Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
Emmanuel A.
Bien meilleur que d’autre très cher
J’ai essayé de nombreuses grammes de Câble pour des connexions modulation sur mon système Attol in 300 Avec streamer et lecteur, ainsi que Dac, de très bonnes factures sur l’ensemble, des cables testés du commerce et ce que j’ai fait fabriquer ce modèle m’a donné la plus grande satisfaction, il est supérieur À l’autre modèle de cette marque, le l2-t2s a beaucoup plus de détails, je trouve le moins montant que le L-4E6S
Pour les avoir tous les deux testés en alternance
Bruno C.
BERRYBAK BEA 1 R2CEPTEUR BLUETOOTH
Excellent rapport qualité prix. Facile à installer , facile à mettre en route!
Paulo A.
This is a tiny, cheap pre amp phono that i bought to replace a broken NAD ... and it sound very very clear and cristal. For the price it is a great product! Love fosi brand.
Paulo A.
TUNG-SOL 12AU7 / ECC82 Tubes (Unit) The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open...
I put this new tube in my Xduuo 605 amp and the sound is fantastic... very good. It's an huge upgrade from the original tube at a very nice price!
Paulo A.
XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a...
Fantastic little amp
This is a great little amp. I love tube amps and the warm sound ...this one is a super budget hifi piece. I roll to a new tube (thanks for the tip) a Tung Sol and it just sound amazing. Great mids and highs, bass is very smooth but present. The sound is vey neutral and warm ... just fantastic
iouri C.
PSVANE EL34-Z Power Tubes (Matched Pair) PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture...
Superbes !
Ces tubes sont magnifiques ! Je ne parle pas du coffret, de l'écrin grande classe dans lequel ils arrivent. Acheté en deux fois deux appairés pour mon primaluna prologue one. J'ai des el34 jj versions 1 et 2, des Mulard 6450, des lion gold KT 88... J'ai débuté avec psvane sur deux 12ax7 puis deux 12AU7 qui ont remplacé des mulards et jj la aussi. Maintenant tout est en psvane. Si j'aime le son des kt88 je les trouve trop "modernes" en son. Avec lrs psvane el34z, je retrouve le grain des el34 série 2 de jj mais avec un son plus analogique et surtout une présence et détails dans les voix, des harmoniques... C'est assez fabuleux alors qu'ils n'ont pas encore tourné plus de 25 heures environ. A voir ou plutôt entendre si ils se bonifient encore !
hugues O.
Ethernet to Optical Fiber Converter (Pair) IEC Power Supply This device converts a 10/100/1000Base-T Ethernet signal to 1000Base-SX/LX optical fiber. This allows the signal to be isolated from the rest of the Ethernet network to limit...
Fibre
C’est le premier et le moins cher des convertisseurs optique qui fonctionne chez moi. Je ne sais pas si c’est dû à la fibre monomode. Ne pas oublier de commander une fibre monomode si vous n’en avez pas et des câbles IEC. SHUKO
Hocine H.
Sceptique, mais...
Je devais changer la double prise qui alimente mon système, je me suis dit cher, mais pourquoi pas. J'étais sceptique, voire je n'attendais rien de particulier ; et pourtant quelle claque. Ce n'est pas le jour et la nuit, mais tout est plus limpide, détaillé. Alors comme j'ai une double prise juste à côté, j'ai pu faire la différence et non je ne rêvais pas, il y a bien un avant et après avec cette prise Furutech et si je devais tout recommencer de 0, c'est la première chose que je changerai, n'hésitez pas, vous ne le regretterez pas, cette double prise change votre perception de la musique.
Sylvain M.
Super streamer. Je ne suis pas audiophile, mais je peut dire que le son est très bon, détaillé, les basses profondes. Un appareil qui s'oublie (avec une bonne application) : pas d'affichage superflu, et une petite taille parfaite pour le cacher dans un meuble. Je recommande !
stoica r.
Neotech 3200
Best cable for the money.
I have exchanged my 3200 with mogami. I lost a sens of 3d on the super lowe frequency. Overall I gained in naturala musical dimension . I have a audio gd master 11 Singularity with audio gd master 1 he vacuum and 2H monoblocs. Speaker go to 2 ohms
Antonio D.
Três bom cable. Bonne construction et trés neutre au niveau son.
Juha T.
Excellent quality
Build quality really good, excellent sound. Although the case is small and lots of power, amplifier case heats only little during modest levels of listening.
George A.
