Krzysztof K.
Good HDMI Cable, indeed!
Hey, folks!
Urtsua R.
Fine
Ruben P.
Audiophile grade +
Customers reviews - There are 19423 reviews.
Julien G.
ELECAUDIO LI-23GB IEC C13 Connector Gold Plated 24k 3x5mm² Ø15mm This IEC C13 Elecaudio LI-23GB connector is ideal for creating quality power supply cables. It uses 24k gold-plated copper alloy contacts of 5mm², which provides a very...
Good
Not so bad design. Except the m2 screws'print a little bit fragile. Good quality product.
Laurent M.
PSVANE KT88-Z Tetrode Tubes (Matched Pair) PSVANE's KT88-Z  power tube  offers a soft, warm sound, full and natural, with good balance and no background noise.  PSVANE  offers us a tube with a more...
Très bon tubes
Des tubes de très bonnes qualités tout est propre merci a l'équipe
Mark S.
FIIO K7 DAC Headphone Amplifier 2x AK4493S THX AAA-788+ 32bit 384kHz DSD256 FiiO's K7 is a high performance  desktop DAC and Headphone Amplifier combo , demonstrating an exemplary design for an audio reproduction marked by great transparency,...
An excellent dac-amp at this price
I use the Fiio K7 with Hifiman HE400se headphones and it drives them well (I usually listen with the volume on low gain and the knob between 1 and 3 o'clock). The volume control is done in the analogue domain, so changing it has no effect on the signal quality. Some people remark on a lag between turning the volume knob and the volume actually changing, but this has not been a problem at all. I especially notice the soundstage (instruments are easy to locate when listening) and the ability to reproduce a large dynamic range cleanly. I listen mostly using Roon upsampled to the dac's limit (on USB, 384kHz-32bit/DSD256), so adjusting the dac filters isn't really necessary, still it would be nice to be able to fiddle. Very happy with the purchase.
Au delà de mes espérances
J’ai endommagé de manière importante le câble d’origine de mon Sennheiser HD800s et le câble de remplacement est très cher.
J’ai commandé un câble chez Furutech mais ils ne sont plus disponibles…
J’ai demandé à Audiophonics de m’en confectionner un et ils ont refusé (c’est pas sympa !). J’ai donc pris mon courage à deux mains et j’ai confectionné moi même le câble de remplacement. Heureusement je suis bien outillé. Je comprends maintenant pourquoi Audiophonics ne veux pas m’en faire un …
C’est une galère ! Surtout au soudage car il faut attaquer à plus de 370• pour que la soudure accroche le fil. (Soudure argent 10%)
De plus les connecteurs de l’embout spécifique au HD800 sont minuscules. Si vous n’avez pas de loupe passez votre chemin.
Le cordon est souple et agréable. Coté Jack j’ai beaucoup moins galéré curieusement. Repérage obligatoire au testeur métrique. C’est pour ça que j’ai commencé par les embouts casque pour finir par le Jack 6,35.
Résultat : exceptionnel. J’ai un gain significatif dans tout les registres . J’ai ce caque depuis plus de 6 ans et je le connais très bien. Et là il dépasse tout. Après rodage la coquetterie dans les hautes fréquences disparaît et le grave est plus ferme. Les voix sont très centrées comme jamais. C’est confondant de naturel. Ampli casque CHORD Hugo2.
Je l’utilise entre mon amplificateur Cayin et mon sub REL .
C’est très simple ; une fois branché je n’entends plus mon sub. J’ai été obligé de vérifier qu’il était allumé ! Comme quoi un câble influence la restitution.
Le sub est beaucoup mieux intégré dans la restitution globale de mon système ; je n’ai plus qu’à peaufiner mes réglages.
Le service Audiophonics est toujours aussi - impeccable -
Gorazd K.
Nice look under the speaker stands and works well against vibrations, but had problems attaching with the included self-adhesive stickers, it didn't work at all. I had to buy better quality ones.
MATRIX ELEMENT P2 Power Amplifier Class D Stereo 2x230W / Mono 1x850W 4 Ohm Continuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly with the other models in this...
