Bruno R.
Un autre monde
Pour essayer le R2R dont j'entendais parler. Dac précédent smls do200pro avec ses 12 puces Cirus Logic qui,...
Davor M.
Davor M.
Very fast shipping to Croatia(4 days)
Customers reviews - There are 20916 reviews.
nicolas g.
Il y a mieux
Je trouvais le sons terne et avec un manque d'image sonore et de spécialisation, bien évidemment j,ai roder le tube je lui et laisser sa chance, jusqu'à se que je le remplace par un JJ ELECTRONC 6SN7 et la des le départ tube neuf sa na rien avoir, le sons et directement HIFI de limage de l'ampleur, bref je suis déçu des ELECRTO-Harmonix ils sons loin des JJ ELECTRONIC sur un systeme XDUOO TA-26S. Rien que sur les comparaisons YouTube il y a de la différence.
Johan v.
Very engaging and musical DAC
After getting rid of a ground loop by insulating the grounding metal part of the Schuko plug with duct tape it turns out to be a
very nice DAC.
Dear Topping engineers signal ground and safety earth are not the same thing so don't connect them together!
I used only the coax SPDIF input so far.
I wanted to eliminate the long warmup time of my tubed pre amp and tubed DAC and this works well now I can listen to music without having to wait for an hour for everything to sound right.
Oh and how does it sound?
What I lost in depth and spacial definition is more than made up for in musical detail and instrumental timbre is good missing nothing.
Very even sound balance with enough bass and body treble is fine mid range great the music is very engaging and in my system conveys emotion very well so far so good after 36 hours of being switched on.
Thomas G.
Fait le job, très robuste et très bonne qualité de fabrication. Attention cependant c'est un câble très épais et donc peu flexible.
Peteris B.
Peter
good quality, good price
Peteris B.
NEOTECH BRDCC-24 Braided Flat Wiring Cable UP-OCC Copper Litz Wire 24AWG 0.2mm² Neotech BRDCC wires are an excellent UP-OCC copper solution. Professor Ohno's UP-OCC process is recognized in the manufacture of high quality HiFi cables. Cotton (70%) and...
Peter
good soldering, good wire
Patrick K.
Sonic master
These cables are true gems, I have many interlinks , from mogami with low mass elecaudio connectors and chord C-line, to XLO reference , signature, wireworld gold eclipse 8 is my daily driver and beats the pants off of all else that came through… however a cable I constructed with this
Manuel G.
RAMM AUDIO 60600GT Female XLR Connector Tellurium / Berrylium Copper Cryogenic Treatment This RAMM Audio 60600GT XLR female connector offers a beautiful design quality, ensuring a particularly efficient audio signal transmission. The connector is made of tellurium...
Mitigé
Jusque maintenant j’étais très satisfait de la marque Ramm audio pour les améliorations audio qu’elle apporte. Je suis cependant plutôt mitigé sur la conception de ce connecteur XLR. Le pas de vis pour connecter le fil de masse flottante est plus petit que les autres et trop petit pour à la fois insérer les 3 brins et la vis de serrage. Il faudra faire un choix. D’autre part les pas de vis sont très fragiles car l’alliage utilisé est mou.
Montage donc difficile. Rien à redire cependant sur le rendu sonore.
Jesus A.
ER-106
He comprado decenas de unidades que uso en los equipos que fabrico, con excelentes resultados.
Xavier N.
LINDY CROMO LINE Digital Cable Coaxial SPDIF Copper Gold Plated 3m The Lindy Cromo Line SPDIF Coaxial cable benefits from a beautiful design quality. Its conductors are made of Copper for a very good conductivity and its connectors are plated...
Cable super pratique car fin et gaine type silicone, donc très souple. Connecteurs sérieux. Vraiment content de cet achat.
Xavier N.
SMSL PO100 2024 USB Interface XMOS XU316 to SPDIF Coaxial / Optical Toslink 24bit 192kHz DSD DoP64 Silver SMSL unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock circuit, it supports up to...
Livraison parfaite comme d'habitude.
Petit appareil qui sait se faire discret, Fonctionne parfaitement avec mon PC portable Wiindows, sitôt branché sitôt fonctionnel, sans avoir à charger un quelconque driver. Utilisation immédiate.
Olivier D.
NEOTECH NEET-3008 Ethernet RJ45 CAT6E Cable UP-OCC Copper 1m Neotech offers with its NEET-3008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It integrates four UP-OCC Copper conductors with a cross-section...
