Pascal H.
Marc C.
Customers reviews - There are 19409 reviews.
Amaral E.
Muito bom cabo.
Maravilhoso cabo de coluna,enorme transparência,muito equilibrado ao longo do espectro sonoro.agudos muito extensos e refinados.Preço excelente.
Beate B.
Pop Pulse T 180 beats them all- best amp ever?
Hello dear hifi friends,
here is Werner from Germany.
Im a musician and do have a hifi Forum in Germany.
Im coming from the Tannoy Prestige Sound, and have owned many years Speakers like the Tannoy Westminster and later Tannoy Kingdom and Glenair.
However, - summer last year the Klipsch fever arrived me!
Im a big fan of ASR Emitter 1 and 2 amplifiers and drive them in different Version since 1998 - you must know my latest ASR Emitter flagship do cost around 20.000 Euro and rules in nearly every hifi Magazine on the world.
A member of my Forum was writing, that he had bought the Pop Pulse T 180 and that it was clearly outperforming my Emitter ( he visited me) and his own pre amp and amp constellation from Aaron for around 6000 Euro.
OK, we had a big thread in our Forum an i was curious about the very cheap Pop Pulse T 180.
But there was no way to get it, because one night after the Review of Christian the amp was sold out completely!
A Long Story and you can read in my Forum many stories! about the Pop Pulse - but here is the result:
First Pop Pulse i got from Audiophonics seemed to be damages (scratches and White noises and stinking/smelling like a wheapon) but i had bg trust in the members of my Forum who used the Pop Pulse !
Audiophonics replaced the unit immediately - 4 or 5 days later i got a new amp- my Review with Pictures is here:
http://www.boards-4you.de/wbb10/1426/thread.php?postid=5934#post5934
It is for Klipsch loudspeakers the by far best amp i ever audited in my life and was even outperforming my big ASR Emitter.
You can be sure that you will get an amp which sounds as natural as the best tube amps do but have the power and attack of the biggest and bests high End beasts made in Class A/B.
I was overhelmed!
And now i try to get another 2 untis but Pop Pulse is still sold out, again
The Pop Pulse do outperform clearly my ASR Emitter - a shock for me!
I hope that we get a german distributor in soon, but i have doubt in it, because of the low Price. If this amp for 400Euro is clearly outperforming best products for 10 or 20.000 Euro - which dealer will be interested to distribute the Pop Pulse?
This product is the wet dream of every consumer..This is my oppinion.
I wish that there would be a higher Modell -
an Top Pulse with 2 Pairs of switchable loudspeaker Outputs and a better remote control.
Of course for a much higher Price.
However in my oppinion the Pop Pulse is the most correct amp ever..
Cheers
Werner and Beate from Germany!
Patrick P.
En définitif, Non !
J'en possède 2 je les essayé avec un pré Shanling PH 300 hybride problème de sensibilité puis avec un pré Pier audio encore pas ça. En stéréo pas assez de puissance et bridgé mono au delà de la moitié de toute la puissance un son donnant l'impression d'incompatibilité ça suffoque quelque part. Je me suis posé la question pourquoi pas les faire upgrader car quelque chose à l'intérieur ne tourne pas rond certains composants ne sont pas à leur place ou de mauvaise qualité. Je les ai envoyer chez AM audiodesign/Pier audio une référence dans le monde du tube et qui vous upgrade presque tout !
voilà ce qu'il pense des dualbloc 22 ainsi que du récepteur convertisseur wifi Shanling DR2.1
copier/coller:
Bonsoir,
Résultats des tests. Les 150 W (sous 4 ohms donc 90 W 8 ohms) ne sont pas atteints l'ampli se met en sécurité et sous 4 ohms l'ampli s'écroule c'est un (2x45W sous 8 ohms limite) .
De plus la puissance subjective n'est pas au niveau des 150w annoncée et le grave est timide médium fade, un des mes amplis de 20 W parait plus puissant que l'elec audio. Conclusion il faudra investir dans un ampli classe ab classique (pas de classe d ou T) ou un ampli à tube.
