Rastislav K.
Nice
Marc A.
Un bon cable...
David m.
une super prise hifi
Customers reviews - There are 19554 reviews.
Harald B.
Pace, rhythm and timing are top
I'm a huge fan of the Allo Boss Dac. I like his musicality. Pace, rhythm and timing are top. I have tried different power supplies, LPS,Ifi etc. I became best results with two supplies. Pi and Boss separate powered. Now I use a Allo Shanti and it's the best i tried until now. The music becomes more natural, less grainy, less sharpness. And this without loosing his musicality. I detected only benefits and no disadvantage.
One power supply and you are done. The Allo Shanti is imho a must have, if you like the Boss dac.
Harald B.
Make good things better
One power supply and you are done. Imho a must have, if you like the Boss dac.
Gianluca S.
Top quality
Top quality connector to be soldered.
Just be careful to scratch the rodium plating on the soldering points inside. This way they will be properly wet by the tin during soldering. I used to replace a 3,5mm connector on a Furutech adl phone cable.
Wolfgang G.
Good product
A Class A transistor amplifier as a kit can only be found at Audiophonics. A very good and cheap product. Unfortunately, there is no data sheet with information about the size of the cooling surface and the adjustment of the quiescent current. Therefore only 4 points.
MINIDSP Infrared Remote for NanoSharc / MiniSharc / OpenDRC / DDRC88/22/24 / NanoAVR-HDA This ready-to-use pre-programmed MiniDSP IR Remote allows direct control of the brand's main DSP modules. It thus avoids the tedious operation of the learning mode programming.
Télécommande minidsp
Produit qui devrait être fourni avec le minidsp. Télécommande appropriée au minidsp. Ras
Pierre B.
Super rapport qualité prix
C'est le deuxième que j'achète et ce n'est pas sans raison.
Je n'utilise pas la sortie casque mais soit la sortie digitale optique en le branchant sur un serveur multi-média Pioneer N-50 (plutôt haut de gamme pour ceux qui ne connaissent pas) ou directement sur une entrée ligne du pré_ampli.
Surprise le son de la sortie ligne soutient la comparaison avec la sortie du Pioneer, clair, dynamique un bon grave. sur Deezer avec une bonne connexion WiFi et avec une téléphone Sony XPeria une écoute très agréable et sans fatigue.
Si vous utilisez la sortie RCA, pensez que son niveau de sortie dépend de la position du bouton de volume, ce qui permet de la régler au même niveau que les autres sources utilisées.
Je vais sans doute l'intégrer dans mon pré-ampli maison, en tant qu'entrée Bluetooth là il aura une alimentation de course et ça évitera la multiplication des boîtiers, câbles et autres alim.
Bref à ce prix là et m^me plus cher j'ai pas trouvé mieux.
Franck B.
J'ai remplacé les borniers de mes enceintes JBL 4429. Dans un même temps, je suis passé d'un câble qed signature à un câble qed xt 40. L'ensemble de ces deux modifications a changé mes enceintes. Je ne saurais dire laquelle de ces deux modifications a eu le plus d'effet. J'ai retrouvé de plus beaux médiums et engins des basses profondes.
Très bien les délais , l'envoi et le produit
jonathan r.
Plug and play
Envoi rapide. Montage facile sur raspberry 3. Avec une image fraichement téléchargée de volumio, tout marche directement.
Content du son!
Jean Noël L.
Satisfait !
Bonjour !
Emballage soigné, livraison dans les temps , très satisfait par ce produit et par vos prestations !
Cordialement !
Jean Grégory R.
Bonjour , il est excellent pour mon utilisation , la batterie interne dure très bien , qualité son au top .
Concernant la livraison à la réunion ben très rapide 3 jours en Colissimo .
1er achat sur ce site et très satisfait .
Merci.
Sebastien D.
Très bon fil, frais de port abusifs
Excellent fil de cuivre, fait des merveilles en cablage interne. Frais de port abusifs (6,50€ pour un colis de 50gr).
Christian O.
Bon RQP, mais...
Ce Little Dot MK2 est intéressant comme base d'ampli casque, mais pas comme préampli.
Je lui fait 3 reproche :
- Les tubes d'origine chinois sont de piètre qualité et ne sont même pas appairés. Il faut les remplacer par des Mullard M8100 et des tubes russes 6p6n.
