Krzysztof K.
Good HDMI Cable, indeed!
Hey, folks!
Urtsua R.
Fine
Ruben P.
Audiophile grade +
Customers reviews - There are 19424 reviews.
SHANLING ME600 In-Ear Monitors Dynamic IEM 16 Ohm 100dB 12Hz-40kHz With its ME600, Shanling unveils dynamic in-ear monitors featuring no less than 5 diaphragms per earhone. Their 16-ohm impedance and 100±3dB sensitivity make them easy to drive.
SHANLING ME600
SHANLING ME600 - you will receive a nicely made box, after opening the headphones are placed in foam padding, there is also a large number of ear reductions, a cable with a 4.4mm jack connector in a nice case, there are also sound filters. After connecting to the Cayin N3 Ultra player, which has a classic tube sound mode, the sound pleasantly surprised me, the headphones are sufficiently dynamic, from low frequencies to the highest tones. The power is more than sufficient, the headphones are very precisely made, the cable is pleasantly flexible. Even after prolonged listening, the headphones fit well, they are not tiring. For the price, a good choice.
Clement L.
SOMMERCABLE MERIDIAN SP215 FG Speaker Cable OFC Copper Shielded 2x1.5mm² Ø 8mm This Sommercable Meridian SP215 FG speaker cable offers excellent performance in terms of conductivity. It features OFC copper conductors and triple shielding in aluminum foil...
Uniquement pour installation
Gaine peu esthétique, très rigide.
Alain R.
Outil indispensable du DIYeur
J'ai plusieurs tailles de ces cloches de découpe, elles sont géniales.
Je découpe aussi bien l'acier, l'aluminium que le bois.
Il faut tourner à la bonne vitesse, ni trop vite, ni trop lentement.
Dans l'acier et l'alu, un peu de lubrification améliore grandement la coupe. Cette cloche de 50mm fera un trou à l'arrière d'une enceinte bibliothèque pour un évent de 50 mm ext.
Jean-Luc L.
Le nivarna
J’ai mis longtemps pour me décider, tellement de choix, les prix. Et à force de lire tous ces retours positifs sur ce dac, j’ai donc passé le cap.
Il a aujourd’hui 150 heures de fonctionnement et c’est une merveille, chaque écoute est une douceur musicale dans le bons sens de terme, une richesse et un respect des timbres, faut il encore avoir les éléments l’entourant qui soient à la hauteur de ce monstre d’efficacité.
Je ne peux que conseiller ce dac .
Bertrand V.
Petit DAP au son étonnant pour son prix !
Si vous voulez du son de qualité (à mes oreilles) au meilleur prix et que vous n’êtes pas rebuté par une interface rudimentaire et quelques bizarreries (classement des fichiers et parfois des titres dans les fichiers), ce DAP devrait vous satisfaire.
Son utilisation est très intuitive, les commandes se trouve facilement à l’aveugle (DAP dans la poche) et il semble plutôt solide.
Il est léger et discret, bref en nomade il est parfait pour moi.
Un conseil : télécharger le dernier firmware : https://xduoo.net/firmware-download/
Yves B.
attention à la petite gaine transparente fournie
la petite gaine transparente fournie avec la fiche jack et son capot vissable n'est pas de la gaine thermorétractable comme on aurait pu s'y attendre. Donc inutile de chauffer dessus pour enserrer vos connexion avant de visser le capot. Vous ne réussirez qu'à la ratatiner! Tout le reste est sans reproche. Bonne soudabilité, bons contacts
Christophe M.
Moyen
J'ai ce câble depuis longtemps et je n'ai pas plus l'utiliser en raison du poids des connecteurs qui sont très lourds, beaucoup trop lourds. Ils viennent faire travailler dangeureusement les prises USB des machines sur lesquelles le câble est branché...
Patrick v.
Great machine.
I ordered the CR60 to pair it with my Auralic Aries G1 to listen to and upsample my CD collection. In "ripper" mode the CR60 was immediately recognized via a USB cable and I can now upsample my CD collection to 352.8k without any problems. Together with a 12V linear power supply this is a perfect combination. And what a sound quality! Thanks Audiophonics for the fast delivery and service.
Chafi M.
DD TC35M2 Adapter DAC Headphone Amplifier USB-C Male to Jack 3.5mm Female 32bit 384kHz The TC35M2 from ddHiFi is a portable DAC and amplifier for headphones. The latter is equipped with an ESS ES9603Q amplifier chip, delivering 2x45mW of power at 32 Ohm, capable...