Le point positif c'est qu'il n'est pas agressif il est au niveau d'un Devialet de ce côté il ne faut avoir aucun regret.
Donc pas de modifs sur cet ampli, le convertisseur wifi utilisé seul est anémique et l'équilibre porté sur le haut du spectre un peu dur, par contre avec un dac externe raccordé sur la sortie numérique c'est infiniment mieux.
Voilà pour les essais.
Cdt.
AM
Conclusion, je vends les dualbloc Twenty two d'Elecaudio et sans rancune !
Bonjour, nous avons bien pris connaissance de votre message.
Une erreur s'était glissée dans la fiche, concernant la puissance bridgée.
Nous avions inscrit sous 4ohm, alors que c'est sous 8ohm.
Cet ampli doit être utilisé en mode bridgé uniquement sur des enceintes en 8Ohm et plus, sinon la protection en courant intervient très vite, et l'on perd l'intérêt de ce mode.
En clair, l'ampli sera plus puissant en mode non bridgé sous 4ohm, qu'en bridgé à cause de la limitation en courant.
Le mode bridgé apporte un gain en puissance pour des enceintes à haute impédance > 8ohm.
Dans le Dualbloc la puce TA2022 est alimentée en 33VDC, qui est une valeur médiane entre la tension optimale de 31V pour du 4ohm, et 35V pour du 8ohm.
Selon la datasheet la puissance est de 60W pour un canal sous 35VDC, ce qui n'est pas si éloigné des 2x45W mesurés par notre confrère.
Interface numérique pertinente
Il s'agit de l'ancienne version, la 2.1 avec la sortie coaxiale à la place de l'entrée 5V DC.
En comparaison avec la V1 que je possède aussi, le saut qualitatif est net et évident. Beaucoup de petits détails apparaissent, les médiums sont plus épanouie et les aigües plus précis, plus fins. L'ensemble gagne en cohérence, le son a plus d'assise, plus de fermeté.
Bref, utilisé en interface numérique (s'intercale entre la sortie USB et le DAC), ce produit m'est de fait devenu indispensable. Impossible de me contenter à présent d'un branchement simple avec un câble USB, fut-il de qualité supérieure…
Seule critique, l'espace entre l'entrée USB et la sortie coaxiale est un peu juste si vos connecteurs sont un peu plus épais que la moyenne, l'espace étant tout juste suffisant.
Le laisser aussi se roder au moins 8h avant de se faire une opinion (beaucoup de crispation dans les aigües).
Patrick M.
A quelque chose malheur est bon
après avoir abimé le bien trop long cable d'origine reliant mon antenne magnum dynalab st2 au tuner ft 101 de la meme marque, j'ai installé cet hicon. le registre grave est inchangé; mais, pour le medium-aigu, j' obtiens plus de netteté et de clarté.
dac Audio-gd NFB 2.2
Mieux qu'un CR prenez le temps de faire une écoute.
Tout simplement extraordinaire dans cette gamme de prix.
Merci Audiophonics, livraison parfaite (double emballage), délai long mais parfaitement respecté.
Cyrille F.
upgrade avec viablue EPC-2
en remplacement du cable fournit d origine avec mon casque Audio Technica ATH-MSR7.
associé à des connecteurs furutech FT-735.
ce que j en pense : pour faire simple le cable d origine a été gentiment rangé dans sa boite... à jamais... tellement la différence était énorme.
je recommande ces produits à tous les bricoleurs (souder n a pas été évident) vous ne serez vraiment pas déçu.
ps : merci à david pour les conseils.
Vincent B.
Dac performant !
Dac installé sur un raspberry pi2. Aucun problème grace au connecteur adapté.
J'ai installé RuneAudio, (que j'ai trouvé bien plus efficace et pratique que Volumio).