Rodage
Il lui faut qq jour de rodage pour avoir plus d'ouverture mais les timbres sont la des le début
Utilisé avec un musician en pre ampli
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 1A 25VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
La classe 5 étroite
produit super top avec des prise secteur furutech NCF rhodium
rapidité qualité l'image o rdv sans hésitation un vrai régal Netflix je note 5 étoile merci !
Ne sonne pas comme un class D
Belle découvert !
sonne comme un a/ab
Merci pour les -20%
Pascal J.
MP-H250S48 SMPS Switching Mode Power Supply Module 250W 48V 5A PFC This SMPS MP-H250S48 switch-mode power supply module is capable of delivering 48V, 5A current and 250W of power. It is also equipped with a PFC (Power...
Parfaite
Parfaite et suffisante pour réaliser un ampli 3E audio
efficace,fiable. Elle tourne avec l'ampli 12 à 16 par jour
depuis 1mois. Ne chauffe quasiment pas.
Pascal J.
Ne cherchez plus!
Si vous avez des Dynaudio emit 30 (en vente sur ce site) cet ampli est fait pour elles: une bande passante parfaite de haut en bas avec
une dynamique d'enfer , les timbres justes, et la transparence alors là un pur bonheur. Sur le lecteur cd Denon 110 anniversaire, pré -amplis FX tube 01 modifié tubes Voshkod avec symétriseur pro Sonifex ou Schiit Jotuheim phono.
Sami K.
EIZZ EZ-505 Banana Plugs 24K Gold Plated Copper Ø7mm (Pair) These high quality Eizz EZ-505 banana plugs are made of 24k gold plated copper contacts. They provide excellent conductivity and durability. The assembly is done simply by means...
Impeccable quality, very conductive
With these plugs the production quality is very good. The surface finish looks even better in reality than in the pictures. While the connector shells are all metal including the surface finish, so it is worth noticing that the only non-conducting part of the connector is the colour band. The connector shell is fully connected to the signal, so maybe not recommended to use these in applications with high voltages present while handling.
The spring structure of the golden part is rotating, which means the connector migh be less prone to breaking when twisted inside the mating connector. Robust double screws allow rather thick wires to be used and secure connections to be made. Overall rather decent quality/price ratio and very good build quality.
bernard g.
ATAUDIO SNOW SLEEK Balanced Signal Cable Silver Plated OCC Copper Ø8mm This balanced modulation cable sold by the meter consists of 12 silver plated OCC copper wires individually insulated with a PTFE sleeve. It ensures an excellent conductivity...
j ai fabriquer 3 alimentations secteur a triple cables de 6mm2 il faut faire du trèssage avec les 3 cables pour éviter les perturbations et avoir de bon connecteurs cuivre pur rodium et la dynamique est la le son glisse tout seul et encore il sont en rodage le son est de trés haut niveau c est super musicalement bernard
Anastasios O.
Exceptional!!!
This cable is a revelation for it's price... VERY natural without emphasizing any frequency... Silky smooth treble with plenty of air but never harsh, natural clear mids and tight deep bass with great extension...Also very articulate and dynamic. Mid/bass is not bloated but the cable never sounds thin... its full bodied with great homogeneity. It replaces my Tellurium Q Black II which it's bloated mid bass bleeded to other frequencies and muddy the sound... Also the soundstage of the Silenos is way better in all dimensions... WELL DONE LUDIC!
Uwe G.
Topp Kabel
Mit kupfer/vergoldeten Schukosteckern herrlich dynamisch auflösend bei kontouriertem Bass.
Wer es softer klingend möchte verwendet rhodinierte Schukostecker
Jerome R.
LHY AUDIO UIP USB 2.0 Isolator 480Mbps OCXO PLL Black With its UIP, LHY Audio unveils a high-performance 480Mbps USB 2.0 isolator incorporating an internal OCXO + PLL clock system for perfect...
Pas convaincu
Utilisé entre un streamer Melco N100 et un DAC Cen Grand DSDAC Deluxe, le rendu ne m'a pas convaincu. Le son ne s'est pas amélioré voir s'est montré un peu plus agressif. J'ai lu qu'il fallait une longue période de rodage pour que le coté agressif disparaisse pour laisser place à plus de fluidité mais après une semaine je n'ai pas vu d'amélioration. J'ai préféré renvoyer le produit avant la fin de le période d'essai.
Bruno F.
