Peter B.
Recomendded!
Edwin P.
Zywno H.
Perfect!
Fast delivery, wonderful DAP.
I strongly recommend!
Customers reviews - There are 19156 reviews.
Adam S.
works very well but its not silver plated
the same cable as the sommercable mercator cat 7 cable that cost 20% of the price of this cable
Adam S.
works very well
it is identical with the viablue solid core rj45 cable
are 99,9% sure its the same cable viablue sells for almost 15 eur
the sound from tidal is the same with both cables
very good top performance
Richard P.
Très bon câble.
Merci à Audiophonics pour vos précieux conseils.
Avec des connecteurs RCA ELECAUDIO TE-RC85S le son est très aérien avec une belle assise. Pas fatigant sur de longues écoute.
Très bon câble.
Maciej Z.
MUNDORF ACW115BK Wiring Cable Copper / Silver / Gold PTFE 1.8mm² The Mundorf ACW115BK is a high quality wire with a high conductivity. Thus, its conductors are made of high purity mix copper / silver / gold and insulated by a PTFE sheath in...
I purchased 1.8mm and 0.79mm Mundorf Angelique to rewire my Snell E3 speakers.
Original Snell cable is nothing special, possible 12AWG twisted multi strand copper.
Mundorf is very stiff and hard to work with, and very hard on speaker connectors, so care ash to be taken while moving drivers with soldered cable.
It's also very hard to domestically twist 2 runs of the cable, as it twist more at the start and then further it become uneven, while if you twist more, you will apply to much pressure on the PVC so it breaks.
After 20h of initial listening I was hoping for more, but nothing changes.
The sound is dull, lacking definition and resolution, with poor soundstage. Everything became closed in. There is not much air and ambience, or textural richness. Tones are ending quicker then they should be without any pleasant overtones.
I like smooth sound too, but it must not lack definition, and clarity. This is nowhere near smoothness. It's too polite. Perhaps it would work slightly better on extremely bright, and harsh system, but if your system is neutral you should choose something else in my opinion.
When it comes to Audiphonics service, its one of the best, as usual. Great communication, great choice, reasonable pricing and fast delivery. 5 stars for the service. 1 - 2 stars for this cable.
christian w.
XDUOO TA-66 Headphone Amplifier / Tube Preamplifier 6N2 6N5P With its TA-66, Xduoo presents a headphone amplifier/preamplifier with tubes. The TA-66 features two tubes, a 6N2 tube for the...
Great value tube amplifier.
Super fast delivery to the UK. Actually quicker than me ordering in the UK
Daniel D.
super cable secteur
J'ai tiré 2 lignes séparées de mon tableau électrique à chacun de mes blocs mono avec ce Tornado sans me ruiner. Gain évident à tous niveaux et superbe musicalité avec prises Iego 8085 pour un son un peu chaud, rapport qualité/prix hors norme. Il me restait quelques mêtres de chute que j'avais remisé à la cave. Venant de recablé différemment toute mon installation, je me suis dit qu'il ne coutait rien de faire un essai avec ce reste de Tornado pour alimenter une source (ce que certains déconseille). J'ai constitué un CS avec d'un côté une schuko Viborg cuivre/or/argent et de l'autre une IEC Oyade C004. EH bien!!! après 60 à 70 Heures de rodage le mariage fonctionne à merveille avec toujours cette superbe rapidité/musicalité et belle ouverture. Je valide à 100% la polyvalence de ce cable. Une vraie réussite, à ce tarif ce câble et une vraie pépite... foncé!
Stefano P.
Addicting!
I just replaced with it the FP-3TS20 power cord feeding my pre, with immediate results! Dead silent, with a simply unheard clarity over the full range of frequencies. Unexpected and addicting.
Hocine H.
Incroyable.