Cependant, deux réglages techniques, mais essentiels à faire :
- permettre à RuneAudio de voir le DAC comme un hifiberry+ (connexion I2S) : editer le fichier /boot/config.txt (avec nano par exemple) et décommenter (retirer le #) de la ligne hifiberry+ : device_tree_overlay=hifiberry-dacplus
- j'avais des craquements et des pops régulièrement lors de la lecture, j'ai trouvé sur un forum (https://volumio.org/forum/fixes-for-common-usb-dac-problems-with-rpi-t328-20.html) le réglage suivant : editer le fichier /boot/cmdline.txt avec nano, et ajouter au milieu de la ligne à l'endroit où il y a déjà ce type de paramètres : dwc_otg.fiq_split_enable=0
Un reboot, et plus aucun problème de lecture, il faut ensuite configurer le wifi et les stockages (nas, disque durs...) et c'est que du bonheur.
Merci audiophonics.
frederic D.
1877PHONO FINA-OCC MKII Shielded Power Cable OCC 3x2mm² 1.5m After the success of the now famous Legion, 1877Phono offers a new power cable based on PC-OCC copper and 24k gold plated connectors. The FINA-OCC is made of high purity copper...
FINA & LEGION
Quelques mots au sujet des câbles ZAVFINO.
Tous mes appareils étaient alimentés en FINA (lecteur, dac, préampli, ampli), y compris la barrette. L’équilibre entre les différentes fréquences était bon.
Etant passé en musique dématérialisée depuis quelques temps, je trouvais que le médium/aigu était un peu mis en avant, et manquait de matière.
J’ai juste alimenté la barrette par un LEGION, et là, les instruments ont retrouvé ce côté charnel, ce velouté qui faisait défaut. L’équilibre est aussi rétabli. Beaucoup de détails sont audibles…
De très bon câbles, qui apportent un plus incontestable, à condition que le reste soit à la hauteur (barrette, prise murale, fusibles dans certains cas, câblage…).
Un certain niveau atteint, tout a son importance, le moindre détail compte…ainsi les câbles HP reposent sur des supports pour éviter les vibrations du sol. Un support en marbre monté sur patins en caoutchouc durcit les aigus, un support en bois n’apporte pas cette dureté… ce sont des détails, mais accumulés, la différence est bien réelle. Comme pour les ZAVFINO.
PHILIPPE P.
interface xmos
comme ci dessus j ai mis une alimentation 5 volt régulée et séparée du portable donc en plus dans mon convertisseur puce fn1242A ... le son est éxèptionnel très bon placement timbres neutre utra rapide ; preamp elektor 2012 et ampli le monstre 8 w...
karim T.
impecable
j attendais beaucoup de ce petit dac , et bien avec mon mac air et cable usb FURUTECH je peux dire qu apres 3 heures de rodage le son est d une douceur et d une propreté digne de l attente d un habitué des console d enregistrement des studio......BRAVO AUDIOPHONICS je vous felicite et des que je peux je prends les amplis et preampli de votre marque.......
Alain G.
Très bonne prise, excellent contact, belle fabrication, bon rapport qualité prix.
Guillaume D.
Indispensable pour les audiophiles entousiastes
J'avais un bruit de fond tout à fait audible que je pouvais nettement atténuer en passant mon pc sous batterie. Cet isolateur a encore un peu amélioré la clarté d'écoute.
Ce produit est juste indispensable pour tous ceux qui utilisent un DAC USB auto-alimenté. Merci à Audiophonics de proposer un tel produit dans une gamme de prix accessible. (les gros budgets se tourneront vers l'alimentation séparée iFi Audio Micro iUSB Power)
Emballage du colis rivalisant avec les poupées russes.
Le cable usb livré est un Delock Câble USB 3.0 type A mâle > USB 3.0 type A mâle 1,5 m bleu 82430
J'aurais préféré une livraison en relais colis en plus de 24h, moins cher.
Mon système :
Cet isolateur USB
DAC USB Creative Sound Blaster X-fi HD
Ampli ATOLL IN-30
2 enceintes closes de ma conception
(2 HP, tweeter : DT-101SK / grave-médium inconnu de 20 cm de diamètre)
Câble hautement recommandable !
Je viens confirmer à mon tour tout le bien que je pense de ce câble après avoir cependant observé une petite période de rodage nécessaire afin de profiter pleinement de toutes les qualités de ce câble, et des qualités il n'en manque pas!