SHANLING CR60 CD Player Ripper Sanyo HD850 Silver With its CR60, Shanling unveils a relatively compact, space-saving Audio CD player/ripper. The CR60 is based on a Sanyo HD850 laser head and a Philips drive mechanism for smooth...
Τα αρνητικά ... είναι η μικρή οθόνη δεν βλέπεις αριθμό κομματιού και χρόνο από θέση ακρόασης, και δεύτερον δεν έχει πλήρες αριθμολόγιο 0 έως 9 πού έχουν τα cd players. Επίσης αργεί λίγο να πάρει εντολή στο πάτημα των κουμπιών του. Δηλ. δεν προδιαθέτει για εναλλαγή κομματιών με το γνωστό τρόπο, σταμάτα ξεκίνα κτλ. Προσωπικά δεν έχω θέμα με όλα αυτά... μπορεί για κάποιον να είναι αρνητικά...
George A.
Shanling cd transport cr 60 + musical fidelity v90 dac. Είχα rotel cd 965, cabridge cd azur 640; Τα ξεπερνάει εντελώς! Υπέροχη στερεοφωνία, ανάλυση αβίαστη απεικόνιση, αθόρυβο εκτός και ο δίσκος είναι άκκεντρος; (Σε ελάχιστα cd). Αρκετά βαρύ (Φούλ αλουμινένιο κουτί και παχύ!!) βλέπεις τα χρήματά σου με το παραπάνω. Με ποιοτικό τροφοδοτικό είναι το κάτι άλλο!
le meilleur de fosi
achetés puis revendus pour fosi v3 mono, je regrette cet echange. Meme si v3 mono est plus propre sur le signal, le plaisir d' écoute( spacialisation, detail, relief) est bien meilleur sur les za3
nickel
cet etain allié a l' argent est super a travailler et les soudure sont propre et brillantes. Apres plusieurs essai de marque, je retiens en definitive celle ci.
tout simplement le meilleur rapport qualité prix en matière de fiche xlr.
bien et jolies
bonnes fiches bananes mais suivant le bornier, on peut être ennuyé pour les enficher.
MUNDORF ACS1150GY ANGELIQUE Wiring Cable Copper / Silver / Gold 1.5mm² Grey Mundorf ACS1150GY ANGELIQUE is a high-end wiring cable with conductors made from a mix of copper, silver and gold for maximum conductivity. This model,...
usage bien précis
J' ai voulu essayer ce câble pour un câblage interne de 'un ampli en liaison HP, a lui seul, il ne convient pas pour cet usage . En effet, il excelle dans le haut médium et les aigus mais trop maigre pour des basses dignes de ce nom.
parfaite
Tout comme les fiches bananes de cette marque présentes sur ce site, ces fourches sont de très bonne qualité, je les recommande.
tres moyen
J' ai essayé ces fiches de qualités moyennes voir en dessous. le signal est assez passant mais la qualité de serrage et de fabrication n e fait pas honneur a Viborg même à ce tarif.
top
ces fiches rca sont parfaites en tous points. faciles a souder, légères et peu encombrante et transmission du signal intègre.
elles font souvent partie des choix des grandes marques de câbles.
parfaite
je epnsais que jantzen était une marque chinoise proposant des produits de qualité moyenne.
Il n' en est rien. C' est une société suédoise qui propose dew produits de treès bonne qualité à un prix ultra compétitif. Ces fiche en sont la preuve. elles sont jolies, bien calibrées et le serrage est parfait meme en faible section. Leur design minimaliste offre une finition hi end. je recommande ces fiches sans hésitation.
Patrice T.
HIDIZS S9 PRO PLUS MARTHA Portable Balanced DAC Headphone Amplifier ES9038Q2M 32bit 768kHz DSD512 Black Hidizs unveils its S9 Pro Plus Martha, an evolution of the S9 Pro, a powerful, high-performance balanced portable DAC headphone amplifier. It features a fully balanced...
Impec !
J'ai acheté ce DAC sur les conseils d'Audiophonics que je remercie vivement. Dans un budget contenu je voulais dépenser pas plus d'une centaine d'euros pour essayer ce type de matériel que je trouve désormais indispensable.
Il ne fonctionnait pas avec mon Samsung S23 Ultra, j'ai donc écrit chez Hidizs qui m'ont répondu très rapidement et de manière bienveillante, je les remercie également de fournir un support de qualité. Finalement il s'est mis à fonctionner. Pour info il fonctionne sous Windows 11.
Il faut absolument respecter le sens du câble, le logo sur la prise du smartphone.