J'étais un peu sur la réserve concernant le monobrin, je l'ai utilisé pour recâbler le woofer de mes enceintes et ce câble après une dizaine d'heures est d'une précision et d'une délicatesse que je n'aurai imaginé. Très belle surprise.
Hocine H.
Belle découverte
Utilisé pour recâbler le tweeter des enceintes, ainsi que le bornier, ce câble est une grande révélation. Facile à travailler et d'une précision redoutable, les tweeters on une nouvelle vie.
ANTONIO M.
3E AUDIO 480-1-29A PFFB Mono Balanced Class D Amplifier Module TPA3255 1x480W 2 Ohm This 3E Audio 480-1-29A amplifier module is a class-D balanced mono amplifier module based on a TI TPA3255 chip. This module delivers up to 480W into 2 Ohm (@ 1% THD+N, 1kHz)...
baja corriente
Es mucho peor que la 3e PFFB stereo que conservo, compré 2 mono PFFB con fuentes de alimentación lineal de 300va cada no reguladas...un desastre, no tenia ni graves ni dinámica, creo que esta internamente puenteada mal el mono de manera que si la impedancia mínima de la 3e estéreo PFFB ya son 4 ohm y necesita cajas muy facules tipo mark audio, Klipsch...la monk es para IMPEDANCIA MINIMA de +8ohm (si) por tanto con casi todas las cajas sonara sin graves ...pero si tus cajas son de impedancia mínima 8ohm, compralas, mide genial
ANTONIO M.
mejor que purifi
Tuve una PURIFI con la desastrosa SMPS hypex y sonaba estéril y enclenque. La devolví. -purifi con fuente de alimentación lineal hubiera sido perfecta sin embargo pero no se hacerlo porque es multivoltaje - . Encargué este módulo por sus buenas medidas aprebachando que la impedancia mínima de mis cajas no es demasiado baja -este no es estable a 2 ohm como purifi- pero como es un solo voltaje se le puede meter fácil un toroidal y una fuente no regulada lineal...resultado: con un previo realmente cálido/transparente como el perfecto Glasshouse TVC, la resolución es infinita el detalle el realismo , calida valvular sin ruido pero con cuerpo con grip emocionante ¡Mucho mejor que la típica Purifi o NCORE con SMPS hypex -probablemente con una SMPS Meanwell hubiera sido mucho mejor+! Brillante suena mejor -con un previo TVC - que la clase A
florent n.
SHANLING MTW200 PLUS True Wireless Dynamic In-Ear Monitors IEM Ø10mm 32Ω 112dB 20Hz-20kHz With the MTW200 Plus, Shanling presents us with wireless in-ear earphones. The brand has opted for a dynamic 10mm driver with a titanium membrane, coupled with a special...
impressive
remarkably light, side independent (left can be right and vice versa, and once you take them out of the box, it resets the earbud put in the left socket as the main earbud), they sound great. Great bass extension while keeping great clarity. No buzzing sounds from bluetooth. Compared to quality wired iem, they sound just as good. The transparency/ANC modes while "available in the voice menu" do not work but who cares? Cherry on top, a beautiful case
Valéry H.
AMPLI DAC CASQUE
Excellent ((petit)) Il lui manque juste une tél.
Comme ampli approchant les " AUDIOPHILE " Il a bien sa place.!..
michel f.
DC 15V Jack Filter with Supercapacitor to Jack DC This DC 15V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 6 supercapacitors 5F - 3.0V and an...
Attention
filtre qui ne convient qu'à une tension strictement de 15v
Maurizio I.
Avevo Cardas, ho ricablato le mie magnepan con Neotech e la differenza è disarmante! piu volume,piu profondità d'immagine,più naturalezza,più armoniche,non credo ci sia cavo migliore di questo!
Maurizio I.