DDTC35M2 adaptateur dac
Bien reçu mon produit commandé vendredi 15/11, reçu en colissimo jeudi 21/11/24, bravo.
J'ai acheté cet adaptateur pour mon smartphone, associé à ma plate-formeTidal et mon casque beyerdynamic DT 770 Pro X édition limitée, il fait super bien le job, la qualité de son est sublime mon casque fait 48 ohms. Je vous le conseille.
Cdt.
Johannes g.
BURSON AUDIO V7 CLASSIC PRO Dual OPA (Unit) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
Rien à dire !!!
ou plutôt si, tout bonnement excellent, en tout point.
détails, dynamique, scène sonore, tout est là mais en mieux.
Comparé à un double op Muzgaudio, qui est trés bien lui aussi, dans un préamp/ampli casque DIY (Whammy), mais que le burson surpasse totalement.
Donc en résumé je suis ravis de cet achat et ce n'est pas un avis sur un coup de tête ça fait 2 mois que je l'écoute.
Carlos N.
JANTZEN AUDIO C-COIL 000-6305 4N Copper Toroidal Coil 12AWG Ø2mm 5.6mH 0.07 Ohm Jantzen Audio's C-Coil Toroidal Coils have very low electric resistance and excellent heat tolerance. They can thus withstand high power without overheat-induced distorsion....
S'est du très lourd
Bonjour, j'ai acheté cette bobine pour modifier le filtre de mes Elipson Prestige 4i, j'avais déjà auparavant changé tous les condensateurs par des modèles allemand haut de gamme et il me restait à changer la self de grave. Grosse claque auditive, des graves propres avec un sous grave de toute beauté. Même la région médium et aigu est changé avec une transparence hors norme. 950 gr s'est du très lourd pour 5,6 mH mais plus aucune sensation de saturation. Je recommande fortement et en plus la résistance interne est très très faible. Mon ampli à triode 845 apprécie.
Francois W.
FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Silver The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a...
Excellent ampli
J'ai ajouté cet ampli FX audio associé avec mes Bose acoustimass 5 série 3, le son est nickel, dynamique, pas agressivite pour un ampli classe d, je trouve le bouton de réglage du volume un peu juste au niveau puissance presque aux max mais dans ensemble c'est très bien et hyper correct vu son prix, franchement rien à dire
Christian C.
le couteau suisse
Cet appareil m'avait été recommandé par un ami suite à un problème avec ma carte son. Cet appareil est très simple d'utilisation. Je m'en sers pour les mesures d'impédance et des paramètres T&S des haut-parleurs et il s'avère extrêmement efficace et d'une excellente précision. Je m'en sert aussi pour la mesure des self et des condensateurs avec une grande facilité et il me donne des résultats de mesures complets avec tous les paramètres associés (RSE, facteur de qualité...). Le logiciel gratuit à télécharger est très complet et pratique.
Jean-Michel j.
TRES BON TUBES
Monté a la place des Electro-harmonix sur le JADIS JA 200 avec les psavanes enECC82 (car je n'ai pas trouvé de ECC82 mulard sur le site),formidables différence des la mise en route aigu,medium et basse avec beaucoup plus de détail et de clarté.Livraison rapide merci Audiophonics
Jean-Michel j.
trés bon tubes
Monté sur le jadis JA200 a la place des elctro-harmonix avec des mulard pour les ECC83.dés la mise en route formidable différence avec beaucoup plus de détail dans les aigus et les basses.Livraison rapide.Merci aidiophonics
Jean-Michel j.
TRES BON CABLE
Monte avec des fiche XANGSANE XS-T1061,très bon câble vraiment pas cher,Aucune différence avec mes câble kimber heros 10 fois plus cher livraison rapide.Merci audiophonics
Jean-Michel j.
TRES BON CONNECTEURS
Monté avec du câble CANARE L-4E6S STAR QUAD,rajout de scotch autour de la gaine pour compenser le diamètre du câble et pouvoir le fixé dans le connecteur,très bonne qualité,reçu rapidement.Merci audiophonics
Pascal L.
TOPPING MX5 Amplifier Merus Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Silver The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks...
Belle petite machine.
Après un peu plus d'un an de service, aucun souci, ampli suffisamment puissant avec des enceintes de rendement moyen et une pièce d'écoute de 20m2, belle surprise pour mon premier ampli classe D.
Stephane N.
Branché en lieu et place de l’entrée usb sur un Audio GD nfb 3, le son est excellent, beaucoup de détails.