Tres bon RQP
Bel equilibre tonal pas montant plutôt dans la lignée des câbles dynamiques avec en premier attribut de la presence et un bel etagement derriere, sans pour autant jouer dans la categorie des cables trop ouverts avec perte de la densité. On est de façon evidente au dessus des cables premiers prix types Yauhodi en gardant cette touche de dynamisme. Attention le cable est tres rigide.
Arnaud F.
3E AUDIO A7SE Class D Stereo Amplifier BTL 1xTPA3255 2x230W 4 Ohm 3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A7se amplifier is based on a TI TPA3255...
Fait très bien le job
Config ordi - DAC Topping E30 II Lite ou Fiio BR13 - 3e audio a7 se - Klipsch rf82 mk2
J'avais un peu peur de manquer de puissance, ce n'est pas le cas. L'ampli tient magnifiquement les basses et les médiums, les aigus sont bons sans être extraordinaires, mais je ne jurerais pas que l'ampli est le maillon faible. Essayé avec op amp d'origine, les 1656 et L275, que j'ai gardé.
J'ai retrouvé la dynamique perdue avec le topping pa7.
Pas de mon souci de mon côté avec le power off automatique sujet à critique.
Validé !
Arnaud F.
Config ordi - Dac Fiio BR13 ou Topping E30
Dominique S.
Oui, la hi-fi et le home cinéma dans le même système c'est possible!
Ma combinaison Marantz Cinema 50 et Dynaudio Emit en 3.0 ne me donnait pas satisfaction: passable en home-cinéma et décevante en stéréo pour la musique. L'ajout de cet ampli, certes pas donné mais bien moins cher que les réalisation de marques prestigieuses qui utilisent les mêmes modules, a tout changé:
- matériel très solidement construit et connecteurs de haute qualité: ça fait haut de gamme
- ne chauffe pas du tout (mais alors pas du tout)
- mon Marantz ne chauffe plus non plus car il ne sert que de pré-ampli
- son home-cinéma beaucoup plus ample et précis, voix et dialogues très clairs, effets de basses amples
- mais surtout, retour dans le monde de la hi-fi pour la musique: clarté, transparence, contrôle des basses, absence de fatigue, aigus cristallins mais élégants, scène stéréo en 3D, positionnement des instruments et des voix "dans la pièce". J'étais déjà passé à la classe D dans ma chaine musicale Nuprime, ici on est au moins à ce niveau voire plus.
Deux minuscules regrets:
- un tout petit parasite à l'allumage
- pas de version "silver" du coffret
Merci à Audiophonics (et Purifi) pour cette belle réalisation.
marc G.
AC/DC Switching Power Adapter 100-240V AC to 12V 5A DC This power adapter delivers a power of 60W, with a voltage of 12V for a current of 5A. Its output connector is a DC 5.5/2.5mm jack (5.5/2.1mm compatible).
reçu un jour avant le delai prevu tres rapide et alimentation ameliore la qualité sonore (grave )
Carsten M.
GUSTARD X26III DAC 2x ES9039SPRO NOS Streamers LAN Roon Airplay UPnP 32bit 768kHz DSD512 Black Gustard's X26III is a balanced DAC and streamer based on two top-of-the-range ES9039SPRO DAC chips, offering accurate conversion of PCM up to 32bit 768kHz and DSD up to DSD512,...
Best DAC I have heard
This is an outstanding DAC. I had previously used a CHORD Mojo 2 in my hi-fi system. That was really good, but the Gustard is a very clear upgrade. It is value for money, too, as it has a built-in streamer that can save you 1.000 EUR for a separate streaming-bridge to match the Gustard DACs sound quality level.
Alain C.
HDMI 2.1 Optical Cable 8K 60Hz 48Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D 3m This 3m-long optical HDMI 2.1 cable supports high-definition video streams up to 8K 60Hz or 4K 120Hz, with a maximum bandwidth of 48Gbps, and is compatible with CEC, 3D, HDR 10,...
J'ai été agréablement surpris par la qualité de ce cable. J'ai été bluffé par son prix m'attendant à une qualité moyenne. Que neni. Il apporte une qualité d'image de premier plan. Attention au sens de branchement du cable.Bien suivre le sens des flèches sinon pas d'image. 5 étoiles à Audiophonics pour la qualité de leur produits et la confection des colis et leurs rapidités d'expédition.
Alain C.
C'est un cable que je connais bien pour en avoir acheté plusieurs. Il apporte vraiment une belle image sur un oled.Par contre je n'ai mis que 4 étoiles car je le trouve trop rigide. Mais en dehors de çà je le recommande sans hésiter.
Anthony O.