NEOTECH STDCT-14 Hook-Up Wiring Multi-Strands UP-OCC PTFE 2mm² The STDCT cable wire is a very high quality multi-core cable with 99.99998% pure UP-OCC copper conductor and PTFE insulation. Ideal for efficient internal wiring.
ho rifatto totalmente il cablaggio interno delle mie Magneplanar3.6 insieme i crossover. Che dire,suono pieno e dettagliato naturalezza e profondità d'immagine pazzesca.
Jacques L.
Câble modulation Audiophonics
Comme l'avais déjà signalé certain acheteurs le connecteur coté ampli est de mauvaise qualité et ne s'enfiche pas sur de nombreux appareils.
Remboursement demandé et effectué sans difficulté.
Gary H.
Excellent, slim profile chassis
Well constructed and finished to a high standard.
pascal B.
petit preamp phono
excellent petit préampli phono, testé sur son entrée MM
son détaillé et clair ; grand silence sur les blancs grâce probablement à la batterie intégrée et à loa fabrication soignée
Hans Peter N.
MUSES8832E-TE1 Dual OPA SOP8 (Unit) The MUSES8832E operational amplifier is a dual OPA in SOP8 format optimized for high-fidelity and professional audio applications. This rail-to-rail OPA features a high maximum...
Replaced an SGM358
Hey there,
I replaced an SGM358 in my FIIO DK03. I am very pleased with the sound now. Thanks Audiophonics for the great service.
Hocine H.
Qualité optimale.
C'est cher au premier abord, mais une fois en main, puis installées on comprend pourquoi on met le prix. Une qualité irréprochable, une installation agréable, un maintien efficace et un son très neutre. Je tenais à remercier audiophonics car avec toutes les commandes que j'aie passée, ils ne se sont jamais trompés sur un article. un grand bravo et merci pour ce que vous nous proposez.
Pavol B.
SMSL PS200 DAC ES9039Q2M USB SPDIF Bluetooth 5.0 32bit 768kHz DSD512 MQA-CD The PS200 from SMSL is a small, compact DAC featuring quality components. It features an ES9039Q2M DAC chip, an XMOS XU316 USB interface and no fewer than 4 OPAs. It supports...
New BEST DAC under 100€
A few words about this little plastic DAC. First of all - the delivery was quick, but unfortunately, even though the package included 10 meters of network cable, they did not fill it with foam, so the paper box arrived completely destroyed. Fortunately, nothing happened to the DAC.
Now to the DAC itself. It's really a single, cheap-looking plastic box with plastic buttons, taking it apart would probably mean destroying the box. It looks really cheap in that sense. The second thing is what's in there and how it plays. And here the game changes completely. Those who saw it disassembled claimed that this is a really seriously made DAC, with quality components and a good architecture. Sound - I compared it with my flagship DAC, built on top of the ESS 9018SE chips, as well as with the NOS DAC built on the Wolfson chip, and with the R2R DAC, although "only" DIY. What I heard got me. It's true that the sound didn't have as much layering and harmonic richness as the two ESS9018SE chips, but that DAC was 20 times the price. On the other hand - the smoothness on the SABER is incredible, the richness of details, the light naturalness, the strength in the bass and yet so deep, the dynamics did not lag behind... But what got me the most was that I could literally hear it playing silently. Silence around the instruments, around the singers, the empty space around them literally played. The space is the same - at first glance more stereo than in depth. But if you listen closely, it's there, it's just not added forcibly. I still have to come back to the price, how much it costs. SMSL probably really invested mainly in the interior, as in the packaging. Although a risky purchase for me, I didn't know what I was getting into. But I'm glad I did. I love the sound of it. He is amazing. And for €100!!!!! I RECOMMEND!!!!
Istvan M.
Weak mechanics...
...or I was just unlucky. I bought two for my monoblocks and while one socket works perfectly, the entire "inner workings" of the other one, i.e. the part with the contacts, pushes backwards when I try to plug in a cable , and of course there is no contact - for some reason the middle part of this socket is not attached correctly or not at all to the sockets frame. It's completely unusual from Furutech.
Génial !!