Que dire...c'est mon premier DAC donc pas de comparaison possible. Je ne vais pas parler de la profondeur du grave, de la transparence des aiguës et j'en passe, non...je vais simplement dire que je suis très satisfait de la restitution, de sa limpidité, d'une bonne musicalité qui me satisfait pleinement. Sur Qobuz c'est magique en Hi-Res.
Il faudrait que j'essaye un jour un DAC 5 fois plus cher pour comparer. Il y a peut-être mieux mais je n'en sais rien...
Le logo sur le DAC s'allume dans une couleur en fonction de l'encodage du fichier lu, c'est du plus bel effet.
Il est petit léger, les boutons volume pratiques, belle construction, bel achat.
Loic T.
pour mon khadas tone2 pro
fonctione parfaitement, impecable !!!
Michal L.
Good
Works/performs as expected. However I must confirm this - from another review: "Another con is the tolerances of the connectors - the plug side is tiny bit too small and tends to wobble when plugged in and the connection does not feel as secure as it should. Same goes with the input side which is a bit too loose."
Amaral E.
Phenomenal
Phénoménal Câble fabuleux à tous les niveaux, gamme de fréquences étendue, séparation instrumentale, image 3D immense. Une grande transparence conserve cependant un raffinement et une émotion appropriés sans jamais paraître analytique ou froid. Câble très bien construit avec maille de cuivre occ, une bénédiction, les deux conducteurs étaient reliés au point positif et la maille au négatif. Une partie de la magie de ce câble peut être due à la nouvelle technologie consistant à ajouter du graphène aux conducteurs. Pour moi, c'est le meilleur que j'ai jamais entendu et j'ai entendu de nombreux artistes de haut niveau comme Kimber kS et Nordost Heindall par exemple. Bien entendu, les meilleurs câbles du futur devront utiliser du graphène. Neotech a pris la tête de la révolution technologique en matière d'excellence en matière de conduite électrique. Les nouveaux câbles d'enceintes devraient avoir les mêmes vertus sonores. Cela vaut le prix élevé, mais cela vaut chaque centime. envoyé un SMS du CD au pré aux vannes et du pré à un moteur Rotel RB 1552.
Fabien A.
Peut-être l'élément le plus important de toute installation hifi. Une fois monté, j'ai l'impression que tous les éléments de mon installation sont montés en gamme. Un bien meilleur rendu général, plus de transparence, un gain sur la scène sonore, en largeur et profondeur. Un grave plus net et profond et de la matière dans le médium. Je suis très satisfait de l'amélioration apporté par cette prise. Et pour le montage murale, j'ai utilisé les plaques proposées par audiophonics spécialement adapté à ce modèle qui m'a permis de monter la prise sans pb dans mon mur et avec un rendu visuel très sympa.
Fabien A.
Wall Plate Aluminum base plate Schuko for FURUTECH FI-E30 Black We designed this all-aluminium wall plate to cover the Furutech plugs FI-E-30 (G) and FI-E-30 (R) and thus transform it into a complete wall socket.
Merci à l'équipe Audiophonics de proposer cette plaque parfaitement adaptée à la prise furutech E30, dans mon cas le modèle NCF. La finition est au top pour un super rendu une fois monté.
DIMOKRITOS D.
Best souding plug for the money, and more
In terms of sound quality, the plug easily betters ANY in its price range and also many much more expensive ones. But it has idiosyncrasies in its structure that make it less easy to use by non experienced users. The slot head screws that are used to hold the wires in place are certainly more difficult to use than the more common Allen screws used buy other manufacturers but the job can be done perfectly if you know or understand how to screw them without damaging the head. Don’t use ANY screwdriver but one that is no wider than the screw itself so that it can follow the screw into the hole, if needed. While screwing, try to keep the screwdriver strictly in line with the axle of the screw and centered into the slot and apply as much force as you can, pushing the scew to the direction of the screwing but without disturbing the balance. Do not overtighten any screw on the plug! Also mind you that the cable clamping system can only fix cables with diameter larger than 12mm and up to 18mm
jean-françois v.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
Upgrade Alim Linear PI pour 5V du FIFO PI Q7 II
Petit retour d'expérience sur ces supercondos de chez Ian Canada. En effet, dans mes autres post sur mon streamer audio à base de produits Ian Canada je ne suis pas déçu de cet upgrade de supercondos en sortie de l'alimentation 5V régulée Linéar PI de chez Ian Canada, tout ça pour alimenter le reclocker FIFO PI Q7 II !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
- Une amélioration de la scène sonore (plus d'espace)
- Une dynamique plus grande
- Une séparation des instruments et surtout des voix
- Des fins de notes plus silencieuses
- Des voix plus naturelles et très charnelles
- Des graves très tendus et très propres
- des micro détails très lointains auparavant qui se détachent nettement
- Un son très analogique sans les effets du numérique et sans les inconvénients de l'analogique
A noter que dans cet upgrade j'ai aussi changer les Horloges de mon reclocker FIFO PI Q7 II par des SC Pure, Il est donc difficile de dire si c'est l'horloge qui l'emporte sur cet upgrade ou l'ajout des supercondos.