SMSL A50 PRO Amplifier 2.1 Class D 2x MA12070 Bluetooth 5.0 HDMI ARC 2x70W 4 Ohm + 100W 2 Ohm The SMSL A50 PRO is a 2.1-channel Class D amplifier featuring two Infineon MA12070P amplifier chips. It is capable of developing power up to 2x 70W 4 Ohm + 100W 2 ohm. One of...
Good for the price, for 90 euros you can't ask for more. sub output a little weak, I thought the bass would be more present, I used a 4ohm bass unit, I think that with 2ohm subwoofers the bass is stronger.
Sandy G.
Brillantissime
superbe sonorité, sur mon système en baffle plan.
il donne une très belle scène sonore.
Couplé avec filtrage en 1er ordre, à un DAVIS 20 DE08
il s'accorde superbement. Rendement élevé vérifié.
Cyril C.
Je possède déjà un récepteur Fosi et il y a vraiment du bruit problématique, même sans appareil connecté.
Avec ce produit ci, aucun problème, le son est vraiment très clean et la connexion est rapide, le BT 5.3 c'est super, bref très content de mon achat. Je n'utilise que les sorties RCA (vers mon ampli Denon)
Richard L.
SHANLING ET3 CD Player Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Silver The Shanling ET3 is a complete, powerful CD player with a modern design and excellent sound performance. Versatile, it offers full connectors and wireless connectivity, enabling...
Shanling ET3
Excellent service from Audiophonics! Well packaged en quick delivery. The Shanling is everything I hoped for.
Jean-Marc c.
AUDIOPHONICS CANARE Digital Coaxial Cable 75ohm RCA-RCA Sleeved 3m Here is our coaxial digital cable Audiophonics Canare in 75Ω version. Its particularity is to include CANARE C5F connectors, certified 75Ω and a cable CANARE L-5CFB.
Câble coaxial numérique
Parfait ,très belle finition et son excellent pour ce câble
Jean-Marc c.
Lecteur réseau wiim pro +
Reçu récemment ce pt lecteur réseau,très beau ,bien fini ,belle connectique,couteau suisse , télécommande incluse,app WIIM , branché en coaxial (cable superbe de audiophonics)sur DAC ext audio gd 38-28 , comment dire ce pt lecteur réseau fait le job radios ( attention certaines sont payantes !), quobuz, Spotify, Deezer ( q je n ai pas) ....le tout en unp/dlna , bluetooth,cast, multirom....
Donc de quoi faire , toute fois parlons du son et c est ce qui nous intéresse le plus : dans mon installation manque de profondeur ,de détails , de spacialisation....c assez déroutant mais toute fois peut comprendre puisque radio Spotify,ou autres ....par contre avec quobuz un léger mieux plus d ampleur ....mais toute fois ne rivalise pas du tout avec mon installation , lecteur réseau melco n 100 on est pas du tout dans la même catégorie !! Le n 100 est 10 fois plus précis et dynamique ....,
Conclusion : au départ pris le Wiim pro pour les radios spotify ,internet et fait le job sauf q son ben comme du MP3 reste en deçà !
Pour le reste j écoute sur mon installation qui est de haut vol et en suis ravis
Wiim pro est là pour avoir tout les gadgets q je n ai pas sur mon installation dans l ensemble ça fonctionne pas mal (wiim pro plus)mais pas assez précis et on dois jouer sur l app de l équaliseur !
Merci a l équipe audiophonics
Duncan A.
Superb quality
Superb quality, beautifully made power amplifier,highly recommended
Florian G.
SMSL HO200 Balanced Headphone Amplifier / Preamplifier Compact and elegant headphone amplifier & preamplifier with output stage capable of delivering up to 6W under 16Ω (3W @ 32Ω). Constitutes an ideal solution to...
En fait non
Correction : tout va bien… (:
STEPHANE M.
Excellent câble secteur
Ce câble améliore tout !! Avec un recul du bruit de fond très net...
Fortement recommandé !!
STEPHANE M.
Vaut son pesant d'or...
J'étais cablo-sceptique....
Je ne le suis plus !!
Le câble Pangea AC14 SE mk2 améliore tout...