Effectivement, tout d'abord on a beaucoup de présence et de détails mais sans en rajouter dans un registre quelconque et sans que cela ne devienne non plus trop vite agressif à l'écoute, les écarts de dynamique sont très bien respectés et même parfois assez surprenants, les timbres sonnent justes avec naturel et le grave est à sa place parfaitement lisible.
Je mettrais juste un petit bémol concernant la soudure avec les fiches RCA qui pour ma part n'a pas été simple en raison de la rigidité des deux conducteurs multi-brins et peut être aussi en raison aussi du mauvais choix des fiches.
Sinon, pour le reste c'est du tout bon !
arnaud r.
Second avis
Suite au conseil d'Audiophonics de considérer cette interface comme une source à part entière, j'ai traité correctement la partie alimentation secteur de l'interface en y ajoutant un vrai câble secteur et en positionnant l'ensemble (interface + ampli DAC Hegel) sur une vrai barette secteur et non celle de chez Casto avec la TV, la Box, le PC salon, etc...
Et la mais quelle claque!!! Je n'enlève rien du commentaire que j'ai posté il y a quelque temps. J'ai gagné énormément sur la scène scène sonore qui se focalise là bien devant vous. Elle gagne en profondeur et la cohésion globale du message sonore a eu une nette amélioration. Superbe!!
Excellent !!!
Après nombre de tests de câbles HP c'est celui-là que j'ai gardé.Pour le prix on a toutes les fréquences et un son excellent(ampli Pass Labs INT30, Klipsch Cornwall 3).Peut figurer dans une chaîne HDG sans souci. Je le conseille sans retenue.
Nicolas B.
Sympathique!
Étonnant petit appareil! Installé dans la chambre de ma fille pour fonctionner avec une tablette ou smartphone, j'ai été étonné de la qualité d'écoute. Branché sur de petites biblio Davis (90db de rendement), ça fonctionne vraiment très bien! L'écoute est limpide, précise, complète... Bref, assez bluffé par la qualité d'écoute!
Le bluetooth fonctionne aussi parfaitement, à condition de ne pas trop s'éloigner.
Jerome H.
rapport qualité / prix
Je possédais une ancienne version qui n'avait pas d'anti plop. Du coup, j'ai fini par acheter cette version qui dispose d'une temporisation. Sans regret car ce modèle est également nettement plus puissant. Mon impression en termes de rendu est qu'il me semble difficile de faire mieux à ce niveau de prix.
Alexandre W.
Très surpris de la différence de son avant/après. Ce boîtier se trouve maintenant entre mon ensemble Hifi (Elipson 4i, PM7000) et mon PC, ainsi qu'entre ce dernier et les enceintes du PC (AV40). La différence de son est énorme en terme d'amplification. Avec le Fiio, plus besoin de pousser l'ampli. On se rend compte de la piètre qualité des sorties analogiques d'une carte mère, même cher ! On gagne également en qualité, c'est indéniable.
Jean Francois A.
Bien vérifier
bonjour - si vous comptez acheter cette gaine , faites attention au diamétre de votre cable car c'est vraiment 16mm maxi , j'ai un cable de 16,5mm et pas possible de la faire rentrer .
jean-christophe f.
excellentisime
cacle secteur excellente qualité facile à monter et son riche et détaillé tres agréable tres doux ce qui évite les fatiques auditives par rapport au yarboo qui se trouvent à la longue quelque peu agréssif,et surtout moin galer à monter,bravo vraiment 5 étoiles!!!
jean-christophe f.
habitué au bi cablage (viablue) ,j'ai été completement bluffé par ce cable détaillé,riche sur toute la bande passante et surtout absolument pas fatiguant à la longue ,vraiment à conseiller ,surtout à ce prix,bravo!!!
jean-luc P.
ce n'est pas un gadget
je ne croyais pas au changement du fusible, mais après avoir essayé d'abord sur les amplis: j'ai été surpris par l'apport à la sonorité générale. J'ai ensuite changé sur tous les éléments de la chaîne et le résultat global est positif: le rapport signal/bruit est augmenté ainsi que la bande passante, les détails sont plus soulignés et le son des instruments plus détouré. Pour connaître le bon sens de la position du fusible, il faut prendre un tournevis testeur de phase et chercher la phase sur le porte-fusible vide, attention le capot de l'appareil est retiré et le secteur est branché. la flèche sur le fusible indique le sens du courant. Pour un résultat encore meilleur, le porte-fusible doit être à la hauteur du fusible. Le gain est surtout intéressent d'abord sur le ou les amplis mais le changement sur tous les appareils est un plus indéniable.
jean-claude t.
