Nikolaus S.
Parfait sur un bureau
MICHAEL K.
Recommended
Customers reviews - There are 19275 reviews.
Alessio V.
JANTZEN AUDIO CROSS COIL 000-7004 Flat Copper Coil 14AWG 0.05mH Jantzen Cross Coils are the closest thing to a perfect inductor available today. They have been developed together with Audio Technology (Denmark) for the filtering of their...
High quality coils!!!
Best coils money can buy!!! High quality, detailed and transparent coils!!!
Alessio V.
High quality capacitors!!!
Best capacitors money can buy!!! High quality, natural, dynamic and detailed!!!
Alessio V.
One of the best capacitors for the price!!! High quality, detailed capacitors!!!
Alessio V.
MUNDORF BL140 Air Core Self 1.4mm 3.3mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Interesting coils!!!
Very very nice coils, well made, high quality and pricise values!!! Interesting price!!! You can't go wrong with Mundorf products!!!
Alessio V.
MUNDORF BL140 Air Core Self 1.4mm 0.1mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Alessio V.
Nice cable!!!
Very very nice cable!!! Well made, interesting price!!!
Alessio V.
High quality cable!!!
Alessio V.
Nice board!!!
It does it's job in a perfect way!!!
Alessio V.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 68µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Nice capacitors for the price!!!
Very very nice quality price ratio capacitors!!!
Alessio V.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 100µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Alessio V.
Very very nice Bananas!!!
High quality and interesting price!!! Well made, strong contact!!!
Alessio V.
Nice forks!!!
High quality, nice forks!!!
Alessio V.
Nice feet!
They do their job very well, strong adhesive!
Alessio V.
Nice capacitors, interesting quality price ratio!!!
Very very nice capacitors at a very interesting price!!!
Alessio V.
Simple and efficient!!!
They do very well their job!!!
Alessio V.
High quality terminals!!!
Well made and high quality at a very interesting price!!! Nice!!!
Alessio V.
Nice quality cable!
Nice cable, interesting quality price ratio!!!
Alessio V.
Nice cable for the price!
Alessio V.
High quality power supply!!!
Very silent and stable power supply!!! Well made with high quality components!!!
Alessio V.
Nice capacitors!
Very very nice capacitors for the price!!!
Alessio V.
Isolated Screw Terminal 5 Ports Ø6,5mm (Unit) Very practical, the domino allow quick and easy connections thanks to a screw system. No soldering required to connect two elements. This model has copper alloy screws and 5...
Well made Terminals
Used in a power distributor, very nice quality!!!
Alessio V.
Nice support
It does the job perfectly!
Alessio V.
Well made
Well made noise suppressor, it fits perfectly on the cable. Nice product!!!
Alessio V.
Incredible upgrade for the price!!!
Installed on an HP PC (very easy to install too) used for liquid music. Voice and instruments are more natural and the soundstage is wider than without...simply amazing!!!
Alessio V.
Very nice box!!!
Very very nice box!!! Even the price is something incredible!!! Used for an amplifier external power supply.
Alessio V.
Well made case!!!
Very very nice box!!! Even the price is something incredible!!! Used for a DAC power supply.
Alessio V.
Very very nice entry level mic!!!
High quality, easy to use, precise measurement mic!!!
Alessio V.
Adhesive Cable Tie 20x20mm White This adhesive cable tie simply attaches to a wall to allow you to group your cables together. The base of the cable tie is adhesive and can therefore be easily attached to any...
Nice quality
Strong adhesive, they do very well their job!!!
Alessio V.
Nice capacitors
You can't go wrong with Mundorf capacitors!!! Nice quality price ratio.
Alessio V.
Very nice feet
High quality, well made feet at a very interesting cost!!!
Emin B.
perfect one more time
about Khadas Tone Board I think a lot has been said and I can confirm that it is so. Simply the best value for money.
I want to thank the staff who quickly solved the small problem I had with the payment.
All recommendations for the Audiophonics service, shipping was fast, delivery as well. Everything is perfectly packed and without the possibility of damage. Great job, keep it up.
Emin B.
perfect
The NanoDigi is a fantastic device that does everything flawlessly. I got a version with a black box which suits me even better.
Patrick M.
mauvaise pioche
L'appareil que j'ai reçu faisait des pauses pendant l'écoute, environ 1 toutes les minutes.
Je l'avais connecté comme cela: entrée sur RCA coaxial sortie sur RCA.
A noter qu'il n'y a pas de télécommande.
Audiophonics a été correct et me l'a repris.
Christophe O.
Bon produit, tarif raisonnable et finition très correcte ! Fait le travail. Je recommande.
Christophe O.
Bon produit, pas cher et assez bien fini. En revanche, prise en main un peu difficile pour brancher ou débrancher d'un appareil.
merci à Audiophonics pour cette paire de bloc stéréo se hissant au sommet
Acheté en double pour une bi-amp verticale, je me retrouve avec un total de 2400w d'alimentation, les graves de 38cm sont ainsi parfaitement maîtrisés.
Par leur neutralité et transparence, j'entends davantage la signature sonore des autres électroniques en amont.
En été, sans clim, les amplis chauffent un peu.
Les blocs ont toutes les qualités requises : transparence, dynamisme et tenue, naturel, encombrement et consommation réduits.
En réflexion post achat je dirais que les idées d'amplis à tubes ou des classiques transistors sont maintenant écartés.
Bravo pour cette réalisation Française en ce jour du 14 juillet 2020 :-)
Mark P.
Excellent cable
Switched from Van damme concert series cable to this super cable.
Better sound and dynamics from this Canare cable.
Nice thick copper strands with strong and sturdy sleeves.