Convient très bien à des câbles résolutifs, Nordost heimdall pour ma part.
Très satisfait de cet achat.
Stéphane
Didier T.
Un très grand cru !
Intercalé entre ma Box et mon Node 2i, de dernier injecte son stream dans un Nuprime Dac 9SE amplifié par un bloc stéréo Nuprime STA 9X (le tout alimenté via un Bada 6610, box incluse).
Sans véritablement m'attendre à quoi que ce soit de particulier, sa mise en service m'apporte un énorme supplément d'humanité assorti de textures fluides, chaleureusement liquides et "fouillées" dans le très bon sens du terme.
A l'opposé des câbles qui exhibent des détails "en veux-tu en voilà pour faire high-end", celui-ci le fait avec un raffinement de grande classe.
Les messages musicaux deviennent "palpables" et sont délestés de leurs côtés "intellectuels".
Bref, un apport spectaculaire au rapport Q/P inversement proportionnel à son "pouvoir musical" !
Un coup de maître !
Didier
Christoph S.
AUDIOPHONICS HPA-DM500NIL Power Amplifier Class D Dual Mono Nilai500DIY 2x500W 4 Ohm Hand-assembled in our workshop in France, the Audiophonics HPA-DM500NIL power amplifier is a high-performance Class D dual-mono model, based on the new Hypex Nilai500DIY...
Surprisingly good
Drives my loudspeakers with ease and precision. Better than expected experience.
Alessandro C.
IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality. The PurePi integrates a 5V...
IAN CANADA PUREPI
Incredible power system for Raspberry PI and for ES9038 + FIFO Q7 II. Allows you to obtain a very clean power supply. Great work at a low cost. I am very satisfied
Alessandro C.
IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi Ian Canada's ShieldPi Pro is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO...
IAN CANADA SHIELD PRO
It works very well and is certainly a clear improvement of the power supply of the raspberry PI as well as being an excellent shield for EMI. I am very satisfied.
Alessandro Catalano
Alessandro C.
IAN CANADA TRANSFORMER I/V Passive I/V Stage Module The Ian Canada Transformer I/V is an I/V transformer module operating in purely passive mode, without any feedback or active components. It doesn't even need a power supply....
Great Audio stage that allows you to play digital music with the sweetness of analog. I am very satisfied
Alessandro C.
IAN CANADA FIFOPI Q7 II FIFO Reclocker Module I2S DSD DoP Syncrhonous The Ian Canada FifoPi Q7 is the new flagship in the FifoPi family of reclockers. It achieves the best performance in terms of jitter and noise by using a number of...
Developed and built at very high levels that allows the DAC ES9038 DUAL Mono II to express itself even better allowing you to reproduce the musical message in an excellent way. Very very satisfied.
Alessandro Catalano
Alessandro C.
IAN CANADA MONITORPI PRO Control Center and Signal Analyzer with Display for Raspberry Pi Ian Canada's MonitorPi Pro is a powerful integrated control center and universal OLED display for all types of Raspberry Pi-based audio applications. To install the MonitorPi...
A real control center very well made and easy to use. I am really satisfied
Alessandro Catalano
Alessandro C.
IAN CANADA DUAL MONO MKII DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono.
IAN CANADA DUAL MONO MK II ES9038Q2M
Developed and built at really high levels that allows you to process digital audio at the highest levels. I am really satisfied.Dac Studied and built at really high levels that allows you to process digital audio at the highest levels. I am really satisfied.
Alessandro Catalano
Didier T.
Excellente surprise... si on lui donne le temps de s'épanouir !
2 mètres de CS-361B exploités en entrée d'un BADA 6610 alimentant ma box, mon Node 2i (via carte PD Creativ + bloc Shanti) et mes Nuprimes Dac 9X & STA 9X).
Ce CS-361B est très déconcertant pour ne pas dire décevant durant les premiers instants, contribuant à une courbe de réponse "en cloche", très centrée "medium" avec un effet bouché et sans vie aux deux extrémités.
M'appuyant sur les précédents avis, et s'il commence à se réveiller entre 40 et 50 heures, j'ai laissé sous tension l'ensemble des maillons durant près de 100 heures (non sans streamer en boucle) avant d'envisager avis "sérieux".
Arrivé à ce terme, le résultat est fait d'ouverture, fluidité aération sans aucune dureté : c'est très convainquant !