Bémol
il me semble que cet accessoire ne reprend pas les appels téléphoniques ni le contrôle. Il n'a aucun réglage ( tels que bass - volume - by pass ).
En effet pas de micro ou de contrôle de lecture intégré. Android permet de piloter sans soucis le volume du convertisseur et IOS permet 12 niveaux de réglages, il est tout particulièrement destiné aux casques à forte impédance.
felix q.
Correcte
Bonne pince qui fait son boulot correctement.
Cependant ma pince est arrivée légèrement oxydée, avec la pince à sertir en plaqué or de marque WBT on ne devrait pas avoir ce type de problème mais son prix est 9 fois celui de cette pince. Donc je ferme les yeux sur ce détail au vu de la grosse différence de prix en lui donnant 5 étoile
felix q.
Ces fiches bananes sont de bonne facture (elles sont belles).
Ma seule déception vient du fait qu'il faille acheter une très petite clé stork au bricotruc du coin afin de serrer le câble: car ce n'est pas livrés avec ces fiches banane contrairement aux FURUTECH qui sont 4 fois plus chère par contre.
Maintenant elles sont en cours de rodage je ferais par la suite une complétude de mon avis (après une dizaine d'heure de rodage j espère que cela sera suffisant)
felix q.
super no problem
Elles sont très faciles à manipuler, pour moi qui ai 2 mains gauches, j ai réussi à les monter sur mes jumpers fait maison a base d' ATOHMS ZEF + fiches bananes rhodium.
Rien a redire vous pouvez y aller les yeux fermées
felix q.
Sans soucis
Ils m'ont servis ils sont très faciles à mettre en oeuvre.
Ils se rétractent super bien sans se bruler, ils ont donnés une belle finition à mes jumpers fait maison
Jean-Claude V.
Bon Produit
Connexion juste possible pour du 1,5 mm2. Mais parfait pour mes VERAC G337 (pas jeunes, mais toujours vaillantes ;-)
Génial
Excellente qualité et rapport qualité-prix imbattable. Je recommande.
Michel D.
Mogami 3103
Après quelques hésitations et au vu des avis j'ai remplacé mon vieux Monster XP de 2,5mm2 par du Mogami 3103. La différence est évidente, plus de basses, de médiums, d'aigues, de profondeur, de spatialisation, des micro détails, bref plus de tout mais sans excès ou ajout artificiel. J'ai l'impression d'avaoir de plus gros tuyaux !
Système CD Marantz 5004, Atoll PR 200 et Atoll IN 100 tweakés et Dynaudio Excite 32.
A adopter sans hésitation...
Bruno L.
DAYTON AUDIO RSS210HO-8 Reference Speaker Driver Subwoofer Aluminium 300W 8 Ohm 84dB 30Hz - 1500Hz Ø21.3cm Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with the entire Reference Series, these...
Une vraie merveille !
J'ai installé ce HP dans un caisson reflex de chez Jamo (E 4SUB.1) en remplacement de celui d'origine. On peut dire que cette modification a donné vie à ce caisson car l'amélioration est stupéfiante. Les basses sont profondes et puissantes, incomparables avec ce que c'était auparavant et ce avec l'amplificateur intégré d'origine (70W rms).
Je le conseille à tout ceux qui souhaitent réaliser un très bon caisson de salon ( prévoir entre 20 et 30 litres en basse reflex )
Francisco C.
Une alimentation dédié
Didier M.
HELP !
Rupert S.
Il y a pas photo
trés bonne interface
Bien au dessus de celle avec SA9023 par exemple.
Pour l'installer sous Windows il faut aller dans gestionaire de périphériques puis mettre à jour le pilote sur le net, sinon avec les pilotes indiqués par Audiophonics ça ne va pas.
