Ludovic P.
Efficace mais manque un interrupteur on/off
Utilisé entre une alimentation linéaire 5v Audiophonics et un Ifi Audio LAN ipurifier pro, ce filtre améliore sensiblement la...
Eric E.
Remarquable !
La neutralité et la transparence sautent tout de suite aux oreilles. Le son est limpide et détaillé, les plans sonores sont...
David D.
Ampoules led bleu
J'ai bien reçu mes ampoules led bleu pour mon tuner Pioneer , elles sont bien compatibles parfait pour moi merci
Customers reviews - There are 19579 reviews.
Joerg M.
Thank you Audiophonics for offering this product!
I'm really glad I bought the Allo DigiOne Signature!
Paired with a good DAC (I have the Topping E50), the sound is amazing.
Wonderful voices, generally excellent precision. - Fantastic!
I use a very good and very low-noise power supply (Allo Nirvana SMPS) for the streamer and the DAC. I assume the Allo Shanti, for example, could bring further improvements.
The speakers seem to exist even less to me, the spatial image has more depth. Everything seems more realistic. Fantastic even for live recordings.
I also have the predecessor (without signature, unfortunately no longer available). This already has amazing qualities. With signature it is actually even better.
The Allo DigiOne Signature is, in my opinion, a fantastic product and definitely worth every cent!
Pierre-Marin L.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
Génial
Super upgrade pour mon RPI qui sert de Host Diretta...
Avant j'avais une alim Allo Shanti. Là c'est le jour et la nuit : je pense me faire un streamer complet en Ian canada...
C
Lucien v.
JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 5.6µF 5% Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most...
condensateur JANTZEN
condensateur bien reçus ,après vérification son plus à 10% pas 5%
6.10 µf à 6.18µf
Pedro V.
Great audiophile headphone - with some caveats
These entry level Hifiman headphone sound excellent with acoustic music, jazz, classical provided you use them with a proper amplifier - smartphone or tablet will not cut it.
It sounds a bit "edgy" with an Adioqiuest DragonFly 1.5 but sound great with a Schiit Vali 2++ and Audiphonics RaspiDAC streamer, beating my Massdrop/Sennheiser HD 58x as the best "budget audiophile" headphone.
The cable could be a bit longer and would prefer it was terminated in a straight rather than an angled jack (in particular because it is much better suited for stationary listening).
Ludger B.
AIYIMA A70 2.1 Channel Amplifier TPA3255 2x185W 4 Ohm AIYIMA's A70 is a 2.1-channel Class D amplifier featuring quality components. In fact, it incorporates a TI TPA3255 amplifier chip combined with two NE5532 AOPs for an output...
Disappointing result, failure of the power supply after few hours
I wanted to use this amp for the bass unit of a threeway-system, 20cm 8-Ohm driver with active lowpass at 500 Hz, nothing special to drive. The amp went really hot but wasn't able to deliver the same bass amount and quality like my Icepower 125ASX2 did. I addition the power supply broke down with loud ticking noises after a few hours of work. It was my first and last experience with an hyped Aiyima Amp. Flawless and good service from Audiophonics with fast payback.
Adrian B.
Einfach am besten, wenn's um richtige Musik geht
Mit dem guten alten OPA2134 macht man alles richtig!
- Sehr warm und musikalisch
- Sie Musik klingt, wie echte Musik ohne auch nur einen Hauch Künstlichkeit
- Qualität des Basses ausgezeichnet, sehr viele Informationen
- Stellt den Bassbereich aber etwas zu sehr in den Mittelpunkt
- Höhen etwas zurückgenommen, dafür aber sehr schöne und natürliche Höhen
- Auflösung gut
- Sehr direkt und breit
- Bring ordentlich was in den Raum ohne unnatürlich oder angestrengt zu wirken
- Ggf. muss der Bass leicht abgesenkt werden, aber Rest ist so überzeugend, dass ich dabei bleibe. ;)
Die französische Übersetzung ist von Google. Ich hoffe, es ergibt Sinn. ^^'
Avec le bon vieux OPA2134, vous faites tout correctement !
- Très chaleureux et musical
- La musique ressemble à de la vraie musique sans même la moindre touche artificielle
- Qualité des basses excellente, beaucoup d'informations
- Mais l'accent est un peu trop mis sur le registre des basses
- Aigus légèrement réduits, mais aigus très agréables et naturels
- Bonne résolution
- Très direct et large
- Apportez quelque chose de soigné dans la pièce sans paraître artificiel ou tendu
- Il faudra peut-être baisser légèrement les basses, mais le reste est tellement convaincant que je vais m'y tenir. ;)
La traduction française vient de Google. J'espère que ça a du sens. ^^'
Adrian B.
