Marius G.
Excellent quality cable
Marius G.
Satisfied
John P.
Top quality product
I ordered this dac for my secondary hi-fi system. In my first system i have a cambridge audio dacmagic dac which costs 200$. I really could not tell any difference between these two dacs which i compared side by side listening to them for about an hour. For the price of 25$ it is a steal. I will order another one for my computer. And i want to say something for the store, audiophonics shipped it the same day i made the payment and i received it only a week after the order, the packaging was perfect. Thank you very much audiophonics.
Laurent f.
fait bien leur boulot
changer dans un ampli lampe parce que les autres était fatigués
très satisfait du produit
Francesco R.
Hexagon Socket Countersunk Head Screw M3x8mm 10.9 Steel Black (x10) These hexagon socket head screws are in M3x8mm format. Made of 10.9 steel, they guarantee a high durability.
Ils ne sont pas noirs.
Ils ne sont pas noirs, ils sont gris.
Près des surfaces noires, elles sont beaucoup plus légères
Stéphane P.
Surprisingly good
I was almost convinced that the arguments about clean digital signal and clock drift were valid only for very end system and with well trained listernes. But i must admit that it improved even on a rudimentary system : a toppling Mx3 as DAC and amplifier (currently replacing my denon 1500 that m m trying to get repaired) and my Triangle Lyrr from around 2000. The gigh are sharped and more defined, for the bass i hear much more harmonic and details (that also exist without) just appear more obviously. Last the dynamic of the sound is much larger.
So of course for 20 euros it is a bargain.
Yet there are issues, 1) the first it that the device is delivered with spacers but those are not to be used since they prevent the Pi to fit in bargain box. So i lost quite some time before i became 100% that the problem were the spacer. Once i had removed them everythinh actually fitted almost perfectly. The second is that with the bargain boxing (the one that ost a few euros) it is impossible to plus the Toslink connector. I know that this connector is aymetric (i have been using those for 20 years) and i have 3 optical cable at home, all a bit different. None fits. If i remove the boxing i can plus a Toslink connector but i need to psuh super hard, and to unplug i need to pull so hard that i m afraid to break the Pi-card.
Note i bought this device to use it with the SPDIF connector so i don't mind to much, but honnestly it is improper.
WONDOM AA-JA32472 JAB2-30 V2 Class D Stereo Amplifier Module Bluetooth 5.0 DSP 2x30W 8 Ohm Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use.
Un bon ampli
Ampli suffisamment puissant pour alimenter un boombox, aucun souffle et plutôt musical. Très simple d’ajouter un potentiomètre, interrupteur, Haut- parleurs, Leds, batterie sans soudure grâce aux nombreuses connections .
ETI BP-20C Binding Post Gold Plated Pure Copper Ø19mm (Pair) The ETI BP-20C are very high performance terminal blocks at contained prices. Made of 1100 Series Hardened Copper conductor with 102% IAC (conductivity index), these terminals...
rapport qualité prix au top
utilisé sur des enceintes Hepta contender hollandaise.. j remplacer les bornier laiton mastroquet par ses borniers hp ..grave tenu et profond et bc plus articulé.. medium plus précis vivant et naturel et les aigus sont filant doux et très riches. plaisirs de mes oreilles .facile a monter .soit soudé ou visé.je les ai dabort visé..et soudé..pas de difference.. pour mes enceintes. alors a vous de choisir.. n oublié pas de protéger vos fils si soudé par de la gaine thermo. et un truc enlever les cosses des câbles internes sa piétine la qualité sur l ensemble des signaux musicaux.. a un point.. j ai d'ailleurs enlevé toutes les cosses et soudé directement les fils sur les plat des hp.. pour les enlever au cas ou.. il suffit de desouder. et d enlever la soudure avec l outil adéquate.. que du bonheur.. prochaine étape.. les filtres. et le câblage en occ de chez oayde.. des explorer et du fils nu argent pour les graves.. je donnerais des news une fois le travail fait..et rodé ;-) vive audiophonics pour leurs matos de dy.. mon porte feuille etant limité.. ont prend vraiment du plaisirs a faire sois même le travail.. avec le temps mon savoir faire vos bien le temps passé ;-) et les conseil des technicien sont bon. ses bornier sont recommander sans modération.. et si besoin du cuivre pl argent les klei sont le meilleures choix pour les petite bourses.. et les grande.. écoutée sur un ampli purify et400 d audiophonics vendu ici le resultat et excellent..
Emmanuel T.
Bon investissement ! :)
Franchement j'ai l'impression que le son est plus "global" et dense qu'avant (j'avais une multiprise Naim depuis quasiment 20 ans).
J'ai été surpris de voir que le grave est plus profond et impactant et l'aigu plus fluide, plus doux, plus présent et mieux intégré au médium.
