rodrigue Y.
Connecteur RCA
Franck M.
Franck M.
excellentissime
Customers reviews - There are 19134 reviews.
Hamidi M.
Waouh
Commandé apres avoir lu les commentaires sur internet: super appareil pas déçu du tout, premier chose testé apres installation, la compatibilité du port Hdmi avec mon Cayin Idap 6,
Antoine G.
Pas terrible
La prise femelle est un peu trop longue et peut-être un peu trop maigre. Résultat même enfichèe bien à fond au dos de mes appareils HiFi, il y a du jeux : ça branle un peu.
Ça ne m’a pas inspiré confiance quant à la qualité du contact électrique . Je vais les renvoyer
Carsten S.
Very good for FRITZ! Box Cable
I ordered the AUDIOPHONICS PSU-HC Linear Regulated Power Supply 12V 5A 100VA as a replacement for the switched-mode power supply of my FRITZ! Box Cable. Fast delivery. The power supply is very heavy and looks extremely high quality. It works perfectly with my FRITZ! Box Cable. Highly recommended. I struggled a little to get a DC cable. The ordered cable with 2.1 mm pin did fit into the power supply unit, but not into the FRITZ! Box. An adapter from 2.1mm to 2.5mm solved the problem. Everyone who is on the move when it comes to sound and reliability: an absolute recommendation for the FRITZ! Box Cable. Very good product. I also have a 5 volt linear power supply from Audiophonics for supplying a primary streaming bridge. Also very good product. The boys know what they're doing. Thank you.
Ji-Ping S.
Great performance!
I don't have any other amp at hand for fair comparison but the combination of this amp with Dali Oberon 5 sounds very dynamic and clear, better than my previous setup of class AB integrated amp with Castle's which costed more and used a lot of electricity.
Will definitely buy this again for center and rear.
PS: no preamp and connected to PC directly.
Damon A.
Excellent cable
I've bought both the NEI-3004 and the NEI-3001 on a cable making spree recently. Both were delivered to the United States with no additional fees, or charges beyond shipping costs.
I also bought Neotech NC-06612 XLR connectors for termination. Both cables are excellent, but the additional features of the NEI-3001 are well worth the extra cost. For DIY cable projects, this is as good as it gets. Spending more will put you well passed the point of diminishing returns (including any ready made cable).
Another cable I've been trying is the ViaBlue NF-S6, which seems to be more in the range of the NEI-3001 for features and price. In comparison, the NEI-3001 was noticeably smoother on vocals. I think NEOTECH's judicious use of silver could be the difference, and, for me, proves you don't need all silver for good performance.
Benjamin A.
Très bon pour le prix
Acheter sans grande conviction pour mes eltax monitor 3 je suis très étonnée par le rendu. Je l'ai relié sur mon pc en USB avec foobar et les pilotes asio, et le rendu est vraiment bon pour cette gamme de prix, c'est détaillé et précis. Un très bon rapport qualité prix, de plus reçu en 24h merci c'est la deuxième fois que je commande sur ce site et je suis très satisfait du conseil.
Benoit M.
Excellent son, la scène est large.
Comparaison avec un autre DAC (24 x TDA1543) : le son est dynamique et raffiné - le 'Velvet sound' du DAC AK4493. Bonne spatialisation et les extrèmes ne sont pas tronqués.
L'autre DAC me met plus près de la scéne, puissant mais moins large.
L'appareil est bien présenté et construit, rien à redire.
Je vais upgrader l'alimentation 5V, peut-être y aura-t-il encore une amélioration.
Thomas N.
SUPTRONICS X450 Class D Amplifier DAC Module ES9023 2x TPA3116D2 2x100W 4 Ohm 24bit 192kHz This digital/analog conversion and amplification module for Raspberry Pi connects directly to the GPIO of the Raspberry Pi, allowing simple operation without special wiring....