OPA1612 Dual OPA DIP8 (Unit) The TI OPA1612 dual operational amplifier benefits from excellent technical characteristics, allowing very good electrical and audio performance. It ensures a very low noise...
Gar nicht schlecht, aber es geht besser
- Warm, aber ausgewogen
- Höhen, Mitten und Bass in gutem Verhältnis
- Auflösung gut
- Etwas flachere Darstellung als beispielsweise OPA2134
- Eine etwas künstliche Darstellung
Auch wenn der OPA2134 weniger ausgewogen ist, spielt er deutlich musikalischer und echter und bleibt deshalb meine Empfehlung.
- Chaleureux mais équilibré
- Aigus, médiums et graves en bonne proportion
- Bonne résolution
- Représentation légèrement plus plate que, par exemple, OPA2134
- Une représentation quelque peu artificielle
Même si l'OPA2134 est moins équilibré, il joue de manière beaucoup plus musicale et réaliste et reste donc ma recommandation.
Adrian B.
AUDIOPHONICS OPA1642 Dual DIP8 (Unit) Audiophonics is proud to present its OPA range with the OPA1642 based on a authentic Texas Instruments chip. This OPA offers excellent performance for audio applications. In...
Leider nein --- Malheureusement non
Ich kann den OPA1642 leider nicht empfehlen.
- Moderne Betonung der Höhen, spielt recht spitz
- Labbriger Blähbass
- Typische Badewanne – Bass und Höhen ohne ordentliche Mitten
- Hat zwar irgendwie Spielfreude, klingt aber dennoch flach und unmusikalisch
- Eine seltsame Mischung aus leichter Wärme und Sterile
Meine Empfehlung ist der gute alte OPA2134, der macht alles besser.
Die französische Übersetzung ist von Google. Ich hoffe es macht irgendwie Sinn. ^^'
Malheureusement, je ne peux pas recommander l'OPA1642.
- Accent moderne sur les aigus, jeu assez aigu
- Basses douces et flatulentes
- Baignoire typique - basses et aigus sans médiums appropriés
- C'est en quelque sorte amusant à jouer, mais ça sonne toujours plat et peu musical
- Un étrange mélange de chaleur légère et de stérile
Ma recommandation est le bon vieux OPA2134, il améliore tout.
La traduction française vient de Google. J'espère que cela a du sens. ^^'
Christian D.
Vraiment super !
Acheté sur les conseils d'une relation , je suis vraiment étonné du rendu : Basses superbes, présentes et biens tendues médium et aigus du même tonneau... Pourquoi payer plus cher ?
Jean O.
Source selector Audio / Video RCA 4 to 1 reversible This switch is an inexpensive solution for connecting up to 4 audio / video devices to a television set, projector or sound system. A digital marking corresponding to the RCA...
mauvais contacts
Selecteur pas cher mais bas de gamme. Souvent une voie ne fonctionne pas à moins de manipuler le poussoir. Pas vraiment recommandé.
Gautier M.
simple et efficace
baladeur comme on en trouve plus, pas d'écran photovidéo ni gadget online qui ne servent à rien, simple avec une bonne puissance et avec un prix abordable, ce qui n'existe plus ! donc merci. structure robuste, à voir durée de vie des touches.
Michel S.
Musical avant tout
Le DAC AK4499EX est ici parfaitement mis en oeuvre. Branché en symétrique sur mon ampli casque le SABAJ combine fidélité, ouverture et énergie. Je lui reprocherai seulement un affichage un peu chiche en informations mais pour le reste c'est vraiment un sans faute. A noter la présence d'un sélecteur de phase intervenant dans le domaine numérique qui ravira les audiophiles pointilleux...
Manfred S.
Alu DIY Box
Unfortunately, the case was out of stock for a very long time.
But now where I was able to order it the case was delivered in a good condition. Well manufactured.
michel m.
Un ampli intéressant, plein de vivacité et d'une écoute plaisante.
Lui laisser le temps de roder ses composants ...
En baissant trop le volume on tendance a l'eteidre.
En ce moment j’écoute "Dark side of the moon" pour préparer ma bolognaise...
michel m.