Simples, bien conçues et facilité de mise en oeuvre. Le signal est très bien respecté. Excellente fiche.
Excellent coax
Il fait jeu égal avec un coax. Diy polarisé équivalent a plusieurs centaines d' euros.
Belle surprise et pour le tarif, c' est une aubaine !
Monte avec des switckraft RCA, beau combo ! A essayer !
900M-T-0.8D Soldering Tip Ø0.8mm This soldering iron tip has a long service life thanks to its high quality of manufacture. It will allow you to carry out your welding for your DIY projects.
Gérard M.
WONDOM PS-BC12112 BCPB3 Battery Management System Module 5x Lithium 18650 The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery...
Très bien.
Fait parfaitement le job pour alimenter un préamplificateur phono. MAIS attention le set de câbles et leds n'est pas livré avec comme indiqué précédemment et il est quasi indispensable.
Renaldo V.
Elipson 1400
envoi très rapide Merci
pour une mise à jour sur des filtres ( Elipson 1400 )
amélioration garantie
Renaldo V.
JANTZEN AUDIO COMPACT MKT 001-8040 Axial MKT Capacitor 160V 3.3µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Elipson 1400
Renaldo V.
Elipson 1400
Une pépite
Je rejoins complètement les avis précédents. Pourtant câble fait cheap... Le bleu un peu clinquant aussi. Mais une fois installé, c'est un remède miracle.
Mon choix désormais.
Validey après avoir essayé Mundorf 10% et dinavix 4%( qui s' en sort très bien).
Les soudures sont belles, et le prix reste correct.
Parfaite
Excellentes fiches RCA, simple efficace et agréable a travailler et au rendu sonore
AUDIOPHONICS MUSES8920A Dual OPA DIP8 (Unit) Audiophonics is proud to present its MUSES8920A AOP in DIP8 format. This dual AOP is based on a high quality JRC (Nisshinbo Micro Device Inc.) chip, features JFET inputs and is...
Mouais
J'ai voulu essayer, je préfère les JRC 1612.
Je n' enlève pas d' étoile car c' est une affaire de goût et ils sont très bien construit.
Brice D.
Rodage KT120
J'utilise ces tube sur un Jadis DA88S et je préfère vous prévenir que le rodage est très long.
Prévoyez minimum 100 heures avant d'avoir une idée et 500 heures pour un rodage total.
Très bon tube si vous avez la patience d'attendre.
Comparativement aux étiquettes link, elles se soudent facilement et sont super bien conçu. Très transparentes, elles laissent le message via le câble intégre !
Superbes fiches aux rqp excellent
Elom G.
Top avec une très bonne réputation.
Testé chez moi dans un fosi v3, le son était bon et bien équilibré; pas grand chose à lui reprocher.
Mais pour le prix je m'attendais à un effet vraiment wahoo !
Bref, bon app très clair et équilibré mais pour moi un peu cher pour le résultat obtenu.
Elom G.
Cet aop bénéficie d'une très Bonne réputation.
Mais, testé chez moi dans un fosi v3, je n'ai pas été convaincu. Le son est doux et musical, ça c'est sur ! Mais les graves manquais de netteté et étaient même un peu brouillons.
Pour le prix, je ne suis pas convaincu.
Elom G.
très bon rapport qualité prix
utilisé dans un fois v3, cet app est assez surprenant. Le son est très bon pour son prix. Les graves sont bien tenus, les aigus corrects sans trop piquer. Il y a surtout un dynamique de fou, à la fois très agréable et peut être parfois un peu fatiguant.
Bref, pour le prix, ça vaut vraiment le coup de les essayer. Je recommande.
Elom G.
Testé dans un Fosi V3, c'est op font un peu mieux qui ceux fournis d'origine avec l'ampli, mais sans être exceptionnels. Les graves sont correct mais les aigus un peu métalliques. Le tout est un peu fatiguant; en tout cas pas très doux ou musical. Je ne les retourne pas vu le prix, mais ils ne me servirons à rien.
