Benoit d.
Robert C.
It is difficult to...
Robert C.
Good quality product
This is for DIYers since soldering is mandatory!
If you have basic soldering skills and tools then it is easy and recommended.
Customers reviews - There are 19628 reviews.
FABRIZIO R.
VIABLUE T6s Banana Plug Gold Plated Ø9.5mm (Set x4) Viablue T6s banana plugs offer excellent design quality for high-performance cable design. Their contact is 24k gold plated offering very good conductivity and resistance to...
BUONO
Qualità costruttiva buona, avrei preferito fissaggio cavo con viti a brugola
Consegna veloce
FABRIZIO R.
Ottima qualità
Prodotto valido per finitura cavo di potenza
Consegna veloce
FABRIZIO R.
Prodotto di qualità
Qualità costruttiva ottima, esteticamente bello
Consegna veloce
FABRIZIO R.
Fabrizio
Prodotto valido, ben fatto,
Consegna veloce
Bruno S.
Quelques gros défauts
Appareil sympathique, avec toutefois 2 gros défauts :
- un défaut de masse erratique, même raccordé à un ampli de puissance. Disparaît puis revient.
- il faut l'allumer et l'éteindre avec l'ampli raccordé sur off, sinon bruit affreux et danger pour les hp.
Stefan S.
AUDIOPHONICS CANARE Digital SPDIF Coaxial Cable 75 Ohm RCA-RCA 10m This SPDIF coaxial cable assembled in our workshops in France consists of an L-5CFB Canare cable and RCAP-C5F connectors of the same brand. This is a high quality 75 Ohm model...
Great Product
I was curious to see if the real 75 Ohm really makes a difference and it does: bass much more round, the room became much wider and the trebles lost harshness - all compared to a cable that has been well tested in leading HIFI magazines.
Stefan S.
Great Product
William M.
Molto comodo e essenziale 10 Strar
Facile da montare e molto funzionale, con questo modulo si ottiene un controllo della gestione di accensione e spegnimento da pulsante senza dover togliere alimentazione scollegando il cavo di alimentazione e dover usare la App per uno spegnimento dolce.
Jean Emmanuel H.
J'avais déjà câblé avec succès mon lecteur CD (Philips CD 624 utilisé en transport), j'ai donc décidé de continuer avec mon DAC et ma prise multiple. Je confirme mes premières impressions, silences plus profonds, sensation de clarté avec cette sensation qu'un voile se lève, légèrement plus de dynamique aussi. J'avoue qu'à l'origine j'étais assez sceptique sur l'apport d'un cable secteur mais j'avoue que je suis bluffé...Prochaine étape, la même chose pour mon Onkyo R1.
Spectaculaire Différence
Je devais avoir du secteur sacrément pollué pour que la différence soit aussi évidente.
Je l'ai branché en bout de barrette, suivi du Dac et de l'ampli.
On gagne en tout, surtout dans les hautes fréquences et les voix, comme si on avait ôté un voile.
On gagne en brillance, non pas que l'appareil en rajoute, mais il supprime les parasites électriques qui masquait certaines hautes fréquences.
Moralité, fabriquer du son avec du courant pollué, c'est un peu, pour un Italien comme moi, faire cuire ses pâtes dans de l'eau boueuse.
INDISPENSABLE, surtout à ce prix..
AMPLI LINE MAGNETIC LM-211IA - Tubes PSVANE 6CA7-TII MARK II  - DAC AUDIOPHONICS AK4495SEQ upgradé avec AOP SPARKOS LABS SS3602 - Enceintes Tannoy xt8f
bruno d.
Produit de qualité
Soudures et liaisons propres
facile à monter
son parfait
seul le prix me paraît élevé par rapport à la concurrence
Dominique M.
Très pratique
Évent coulissant permettant de répondre à de nombreux besoins.
Julien R.
Hallucinant !
Je suis vraiment bluffé par ce préamplificateur à tubes ! Déjà d’entrée Le son est pas mal avec aucun souffle, mais en changeant les tubes le son est exceptionnel, il faut prendre des tubes 5654W mode in usa, 17 euro la paire. Je l’ai relié à un nuprime STA-9. Le son est équilibré, ni froid ni trop chaud , plein de détails avec une belle stéréo, possibilité de régler est un plus selon l’ampli ou enceintes. J’ai l’impression d’avoir Fait un hold-up sur le site, le prix est dérisoire, je ne pense pas qu’il soit possible d’avoir Mieux , j’ai testé des ampli à 2000 euros chez moi qui ne fournissais pas autant d’équilibre.. bref je suis bluffé. La finition est très bonne aussi
Je vais certainement commandé un DAC sur le site
Alexandre W.