En ce moment "Dark side of the moon" pour préparer ma bolognaise...
Rodolphe L.
LJM L-15D-PRO IRS2092S IRFB4019 Class D Amplifier Module Mono 300W 4 Ohm This LJM L15D-PRO amplifier module features an IRS2092S main amplifier chip and two IRFB4019 Mosfet transistors for power up to 300W at 4 ohms and low distortion (THD+N < 0.06%).
Bon module ampli
Bon ampli classe D. Fait très bien le job. J'aime bien le son du IRS2092 qui est très neutre sans aucune coloration et sans dénaturer le son.
Dans les amplis de MR. 刘 (Mr Liu) c'est l'un des meilleurs avec le L20V10 (avec un peu de courant de repos) à mes oreilles.
Le designer n'aime pas les amplis à base de Mosfet et evidemment le class D mais il a des clients à satisfaire. Notez Mr Liu a une bonne maitrise industrielle de ses produits, chaque composant utilisé est testé et validé, ce qui est un gage de fiabilité et de qualité.
Le secret d'un bon ampli est une bonne alimentation. Ici je recommande une alimentation double mono si le budget le permet.
Soit du linéaire 2x35Vac qui donne 50V redressé, filtré. Sur le site Audiophonics.fr il y a un transfo 500Va qui fera l'affaire et le redressement plus filtrage.
Soit une alimentation à découpage bien moins lourde car il y a qui fonctionne bien par orde de préférence en HYPEX ou CONNEX en +-46V ou +-50V. Vous avez le choix !
Ah j'oublais Mr Liu préfère les alimentations linéaires, ne recommande absolument pas les alimentations à découpage. Pas sur qu'il ait été convaincu mes L20V10 alimenté par un module Hypex et par ma prose sur l'alimentation du Benchmark AHB2, un des meilleurs ampli mesuré en SINAD.
Bonnes'écoutes !
Edoardo I.
Ottimo
Il prodotto è arrivato in tempi brevi e ben confezionato essendo una spedizione internazionale.
Inserito tra lettore cd Cambridge e DAC entry level ha migliorato il suono rendendolo più equilibrato.
Complimenti a tutto lo staff audiphonics.
Luis C.
segunda vez que compro
Segunda vez que compro y de igual manera todo perfecto, un gusto comprar en vuestra página, me hicieron un descuento por fidelización y tuve un problema con el pedido y lo solucionaron sin ningún problema .
Con estas válvulas se percibe una mejoría muy notoria, un dinero muy bien gastado, gracias de nuevo.
Luis C.
todo el proceso impecable
Rapidísimo, muy bien embalado y buen precio, buen trabajo, gracias.
Sandy G.
[GRADE A] LHY AUDIO LPS80VA PREMIUM Linear Regulated Low Noise Power Supply 230V to 9V 3A 80VA Refurbished product - Grade A Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are...
amélioration significative de la sonorité de votre système
Connectée à un streamer lecteur "NanoPlayerSignature" 3DLAB , l'amélioration est bien réelle et non discutable.
hervé P.
Jantzen audio SELF IRON CORE 6.8mH
Utilisé pour filtrer le grave le rapport qualité prix est excellent. Pourquoi dépenser plus ?
hervé P.
Utilisé pour filtrer le haut-parleur de grave, Pour vous dire que ces selfs sont d'une finition et d'une qualité incroyable à ce prix ! rapport Q/P remarquable (mieux qu'une certaine marque très connue mais en beaucoup moins cher). Hervé
Jesse D.
Tout simplement excellent !
Merci à AUDIOPHONICS pour cette réalisation de grande qualité et surtout continuez d'étendre cette nouvelle gamme de produits à d'autres références.
Juste un petit effort dans la finition des bords du PCB et l'on aurait presque pu évoquer un chef-d’œuvre !
Ne souhaitez vous pas associer le nom de votre entreprise à ces termes ?
Je ne doute pas un instant de la réponse que vous apporterez à vos nombreux clients ;)
En complément de cette introduction, je souhaite conseiller aux possesseurs d'amplificateur AIYIMA A07 MAX (comme moi), d'utiliser cette référence d'amplificateur opérationnel en remplacement de ceux qui l'équipent d'origine et qui ne sont pas adaptés à la "topologie" du circuit où ils ont ici été intégrés.