Au-delà de sa très belle texture sur les voix (déjà mentionnée par ailleurs), mais pas que, je lui trouve surtout dans mon cas une homogénéité, pour ne pas dire une intégrité tonale sur l'ensemble du spectre : je constate qu'aucun segment du spectre particulier n'est favorisé au détriment d'un autre.
Guitariste possédant mon propre studio avec plusieurs (jolies) guitares (et leurs amplis), batterie et clavier, mes tympans m'invitent à rendre à ce câble secteur ce qui lui revient, c'est à dire sa capacité à éclairer (étirer ?) la restitution sans écraser la dynamique.
Au contraire, je trouve qu'il contribue très probablement à faire vivre les micro-détails avec subtilité sans rien dénaturer.
De telle sorte qu'il me donne la sensation d'être sinon immergé au milieu des musiciens, du moins au premier rang du concert en pouvant savourer l'effet tri-dimentionnel du spectacle musical proposé.
Surtout, il ne me donne pas envie de découper les décibels en quatre sur "mon aigue ceci, mon medium cela et mon grave machin" : cet ELECAUDIO CS-361B me donne tout simplement l'effet de contribuer à faire passer la musique avec sincérité.
Et, oui, comme le bon vin, il faut lui donner sa chance sans "sur-réagir" dès les première minutes...
Pour conclure concernant sa construction, je lui trouve bcp d'atouts techniques et sa mise en oeuvre, si elle demande un minimum de rigueur et de précaution, ne présente aucune difficulté.
Enfin, sa relative souplesse (ou raideur, c'est selon), ne pose pas de difficulté particulière dans son ergonomie.
Didier
Thierry L.
RK
Le meilleur câble que j'ai trouvé pour faire une installation audiophile à partir du disjoncteur. Facile à travailler dans les murs (3.3mm2) avec une très bonne qualité de cuivre. La qualité du blindage assure un excellent silence de fonctionnement des appareils. A recommander ***
Jean-François B.
Que dire de plus, ce produit est excellent et de très haute qualité. Installation facile et utilisation ultra simple. Bravo !
Philippe H.
AUDIOPHONICS OBSIDIAN Interconnect Cable RCA-RCA Pure Silver 0.75m (Pair) Optimal audio signal transmission without any defects is what we offer you with the Audiophonics Obsidian premium RCA interconnect cable. Its pure silver conductors and...
Une ouverture remarquable …
J'ai attendu 10 jours de rodage quotidien pour partager cet avis ; je suis allé vers le "tout argent" à reculons, sur la seule confiance en M Aubert. Et j'en suis juste ravi ! Comme prévu, ce câble est bien du côté "ouverture / rapidité / détail", mais sans aucune dureté comme je craignais, au contraire : je trouve que le gain très conséquent en définition se fait sur toutes les fréquences, dans une forme de plénitude inattendue, avec un étagement des plans superbe … Et le plus étonnant, c'est dans la zone haut-médium : ce qui fâche régulièrement, les chuintantes des voix ("s", "ch"), le violon ou le saxo alto passent avec une aisance rare. L'impression subjective est que la rapidité est non seulement dans l'attaque mais aussi (surtout ?) dans l'extinction de note, comme si l'énergie était bien là, mais sans surcharger la reproduction … Aspect peu évoqué concernant les câbles argent, le grave est impressionnant, en clarté et impact (réglage du sub à refaire !). Bref, je suis conquis par ce câble, dont le rapport qualité/prix frise l'insolence. Merci M Aubert pour votre clairvoyance
Tres bien
Colis reçu rapidement
Premières impressions très bonnes
Pour l'instant je ne m'en sert que comme transport est c'est nickel.
Impression d'un appareil aboutit et de très belle esthétique
Pour accéder a un transport CD a ce prix est a conseiller.
Stéphane V.
Après une longue période de rodage, la justesse, la spontanéité de cet appareil impressionnent. La scène est bien plus large qu’avec les autres amplis casques essayés ou conservés (même bien plus chers). Il n’y a pas de duretés, les placements sont aisés à repérer, les timbres sont expressifs et posés. Cela aide beaucoup pour la composition musicale. Il aide aussi à bien choisir l’ampli opérationnel du Dac, quand c’est possible. Cet ampli casque a été livré avec des OPA 2604 (après réassortiment) plutôt que les Muses 8920 annoncés : mieux ou moins bien, je ne sais pas, en tous cas c’est très beau.
Je continuerai à demander conseil à l’équipe d'Audiophonics pour d’éventuels compléments ; d’autres amplis opérationnels ou d’autres câbles.