Parfait pour mon besoins
Je suis étonnamment impressionné par ces isolateurs acoustiques. Il y a eu une amélioration immédiate et très perceptible de l'image, les instruments étant beaucoup mieux fixés.
Pascal A.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 5V 2.5A 50VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Alimentation linéaire
Par rapport aux autres alimentation linéaire, celui-ci est très détaillé médiums aigus très agréable, les basses sont plus rondes il y a pas besoin a mon avis d'aller chercher plus loin
Didier B.
Purifi
Je me suis lancé avec courage pour acquérir deux PURIFi mono, ne croyant pas beaucoup à une nouvelle classe D pour la HIFI. Et bien, ils sont incroyables ses petits amplificateur. Tout le spectre est parfaitement reproduit avec une belle image stéréo avec de la puissance et sans distorsion. Mes HP 38cm sont maintenus avec une main de fer dans un gant de velour normal, puisque j'ai aussi aqueri le DAC Topping E70 VELVET. Aucun regret pour cet achat.
Merci à Audiophonics pour cette très belle réalisation ainsi qu'à Bruno PUTZEYS pour avoir réalisé PURIFi .
Rui V.
C’est avec beaucoup de regret que j’ai monté les prises sur les câbles (SOMMERCABLE TRICONE XXL) car ils sont très beaux.
Construction simple et soudure facile.
Excellent produit.
Rui V.
Bien construit, bons matériaux. Son neutre. Très bien compte tenu du prix.
Rui V.
Un peu épais mais assez précis.
Thomas V.
Beaucoup (trop?) de douceur
Installé sur la sortie rca du dac Fosi zd3. Oui ça s’entend clairement, c’est « joli » mais ça assagit la restitution. Je perds en attaques, sans doute en dynamique. Tout a l’air plus propre mais bridé, on est un peu dans la « musicalité à la sauce hi-fi ».
Cet aop me prive de l’énergie et de la rapidité de la très bonne alimentation qui faisait merveille sur ce petit dac.
Avec l’aop d’origine c’était peut-être un peu plus crade mais nettement plus vivant.
Jean-Emmanuel G.
AUDIOPHONICS CONTRAST RCA Interconnect Cable Subwoofer LFE OFC Copper Triple Shielding 5m (Unit) The Audiophonics Contrast LFE (Low Frequency Effect) RCA cable, designed and assembled in our workshops in France, has been conceived to provide a high-performance signal...
Câble avec une bonne finition, relié à un caisson il apporte un gain certain dans la lisibilité et la dynamique des graves. La longueur ne provoque pas de décalage par rapport aux enceintes.
Banana Plug Gold Plated Copper Ø5mm (Set x4) This banana plug offers an excellent quality / price ratio. Made of copper with gold plating, it ensures a very good conductivity and durability. Its design also allows a good...
Bon rqp
On ne peut pas se plaindre pour le tarif proposé car ces fiches bananes valent le coût.
Cependant pour un usage sédentaire si une fois enfichees elles ne bougent pas trop , ça va sinon, le plaquage or est très fin et s' enlève après une dizaine de manipulation....
michel m.
Bonne Alim. Y a plus qu a ... câbler.
Reçu dans les temps ...
Pascal j.
habitué aux appareils de format "conventionnels", j'ai mis un peu de temps à me décider...
Mais client Audiophonics de longue date, j'ai succombé à la tentation.
Associé à l'excellent ampli à tubes Cayin Jazz KT 88, enceintes Triangle Australe EZ, le résultat est bluffant.
Je ne passe pas mon temps à décortiquer le rendu des aigus, médiums et graves ; j'écoute mes cd et mes oreilles apprécient.
Le tout fait de la bonne, très bonne musique.
Le câble RCA Obsidian enfonce le clou.
Audiophonics, une entreprise honnête qui propose d'excellents produits et n'est jamais avare de conseils précieux.
michel m.
Ampli interessant
Une fois le montage et le rodage terminés, j'ai augmenté légèrement les basses et baissé légèrement les aigus a l'égaliseur graphique, cela me paraît mieux.
Beaucoup de pêche et de détails.
Sinon, ne chauffe pas beaucoup (peut-être dissipateur trop volumineux).
Et surtout, pas de ronflette.
DIMOKRITOS D.