Ampli BT 2x25W
produit conforme à la commande
Avantage : très compact et bien fini
Attention, pas de doc technique livré avec.
daniel k.
Great Case!!
Great Case! Well without a Manual i had tu first figure out how to screw the Khadas Boord in this thing.
Well work, its Aluminium and anyone nagging about the finish quality.. "14,92 €" .. so i wont take it into my bed every night to snuggle with it ;) ...
its feeling solid, no sharp corners ans solid laquering and prints.. without this one you have this raw tone board wich super sucks!
so 5stars!!
Hugues P.
Ce transfomateur convient parfaitement à l'utilisation requise.
Hugues P.
Bon produit, bon design.
Olavi M.
Well made!
Olavi M.
jean francois F.
pratique et neutre
produit bien fini, pratique et absence de détérioration du son (heureusement!), pleinement satisfait.
Michael T.
Réglage du bras au top,
Par contre ne faites pas comme moi.... commander les piles avec.
Michael T.
Très bon petit amplificateur
Petit ampli suffisamment puissant pour sonoriser mon atelier.
Que du bonheur de bosser avec du son de qualité
Merci à audiophonics pour son sérieux
Yann J.
Bon support d'écran
Je suis très content de mon achat. Le support est compatible avec tous les raspberry pi y compris le 3 B+. J'ai également pu lui rajouter un DAC HIFIBerry AMP 2 pour me servir de l'ensemble comme chaine hifi.
Le montage n'est pas sorcier mais aucun manuel ne l'explique clairement (pour ça je retire une étoile). Une fois que l'on a compris on peut monter l'ensemble en 2min chrono. Le support lui même a un bel aspect et semble robuste, je n'ai eu aucune crainte à le manipuler et à me servir de mon écran.
Pour finir, c'est mon premier achat chez audiophonics et je suis particulièrement satisfait du temps de traitement de ma commande et de la livraison (le géant jaune n'a qu'à bien se tenir ^^).
Jacques B.
SOMMERCABLE EPILOGUE Modulation Cable Male XLR to Female XLR 0.5m (Pair) This high quality XLR cable pair consists of a Sommercable Epilogue modulation cable and Neutrik connectors, specially designed for optimal signal transmission. The cable...
Très bon câble et pas cher !!
Un rapport qualité/prix assez remarquable pour ce câble XLR !!! Stupéfiant, le son délivré !! La connectique symétrique de qualité n'y est pas étrangère mais le cordon est très neutre, dynamique et n'enlève rien au message sonore !!! Vous devriez le décliner en plusieurs longueurs !! Deutsche qualität !!!
Julien M.
Bonne qualité mais pas très souple.
"C'est du costaux" : c'est la première chose qui vient à l’esprit quand on vois ce câble pour la première fois. Les connecteurs, la gaine, ..., tout respire la qualité.
Mais voilà, la gaine est vraiment très rigide et fait un peut ce qu'elle veut. il est très difficile de lui faire prendre la forme que l'on souhaite. C'est sans doute son seul défaut.
Julien M.
Marche impec'
Cet adaptateur me sert à alimenter un ampli TDA7498E de chez AUDIOPHONIC et la puissance que peut sortir l'amplificateur est bien au delà de mes espérance !
Je ne peut que recommander !
Julien M.
Impressionnant
Ce petit amplificateur cache bien son jeu. Alors oui il est pas cher et oui n’accepte qu'une entrée RCA mais il n'a rien à envier à des ampli 10X plus chers !
Bon il faut aussi prendre en compte l'achat d'une alimentation en plus, dans mon cas une 32 V 5A DC mais on peut aller encore plus haut avec une 36 V DC. Et il y a aussi les borniers, trop petit pour mettre des câble nus de section 2,5 mm, il faut donc aussi des fiches bananes...