Un très net recul du bruit,
une clarté sonore inconnue sur mon système
auparavant. Les aigus
gagnent en détails, les voix
sont plus intelligibles, les
graves sont serrés et rapide. Ce câble secteur est un must !!
Sylvain G.
AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex...
Impressive and immersive sound details !
Now getting the full sound detail potential and precision of my dynaudio confidence 20 using the latest very powerful power amplifier from Audiophonics
The difference with the also very good 2 cyrus X power in mono is perceptible : in the Bass and medium: more refined and overall more immersive soundstage and no fatigue at all !
Excellent service from audiophonic all the way !
System :
-Denon avc 4800h with Dirac bass control
-2 subwoofers : B&W 610
- Source : quobuz with Octavio streamer and Denafrips Pontus 2 DAC
/ vinyl : project X2 ( ortofon 2M black ) with project Ds2 tube preamp
Franck M.
Incompatible sur ampli DENON PMA 520
Produit de bonne facture mais incompatible avec mon vieil ampli Denon PMA 520, le volume de sortie RCA du récepteurs est trop faible pour une écoute correcte. Bien dommage
Patrick C.
iFi Audio GO Bar Kensei Portable USB DAC Headphone Amplifier XMOS 32bit 384kHz DSD256 MQA K2HD With the Go Bar Kensei, iFi Audio offers its most powerful USB DAC and ultraportable headphone amplifier. With its particularly compact format, it...
Le meilleur !
Je possédais le précédent Go Bar et j’avoue être bluffé par cette version Kensei : le son est indéniablement plus délié, plus riche, plus réaliste quel que soit le type d’écouteurs (intra, casque) et surtout le type de musique. Les ingénieurs japonais ont réussi une belle amélioration par rapport à un produit déjà remarquable avec le traitement K2HD qui restaure des harmoniques naturelles et des harmoniques au-delà de 22 kHz, offrant une qualité audio proche du signal d'origine. Bravo !
Julio L.
Très efficaces
J'ai essayé ces pieds isolants pour mes enceintes colonnes après avoir utilisé des pointes de bonne qualité, et la différence est notable.
Bien que le prix puisse sembler élevé, leur efficacité est indéniable. Pas besoin de dépenser une « fortune » chez des marques concurrents..
Je les recommande vivement pour des colonnes avec de bonnes basses (Sonus Faber dans mon cas).. Le parquet vibre beaucoup moins, et le reste du spectre sonore reste extrêmement controlé. Excellent produit et prestation Audiophonics au top comme toujours.
RENE R.
Power Plug Adapter Female US NEMA 1-15 / C Type to Male FR C Type This power adapter allows you to use US format power cables on European, Schuko or French plugs. The female part of the adapter can also be used for Type C / Schuko.
ADAPTATEUR SECTEUR.
BON PRODUIT QUI ME PERMET LE BRANCHEMENT D'UN TUNER YAMAHA T7.
RENE R.
1877PHONO EVANJEL MK2 3.5-RCA Jack 3.5mm to RCA Modulation Cable 1.5m A remarkable evolution of its predecessor, the EVANJEL MK2 distinguishes itself by a choice of high quality materials and particularly meticulous finishes.
CABLE 1877 EVANJEL MK2
COMME D'HABITUDE AVEC CETTE MARQUE LA QUALITE EST EVIDENTE ET COMME TOUJOURS LE PRIX EST RAISONNABLE
loic s.
SHANLING M6 ULTRA Digital Audio Player DAP 4x AK4493SEQ Bluetooth 5.0 aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA Green The long-awaited new version of the Shanling M6 Walkman, the M6 Ultra, is finally here, bringing not only an upgraded Android platform, but above all marking the return of AKM...
Excellent mais déroutant.
Pour commencer j'ai failli le renvoyer, au moins 4 fois. Trop doux, trop ouvert pour mon écoute et mes casques, et puis en équilibrant le gain, en choisissant de meilleurs casques et intras, en utilisant le Replay gain, je pense que tout ses défauts sont de belles qualités. Persévérer vaut le coup je pense. Doux analytique équilibré, belle scène, et vraiment différent d'autre dap plus acide.
VIBORG VE504AG Schuko Type E/F Power Connector Pure Silver Cryo Treated Ø18mm Viborg has further expanded its range of power connectors with the VE504Ag, a high-end Schuko connector that takes advantage of the best materials available to ensure perfect...
