to the Pi is simply cut when the Pi is just powered by the DAC board.
Therefore: 3 stars.
Hi,
It's gonna come shortly we are working on that (no hardware change will be needed to do this update).
Sami H.
Perfect dac with perfect price
This truly transfermed my studiomonitors sound and headphone amp was ok as well with 660s. However, it could be slightly better with better headphone amp. this was version 2 and it is hard for me to found any fault with unit or sound of it.
At first there was drop outs with optical signal with lg c8 however, that was fixed just by increasing dpll setting in the meny.
Top notch product.
Olivier P.
rapport qualité prix fou !!!
Excellent DAC, franchement pour le prix ce DAC est à la hauteur de bien d'autres qui sont à des tarifs bien supérieurs, l'esthétique est de mon point de vue très séduisante. Associé à l'ampli SMSL SA300 et mes Dynaudio Emit M20, c'est que du bonheur, clarté précision, neutralité, j'adore ! Foncez !
Rob S.
Good-value, brand-name capacitors dented/scratched in transit
One cannot argue with the quality and price of these capacitors. The issue is Audiophonics lazy and careless approach to packing such delicate components for delivery to the other side of the world. There was zero foam or bubble protection for eight capacitors which were merely lumped together in one plastic bag with all other components, to be thoroughly dented and scratched en route. Come on Audiophonics. You offer some great products. Match your products with suitable shipping protection!
Sébastien R.
Sympas
C'est fiches bananes offre un bon contact dans la prise car ça force un peu.
Et les 2 vis sur la fiches permette de bien serrer le câble, je n'ai pas ressentis
de fragilité avec les pas de vis comme certain.
Par contre je n'ai utilisé leurs gaine thermo. car on à plus accès après au vis et sur les câbles c'est trop gros.
Sébastien R.
Un bon petit ampli
Bonne ampli compte-tenu du prix avec suffisamment de puissance et en plus il prend vraiment pas de place, pratique pour le mettre à côté de la télé.
Hannibal G.
TINYSINE ANT-RPSMA3 Antenna 2.4GHz RP-SMA 3dBi Female This TinySine ANT-RPSMA3 2.4GHz 3dBi antenna has a RP-SMA (Reverse Polarized) connector. It is ideal for extending the range of a wireless transmission module.
Bon rapport qualité/prix.
Hannibal G.
Mis en interne dans un boitier, bonne réception. Vu le prix, pourquoi s'en passer.
Hannibal G.
TINYSINE Adapter Cable RP-SMA to U.FL 10cm This adapter includes a U.FL connector and an SMA connector. It will therefore allow you to connect to a module with only U.FL connectivity a more efficient antenna in SMA...
Assez bien
Fait le job. MAIS alliage de l'écrou un peu fragile : marque facilement au serrage. Après il est vrai que j'ai tendance à y aller un peu fort...
Hannibal G.
Très bien.
Comme dit François.M dans son commentaire :
"Bien conçu, bien fabriqué, prenant bien la soudure, facile à monter et très bon contact !"
Hannibal G.
Utilisé pour ajouter une réception en entrée BT sur des amplis des années 70, Scott 636, Sanyo DXL2000 etc... connecté sur entrée ligne auxiliaire. Sortie casque Senheiser HD ou enceintes Studio Lab 102.
Emetteur depuis un ordinateur portable Dell, Samsung, Acer, ou téléphone Motorola, tablette noname.
Tout marche très bien. Détection rapide, pas de latence, distance très correcte (j'ai mis une antenne à 2€), éventuellement un très léger bruit de fond que l'on entend que si on le cherche.
Je recommande.
aurelien b.
SHANLING MTW100 V2 In-Ear Monitors IEM Bluetooth 5.0 White The Shanling MTW100 V2 headphones, particularly practical, allow a stable and efficient transmission of your music. Knowles loudspeakers and the intelligent design of these IEMs...
très satisfait
livraison rapide et colis bien emballé, produit conforme à la description, très léger dans l'oreille et confortable, bon son, pas de notice en français
Laurent F.
Excellent Connecteur
Ce connecteur de marque Furutech est un excellent produit. Le poids de celui-ci, même si cela ne fait pas tout, montre bien que l'on est en présence d'un produit de qualité. Le montage du câble ne pose pas de problème, même si des câbles de bon diamètre et blindés sont pas faciles à positionnées dans le coude. Le dispositif de serrage des câbles est très qualitatif et très efficace. Le fait de pouvoir orienter la sortie sur plusieurs positions est un plus. Le prix peut paraître élevé, mais pour connecter des câbles de qualité supérieure, cela est justifié.