Bref la musique est plus tactile, plus incarnée et plus réelle.
Emmanuel T.
nvestissement
Franchement j'ai l'impression que le son est plus "global" et dense qu'avant.
J'ai été surpris de voir que le grave est plus profond et impactant et l'aigu plus fluide, plus doux, plus présent.
Philippe S.
ELECTRO HARMONIX EL34 Amplification Tubes (Matched Quad) The Electro Harmonix EL34 tubes contribute to offering a sound reproduction of great musicality and richness. These are perfect models to replace unsuccessful units on vintage...
Bonne sonorité générale
Agréable sonorité générale.
J'espère qu'ils seront plus fiable que le haut de gamme PSVANE.
En tout cas ils sont bien moins chers
Jean B.
Bon câble trop cher
Rien à lui reprocher sur la plan fonctionnel, il fait bien le job, mais à plus de 3€ le mètre c'est vraiment trop cher payé pour ce que c'est! Mauvaise impression d'avoir été pris en otage par l'exclusivité du distributeur...
Mariano S.
Perfect product
Two months delay delivery
Peter D.
Produit répondant parfaitement à mes besoins, reçu plus rapidement que prévu.
Jean S.
Armature Hécate
Mon 2eme exemplaire.
Quand on aime...
Yngve I.
Unbeatable
For the money spent per tube I've yet to find better. Not quite up to par with genalex gold lion but very close, but a clear step up from JJ
Excellent chargeur pour s’affranchir de l’alimentation secteur
Très bon rapport qualité/prix , très facile à connecter à l’ampli JAB 2. J‘ai testé l’autonomie pendant 4 heures et aucun problème. A recommander pour rendre un boombox complètement autonome.
Hendrik W.
ETI BP-20C as replacement on class-d power amp
Used the binding post to replace in purifi class-d power amp in combination with elacaudio HP-25occ cable. Love the combination. Most pronounced was making the sound more natural and fluid.
Hendrik W.
HP-25occ in power amp very good
Used the cable to replace in purifi class-d power amp in combination with eto bp-20c binding post. Love the combination. Most pronounced was making the sound more natural and fluid.
christophe b.
câble révélateur et musical
très satisfait de ce câble joueur et musical: il est précis et généreux pour donner vie à tous les instruments et autres petits sons ou effets sonores, la scène est bien étalée et les voix sont mises en valeur avec réalisme. Le rythme n'est pas en reste puisque ce câble apporte également de la dynamique.
Hendrik W.
Love the sparkos ss3602
The sparkos replaced the opa627 which replaced the lm4562. To my ears the lm4562 is very unpleasant (boring, dull, small soundstage).
With ss3602 the sound is fluid, impulsive, natural and sound is coming loose from speakers and showing wide soundstage. Used in purify class-d power amp.
Hendrik W.
HPA-S400ET - Got it to swing
First weeks not too happy with the amp. I knew the LM4562 was not my taste and planned to swap it anyway. Changed it to OPA627 I had lying around and it improved, but not as much as expected. Next adjustment was swapping to Sparkos SS3602. This was good step forward in frequency response and soundstage nice and fluid only after changing internal cables and binding post. Signal cable changed to single core silver plated and screened occ cable (not sure about brand, got it ‘donated’). The binding posts were changed to eti bp-20c. The internal speaker cable was changed to elacaudio hp-25occ (non-twisted). I first tried untwisting the original cable to check whether or not audible noise would occur, this was not the case. Now the sound is very fluid with broad and high soundstage.
I believe in original state the amp is OK-ish and for me an item to sell again (for me max 2 stars then). It is a keeper after the changes. Rather minus 1 star because of the many changes required.
Frederic F.
super appareil complet et de qualité à petit prix
J'utilise le dp3 uniquement en lecteur de fichiers stockés sur un disque dur branché au port usb de l'appareil.
Aussi bien avec la télécommande et le petit écran, ou bien avec l’application Hiby sur mon smartphone, qui me donne accès aux dossiers contenus dans le disque dur.
Simple et efficace.
Concernant le dac intégré, il est vraiment pas mal, très détaillé, beaucoup de relief, scène large mais j'utilise malgré tout mon dac externe Musical Fidelity v-dac2 qui offre un petit plus niveau réalisme et naturel.
La section ampli casque est vraiment bonne aussi, sans atteindre le niveau d'immersion et de sensualité de mon ensemble v-dac2 + ampli bravo audio mk1 à tube .
davide b.
It is sufficent listening to
It is a little dac but with a great power and a detailled sound: warm and worth of be part of your hifi.
Pierre P.
excellent produit
Résultats excellents en pcm comme en dsd, supérieurs au module LJ CM que je possède aussi.
J'ai eu un souci avec le DSD qui ne passait pas. Audiophonics a oublié d'indiquer le driver à charger pour windows. Problème réglé avec le SAV.