Dans tous les cas après lecture de bien des avis sur les forums concernant les DACs, les Reclokers, les alimentations ou les horloges et après avoir vérifié par moi même en upgradant petit à petit mon streamer audio (cela m'a pris 2 ans et ce n'est pas fini) à base de Raspberry 4 avec des produits de chez Ian Canada. Il y a à chaque fois une amélioration de la qualité sonore du système qui est très nette à condition d'avoir des enceintes capables de révéler ces différences. Pour ma part je suis en Haut Rendement, bi-amplifé avec en amont un filtre actif Najda tweaké muni de sorties analogiques épaulé par des Ampli OP de compétition de chez Sparkos Labs (les plus haut de gamme, du pure class A). Pour les HP Altec 414 Z (30 cm) , chambre de compression TAD 2001 (membrane Béryllium d'origine) + Pavillon DIY (tournage CNC).
Pour finir beaucoup de passionnés se chiffonnent sur les forums de discussion pour afficher leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque dac a sa signature sonore avec nos préférences personnelles. Cependant même un dac qui au premier abord ne nous a pas plus peu se révéler redoutable après avoir changé les alims, les horloges, le reclocker, etc... C'est ce que j'ai pu vérifier en construisant mon propre système, voilà pour mon avis perso. Si cela peut servir pour prendre des décisions dans des réalisations futures, c'est plutôt cool.
Jean-François.
AUDIOPHONICS GXDC-21 Power Cable Jack DC 5.5/2.1mm to GX16 OFC Copper for LHY Power Supplies 1m This Audiophonics power supply cable, assembled in our workshop in France, is composed of a Jack DC 5.5/2.1mm connector and a GX16 connector. It can be used with LHY power...
Mettre un Olflex secteur en amont de cette trés bonne alim.
Le câble d'Alimentation Jack DC 5.5/2.1mm vers GX16 Cuivre OFC (pour Alimentations LHY) fourni avec cette alim fournissant du 15v, est correct.
Par contre, le câble secteur IEC en amont de 3x0.75mm2 fourni d'origine, est une vraie daube, il gâche vraiment cette alim qui est au demeurant excellente.
Je recommande donc fortement d'utiliser à cet endroit un Olflex de 3x1,5mm2, lequel apporte une lumière et une transparence des plus agréables.
Dominique M.
Bi amplification
Difficile à monter,pas d’indications de montage,faut-il garder les fils argentés ou les supprimer comme le montre une vidéo you tube?dans l’expectative je l’ai les enroulées autour du cuivre.
Des précisions de montage de la part d’ audiophonics seraient bienvenus au prix de ce câble.
Ceci dit je ne regrette pas cet achat,le son est vraiment bon sur tous les critères.
Un avis de quelqu’un en ayant aussi l’expérience en France peut être ?
Theodore A.
EIZZ EZ-213 XLR 3 Pin Male and Female Connectors Rhodium Plated Ø10mm Black (Pair) This pair of EIZZ EZ-213 XLR connectors consists of one male and one female XLR connector. They feature 99.99% pure copper contacts with non-magnetic rhodium plating.
Very good connector
Sound is really good, not however like the top connectors, there is a difference. For the money however the sound worths every penny.
My problem is that I used 10mm cable and the fixing screws, either sunk (had to put extra sleeve to reach 11mm) or in two cases the plastic where the screws reside was broken. Its a pity. My recommendation to EIZZ. Put an extra hardened plastic ring where the screws will reside and make them a little longer.
Theodore A.
Amazing cable
This cable provides tons of detail without fatigue!. Impressive voices. It worths every penny. And certainly a big upgrade from my previous (a good cable of 60EUR/m). Totally recommended, just get it. Used it with EIZ rodium connectors - because I prefer screw than soldering on interconnects
Marko J.