Efficace, peu encombrant et qualité
Je n'ai pas l'oreille fine de l'ingénieur du son. Mais en comparaison avec d'autre type d'ampli que j'utilise pour des systèmes de diffusion autonomes sur batterie celui ci est très satisfaisant. Alimenté en 24V et testé sur différents modèles d'enceinte "ça envoi", pas de souffle et ça tient dans la main. Je vais lui ajouter une ventilation car ça chauffe pas mal. Bémol: lors du branchement d'un jack 3,5 sur l'entrée auxiliaire l'ampli bascule automatiquement sur celle-ci, je vais tenter de résoudre cela par mes propres moyens.
correct mais trop sensible a l'alimentation donc peu utilisable
ce petit ampli est sympathique marche correctement sauf sa sensibilité à alimentation utilisé avec 3 alimentations différentes de 12 à 19 volts certes à découpage venant de Pc portables.
il n'aime pas du tout il subsiste un bruit audible pendant l'écoute de la musique (pour info rien avec mes fx audio et smsl avec les memes alims) C'est présent en bluetooth rien sans musique car le silencieux se met en marche par contre sur l'entrée analogique le bruit est perceptible tout le temps dommage car il est bien agencé à essayer avec une alimentation linéaire sinon utilisable en ambiance lointaine seulement.
MARC P.
SMSL AD18
Ampli excellent, juste que l'alimentation de très mauvaise qualité vient de cramer,
Luis V.
Supreme sound
This amplifier is capable of devivering very clean sound, although the capacitor in photo is diferent in size and color from the real one, also the size dont match the description.
The real size is 120mm x 51mm x 25 mm.
Anthony B.
DAYTON AUDIO DMA80-4 Speaker Driver Full Range Aluminium 25W 4 Ohm 88dB 90Hz - 20kHz Ø7.6cm Offering high efficiency while maintaining low distortion, the Dayton Audio DMA80-4 Aluminium wideband cone driver is ideal for integration into many compact DIY speaker projects.
Bon produit, reçu dans les délais
FABIEN A.
fiche banane Viablue TS2
FABIEN A.
fiche banane viablue TS2
Fabien S.
ALLO USBRIDGE SIGNATURE Audio Streamer Raspberry Pi Compute 3+ Ultra Low Noise USB Interface The Allo USBridge Signature is a network drive based on an SBC Raspberry Pi Compute 3+ and the DietPi operating system. It allows to reduce the noise of the Pi Compute and all...
Le centre d'étude audio de allo est situé à Toulouse et ça se ressent dans la qualité de leurs produits. Après un petit rodage (deux semaines quand même), le usbridge a réglé mon problème de balance gauche droite sur mon système : la stéréo a été améliorée. J'utilise Moodeaudio et le usbridge est irréprochable par rapport à un RPI 3B+. Il est réellement fait pour l'audio.
Hamidi M.
Pour des écouteurs à ce prix, je les trouve très bons je les ai utilisé dans un 1er temps avec l'ibasso Dx220, même sans rodage le son est superbe, et après avec un Ifi Hip dac, je ne pourrais dire que: c'est une régale, et ils vont sûrement se bonifier après quelques heures d'utilisation
Loïs C.
Tète de vis de mauvaise qualité..Ai également eu 2 sachets avec 1 vis sans tête bombée. Pas très serieux
fabuleux !!!
j'ai acheté 6.50 de ce cable pour relier ma LH AUDIO à une prise murale située dans la pièce attenante à ma salle d'écoute ; et 1.50 pour alimenter mon cd !
excellente qualité de fabrication tout germanique !
Plutôt délicat à monter coté iec (elecaudio) ;faute à la rigidité des fils et du fait de l'inversion terre/neutre il faut dénuder pas mal et laisser la phase plus longue ! il faut prévoir des embouts car le système de serrage de l'elec ne retient pas les brins plats du yarbo ! (surtout ne pas toucher les brins avant l'insertion dans les embouts (6mm2) sous peine de ne plus pouvoir les passser ! )
A l'écoute :
première impression :
beurk c'est sourd , les basses se traînent , le medium a disparut , et les aigus sont descendus à sa place ronds et sirupeux !!!
passé un instant de panique je me dis que le rodage ...
5eme heure :
c 'est mieux les basses se tendent ; le medium refait surface et les aigus remontent ,plus jolis plus soyeux plus précis !