Pour son prix, ce module est étonnant.
Je le recommande fortement.
Pierre
davide b.
Wonderful!
It is a dac not expensive which has a warm and detailled sound. The remote control completes the product.
Yves A.
Un calvaire à souder - réservé aux professionels bien équipés
Je ne suis pas professionnel, mais j'ai fait des milliers de soudures. Jamais je n'ai eu autant de difficultés pour faire une simple soudure. Il m'a fallut 2 heures pour souder un simple câble de casque XLR, et je ne suis même pas content du résultat tellement j'ai dû chipoter.
pascal s.
Voltage Display Voltmeter with Blue LED 60-500VAC Ø22mm This voltmeter will allow you to monitor the voltage of a device. Its blue LED display is easy to read. The voltmeter accepts voltages from 60VAC to 500VAC. Its...
pascal s.
Excellent produit avec un super rapport qualité prix
Jacques M.
trigger
Possédant un ancien Rotel 985 MKII qui n'a pas de trigger ,associé à un Yamaha RX-A 2060 ,j'ai relié le tout avec ce trigger et nickel allumage et extinction avec le Yamaha ;produit recommandé
Godehard B.
Is it snake oil, or does it make an audible difference?
Does it make sense to add a 270 Euro power supply to your IntelNUC-based music server? I was not sure until I tried. The answer is a resounding (pun intended!) YES. The music is less anemic, more authoritative, especially due to a more robust base foundation. Worth every Cent, highly recommended.
Pierre J.
Le produit semble correcte, mais je confirme la remarque de Serge D, il est donné 18v mais donne 22 même en charge, pour ma part je change pour du 2x15v
Bertrand M.
C'est fin, c'est très fin...
Petit câble, mais fin, fin, fin...
On verra à l'usage.
Maintenant, vu le prix...
Bertrand M.
Fait le job.
Bon câble, souple, fait le job.
Bertrand M.
La gaine thermo fournie permet une jolie finition et un détrompage Visible.
ETI SILVER LINK Pure Silver RCA Connector Ø11mm (Set x4) Pure Silver RCA Connector Ø9mm (Set x4)The top-of-the-range ETI Silver Link connectors are based on the concept of the Silver Bullet, recognized by many as the best RCA...
excellentes performances
utilisé avec du nemoi 1210 argent a section rectangulaire ses rca donnent entière satisfaction. comparée a des klei. je n est pas entendu de différence notable.. je l est achetée car les klei n accepte pas le diamètre des neotech nemoi 1210. a acheter les yeux bandés si le diamètre de câble est plus grand que celui des klei.. si assez petit pour des klei..alors privilégier les klei moins cher et tous aussi exceptionnelle
Modules MA12070 Infineon en double Mono
J'ai monté une configuration double Mono avec deux modules et deux alimentations SMPS 24V/150W. Je suis assez épaté du résultat... c'est proche d'un TPA3251 (je parle d'une version haut de gamme pas made in China).
La version que l'on voit sur les photos est la revision 1.2. J'ai reçu la nouvelle révision 1.3 avec un connecteur "ground" en plus.
Prevoyez des sections de cables fines car les connecteurs de type "push" ont un petit diamètre.
A l'écoute :
+ + c'est dynamique, musical avec une bonne source obligatoire
++le THD donné par Infineon est très intéressant,
++circuit Anti pop, pas de souffle, c'est propre
-- manque de patate. pas aussi puissant qu'un TPA3251/55 de bonne facture (avec PFFB). On droit approcher les 2X90W sous 8ohms en double Mono. Mais suffisant pour une pièce de 40m2 à volume sympa.
Richard K.
AUDIOPHONICS Trigger 12V 230V Device works great
I am using crown xli3500 to run 2 15 inch subwoofers and the crown don't have the 12V trigger switch so I decided to try this and it works great but I had to modify my receiver for it to fit which only took half hour but I am handy with tools. check that you have plenty of room around plug entrance on your device before you buy. highly recommended.
GEORGES V.
Aluminium Graduated Knob D Shaft 38x33mm Ø6mm This Aluminium knob is graduated from 1 to 12. It is fixed with a hexagon socket screw integrated on the flat axis of a potentiometer. Its long grip ensures ideal ergonomics.
Sens de lecture des chiffres inversé
Les chiffres défilent correctement de 1 à 12 en tournant le bouton de la gauche vers la droite MAIS on les chiffres sont à l'envers si on les lis en haut du bouton ! EN FAIT IL FAUT QUE l'index soit sous le bouton et non au dessus. Curieux non ?
Patrick G.
smsl m8a v3
Bonjour,au vu de la similitude des composants avec khamas tone board,j'ai voulu essayé ce DAC,le comparer au sanskrit 10° anniiv(que j'ai achete sur ce site ily a qqs mois).