Also twisted which is the better way to make speaker cables which is why Kimber makes all cables like this.
Thankyou Audiophonics for supplying these excellent cables!
Alvaro S.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.2μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
Timbre natural, realismo sonoro.
Usados como desacoplo en la entrada del ampli, en un equipo que ya sonaba muy bien. Esperaba cierta mejora con respecto a los Cross Cap que había pero el resultado superó lo esperado. La mejora es general, el ataque de las notas y el timbre de las voces e instrumentos es súper natural, hay mucha más información y detalle, llegando a engañar al cerebro que cree que tiene los músicos delante... Yo mismo soy músico, tengo muy claro cómo suenan las cosas en la realidad. De verdad que no esperaba semejante mejora. Un 10/10 a los condensadores. Por parte de Audiophonics todo perfecto, envío rápido y precios razonables pero eso ya lo sabíamos...
Bernard B.
connecteur cable alim source
Par rapport au connecteur FI-E11-N1(G) qu'il remplace, celui ci apporte focalisation et densité des sons sur l'ensemble du spectre et au final un bénéfice certain sur le timbre.
Carsten S.
Very good quality, perfect linear power supply for high-end USB
I am happy to write a short review of this product. I use this linear power supply for high-end computer audio. It feeds an ifi defender. An ifi ilink USB is attached to it (USB-SPDIF converter). In my opinion, the USB-SPDIF converter benefits from this. The sound is excellent, which is certainly also due to the excellent converter.
The processing of the order and shipping to Germany worked perfectly. Audiophonics works very professionally with very good communication. The power supply arrived very quickly and excellently packaged.
Anytime again. Greetings to France.
Thank you for this great review.
A small correction : Allo Nirvana is a ultra low noise switching mode power supply (not a linear power supply).
Michel h.
delif
Acheté pour alimenter mes amplificateurs Jadis JA 200
Câble Secteur de bonne fabrication, résistant et assez souple pour son diamètre, pas difficile à monter à condition de bien dégager les fils d’alimentation de la garniture en coton et du fil de drain.
Assez mélodieux, pas de dureté, médium aigu un peu descendant, grave ample mais sans excès, spatialisation et dynamique moyenne. Globalement la reproduction est un peu triste, sonne mate et manque, de respiration.
Ce câble peut aller sur des électroniques avec une prédominance du médium, haut-medium, aigu, mais ne convient pas sur mon système.
Michel h.
delifi
Connecteur IEC de médiocre qualité, le serrage des fils n’est pas très efficace et les contacts « à pinces » avec la partie mâle sont de mauvaises qualités, surface des contacts insuffisante, la prise tient très mal.
SCHURTER propose d'ordinaire des connecteurs de qualité, peut-être êtes-vous tombé sur un modèle défectueux ?
Vous pouvez contacter notre SAV afin qu'il procède à un échange.
Rémy V.
Tout simplement Excellent !
Voila une très bonne banane ; Finition de qualité, bien conçue : belle mécanisme de fixation à 2 vis permettant un serrage efficace des câbles (pour une fois les vis ne sont pas trop courtes comme c'est souvent le cas sur de nombreuses bananes même très chères ...). Système de serrage par écartement de la pointe efficace. Pas d 'impact négatif sur la transmission sonore. Je recommande.
Rémy V.
Tout simplement excellent !
Michel h.
delifi
Connecteur secteur de bonne qualité à un prix imbattable, facile à monter, bons contacts. Le principe de serrage du câble est excellent mais rend la prise peu longue.
Lorenzo B.
Excellent product
I think this could be the best streamer (and server) for this price point. I came from a GCA and it was good but I need something better and more flexible. I’m totally satisfied.
Câble de grande qualité.
Ce câble est très bien fabriqué. Les prises tiennent parfaitement ce qui assure des contacts impeccables. La souplesse de ce câble est un véritable atout. Cette souplesse permet une installation sans contraintes sur les connecteurs. Par rapport à mon ancien câble Furutech qui coûte près de 2.5 fois plus cher et dont les connecteurs ne sont pas au top il y a pas photo! Pour ce qui est de l'écoute, je constate à nouveau que point n'est besoin de dépenser des fortunes pour obtenir d'excellents résultats. La première vertu a retenir c'est la qualité de fabrication. J'ai fait l'expérience également avec un câble firewire OXAIDE qui coûtait près de 120 € avec des connecteurs absolument indignes par rapport à un câble lambda à 15 €.
Là sans hésitation ce câble a un rapport qualité /prix excellent. N'hésitez pas!!!
Alain A.
Incontournable
Ideal pour fixer le cable de masse d'une platine vinylevsur l'ampli.
Alain A.
FURUTECH FP-900 (G) Gold Plated RCA Plugs (Pair) Furutech RCA subbases have been developed to satisfy the most demanding consumers. These bases are made of phosphor bronze and are 24k gold plated.
Qualite or
La qualite est palpable, montage facile, rca classieuse
Phillip F.
first impression: exceptional value
I bought this on the strength of a very positive review of this module in a DIY application in Archimago's blog.
It took a long time to get it, thanks to the pandemic, but once in stock, delivery was quick and painless.
The unit is self is incredibly small, runs very cool, is dead quiet, and sounds as good as any amplifier I've used. I despise subjective audiophile descriptions, so will merely say that in terms of detail, dynamics and lack of irritation, I can't fault it. It also looks very good (although the "on" light is a bit bright - that is common these days.)
At the price, even including shipping and Canadian tax, it's a phenomenal bargain.
I'm giving it 4 stars because it has to prove its reliability, and also because I would like to measure its performance first.
Bravo Audiophonics!