Sebastian E.
Works very well
I have just received and tested my order.
Works very well. Transport took a bit longer (France to Germany) but that may be caused by the pandemic.
Recommend this shop/product.
pierre m.
Bien mais un peu difficile à rentrer le câble dans la fiche banane.
pierre m.
Très bonne qualité, facile à relier au câble.
pierre m.
Câble de bonne qualité, facile à couper avec une scie à métaux.
Clément E.
Excellents !
Acheté pour remplacer le tube stock de mon Bravo Audio Ocean, je dois dire que le JJ est impressionnant.
Comparé au tube stock, les basses sont plus "punchy" sans perdre en détail, les médiums gagnent énormément en réalisme et donnent une impression assez saisissante, et les aigus ne sont pas négligés non plus.
Un excellent tube donc !
Peter E.
great sound...thanks audiophonics
Eugen G.
The Tripath
The circuit board has been cleaned.
DC offset 2 mv (adjustable)
After 50 hours of playing time - sounded
very detailed with a lot of bass and dynamics.
Jean-Marc G.
Rapport Q/P excellent.
A recommander sans réserve.
Jean-Marc G.
Sécurité et qualité.
Yves R.
remplacement
pour les personne comme moi qui cherche le saint graale ,foncer le résulta est hallucinant ,pour ma part j'ai modifier un ATOLL AV 100 tout les condensateurs on été changer les gros aussi par des MUNDORF M LITICK la différence un sont très spacial,un médium clair presis et des aigus fin et travailler , jamais vous ne trouverez se genre de condo meme sur des appareil a 25000euros le seul était la societer AUDIOCOM ,QUI MODIFIAIT les OPPO actuellement il modifie les lecteur BD pioncer
Daniel N.
Merci pour ces LED mon Ampli Tuner a retoruvé une nouvelle jeunesse la l'affichage est plus beau qu'avant top! envoi rapide en prime
Daniel N.
Merci pour ces Ampoules LED . Mon Amplituner Marantz a retrouvé une nouvelle jeuness et en plus c'est plus beau .
Top et rapide incroyable!
Jean-Paul R.
ok
livre rapidement bonne qualite
Christian D.
Rien de spécial, à dire, c'est un bon porte-fusible!
Chebl D.
SMPS300RS Module
I am still wrapping myself around using it.The fact that it comes with no manual does not help. I will come back to you later to give you my opinion.
Christian D.
Un peu cher mais indispensable pour obtenir des résultats de qualité.
Christian D.
Très pratique.
Petite alimentation utile pour faire différents essais.
Christian D.
Indispensable!
J'avais acheté un coffret et ne savait pas comment fixer le matériel à l'intérieur sans percer le fond. Ce que je voulais éviter. Cette grille robuste a résolu le problème.
Rob S.
Surprisingly-capable detailed, dynamic, spacious, full-range sound
Not a preamp for purists or price-deluded elitists. Their loss. Featuring full dual-mono design, shunt-regulated DC, dual-stage opamp gain, relayed input switching and tri-band equalizer (!), this Chinese product offers great value for money. A most pleasant surprise.
Rob S.
Functional, well-engineered, neat industrial design
If you wish to invest in a fairly-priced, well-engineered IEC mains plug that accepts weighty-gauge wire, this Viborg plug should not disappoint. As to sonic character, it gels well with OCC copper and non-teflon dialectrics such as PET/PVC, presenting a neutral, dynamic, full-frequency result. Recommended!
Rob S.
Not as described, poor quality control, works once fixed
As of today (4 October 2020), this Audiophonics web item (Ref 11645) is described incorrectly. Of the two linear power supply modules I received in September, neither had an LT1083 regulator installed. They both came with an LT1084 small plastic format. Furthermore one of the regulators was not bolted flush with its heatsink, standing in free space 1.5mm away. Easily fixed, sure. But very poor quality control. As we are dealing with voltage and current (and sensitive, costly connected devices), please check your item carefully once it arrives. Enjoy!
Edwin P.
Nice sturdy power strip. The sockets have strong springs, gives a tight fit on the plugs. This strip shields and surpresses radio frequencies that disturb the audio. The side ends are plastic so it is not completely shielding but it works as wanted and it's positive for the micro audio signals.
The feed rails does not have a cross section of 6mm² but it is ca 5 mm2.