Mais quand on sait qu'il est capable d'alimenter des enceintes colonnes avec en plus le luxe d'avoir encore une resserve de puissance...
jean francois F.
polyvalent et excellent rapport qualité-prix
je cherchais un DAC peu onéreux à entrées diverses et alimenté en 12v (projet de le faire fonctionner sur batterie). Effectivement très souple d'emploi et je suis très agréablement surpris par la qualité d'écoute (après rodage d'une cinquantaine d'heures) très agréable. Semble très sensible aux cables employés (je préfère les plus neutres). Grand plaisir pour petit prix!
Cyril s.
Bluffant
J'avais déjà acheté 2 câbles de cette marque pour mes sources (DAC REGA et Streamer Bluenode 2 et j'avais ressenti une amélioration substantielle.
Mais là, avec ce câble sur mon ampli Creek evo 2 c'est... bluffant. Sachant que je me suis trompé ayant acheté ce câble "typé source" au lieu de celui "typé ampli de puissance" (PANGEA AC-9 MKII Câble secteur triple Blindage OFC / Cardas 3x6.6mm²). Je l'ai malgré tout testé et adopté ce câble en 2mm² de section seulement. Détails, scène, dynamique...cela "respire" et je redécouvre ma discothèque. Je suis le premier surpris sur l'importance des câbles secteurs au final, j'étais vraiment sceptique. Est-ce le fait que dorénavant toute la chaîne alimentation secteur est équipée du même type de câble que l'amélioration est aussi sensible ?
Le fait est que le résultat est là. Pour mon usage et puissance demandée par mon ampli, ce câble semble bien suffisant, après pour des amplis très puissants / écoute à puissance très élevée ? Ceci étant dit, je ne suis pas sûr que le câble livré de base avec l'ampli soit plus épais...
NB: avis au bout de 3 semaines d'écoute intensive.
Jeremy R.
Petite boîte magique !
Tout d'abord, concernant Audiophonics, livraison super rapide et colis très bien emballé, seul petit bémol je l'avais commandé en gris et j'ai reçu un noir, mais finalement j'aime bien.
A propos de la bestiole elle même, comment ne pas mettre 5 étoiles compte tenu du prix ? Alors oui les fiches des borniers sont un peu petites, le bouton de volume fait un peu cheap oui ... mais encore une fois pour le prix on ne va pas chipoter. Ca ne chauffe presque pas, ça s'éteint tout seul quand il n'y a plus de signal et ça ne prend pas de place. (Comme beaucoup je le savais petit mais j'ai quand même été surpris de voir à quel point il l'était ...)
Côté son, et c'est ce qui m'intéressait le plus, zéro souffle, une puissance étonnante, et c'est droit et détaillé. Ca me rappelle l'écoute sur mes enceintes de monitoring Yamaha, on aime ou pas ce côté "sec" mais moi j'adore. Une belle petite claque
Emmanuel G.
LA BASE
J'avais un a priori quant à la section de ce câble qui devait remplacer l'actuel (Mogami 3103) qui annonce 4mm².....
Quelle erreur ! un très bon câble qui chante parfaitement sur mon système ATOLL (PR 200 et AM 100) DALI (Zensor 7).
5 étoiles sans hésitations.
Peter V.
Impeccable !
Se branche en quelques secondes, fonctionne du premier coup, et depuis l'installation délivre une qualité sonore de très haut niveau. Bravo !
serge A.
STYROFLEX Capacitor 65V 0.0068µF 2.5% Styroflex axial cylindrical capacitors can be integrated in many electronic assemblies. They have a tolerance of 2.5%.
ok
ok
serge A.
serge A.
produit conforme
ok
laurent u.
livré rapidement malgré une rupture de stock, Pas de mauvaise surprise. Si tous les fournisseurs étaient aussi fiables...
Laurent U.
Arthaud B.
Superbe écoute
Une enceinte bibliothèque relativement petite avec un son ample, très équilibré. Les instruments se distinguent très finement et les basses sont vraiment généreuses pour un aussi petit volume. Je suis enchanté de cet achat. Quelle différence avec les précédentes enceintes (des Philips sans interet). J'ai également de grosses enceintes Monitor Audio III et on pourrait presque croire qu'elles jouent dans la même cours. Pour une pièce de taille moyenne (pour moi 25m2) c'est très réussi. Vous ne regretterez pas.