André-Pierre G.
Excellent appareil
Tout est dans le titre.
Vous pouvez brancher plusieurs sources sans interférence.
Produit bien construit, de très bonne qualité.
Vraiment très intelligent d'avoir conçu ce genre d'électronique.
Bon produit mais erreur dans fiche descriptive
Bon produit avec de bonnes finitions. Pas encore monté ni écouté. Donc à voir...
Attention, les trous de perçage ne sont pas à 12mm comme mentionné (cela ne passe pas). Il faut plutôt prévoir 13mm. Donc ne pas se fier les yeux fermés aux données inscrites dans le descriptif. Encore une fois, c'est bien de détailler mais c'est encore mieux quand les informations sont justes !
Francisco C.
Du bas de gamme en prix mais du haut de gamme en prestation.
Si vous voulez un excellent condensateur qui rivalise avec des condos beaucoup plus chers, vous l'avez trouvé. Ceci est la preuve que parfois moins cher est très bon...
En sortie d'un dac TDA et dans l'entrée d'un ampli tripath, j'ai eu d'excellents résultats.
Du haut de gamme, vraiment.
Francisco C.
Bon prix, belle qualité.
C'est une très bonne alimentation.
Pour un prix très doux on peu avoir de très bons résultats.
On peu la brancher à deux ou trois cartes, mais par précaution, pas à plus que deux amplis. Très fiable aussi.
Francisco C.
Très bonne si bien alimentée
J'étais un peu déçu, au début. Le son était bon, mais par rapport à une certaine concurrence cette carte laissait à désirer. Grave très court, distortion audible, scène sonore bonne mais limité. Je dis encore que le son était bon, mais pas au niveau des exigences du haut de gamme.
Cela dit, je l'ai connecté à une très bonne source d'alimentation en utilisant le brochage 12s 5volts/gnd.
La oui, ça marche! Grave bien présent, amplitude sonore largement augmentée, et ce qui vient avec : détails, densité, etc. J'avais planifié d'utiliser deux sources d'alimentation : une pour le dac Audiophonics I-Sabre DAC ES9023 B Raspberry Pi B / I2S et une autre pour une carte de la concurrence, qui se nourrit de 3,3 volts. J'avais donc besoin de deux sources d'alimentaion, ce qui augmenterai considérablement le prix du projet et l'espace dans le chassis.
Cette carte travaille avec 5volts, comme le dac. Je peux utiliser une alimentatiuon seulement, en 5 volts, ça marche très bien et si j'utilise deux alimentatiuons de 5volts le résultat est le meme - si la source d'alimentation est vraiment bonne. Il ne faut pas négliger l'importance de la carte usb, c'est quand mem le transport, la source, il faut le donner le mieux, c'est encore plus important que le dac, parce que c'est la source hardware. Il faut aussi avoir un bon logiciel, sinon tout est inutile.
Merci encore à David, d'Audiophonics, pour répondre à mes questions.
christophe C.
Câble modulation Canare Star Quad L-4E6S
Ce câble est pour moi une très bonne surprise car enfin il égale des câbles type aéroronautique cuivre plaqué argent isolés PTFE et Kapton. Cerise sur le gâteau il est insensible à toutes perturbations que ce soit électromagnétiques ou numériques. Un très bon produit pour les systèmes haut-rendements.
Diamètre est faux: 32mm et non 33mm
Déception en le recevant de constater qu'il ne fait que 32mm au lieu des 33mm indiqués. Ce n'est que 1mm mais quand on fait faire une face sur-mesure en se basant sur ces cotes et que l'on calcule tout au millimètre près, c'est frustrant.
Merci de détailler vos articles, c'est agréable et utile en tant que client. Mais s'il vous plait, vérifiez lorsque vous recevez les produits de votre fournisseur qu'ils correspondent bien au cahier des charges. Ou alors, modifiez les données sur le site.
Néanmoins, l'article est bien réalisé en 32mm.
Bonjour, Nous allons rapidement vérifier et corriger le problème.