- Pour accéder au réglage de gain, il faut démonter l'embase en dévissant 4 vis (pas très pratique), surtout quand les vis ont tendance à foirer.
- Enfin ce Little Dot possède un peu trop de distorsion (3% de distorsion ca s'entend).
Pour toutes ces raison le Little Dot MK3 est bien plus intéressent, et sont RQP est nettement supérieur.
jerome s.
J'avais les "meilleurs" câbles achetés dans les grandes enseignes classiques.
A l'écoute sur mon installation, pour moi, pas de différence sur les sons graves. Par contre une nette amélioration sur les aigus. Très très appréciable.
Merci à toute l'équipe d'audiophonics.
jerome s.
L'AK47 des DAC!
Attention ça tue sa raçe!
Alex C.
Tres Bien sur tous les plans!
J'ai mis du temps à en venir aux câbles secteurs! Maintenant c'est fait, Pas de regrets. Sur un ampli à tubes (Prima Luna Prologue One), et après une recherche de la bonne phase, le résultat est là: superbe spatialisation.
Je n'écoute plus les basses, les médiums, les aigus, mais chaque interprète ou instrument...pour peu que la qualité d’enregistrement soit là, bien évidement, aussi bien sur vinyles que CD.
Excellent cable neutre et défini
Ayant dernièrement investi dans l'excellent DAC AUDIO-GD qui va très loin dans la finesse de décodage, je sentais qu'il y avait un truc dans le son qui ne convenais qu'a moitié, comme un frein dans le rendu.
Sans remettre en cause mon ampli tube et mes enceintes Tannoy, j'ai réfléchis au cable et c'est en lisant le commentaire de Christion O........ "Personnellement je le trouve supérieur au Mogami W3103, qui est pourtant un excellent câble, mais qui est quel que peu brouillon dans le grave et qui manque de subtilité dans le haut du spectre"......qui décrivait ce que je ressentait, car moi aussi j'avais un câblage Mogami 3103.
Donc je me sui jeté à l'eau et investi dans ce cable VIABLUE SC-2, et bien ce cable a gommé les defaults du Mogami 3103.
Les basses sont franches, nerveuses et dans le haut du spectre, les micros détails délivrés par le Dac R2-R et pour lequel il fallait prêter l'oreille, sont clairs, évidents et audibles même à faible volume.
Cable de surcroît très facile à travailler. ils auraient pu mettre un fil rouge pour le + ... attention sur la gaine externe, il y a une flèche pour le sens de montage ampli vers enceintes.
J'ai serti les cables dans les très pratiques cosses de la même marque, comme cela les précieux brins de fil sont préservés.
Dominique M.
Un beau petit ampli très complet
Je possède déjà un FX D802 depuis 6 mois et séduit par sa musicalité, je passe au D2160 pour avoir un ampli plus abouti, à savoir une entrée RCA, sortie casque, bluetooth et une entrée USB de meilleure qualité.
Au niveau son je retrouve donc les qualité du D802 en meilleur. A savoir principalement des médiums plus pleins et davantage de présence. Au quotidien il est aussi plus pratique. Le volume de mes Klipsch Heresy III est plus progressif grâce à la position L Gain, avec le Nad et D802 cela était vraiment pénible. Sinon je l'utilise surtout en mode HI-FI, très peu avec TONE ON et ses correcteurs....
J'apprécie toutes les entrées qui sont équilibrées aussi bien en qualité sonore qu'au niveau gain. Je n'ai pas de perte sonore avec le vinyl (équipé box pro-ject et cellule ortofon blue), le son est terrible. L'entrée USB pour lire mes fichiers FLAC sur disque externe est nettement supérieure au D802 et rivalise presque avec l'entrée coaxiale et mon lecteur CD.
Le bluetooth est détecté par mes deux ordis portables win 8, 10 et smartphone, le son est plus que satisfaisant.
La sortie casque est de qualité mais peu puissante, avec mon HD 650, il faut bien ajuster le volume ou passer au mode H-gain. Il est à noté que l'ampli conserve séparément en mémoire le degré de volume au casque et celui des enceintes, une fonction très pratique pour éviter les surprises sonores ! Au casque la neutralité de l'ampli surprend une fois encore par rapport au Nad plus dur musicalement.