Cristian E.
Delacour j.
un câble pour équilibrer mon système
Une bonne finition,un câble que je possède en deux exemplaires afin de parfaire l'équilibre tonal entre le préampli et l'ampli...JMD
mon premier dap depuis un sansa !
bel appareil, complet, sobre.
les + : sortie casque et ligne (volume fixe max ou ajustable dans un menu)
non tactile, choix de la musique en dossier est la plus rapide si vous avez une grande quantité bien rangée.
Je ne l'utilise qu'en écoute d'album complet dans l'ordre des morceaux.
Accepte une carte de 256gb.
sortie ligne correcte mais pas hyper rendement non plus. Pas testé de le brancher en usb.
livré sans casque, sans étui, sans chargeur, juste le cable type-c usb.
Très neutre en écoute hifi sans aucun egaliseur. Le choix du casque sera peut etre pas évident.
il affiche la pochette mais la définition de l'ecran pourrait être meilleure.
J'aurai préféré les sorties ligne et casque en haut de l'appareil.
au final, enfin un lecteur nomade à bon prix, sans défaut de software ou de son, que l'on peut sans rougir brancher sur sa chaine hifi et bien sur utiliser en casque.
Ampli très complet, excellente qualité sonore, des détails à améliorer.
Très bel ampli, manifestement très bien conçu, look et matériel, rien à dire.
utilisé avec des enceintes colonnes de rendement moyen, il remplit bien son rôle. Pas noté de distorsion.
Volume 0 à 100, musique écoutée au niveau 5-10 en optique coaxial, 15 pour le dac usb (pulseaudio linux mint ) entrée rca pour platine phono (avec ajout d'un préampli phono) ou d'un lecteur mp3 volume 25-30. Celà donne une idée pour des colonnes en 88db pour une écoute moyenne avec conversatiion possible.
L'entrée analogique rca n'est pas mauvaise, mais moins "puissante" que les coaxiaux et optique, il faut monter plus le volume si on branche une platine cd avec sortie rca. Pas de souffle.
mon entrée préférée est donc la spdif coaxial.
Cependant je l'utilise principalement sur son dac usb avec un mini pc pouvant gérer une grande audiotheque. Très bien.
Au niveau de la tonalité, mode hifi ou tone à privilégier, en tone, réglage aisé des graves et aigus avec la telecommande.
Ce qu'il manque : surpris de ne pas trouver un menu de réglage pour l'eclairage du lcd, et une mise en veille automatique. La plupart des concurrents ont ce genre de chose. Pas de firmware update non plus.
autre point amusant, un cable usb est fourni, très épais, blindé, tellement blindé que rien ne passe ! mon pc sous linux mint ne reconnaissait pas le dac de l'ampli, changement pour cable usb standard et reconnu de suite !
Pescaru L.
Plus de détails
More detail than any single AOP I tried.
Claudio c.
Du tres bon son
Couplé avec un ibasso dx120 synergie parfaite bass medium aigu tout y est, dynamique bonne scène sonore pour le prix difficile de trouver mieux.
David T.
Dave
very well constructed cable, extensive screening.
David T.
Dave
Very well made connector - pretty straight forward to fit, good instructional videos on line
Jorma M.
Amazing little DAC/AMP.
I was really surprised how well this tiny DAC/AMP sounds. Great implementation of dual AK4493's. Perhaps the best bang for the buck product in this category. This device makes me tap my legs and smile while listening it.
Daniel P.
Fait son travail correctement
Pas de différence avec une alimentation basique mais l'interrupteur met en marche le Daphile Drive. Chauffe quand même un peu trop.
Daniel P.
Encombrante
Très bonne qualité, solide, mais trop longue, je l'utilise pour alimenter un ampli guitare, pas vraiment faite pour la hifi.
Laurent G.
Fiches bananes parfaites pour du câble Maxitrans
Très bon contact et serrage avec le gros câble Maxitrans. C'est assez subjectif, mais il y a une légère amélioration du son.
Ludovic L.
tweeter de remplacement pour enceintes pioneer vintage
Bon tweeter, qui fait bien son travail et redonne vie à une vieille paire d'enceintes pioneer. En revanche beaucoup de travail pour les installer car les tweeter d'origine faisaient le double en diamètre.