10eme heure : enfin le miracle !
tout revient à sa vraie place et la matière et l'ampleur augmentent au fil des morceaux de manière assez hallucinante ! J'ai du mal à en croire mes oreilles !
A chaque minute maintenant tout s'améliore jusqu'à atteindre un point ou tout est superbe de maîtrise ,d'équilibre et d'ampleur !
au final je dirais : un rqp effectivement assez extraordinaire pour un produit assez étonnant de qualité !
je vais équiper à terme tout mon système avec ça !
produit agréable facile a monter bonne qualité de fabrication !
tres bon produit !
produit agréable plutôt facile à monter si on reste dans le diamètre maxi ! seul bémol le système de serrage ne retient pas les brins plats du câble yarbo 8000 et nécessite donc un embout de serrage sur chaque fil ; donc ne surtout pas toucher aux brins avant d'enfiler l'embout ( 6 mm2) sous peine qu'il ne rentre plus !
article sympa
bonne qualité ; un peu large mais facile à monter sur un cable de 16.5 mm ;s'effiloche un peu au bout mais rien de grave ! couleurs conformes à la photo !
moyen !
plus rose que rouge helas , je voulais l'assortir a une elecaudio couleur wine ,mais ça ne correspond pas du tout !! et dans mon cas bcp trop large pour un cable secteur de 16.5 mm de diametre ; une erreur de jugement de ma part ! !
super
tres bien , bon complement ! surtout avec une ic elecaudio dont le systeme de serrage ne convient pas au yarbo 8000 dont les brins plats n'accrochent pas ; les embouts ont résolu le probleme !
merci!
Efficace et simple
Pour tous ceux qui veulent améliorer leur écoute sur casque , ce petit DAC est parfait . Bon rendu, clarté , scène sonore étendue et bonne dynamique . Il faut évidemment utiliser de bons fichiers !
Une nette différence avec le DAC incorporé de la carte mère ALC 889 .
Gino m.
Reçu rapidement et forte vibration
Georges B.
Boitier ECo 551010
Très bon boîtier pour y loger mon VFO synthétisé.Qui suivra avec mon transceiver construction maison de 40 ans .
73 de f6goz
http://gozgeorges.fr
rene a.
TA 2022 amplificateur TRIPATH
Module de valeur, mais dommage que les borniers ne soient pas a la hauteur du résultat d'écoute en enceinte assistée
rene a.
module de valeur mais dommage que les borniers ne sont pas a la hauteur du résultat d'écoute
Entretoises Plastique
Toujours utile pour rehausser un PCB
entretoise nylon
VISHAY DALE CMF55
Resitance de qualité et de très grande précision
VISHAY DALE CMF55
VISHAY DALE CMF55
VISHAY DALE CMF55
VISHAY DALE CMF55
VISHAY DALE CMF55
Resitance de qualité et de très grande précision, la valeur mesurée est conforme à celle annoncée
Metal Drill Bit HSS Cobalt 5% Ø2mm This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage...
Foret Métal
Attention comme tout les petits forets ça casse facilement (surtout si on est pas bien dans l'axe)
Prévoir du stock
Thierry W.
Très belles bornes. Qualité irréprochable. Elles sont énormes !!
Serte un peu chère, mais la qualité à un prix...
Je recommande fortement si vous avez le budget, vous ne serez pas déçu :-)
Fabrice d.
bornier hp très pratiques
bonjour,
J'ai acheté ce bornier pour connecter des grosses colonnes arrières (installation muralle)
Résultat Impeccable et s'encastre parfaitement dans les boîtiers legrand.
Très pratiques, car pas besoin de souder les fils derrière.
Installation très propre, je recommande.
Cdlt
Olivier R.
Excellent résultat, le son du câble n'est pas dénaturé. Très bon produit sauf le support en plastique qui n'est pas génial, on ne peut pas bloquer le clapet même avec un câble de petit diamètre.
Olivier R.
Pete K.
Doesn't fit together very well
No instructions and no spacers to mount the board also there's a bit of plastic in the kit which looks like it goes around the connections but I didn't know if it was supposed to go inside or outside so I left it off - not impressed
Frederic S.