Cette "manipulation" vous permettra d'obtenir une justesse des timbres, aucune agressivité quelconque sur l'ensemble du spectre mais surtout atteindre le niveau de réalisme et de justesse recherché par l'utilisation de cet appareil.
Faites l'essai, ne vous privez pas, surtout au tarif si léger demandé par votre fournisseur préféré !
Bonnes écoutes à tous.
Jesse.
Mohammad m.
Great!
Surprisingly more than my expectations. Order in Silver color but look luxuries, shiny, and elegant, has all screws and they fit perfectly. Very easy and straight forward to set up, but the quality and build look very high end. Its worth feed high end resolution gears.
Special thanks to CS, and more more to David.
John G.
DENAFRIPS IRIS 12TH Digital Interface DDC USB I2S SPDIF 32bit 384kHz DSD512 Black Denafrips' very first USB digital-to-digital converter or digital interface (DDC), the Iris 12Th is the fruit of 3 years of research and development by the brand, taking...
Denafrips Iris 12
Highly recommended. If you ave a reasonably good system you will hear an improvement. Better definition pace and timiming / rythm
Denis B.
DENAFRIPS ENYO Balanced R2R DAC 24bit 1536kHz DSD1024 Black The Denafrips Enyo DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to deliver...
DENAFRIPS ENYO DAC R2R
Commande sans aucun problème merci
Henrik H.
Good with moderate volume, after correction.
Bought 2 for simracing(under chair), but then I tried it with some music, and I use them for that since almost every day.
I like bass, had a big sub, but now I dont have the space and privacy, so I use headphones with shakers, and they really are can provide the same or even better feeling that a good subwoofer can do, but more shaking with almost no audible volume, combined with a good low extension headphone, its the best thing to have. I work from home with my partner sitting next to me, and I can hear and feel my music perfectly witout disturbing her.
Now, its all nice and good, but it has its flaws and limitations, got a faulty one with a broken spider (they have a plastic spring that holds the shaking weight) and got that replaced, had no faults since, but i heard others are getting their spiders snap too, so must be careful with them.
They are also not the strongest performers, having a huge resonance spike around 33hz, and not having any low end extension, because it starts rattling.
I have switched firmware on my 3D printer calibrator (accelerometer) and made some custom apps and code, so I can measure the frequency response on my chair, and generated some PEQ curves with REW based on those measurements, and managed to get the response mostly flat, and its like night and day! Not just the same frequency overpowering, but nice resolution, better low extension, but.. still has no power, so I'm getting the new bigger brother, the 300 to replace the 2 small one, and planning to measure and calibrate the hell out of that too, and will put these under my footrest/pedal plate.
So overall, if you can smooth the response, its good enough, just a little weak. Without EQ its meh, but okay for simhub if you dial in the effects optimized for its curve.
Henrik H.
Does its job.
Bought it for BST-1 bass shakers, (simracing/music) but it was too weak for them, so I use it for smaller (15W) exciters now (Sim pedals), there its okay.
Had a faulty one that went up in smoke, got it replaced.
Knob is a little noisy when used, but other than that its okay, for the price for low wattage stuff, with integrated USB DAC its good value.
Henrik H.
Love it!
Bought it with a Topping DX3 Pro+, really nice combo.
My first planar, heard great things about it, expected great bass, but when I tried it stock, it was meh.. overall better than my K7XX, but lowend was nowhere.
Then I applied an Oratory PEQ and added the linear subbass extension & ~10db extra for the bass shelf, and wow.. there it was!
Very nice clean bass, much better low extension than my K7XX
(Note that I have an overall negative gain to compensate for the bass, so I sacrifice some max volume for better bass, but im nowhere near maxing the amp, so its fine.)
So sound is great, bass iw awesome, also very comfortable, love it.
Cannot think of anything bad to say, would buy it again.
Henrik H.
Great Price/Value
Bought it with a Hifiman Sundara, mostly use it with my daily AKG K7XX.
It is perfect for both, I use software EQ to aligh them, and ASIO for low latency. (Gaming/Shaker setup)
Sound is very good.
One flaw is some of the segments of the display went bad, but its not affecting anything, and they are mostly off anyway.
Super!