Côté défaut, ben oui il en a quand même, comme le D802 il faut veiller à chaque allumage que celui-ci est bien en mode HI-FI avec la télécommande. Il aurait pu mettre la fonction sur une touche de l'ampli. Evidemment comme pour comme beaucoup d'appareil il lui faut un rodage d'une cinquantaine d'heures pour avoir un son bien défini surtout dans les graves.
Bref je ne regrette le gap et l'investissement dans cet ampli FDA qui renvoie mon Nad C720 BEE au placard sur bien des aspects. A côté je conserve malgré tout un ampli à tube (sauf pendant la canicule...) pour une écoute plus typée suivant mon humeur mais l'écoute du FX D 2160 me convient parfaitement par sa neutralité, dynamique, espace sonore, détails et ergonomie.
Je recommande donc cet ampli sans hésitation.
Maryse M.
Livraison rapide et correctement emballée !
Amplificateur excellent !
Belle qualité, belle finition, du haut de gamme, à un prix très correct.
Très bon ampli
J'ai été très étonné du dynamisme de ce petit appareil, qui n'a rien à envier à des appareils bien plus imposants. Analytique, aéré, et aucunement enjôleur ou clinique. En plus ça ne chauffe quasiment pas, parfait pour la multi-amplification. Pour être parfait, si vous pouviez améliorer le défaut de "ploc" à l'allumage, ou à l'extinction, sur des enceintes à très haut rendement (105 db/1/w/1m), ça s'entend quelque peu...
AUDIOPHONICS PA-M250NC Amplifier Mono Class D NCore 1x250W 4 Ohm The Audiophonics PA-M250NC incorporates a Hypex Ncore NC250MP power amplifier module. This is a solid basis to build a high-performance mono HiFi system, capable of delivering...
Excellent appareil
Belle qualité, belle finition, très costaud, ne fait pas "cheap", bref je recommande sans réserve !
Belle qualité, très pratique, composants de bonne facture.
Juste attention à ne pas trop chauffer les fiches si soudées, sinon, pour plus de sécurité, achetez les fiches idoines !
Anodized Aluminium Push Button with White Circle Light 1NO1NC 250V 5A Ø25mm Black Flat Head Here is a push-button 1NO1NC with cylindrical head allowing the control of an audio device with white illuminated display in a circle. Ideal for all types of DIY projects.
Bon article
Juste attention à ne pas chauffer les fiches trop longtemps lors des soudures, sinon acheter les fiches idoines !
Bonne qualité, belle finition, attention à ne pas trop chauffer les cosses si soudées, assez fragile, sinon achetez les fiches prévues pour !
Très beau produit
Belle qualité, belle finition, produit très correct, aucune réserve.
Correct
Produit correct, sans plus !
Coffret de très bonne qualité, très costaud, rien à voir avec les "Hifi 2000" qui font "toc" à coté.
Je recommande totalement, et sans réserve !
Produit de bonne qualité, prix très correct, rien à redire !
Michel D.
Remplacé 2 x 6 résistances 0,22 ohm bobinées en // avec 0,1µF par des MR5 seules (sans 0,1µF) : résultat immédiat sur la lisibilité du message musical.
Bravo à AUDIOPHONICS pour sa réactivité et son respect des délais surtout en période estivale.
Jean-Luc B.
Musique en réseau
Bonjour ,
Voilà une très bonne alimentation double !
Prévue pour ma Box et un disque dur en réseau , ça chante dans le plus grand silence !!!!
Chaudement recommandé pour le résultat obtenu , un investissement à ne pas négliger .
Patrick D.
Tranfo audio Haut Niveau Vers Niveai Ligne
J'ai utilisé ce petit transfo afin d'enregistrer vers un PC le son d'un projecteur de film Super 8 ne disposant qu'une sortie HP de 10 W.
Fonctionnement et résultat très correct.
De plus l'envoi et la livraison ont été très rapides.
Le son est meilleur en sortie rca que l' optique . La fiche optique vient toucher la fiche électrique ce qui dévie la position de l ' optique (pas pratique). Son très net , réaliste , avec du punch. J'ai upgradé en positionant le récepteur sur un assemblage anti vibratoire fait maison (vibrapod 1 , plaquette symposium ) qui élargit la scéne sonore avec plus de naturel. J'ai néttoyé les contacts de la fiche électrique et rca à la bombe pour contact électrique afin d'apaiser les aigus aigrillards de début d'écoute. Moins cher et meilleur que mon précédent récepteur. Mérite une mise en oeuvre soignée pour en tirer la quintescence.