Elsa A.
Embase complete
Embase compacte très pratique pour le DIY, rapport Q/P imbattable , idéale serait avec contacts Au ou autre excellent conducteur au double au plus du prix, mais bon...
Elsa A.
Elégant cache!
Élégant cache pour refermer une ouverture XLR d'un ampli dual transformé en mono, en tous cas masque élégamment toute prise XLR devenue inutile.
Elsa A.
Excellent boitier
Très belle et très luxueuse fabrication , de plus les perçages de fond sont bien appropriés à l'alimentation, montage facile et très élégant , les perçages personnels sont facilités par l'épaisseur de la façade arrière, l'idéal serait avec fourniture de façade avant lisse sans perçage aucun pour les montages d'ampli mono ou autre montage sans nécessité d'accès à l'intérieur, et aussi vis de façade argentées et non noires.
Quoiqu'il en soit superbe boitier.
Victor D.
Fais le job
Premier câble optique acheté, je n'ai pas de comparaison. Semble costaud. Se branche bien, ne bouge pas, cordon souple pratique.
Audiophonics toujours au top par contre !
Francesco R.
Hexagon Socket Round Head Screw M3x6mm 10.9 Steel Black (x10) These hexagon socket round head screws are in M3x6mm format. Made of 10.9 steel, they guarantee a high durability.
Ils ne sont pas noirs, ils sont gris.
Ils ne sont pas noirs, ils sont gris clair.
Francesco R.
Hexagon Socket Countersunk Head Screw M3x8mm 10.9 Steel Black (x10) These hexagon socket head screws are in M3x8mm format. Made of 10.9 steel, they guarantee a high durability.
Ils ne sont pas noirs.
Près des surfaces noires, elles sont beaucoup plus légères
Francesco R.
Près des surfaces noires, elles sont beaucoup plus légères.
Francesco R.
Frank O.
Voor de prijs een prima kabel!
Deze kabel gekozen ter vervanging van de standaard meegeleverde Rotel Michi kabels. De WM kabel is vrij stug maar ziet er verder prima uit. Bij het verwijderen van de buitenmantel valt direct op dat deze zeer goed geïsoleerd is. Dit was dan ook meteen de reden van de aankoop. Voor deze prijs vindt je geen betere. Kabel werd heel snel verzonden door Audiophonics, waarvoor dank!
Michel B.
Qualité et solidité Irréprochables
J'avais confectionné un 1er câble XLR avec ce connecteur (et son compagnon Mâle le XLR900R-M) il y a quelques temps: la qualité est tellement impressionnante que je n'ai pas hésité une seconde lorsque j'ai dû en fabriquer à nouveau.
Jugez plutôt:
-C'est du tout métal, du très lourd et du vraiment très costaud : il n'y a pas une seule pièce en plastique et comme quelqu'un l'a déjà dit dans son commentaire, le poids sur la balance est élevé.
-Toutes les vis rentrent dans des filetages eux-mêmes en métal costaud: impossible à foirer.
-La pièce circulaire dans laquelle les 3 contacts sont enchâssés est indestructible même en étant un descendant direct de l'homme des cavernes.
-Lors du soudage des câbles sur ces 3 connecteurs, il est impossible de créer le moindre jeu même à 400°C (ce que j'ai fait), ça ne bronche pas d'un micron, ça ne devient pas souple: un vrai plaisir.
-Les contacts sont repérés par leur numéro: 1,2 et 3 du côté à souder, ce qui évite toute erreur puisque chacun le sait: il y a 3 fils à souder un connecteur XLR.
-Cerise sur le gâteau: ces pins sont également numérotées du côté extérieur...
Qualité et fiabilité sont exemplaires pour un connecteur à moins de20€ totalement indestructible, je ne vois pas la moindre chose à changer.
La seule amélioration que YARBO pourrait faire serait de proposer ce connecteur avec des contacts UP-OCC à un prix contenu: il en existe chez Yarbo mais à un tarif stratosphérique...
Alain C.
Très bon produit, livraison rapide comme toujours avec AUDIOPHONICS . On peut commander n'importe quel produit
sur ce site les yeux fermés sans etre déçu.
Yves M.
Yves
J'ai commandé cet amplificateur, je l'ai reçu très vite et en bon état par Colissimo. Je l'ai raccorde sur mon combiné audio et sur les baffles que je possédaient. Aucun problème pour la raccordement.
Je suis satisfait de mon achat.