Et non ! ce n'est pas le câble ultime mais on en a vraiment pour son argent. Pensez, pour a peine plus que le prix d'une jolie gaine. Vous hésitez encore ? Ce câble est excellent pour les montages courants mariés avec des connecteurs Amphenol qui lui vont comme un gant on a un champion du RQP ! Des timbres respectés, de la profondeur, c'est rare a ce prix comme par exemple son petit frère le lt2s qui n'est pas aussi réussi je trouve. Après si l'on veut titiller le hdg pour un peu plus de 12 euros avec par exemple le feu NEOTECH NEI-3004 Câble de modulation symétrique UP-OCC on atteint d'autres sphères, du raffinement, de l'espace, de l'émotion...
Bien mais...
Connaissant et appréciant déjà le L-4E6S du même fabriquant j'ai essayé ce câble et l'ai monté avec des fiches Amphenol trouvée sur ce site et qui lui vont à merveille. Un peu déçu car c'est moins bon qu'avec le star quad, on a moins de profondeur et des timbres un peu quelconques. Du coup pour le même prix je reste sur le L-4E6S STAR QUAD qui reste mon champion des petits prix, avec le Goblin aussi, parfaits pour mes montages courants et les raccords din-rca possibles avec les 4 fils.
Michel P.
Mis en aval d'alimentations à découpage stabilisées sur toute la ligne Internet et Ethernet (box-switch-décodeur). Son : augmente la richesse des harmoniques sur toute la plage du médium, son plus "analogique"(Quobuz via Bluesound), toutes proportions gardées à ce que l'on peut ressentir en passant sur un ampli à tubes ; en 5.1 (Netflix) meilleure spatialisation et enveloppement. Image : beaucoup plus nuancée et riche dans les couleurs, exemple : sur une image basique (tv par fibre) raccords de maquillage du présentateur TV nettement perceptibles, films via Netflix : profondeur, réalisme des teintes. Toutefois l'appareil est très léger et j'obtiens un meilleur résultat en l'isolant des vibrations, fixé sur une plaque de bois bitumée.
Jean Emmanuel H.
DAYTON AUDIO DC28FS-8 Speaker Driver Dome Tweeter 50W 8 Ohm 89dB 1600Hz - 20kHz Ø2.9cm This Dayton Audio DC28FS-8 tweeter is an improved version of the brand's silk dome tweeters, benefiting here from motor structure shielding and ferrofluid cooling.
Excellents
Montés en remplacements des tweeters Dynaudio de mes ASA monitor pro qui avaient lâchés après 25 ans de bons et loyaux services...le résultat est bluffant, pas de différences flagrantes avec les Dynaudio...à part le prix
Rien a redire
Je suis passé de la FI-E12L (G) à la FI-e46 (g), il y a bien une différence...c'est plus aérien, plus précis, plus fin, et sans agressivité
J'étais septique et le prix laisse à réfléchir, mais je ne regrette pas, après avoir essayé la p004 d'oyaide (pas mal mais fatigante), je suis conquis, et le plaisir d'écouter de la musique acru.
Fabien B.
Pas trouvé mieux à ce jour!
Fabien B.
Fait bien le job. Plus précise que mon ancien pèse cellule
Fabien B.
1877PHONO Z-LITZ100 Phono Headshell Leads Litz Wire 24k Gold Plated OFHC Copper 40mm (Set x4) These 1877Phono Z-LITZ100 cables allow you to wire a phono headshell in an efficient way. Using Litz wire, each strand of each conductor is isolated from the others to limit the...
En remplacement des câbles d'origine de mon bras SME 3009 et raccordés sur une Shure V15 type 4.
Micael C.
DC 5V Jack Filter with Supercapacitor to Jack DC This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an...
Vastly improve Google TV 4K
I added this little thing after a 5v/3A SMPS and a DC2.1 to USB C cable to my Google TV 4K. It greatly improved both the sound and picture. Love it!
Jean-Pascal H.
FOSI AUDIO LC30 Audio Selector Switch for Amplifiers / Speakers vu-meter Yellow With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of...
Fosi LC30
Beau produit mais il faut trop de watts pour que ça bouge dommage ça restera en déco merci au service technique car ça fonctionne sur un ampli classe G réponse très rapide et ça c'est super merci .
Jeanphilippe c.
Eversolo.
Appareil très complet sonorité exceptionnel. Je recommande. Livraison rapide. Merci audiophonics.
Thierry S.
kt 120 quad
Délai 1 semaine, peut mieux faire, mais ça va.
plus important, si la logistique lit ce message.
Puisque vous expédiez dans des cartons suffisamment larges pour mettre plein de garnissage de protection, autant mettre le produit fragile au milieu des protections. j'ai reçu le quad calé dans un coin sans protection sur 3 cotés.
c'est ballot et surtout risqué pour le produit.