Hugo B.
High grade balanced connection
If you're on a budget but want to upgrade your system with quality connectors then look no further then these.
Goodlooking en easy to use/solder.
Hugo B.
high grade balanced connection
Hugo B.
nice with Lapp Olflex Classic
Goodlooking en snug fit.
Hugo B.
Nicely made and affordable
Jean-Marc F.
Petit... mais sérieusement costaud!
En parcourant les différents avis laissés pour cet amplificateur casque, je me rends compte que tout a été dit!!! Vraiment tout!!! Alors, que dire de plus, si ce n'est qu'il n'y a pas à hésiter à le choisir? Son prix est un plus dans la prise de décision. Mais surtout... quel son!!! Je ne m'en passerai plus. Adopté!!!
Michael T.
AUDIOPHONICS TDA-S50 Amplifier TDA7498E Class D 2x 70W 4 Ohm
Agréablement surpris
Très abordable, et pourtant il fait le job et il le fait bien.
Joshua Y.
Parfait pour remplacer un transformateur équivalent dont le primaire était coupé.
Jorge B.
Excellente qualité de construction.
J'ai construit un câble secteur pour connecter mon préamplificateur à une barrette multiprise. Pour l’instant, je suis très satisfait du remplacement, même s’il est encore trop tôt pour les évaluations car il a besoin de plus de temps.
Jorge B.
Globalement, une bonne prise schuko, bon rapport qualité prix.
Pieter d.
ifi Audio iPOWER AC-DC Adaptator / Low noise Power supply 15V 1.2A This high-quality iPower power supply unit has low noise and a large number of DC jack connectors allowing it to provide stable and clean voltage and current at 15V DC 1.2A. It...
I used it with a Topping DX3 DAC. It is a very remarkeable sound update! Sounds now much better to real absolute High-End quality.
Best I ever heard on a High-end audio set.
Laurent T.
Prises vraiment super pratique pour gagner de la place avec des câbles secteur imposants , chez moi un Synergistic très rigide qui me posait soucis dernière mon caisson.
Qualité et finition toujours au RDV avec Elecaudio et commande toujours au top chez Audiophonics !
Laurent T.
Vraiment nickel!
Je cherchais depuis longtemps des pieds pour mon caisson de 44kg et ceux ci sont tout simplement parfaits .
Le caisson ne bouge pas du tout contrairement aux modèles coniques et cela donne un assise dans le grave chez moi très appréciable ;)
Commande toujours aussi parfaite chez Audiophonics !
Laurent T.
Top qualité !
Superbe fabrication et très belle finition , adaptateur vraiment très pratique.
Commande toujours aussi parfaite chez Audiophonics ;)
Sylvain T.
Formidable !
Pour prendre le relais d'un ampli hybride haut de gamme de 150W/8Ohms (tubes en étages d'entrée, Mosfet en sortie), avec des enceintes Aeria Compact (pavillon pour les aigus) c'est encore meilleur ! encore plus précis dans le placement des instruments (avec correction de pièce HAF), et des basses pareil qu'avec mon ancien ampli 20 fois plus gros et plus cher ! Trois remarques:
1/ sous Windows 10, le driver XMOS ne marche qu'après avoir désinstallé le Secure Boot et la sécurité des signatures de drivers...çà ne plaira pas à tout le monde même si ce n'est pas très difficile...
2/ les fiches banane fournies: j'ai viré le plastique et soudé directement mes gros câbles sur les fiches dorées; avec un bon isolant rétractable dessus, rien à dire !
3/ Bien sûr, à fond, la saturation PEUT arriver et là çà craque un max ! vaut mieux éviter ! pas de miracles, il n'y a quand même que 50 W mais c'est bien suffisant dans une grande pièce avec des enceintes de bon rendement. Merci Audiophonics pour le service de qualité.
Christian O.
Superbes timbres
Ce câble est réellement impressionnant. Il est neutre, équilibré et ces timbres sont de toute beauté. Il y a une sorte d'élégance et de justesse de timbres dans la restitution. On retrouve un bel étagement des plans sonores. Personnellement je le trouve supérieur au Mogami W3103, qui est pourtant un excellent câble, mais qui est quel que peu brouillon des le grave et qui manque de subtilité dans le haut du spectre. Personnellement je pense que ce Viablue SC-2 est un des meilleurs câble du marché à moins de 15 euros le mètre.