Sachez que vous pouvez nous le retourner si cette différence de caractéristique est rédhibitoire.
Vincent B.
Bon produit !
Bon produit, livré avec un petit câble jack-jack 3.5 mm, des fiches bananes à visser, rallonge alimentation molex PC. Le serrage obtenu avec les fiches bananes fournies n'est pas optimal, j'ai préféré utiliser d'autres fiches bananes offrant un double serrage du câble. J'ai était confronté à un problème de masse entre mon dac usb et la carte amplificatrice qui rendait impossible l'écoute (bourdonnement et grésillement). J'ai mis du temps à comprendre qu'un jumper situé juste derrière la prise jack permet de découpler les deux masses ! J'ai donc retiré ce jumper, et ainsi pu profiter pleinement du son fourni par cette carte. Les composants sont de bonne qualité et des relais libèrent le son quelques instants après la mise sous tension pour éviter les plocs lors de l'allumage du PC. Carte parfaite pour optimiser l'espace sur le bureau. Merci audiophonics de nous proposer de type de produits.
Mickael C.
Problème de LED résolu
Je viens de recevoir ces Vu-métre, et les LED s'illumine normalement.
Deux résistance de 330 Ohms (CMF55) ont été rajouté, donc plus besoin de rajouter quoi que ce soit.
Par contre les aiguilles sont orange, et non pas blanche, mais c'est tant mieux...
Amaral E.
Excelente cabo
Utilizei este cabo em bicablagem activa,No inicio pareceu-me ter um som apagado e liso.Depois de rodar mais de 50 horas e de comparar com vários cabos de outras marcas . Notei que este Mogami é muito melhor.Com um grande palco sonoro, de grande profundidade,largura e altura.Boa transparência,dinâmico e detalhado sem ser agressivo.
Em monocablagem ligando o amarelo+ vermelho(positivo) e castanho+laranja em negativo.Ainda é melhor.
É um cabo de aspecto simples mas muito eficaz.
Melhor sem duvida do que outros 20 vezes mais caros,com aspecto bonito mas som pobre que apenas servem para levar o nosso dinheiro.
antoine L.
psvane 12AU7 TII appariée
1 paire était livrée sur un ampli casque, j'ai voulu faire un essais avec ecc82/12au7 Philips NOS, qui à la 1er écoute paraissait plus flatteuse, mais en réécoutant les psavane j'ai vu qu'l y avait un medium bien plus beau et plus riche, elles ne sont pas données, mais apportent un plus, par contre il faut soigner aussi les autres tubes, merci à audiophonics de les avoir sélectionnés
Olivier P.
il fait le boulot
Très bon récepteur, connecté en coaxiale au convertisseur technics sh-x1000 de ma platine cd
J'ai comparé un cd (opeth pale communion) et le même fichier en 320 kbps en bluetooth
Difficile de trouver une différence !
Merci à david d'audiophonics pour le conseil.
Marc M.
Minuscule et efficace.
Utilisée pour alimenter des DACs à base de ES9023, cette alimentation est simplement parfaite. Minuscule, protégée, sans le moindre bruit ou rayonnement et pas chère, je la recommande chaleureusement.
Marc M.
Flexible et de belle facture.
Bonjour, j'ai associé pour le moment 1 carte de ce type à l'interface MiniDSP | USBStreamer pour réaliser une carte multicanaux de qualité. Après les quelques modifications requises (basculer sur l'horloge en provenance du bus I2S en déplaçant une résistance sur la carte à l'emplacement prévu) et le retrait des connecteurs pour souder directement mes nappes de signaux et l'alimentation (le petit module 5V à découpage), les premiers tests en 16/44.1 et 24/192 sont très concluants. Ecoutant sur un système de test (FE103 Sigma + sub), je ne pourrai pas discuter de la coloration et des timbres mais le grave est très profond, aucun souffle présent, la dynamique et les détails sont impressionnants pour une carte de ce prix. Je recommande en toute situation hormis si vous êtes prêts à casser la tirelire pour les tous meilleurs DAC disponibles, cependant le rapport Q/P s'effondrera totalement car les gains ne seront pas à la hauteur de l'investissement !