Les tubes sont heureusement fonctionnels.
je rejoins un avis précédant sur la sonorité, pas top au début et qui s'améliore dès la 4éme heure.
grave bien présent mais plus propre, médium se calme et apparition d'un peu d'aigu. à suivre.
Ce qui est surprenant à ce stade c'est les détails qui apparaissent, jamais entendus avant. Je sort pourtant de GEKT 88 et 88 Z pourtant de très bon tubes fins et détaillés, mais là ça va un peu plus loin tout en gardant une tonalité "chaude".
seule réserve est justement sur la justesse des timbres
pour l'instant.
Techniquement, attention à bien vérifier que votre alim peut les supporter. Sur le cs 55 ça fonctionne bien mais ça chauffe le transfo.
il faut bien le dégager pour qu'il se ventile et même comme ça j'ai mesuré 50° sur le capot.
En tout cas, à ce stade, tout indique que c'est un très bon tube et pour la durabilité... on verra, et donc 4* pour cette raison.
Philippe s.
Je l’utilise pour connecter mon DAB sur le DAC de mon installation et c’est parfait. Merci Audiophonics pour le conseil et l’envoi très très rapide.
Philippe s.
Je l’utilise sur une platine Pro-ject et il a indéniablement amélioré ses performances : moins d’électricité statique, moins de bruit moteur. Le son me paraît également meilleur.
Frank j.
pure battery voltage
just as good battery thanks to the Ultra Capacitor
5 volts
equally good farad super 3 or ifi powerelite
Mika E.
MOONDROP PARA Planar Magnetic Circumaural Open-back Audio Headphone Ø100mm 101dB 8Ω 15Hz-53kHz The Moondrop Para is a high-quality headphone based on Planar Magnetic technology. It has inherited part of the structure of its predecessor, the Moondrop Venus.
Supraṇava
Ordering worked perfectly and delivery was superb fast to Finland. Ten points and a parrot badge:-)
Daniel D.
TINYSINE TSA7804B Class D Amplifier Module TPA3116D2 DSP Bluetooth 5.0 4x50W 4 Ohm The TinySine TSA7804B module is a four-channel Class D amplifier board with integrated DSP and Bluetooth receiver. Its TPA3116D2 chip is capable of developing 4x50W power at...
Nice, but needs noise reduction mod
I've built 2x 2-way active speakers with it and the result is awesome. The only issue was noise, which needed adjusting gain of TPA3116D2 by desoldering resistor 2 and replacing resistor 1 with 5.4kohm smd. They are under the heatsink. Would be nice if that was a default config or at least easy way of adjusting.
Pascal J.
IFI AUDIO ZEN PHONO 3 Phono Preamplifier MM/MC With the Zen Phono 3, Ifi Audio brings us the latest iteration of their renowned range of phono amplifiers. The Zen Phono 3 is a versatile, ultra-quiet phono amplifier with...
Suivi de mon 1er post
Je plussoie et même plus 1 étoile. Nouvel essai avec ma Technics sl-1500c et cellule Denon dl110, une MC haut niveau, le prépré sur le gain 2 : La grosse claque jamais entendu un vinyle sonner aussi bien, on retrouve la dynamique du cd , bien timbré de haut en bas, transparent à souhait, franchement les British ont fait un prépré au rapport Q/P imbattable . Pas étonnant qu'il soit déjà en rupture de stock, soyez patient il vous le rendra au centuple... Bonne écoute à tous...
Incroyable à ce prix !!!
Vu les débats médiatiques sur cet appareil j’ai tenté l’achat pour un équipement de bureau. Je ne suis pas déçu du résultat avec des enceintes TRIANGLE COMÈTE 40TH.
Pour en savoir un peu plus avec un ami nous l’avons connecté et essayé sur du matériel beaucoup plus cher (chacun jugera de la qualité de ces appareils) Préampli ACCUPHASE enceintes B&W série 800 D4 câblage AUDIOQUEST dans une pièce de 35m2 et le résultat est tout simplement impressionnant au regard du prix.
Une écoute très naturelle sur tout les registres pas de limitation de puissance ressentie . Évidemment le niveau d’écoute était modéré mais suffisant.
L’amplification numérique c’est l’avenir. Je serai curieux de tester les blocs mon dans les mêmes conditions. Bonnes écoutes à tous. Philippe.