Apporte un surcroît d' énergie sans aucune coloration.
laurent C.
excellente finition
accessible côté tarif en cuivre pur, le repérage pour l'emboitage des deux partis du boitier est à améliorer
laurent C.
excellente finition
reste encore accessible en cuivre pur pas de problème particulier
laurent C.
La gaine est énorme ! mais les cables intérieure sont très souples et bien isolés ce qui pose problème au montage s'est surtout la gaine d'un diamètre imposant, a par cela le montage se fait facilement. J'utilise ce cable sur une barrette secteur Taga harmony. C'est limage de mon TV oled qui s'est amélioré (définition, précision et clarté) pour le son, plus d'ampleur dans le grave ça reste précis et pas baveux pour autant il ma semblé que l'aigu manquai un peut de pèche ! la définition générale reste douce pas agressive du tout avec une énergie qui fais plaisir. Le cable est monté avec des connecteurs de marque VIBORG en cuivre pur. J'ai relier la petite stresse sur la cable de terre seulement coté connecteur schuko
Željko N.
No bass
One power distributor (with 6 sockets -Furutech Rhodium NCF) is wired with this wire. The second one (with same sockets) is wired with Duelund wire.
Both have more than 400 hours of work.
The same system with an oyaide distributor has a very withdrawn bass. The musicality and beauty of the rest of the spectrum is automatically questionable.
Probably the effect is multiplied when 5 devices of the system are connected to the distributor, so with one power cable you probably won't hear a big lack of bass.
COLOMBO N.
Altoparlante Favoloso. Bassi e gamma media incredibile.
L'altoparlante è realizzato con grande attenzione ai dettagli. Cestello in alluminio, membrana in carbonio, magnete in ferrite e supporto bobina in Kapton. Il MONACOR SPH-135C sottoposto ai test ha fornito prestazioni piuttosto valide. I parametri rilevati sono sensibilmente difformi con quelli dichiarati dal costruttore. La frequenza di risonanza inferiore a 40 Hz e la ragguardevole tenuta in potenza permettono di ottenere prestazioni di rilievo in gamma bassa. Risposta in frequenza regolare a vantaggio della progettazione del filtro crossover che, par tali motivi sarà di semplice realizzazione. Qts e il BL elevati permettono una sensibilità di buon livello. E' un ottimo altoparlante, con apprezzabili caratteristiche che ne permettono l'impiego in sistemi a due vie di qualità. Ho personalmente adottato l'altoparlante in sistema bass-reflex, da 12 litri netti accordato a 50 Hz dove riesce a scendere in frequenza fino a 46,5 Hz (-3 db).
Dawid P.
TOPPING DX5 LITE DAC 2x ES9068AS NFCA Headphone Amplifier XMOS Bluetooth 32bit 768kHz DSD512 Silver Topping offers with its DX5 Lite a DAC and headphone amplifier combo benefiting from both an exceptional conception and a resolutely modern design. At its heart is a...
Absolutely marvellous detail and spatial effects. Very good bass and no exaggerated highs. The functionality is also great - auto off, filters, adjustable 3-step display brightness, gain. The volume knob could be improved a bit (still, it's better in comparison to DX3).
Yannis D.
Audio Extractor HDMI 1 to 2 DTS Dolby HDCP2.3 HDR 4K 60Hz eARC CEC With its high bandwidth and 18Gb/s digital data rate, this extractor is capable of working with 4K2K@60Hz HDCP 2.3, HDR 10bits streams and accepts a wide range of audio...
Fait ce qu'on attend de lui
Appareil qui m'a permis de garder mon projecteur de son ysp 5600 en le couplant a une TV récente mais en intercalant un NVIDIA Shield.
Petite frayeur car impossible de décoder le dts x 24bits lorsque l'extracteur était en place mais problème résolu en passant la TV en bitsream
MOONDROP PARA Planar Magnetic Circumaural Open-back Audio Headphone Ø100mm 101dB 8Ω 15Hz-53kHz The Moondrop Para is a high-quality headphone based on Planar Magnetic technology. It has inherited part of the structure of its predecessor, the Moondrop Venus.
Impédance...
Bonsoir.