Alps potentiometer
Works great. It's been really hard to find these, but thankfully audiophonics has them!
Marko J.
Great!
Fast delivery, very safe packaging. Banana plugs are great quality, easy to install. Recommend!
Armin w.
RCA Sockets Rhodium Plated Pure Copper (Pair) These affordable yet high-quality RCA sockets are made from rhodium-plated pure copper for optimum conductivity and resistance to corrosion and oxidation.
good, hard to solder
Need a massive amount of heat to solder the outer ring
david h.
AUDIOPHONICS TPA-SW25F Class D 2.1 Amplifier TPA3116D2 2x50W + 100W 4 Ohm Black This 2.1 Class D amplifier based on a TPA3116D2 chip offers high quality sound reproduction in a compact and robust format. It delivers indeed a power of 2x50W under 4Ω...
ampli
ampli de qualiter
david h.
monacor
enceinte vibrante de qualiter
david h.
haut parleur
de grande qualiter et un son tres bon
david h.
DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4...
subwoofer
un subwoofer de grande qualiter je recommande
Stéphane M.
1ér Planar HifiManifFLY
Un son très équilibré cristallin ! un vrai régal ! Très détaillé, le surround très précis aussi mais je m'attendais a plus spacieux mais comme il est très ouvert, alors oui j'ai l'impression d'entendre des hp autour de moi. Quand j'écoute ma ambeo en mettant ce casque sur mes oreilles eh bien je peux entendre tous les sons de ma ambeo + caisson de basse, donc un casque fait pour des endroits très calmes pas comme chez moi près d'une autoroute et aéroport ! mais comme il fait 92dB et avec mon Ifi Zendac v2 à fond eh bien ce n'est pas dérangeant. Très très bon casque et le prix est en train de fondre ce qui en fait un excellent rapport qualité prix.
Jean-Yves F.
Utilisé pour recaper un ampli Luxman L230.
Modèle identiques aux originaux.
Fonctionne parfaitement avec un ESR hyper faible
Jean-Yves F.
Condensateur hautes performances
J'ai "recapé" un Luxman L230 de 1985 initialement équipé de Condensateurs Rubycon et Elna Audio avec des Nichicon KZ Muse et j'en suis ravi. Il a maintenant une dynamique et une transparence qu'il n'a sans doute jamais connu auparavant !
C'est bien plus qu'une réparation, c'est un vrai upgrade qualitatif !
Jean-Yves F.
NICHICON KZ MUSE HiFi Audio Capacitor 25V 100µF Nichicon's KZ Muse series of electrolytic capacitors is ideal for processing audio signals in devices requiring high quality capacitors.
Jean-Yves F.
Jean-Yves F.
Jean-Yves F.
NICHICON KZ MUSE HiFi Audio Capacitor 100V 220μF The capacitors of the KZ Muse series can be used in particular for the processing of audio signals in devices requiring the best possible quality. They offer excellent performance.
Pedro P.
GUSTARD X30 DAC 4x ES9039SPRO + ES9311Q XMOS XU216 Airplay 2 DLNA 32bit 768kHz DSD512 MQA Black With its X30, Gustard unveils a DAC of exceptional performance and versatility. In fact, this DAC features no less than four ES9039SPRO DAC chips coupled with an ES9311Q linear...
DAC très addictif !
Attention, personne ne vous le dira, ce DAC est hautement hallucinogène, mais heureusement pas toxique ;-) Ce qui frappe d'emblée c'est son caractère organique dénué des artéfacts qui nous accompagnent depuis le début de l'ère digitale. Il faut un certain temps d'adaptation, comme pour se débarrasser d'une mauvaise habitude, après on passe avec aisance de l'autre côté du miroir, on se retrouve dans un espace où chaque son surprend par son réalisme, vous ne vous posez plus de questions d'audiophile insatisfait... Si vous êtes à la recherche d'un DAC hors du commun, celui-ci vous comblera à coup sûr. Musicalement parfait, j'en dirais pas autant de sa télécommande peu en rapport avec le pédigré de l'appareil. Ce DAC est muni d'un potentiomètre à relais, à mon avis fort peu pratique, mais surtout, il enlève une grande part de la magie dont il est capable. A utiliser en position "fixed" pour passer outre et à utiliser avec un préampli haut de gamme. Il se marie très bien avec mes amplis Audiophonics à base de modules Purifi et Sparkos, ils se sont adaptés avec plénitude et extrême fidélité au nouveau chef d'orchestre !