Whaou!!quel bon en avant,quel naturel.....Superbe...Merci Audiophonics!
Patrick V.
Nice sounding versatile DAC board
I use this board inside the appropriate case (sold seperately), together with two displays and a RPi4.
Pros:
Nice sound quality
Versatile inputs
Volume control with almost no sound degrade.
Remote control signals are also passed to the Pi.
Cons:
No graceful shutdown of Raspberry Pi when pressing the off button on the case or on the remote control.
Volume is not remembered when completely powered of (plug pulled).
I would give it a full 5 star review if it also had a graceful shutdown function for the Pi. For my purpose this is needed for I am not using a Pi with a readonly OS and need to store settings on the SD card just before closing down. Now when pressing the Off button the power to the Pi is simply cut when the Pi is just powered by the DAC board.
Therefore: 3 stars.
Hi,
It's gonna come shortly we are working on that (no hardware change will be needed to do this update).
Sami H.
Perfect dac with perfect price
This truly transfermed my studiomonitors sound and headphone amp was ok as well with 660s. However, it could be slightly better with better headphone amp. this was version 2 and it is hard for me to found any fault with unit or sound of it.
At first there was drop outs with optical signal with lg c8 however, that was fixed just by increasing dpll setting in the meny.
Top notch product.
Olivier P.
rapport qualité prix fou !!!
Excellent DAC, franchement pour le prix ce DAC est à la hauteur de bien d'autres qui sont à des tarifs bien supérieurs, l'esthétique est de mon point de vue très séduisante. Associé à l'ampli SMSL SA300 et mes Dynaudio Emit M20, c'est que du bonheur, clarté précision, neutralité, j'adore ! Foncez !
Rob S.
Good-value, brand-name capacitors dented/scratched in transit
One cannot argue with the quality and price of these capacitors. The issue is Audiophonics lazy and careless approach to packing such delicate components for delivery to the other side of the world. There was zero foam or bubble protection for eight capacitors which were merely lumped together in one plastic bag with all other components, to be thoroughly dented and scratched en route. Come on Audiophonics. You offer some great products. Match your products with suitable shipping protection!
Sébastien R.
Sympas
C'est fiches bananes offre un bon contact dans la prise car ça force un peu.
Et les 2 vis sur la fiches permette de bien serrer le câble, je n'ai pas ressentis
de fragilité avec les pas de vis comme certain.
Par contre je n'ai utilisé leurs gaine thermo. car on à plus accès après au vis et sur les câbles c'est trop gros.
Sébastien R.
Un bon petit ampli
Bonne ampli compte-tenu du prix avec suffisamment de puissance et en plus il prend vraiment pas de place, pratique pour le mettre à côté de la télé.
Hannibal G.
TINYSINE ANT-RPSMA3 Antenna 2.4GHz RP-SMA 3dBi Female This TinySine ANT-RPSMA3 2.4GHz 3dBi antenna has a RP-SMA (Reverse Polarized) connector. It is ideal for extending the range of a wireless transmission module.
Bon rapport qualité/prix.
Hannibal G.
Mis en interne dans un boitier, bonne réception. Vu le prix, pourquoi s'en passer.
Hannibal G.
TINYSINE Adapter Cable RP-SMA to U.FL 10cm This adapter includes a U.FL connector and an SMA connector. It will therefore allow you to connect to a module with only U.FL connectivity a more efficient antenna in SMA...
Assez bien
Fait le job. MAIS alliage de l'écrou un peu fragile : marque facilement au serrage. Après il est vrai que j'ai tendance à y aller un peu fort...
Hannibal G.
Très bien.
Comme dit François.M dans son commentaire :
"Bien conçu, bien fabriqué, prenant bien la soudure, facile à monter et très bon contact !"
Hannibal G.
Utilisé pour ajouter une réception en entrée BT sur des amplis des années 70, Scott 636, Sanyo DXL2000 etc... connecté sur entrée ligne auxiliaire. Sortie casque Senheiser HD ou enceintes Studio Lab 102.
Emetteur depuis un ordinateur portable Dell, Samsung, Acer, ou téléphone Motorola, tablette noname.
Tout marche très bien. Détection rapide, pas de latence, distance très correcte (j'ai mis une antenne à 2€), éventuellement un très léger bruit de fond que l'on entend que si on le cherche.
Je recommande.
aurelien b.
SHANLING MTW100 V2 In-Ear Monitors IEM Bluetooth 5.0 White The Shanling MTW100 V2 headphones, particularly practical, allow a stable and efficient transmission of your music. Knowles loudspeakers and the intelligent design of these IEMs...
très satisfait
livraison rapide et colis bien emballé, produit conforme à la description, très léger dans l'oreille et confortable, bon son, pas de notice en français