Le Dac et l’ampli sont reliés avec un câble symétrique Canard, TRS 6,35 M vers XLR M. La sortie est reliée au casque pour l’instant avec un câble asymétrique Syrnarn.
Je tiens à dire que le produit ne me gène pas sur le plan de la radiosensibilité : ce qui est une aubaine. Merci !
François M.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Silver Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
RQP exceptionnel
La qualité des dacs ne cesse de s'améliorer.
Utilisé sur ses sorties symétriques(meilleures que les asymétriques) il a remplacé avantageusement mon "vieux" Bel Canto 3.7 et tout ça pour 229 €. L'écoute avec une excellente alimentation à découpage MONACOR est remarquable.
Seule contrainte en symétrique, il faut se confectionner un câble Jack 6.35 vers RCA ou XLR. A moindre frais avec du canare L-4E6S on peut se fabriquer un très bon câble de modulation.
J'avais envisagé dans un premier temps le modèle D90 III mais il est 5 fois plus cher.
Seules différences majeures avec le d50, une alimentation faisant partie du produit et donc non remplaçable, le MQA et des sorties symétriques en XLR au lieu des jacks. Mais rien de plus musicalement parlant je pense.
claude D.
AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home...
Ampli class D
j'ai attendu un moment pour donner mon avis.
Ce qui ne va pas : à quoi sert l'inter M/A l'appareil est toujours sous tension sifflement dans les tweeters dès la coupure du bouton M/A , j'ai été obligé de mettre une barrette avec inter M/A
A par ça le son de cet appareil est magnifique un pur régal pour moi le meilleur amplificateur que j'ai eu jusqu'à présent et j'en ai eu beaucoup classe AB, classe A et tubes mais jamais de class D.
j'écoute de la musique maintemant je me pose plus de questions
claude D.
SILKLINE ZUKI I Balanced preamplifier / DAC 32bit / 192kHz USB XMOS Silkline's Zuki I combines the functions of preamplifier and DAC . The preamplifier function has a balanced and unbalanced output and a v oltage gain of 12dB ....
Préampli
Très surpris par ce préampli convertisseur avec un très bon son
Acheté pour un second systeme, mais branché sur mon installation principale à haut rendement juste pour voir, aucun bruit très beau mariage avec mon ampli NCORE 6 canaux en amplification active à haut rendement
Incroyable à ce prix. Merci AUDIOPHONICS pour trouver des produits de cette qualité et toujours aussi rapide pour l'expédition et le suremballage.
Ravis de mon achat
Krešimir F.
MOONDROP MOCA Dynamic True Wireless In-Ear Monitor IEM 20Hz-20kHz Grey With the Moca, Moondrop offers us wireless in-ear monitors equipped with a dynamic 10mm driver with a ceramic and titanium nitride membrane, ensuring a sound experience that is...
Very solid sound and build quality
It's probably the best buy in this price category. It has very clear and transparent sound and solid build qualility.
Fast and reliable order processing and shipping.
Aleksandar C.
Fantastic headphones
I can safely say that these headphones will gain cult status. Great sound, the bass is excellent, which I like the most. From the equipment you get with the headphones themselves to the quality of construction and comfort. For this money, you can't do better. You even get a lot more. All recommendations for this model.
And of course I would like to thank the people from Audiophonics, for the quick realization and sending of the product.
Le magicien !
Pfuuuu, c'est raffiné, spatial, chaud, la musique coule sans stress, la trompette de Clark Terry est dans mon salon comme jamais ...et pourtant monté avec de simples Amphenol. C'est une belle découverte pour moi qui connaissais déjà et appréciais le 3004 et le nemoi 3220. Tout est remis en question...Et merci Audiophonics pour toutes ces pépites que vous proposez. Un audiophile connecté.
Raymond L.
Hub USB 2.0 OTG Micro USB USB-A This USB hub has a total of 4 ports: 2 female USB-A connectors and 2 female Micro USB connectors. The interface is via a male Micro USB connector, ideal for connection to a...
Erreur de Cde
Sans doute bien mais je me suis trompé dans le modèle. Il me fallait le hub normal a 4 branchements. R.L.
Hubert K.
Je suis un vieil audiophile dont la "chaîne hifi" ne comportait qu'un lecteur CD et un DAC Audiphonics associé.