Douceur
Comparé à mon couvre plateau en cuir, la différence sonore est flagrante; les hautes fréquences sont plus" liquides" comme adoucies mais non écourtées. Sur le reste du spectre, c'est le bas médium qui s'enrichit de détails. Pour ce qui est du produit en lui même, la surface est brillante et adhère parfaitement au disques qui se trouvent comme ventousés. Platine Rega, cellule AT VM 95 ML
ABL SURSUM ELAMID Schuko Type E/F Power Connector 16A IP44 Ø12.5mm Black This durable thermoplastic Schuko connector can be used for various mains cable assemblies. It is compatible with Schuko sockets with double "rubbing" grounding contacts. Thanks...
quoi d autre ?
cette fiche de très grande qualité à été acheté pour confectionner une rallonge et vehiculer le courant avec 2x2.5 mm2 de câble d électricien , ce quelle fait tres bien . mon ouïe contrairement à beaucoups ne doit pas être très bonne , je n ai jamais constaté de gain à l ajout d un câble secteur soit disant "amélioré ". toujours est-il j ai limité la casse au max ...
la différence sera mise dans l achat d un nouveau panneau acoustique dont l apport est fois cent par rapport à n importe quel câbles tout prix confondu .
produit très qualitatif .
Jean François R.
Gaine 6-12
Parfait, très bon rapport qualité prix
Gérald F.
Ampli TPA3116D2
Très bon produit, correspond à ce que j'attendais, très bon site sérieux.
jérôme l.
Vive la France! Vive la classe D!
Parfait! J'utilise deux de ces amplis reliés à un préampli. haut de gamme en XLR et/ou en RCA à un ampli home cinema et le résultat est parfait.
Rapport qualité/prix imbattable et en plus fabriqué en France, Bravo.
Guillaume V.
TOPPING DX3 PRO V2 DAC 2x AK4493EQ Headphone Amplifier TPA6120A2 Bluetooth LDAC XMOS XU208 32bit 768kHz Silver The DAC combo and headphone amplifier DX3 Pro from Topping returns in a revised and improved V2, benefiting in particular from new practical features and ensuring even better...
un modèle de neutralité
Un peu froid à la première écoute , il fait la transition de mon premier dac, un FIIO Q1 II, et nécessite un temps d'adaptation un peu long pour finalement faire apparaitre son potentiel; une fidélité sans fioriture.
l'utilisation en ampli casque est satisfaisante, avec un AKG K371 casque on ne peut plus neutre, l'écoute est vraiment très réussi.
pour ma part je ne m'embête pas avec la sortie ligne et branche mes différents amplis sur la sortie casque, rien a redire, juste le volume à monter à -10db, niveau de sortie amplement suffisant.
Côté fiabilité j'espère que la prise jack sortie casque tiendra le choc au vu des nombreux changements que j'effectue (2 amplis + plusieurs casques).
le relais de la sortie son m'a fait un petit caprice en refusant de se connecter au démarrage, puis tout est rentré dans l'ordre après plusieurs redémarrages, depuis plus de problème.
Le seul petit reproche que je me permettrait est celui du gain réglable certes, mais pas vraiment progressif, on passe de 0db à +9db, une position intermédiaire aurait permis plus de modulation, ceci dit à +9db cela convient.
je suis globalement très satisfait de ce petit dac ampli casque qui a, je dirais, tout d'un grand.
sa neutralité exemplaire, dénué de toute coloration, satisfaira l'oreille des puristes.
en attendant d'essayer un de ses grands frères...
THIERRY S.
Brass Spacers Male / Female M3x10 + 3mm (x10) These Brass spacers have a 3mm long M3 thread and a 10mm long body. Ideal for all your projects and DIY mounting on PCB (printed circuit board) or other. High quality machining.
Attention
La tige filetée est trop courte pour se fixer sur un circuit imprimé.
(Ceci dit la description du produit est précise à ce sujet)
THIERRY S.
Trés bien
Câble très pratique pour faire du câblage en interne, de plus il présente des caractéristiques plus que correctes.