Elom G.
AUDIOPHONICS WIRE Interconnect Cable Stereo RCA OFC Copper Gold Plated 75cm The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a...
Bon câble avec un bon équilibre. Je n'ai pas pu le comparer au canard star quad qui est actuellement en rupture.
En attendant le réapprovisionnement pour faire la comparaison, je suis plutôt satisfait de ce câble.
Elom G.
Moyen
Ce câble est un bon rapport qualité prix; mais vu l'incidence du câble de modulation sur une installation, il vaut mieux mettre un peu plus cher pour quelque chose de plus équilibré. Pour 40euro le Audiophoncis à base de Mogami Neglex W2549 a été pour moi un meilleur choix.
Elom G.
Je rejoins la multitude de commentaires élogieux sur ce câble. Après avoir essayé beaucoup de câbles enceintes (audioquest, elecaudio, triangle, real cable, oehlbach), j'ai trouvé mon bonheur avec ce câble que j'ai adopté pour toutes mes installations audio, en simple et en bicablage avec la version 4x4mm2
Elom G.
TANCHJIM ONE In-Ear Monitors IEM Dynamic Ø10mm 126dB 16Ω 7Hz-45kHz These affordable Tanchjim ONE in-ear monitors feature dynamic Ø10mm drivers and a low-frequency design.
Ecouteurs de bonne qualité, sans prétention. Le son est bien équilibré; graves médium et aigus sont bien restitué. Pas de fatigue sur la durée d'écoute.
Après, ce sont des intra-auriculaires donc pas de sessions d'écoute trop longues ou pas à volume élevé, si vous voulez préserver votre audition.
Les écouteurs tiennent bien dans les oreilles grâces aux embouts de différentes tailles fournis.
Très bons conseils de la part d'audiophoncis
Serge G.
Decu
Claquements a la mise sous tension. bruit de moteur pendant la lecture.pas de clavier numérique sur la télécommande . obligé de faire défiler les chansons . vraiment déçu
Sandy G.
MUSICALITE ET PRECISION
Une belle expérience, que l'écoute de ce magnifique amplificateur.
Raccordé à un préampli MUSICIAN Monoceros, le résultat est excellent. Le différents registres musicaux sont présents, et fouillés, sans tomber dans un coté "ultra". La musique est belle, douce mais punchy à la fois...Un ampli a tube (j'en ai un) se justifie t il encore, au vu de l'évolution des "transistors" ?
IBASSO DC06PRO Portable DAC / Headphone Amplifier 2x ES9219C 32bit 384kHz DSD256 MQA 16x Ibasso unveils a new version of its DC06 portable DAC/headphone amplifier, the DC06 Pro. Compact, it features 2 ES9219C DAC chips and volume control knobs, new advanced features...
Excellente qualité audio et finition du produit
Mon meilleur dongle DAC, et cerise sur le gâteau, il chauffe peu (à peine tiède).
Cyril J.
Node2021
Respire la qualité
Cyril J.
BEATECHNIK x LHY AUDIO Filter Power Supply Module Kit for Bluesound Node X / N130 This filtered power supply module kit has been designed by LHY Audio at Beatechnik's request, and is intended for use with the Bluesound Node X and N130 products.
Node 2021
Changement de l' alimentation en une demi heure enfantin
Restitution sonore transcendai tout est plus naturel équilibré aucun regret
Claude T.
IAN CANADA TRANSPORTPI DIGI II Ultra Low Jitter Digital Audio Interface Module With the TransportPi Digi II, Ian Canada has taken their high-performance all-in-one digital audio interface for the Raspberry Pi to the next level. This module delivers a...
grande évolution
Par rapport a la version précédente, il y a une nette évolution dans la qualité du son. De plus en mode coax les parasites emi ont disparu.