M Aubert d'Audiophonics m'a parfaitement guidé dans les méandres de la musique dématérialisée, incluant son conseil pour la mise en place d'un CPLwifi dans la dépendance où ma pièce d'écoute dédiée est installée
Depuis, ce petit et mignon streamer WIIM PRO relié à mon préampli par le cordon fibre optique fourni et un abonnement Qobus studio enchantent mes oreilles, avec une qualité d'écoute extraordinaire.
Encore merci M Aubert!
Hubert K.
Christophe l.
XANGSANE XS-DIY1 Pure Silver Wire 99.99% FEP Ø0.8mm The Xangsane XS-DIY1 is a high-end cable with 99.99% pure silver as the conductive material. This ensures maximum electrical conductivity for optimal audio signal transmission....
Très bien dans mon cas
Câblage interne Ampli cochet transfo vers borniers .
Améliore nettement les détails . le haut du spectre est mieux .
le bas moins présent , mais plus précis et rapide .
facile a souder , j'ai double le câble.
sur mon système c'est mieux .
Christophe l.
Super petit câble
J'ai utilisé ce câble argent doublé sur sortie transformateur d'un ampli cochet vers bornier avec de la soudure argent en 4 % .
J'ai gagné en détails et l'image sonore est plus précise cela réveille le haut du spectre .
Dans mon système c'est mieux.
Impeccable!
Le transformateur est livré avec les tensions attendus et avec la forme attendu. Petit bémol: deux mois de délai pour la livraison! Le fait d'avoir le choix et de dimensionner son transformateur comme on veux est une grande chance, alors on peut pardonner sans peine Audiophonics si le délai de livraison n'est pas très bien contrôler...
gerard p.
DAYTON AUDIO SPA300-D Class D Amplifier for Subwoofer 300W 20Hz-200Hz The Dayton Audio SPA300-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in...
correspond à mon attente. Livraison très rapide. 48h. Site à recommander. Date livraison, respectée, colis très bien conditionné. Site à retenir pour prochains achats. Ampli mis en place dans mon caisson de basse, fonctionne très bien .Vraiment pas déçu!!
Laurent Olivier M.
O-NOORUS D3 Class D Amplifier TPA3255 Bluetooth 5.0 2x130W 4 Ohm Red With its D3 class D amplifier, O-Noorus offers a compact, powerful amplifier with the essentials. The D3 features a TPA 3255 amplification chip and an output power of around...
Très bon ampli polyvalent
J'étais à la recherche d'un ampli 2.1 pour piloter deux enceintes extérieures Focal et un caisson de basses. Utilisation : regarder des films en plein air, et mettre l'ambiance pour les soirées entre copains.
Objectif atteint : la puissance est suffisante (les focal ont un rendement plutôt faible), le son de grande qualité quelle que soit la source. Un bon point aussi pour l'affichage, très lisible.
Ce qui lui coûte une 5e étoile : les 2x300w annoncés dans le descriptif sont tout à fait fantaisistes (2x75w des spécifications sont plus réalistes, mais pas avec l'alimentation fournie), même si la puissance est plus que suffisante pour mon usage, et la fréquence de coupure du caisson n'est pas annoncée ni réglable.
Richard P.
Équilibre !
Utiliser en câble ampli/enceintes et en interne pour le grave/médium des 2 voies que je restaure, il s'avère très naturel, dynamique et équilibré.
Pas de surprise. Ça marche à tout les coups. (Elipson, Focal JM Lab, SIARE)
Une référence pour moi à ce prix.
Sur des 3 voies, je l'utilise pour le grave et je préfère en médium l'Athom Zef mini mais c'est un autre tarif 3 fois plus cher.
Pour les aigus de toute mes restauration, mon chouchou est l'Oyaide explorer.
En conclusion l'Orbit 225 est un très bon câble pour 4€/m.
Patrick M.
OYAIDE PA-2075 RR V2 Phono Cable RCA-RCA Pure Copper OCC Shielded with Ground Wire 1m The OYAIDE PA-2075 RR V2 is an RCA-to-RCA phono cable featuring a high-end design that transmits a stable signal faithful to the original.
Un must
Aigu lumineux, médium souple, grave ferme et bien détouré.
Système d'écoute: platine vpi classic 1,cellule Dynavector xx2, préphono Aurora Vida Phono.Un excellent rapport qualité prix.
Alain L.
LHY AUDIO LPS-A6 230V Linear Power Supply Module for EverSolo DMP-A6 The LPS-A6 linear power supply module developed by LHY Audio has been specially designed to improve the power supply stage of the EverSolo DMP-A6 and DMP-A6 Master Edition...
Pas de chauffe.
Pierre L.
Qualité du son au top.