À mon humble avis, les amplificateurs de casque ne sont pas adaptés à une impédance de 8 ohms. Ce casque est comme une petite enceinte acoustique.
Donc, il faut le brancher sur la sortie de puissance d'un amplificateur.
Pas nécessairement puissant : la question n'est pas d'avoir du voltage, car il a une bonne sensibilité, mais du courant, afin que l'ampli ne s'effondre pas.
Je vous salue cordialement.
PS. Les 5 étoiles sont pour audiophonics, je n'ai pas écouté le casque...
OLIVIER G.
Petit ampli classe D très sympa
Meilleur qu'un ad18, son mieux defini et une sonore moins étriquée.
Epaulé par un dac su-1, cela fait un système d'un bon rapport qualité prix.
fabrice G.
PSVANE EL34-Z Power Tubes (Matched Pair) PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture...
PSVANE EL34-Z
Vraiment étonnante sortie de boite un son chaud et plaisant on verra sur la durée mais pour le moment je suis plutôt emballer
Laurent B.
La claque totale !!!! Allez y les yeux fermés
A peine branché sur mon système habituel en remplacement d'un LPA S400 ET Purifi déjà excellent , c'est à ce jour ce que j'ai entendu de mieux .Qu'elle réserve de puissance et respect des timbres même à bas niveau . Image stéréo en 3D avec une profondeur de champ magique . Je précise que l'ampli drive des enceintes difficiles à savoir des moniteurs A2T INA sur base de dynaudio avec un rendement assez faible . les câbles sont de simples mogami . les basses sont là, sèches et non envahissantes cela grâce à la capacité dynamique énorme de l'ampli ,médium et aigus détaillés et surtout pas fatiguants. Si rodage il y aura cela ne sera encore que mieux .Oui c'est un sacré investissement coté tarif ... mais je ne le regrette pas pour cet ampli aussi bien construit et performant . Merci Audiophonics de produire des amplis de cette qualité . coté livraison c'est précis et super rapide. Laurent
Gilles D.
Très bon tube
Ce tube se marie très bien avec le SHUGUANG KT88 -Z !
Et le son devient exceptionnel sur un MUZISHARE X7
Merci AUDIOPHONICS
Gilles D.
Magnifique !
Merci AUDIOPHONICS
Claude P.
TOPPING PROFESSIONAL E2X2 Audio Interface USB 2 In 2 Out 24bit 192kHz Black With the E2x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of performance for...
Essais Topping E2X2
Testé (avec la version à une seule entrée micro qui est de qualité identique) dans un contexte pro mais juste essayé jusqu'à présent en convertisseur D/A devant un Flex commuté en analogique, il constitue une excellente surprise et permet de redécouvrir les titres que l'on pensait pourtant connaître par cœur.
Les autres cartes son type Behringer ou Focusrite peuvent aller se rhabiller au point qu'on a parfois l'impression de passer d'une écoute MP3 à du FLAC 96K...
La sortie casque est très bien, surtout avec le gain enclenché, et va à merveille avec mon Sennheiser HD 400 Pro favori qui a pourtant besoin de niveau.
Je n'ai pas encore testé les entrées micros ni pu constater la latence direct/retour.
Seuls points négatifs, l'absence d'une sortie optique qui m'éviterait une double conversion A/A et un bouton de volume 'cheap' et trop léger qui aurait mérité beaucoup mieux.
Pour finir, voilà enfin un produit chinois en béton armé côté logiciel et driver, il est reconnu instantanément et est très stable, idem pour le logiciel gratuit l'accompagnant qui est bien pensé et qui peut être déconnecté de manière totalement transparente.
Denis C.
Bluffant pour le prix
A mon avis, un câble intéressant pour se fabriquer des câbles HP de qualité à des prix compétitifs. Considéré par des youtubers comme un des meilleurs choix possibles pour cette gamme de prix. Je suis assez d'accord avec cet avis. Donne une écoute assez bluffante et détaillée avec un ampli QUAD et des CABASSE. A noter le terme SUPERFLEXIBLE est mal choisi, il est assez rigide.
BOF
câble sec, qui écourte le grave comme l'aigu, manque d'ouverture
J'ai remis le mogami 3103 qui est bien plus ouvert et naturel.