Sonicaly wonderful and compatible with ribbon cables
The body of the plug is slotted so it can accommodate ribbon cables and as such is irreplaceable. Thanks to Audiophonics for this very good solution to those who use (or want to use) such cables. But this means that you should not tighten the clamping screws with excessive force because then of course you will cause the plug to split (although this does not happen easily). It can withstand enough force to tighten any cable properly but it will not forgive careless use. Sonically it is transparent, very clean and detailed, with beautiful timbres and without any harshness. Easily competes with MUCH more expensive plugs (I have a bunch of them). Loved it!
m t.
tres bon mais !
très bon câble mais très long à roder Début à froid pas top après un temps de chauffe c'est très bien
Oliver B.
I am the proud owner of a preamp and power amplifier combination from a French manufacturer of first-class tube amplifiers. I actually ordered the small Audiophonics power amplifier with the intention of reducing the high power consumption of the tube combination when using it as a home cinema sound system (the tube power amplifier has 12 power tubes). At the weekend I had the opportunity to "test" the Class D power amplifier for the first time. To put it briefly: what the small power amplifier delivers in combination with the tube preamp is simply a small sensation. The sound is powerful and warm. The stage is large. Instruments can be located precisely. Vocals sound simply fantastic. I had not even remotely expected that from a power amplifier that costs less than a tenth of the purchase price of the preamp. The large tube power amplifier will probably only be used rarely in the coming weeks. Instead, I am looking forward to many hours together with the little "magic box". Thanks to Audiophonics. What you deliver for this price is simply unbeatable.
Gwendal L.
simple efficace
j'avais un peu de réticence à mettre 89€ dans un simple commutateur, mais force est de constaté que la qualité est là et qu'il sera à même d'encaisser une installation puissante.
Simple efficace.
Gwendal L.
Intéressant
au vu du prix je n'avais pas grand chose à perdre. Après m'être équipé d'un MPA-S250NC j'avais envie d'ajouter un petit quelque chose un peu moins "numérique" à mon ensemble malgré avoir un DAC.
En soit de base le son est très correct mais j'avais un buzz sur une enceinte, j'ai préféré une autre paire de tube, ce qui a réglé le problème et amélioré la qualité sonore, j'ai également changé les Op amp et je suis très content du résultat, j'ai gagné en dynamisme et en chaleur, ce ne révolutionne pas non plus mon installation mais ca lui donne le petit truc que je cherchais en plus.
Gwendal L.
génial
je souhaitais au début changer d'ampli pour booster un peu mes Elipson Prestige Facet 24F qui étaient très à la peine avec mon ampli Marantz.
On m'a conseillé de jeter un œil à cet ampli de puissance et je l'ai commandé.
C'est une vraie révélation, je redécouvre totalement mes enceintes qui malgré leur qualité me décevaient. Je suis ravie, le son est détaillé, dynamique, elles revivent.
Je suis très très content de cette achat, merci Audiophonics de faire ce genre de produit pour un prix très correct au regard de la qualité.
CLAUDIO R.
IEM muy cómodo.
IEM de buena construcción, muy cómodo, liviano y con una excelente relación calidad/precio. Mi hija se ha quedado muy satisfecha.
CLAUDIO R.
RCA Connectors Gold Plated Ø6mm (Pair) Silver These high quality RCA connectors feature gold plated contacts, ensuring good electrical conductivity and resistance to oxidation. They are also color coded (red and black) to...
Un buen producto.
Conectores RCA de buena calidad y de uso sencillo; no se necesita soldador... Ideales para cables cortos con diámetro 6 mm y para cables con estructura coaxial. Relación calidad/precio inmejorable.
PHILIPPE D.
Viablue marque prestige
Magnifique connecteur, qualité fabrication exemplaire, un produit haut de gamme. Référence de prix élevé.
Erwin C.
TRUTHEAR X CRINACLE ZERO:RED In-Ear Monitor IEM Ø10mm/Ø7.8mm 17.5 Ohm 117.5dB 20Hz-40500Hz With the Zero RED, Truthear has once again teamed up with Crinacle, renowned for its expertise in IEM, to offer a new version of the fruit of their previous collaboration. These...
Very happy. These iem's are a steal!
For this very reasonable price, finding an equally good sounding iem will be a serious challenge. This time you can trust those rave reviews. The Zero:Red is extremely neutral, detailed and free of distortion. It deserves to be partnered with your best DAC/headphone amp. They are also comfortable. On the other hand, for those people with small ear canals, keep in mind that the nozzle size is bigger than usual: 6 mm.
Initially there was a supply problem at the manufacturer (I suppose) due to the high demand, but those fantastic people at Audiophonics kept me informed at all times. A shining example of how to do business!
Eric D.
bof
Honnetement ce truc me rend chevre, a l'ecoute on dirais que j'ecoute un vieux vinyl tous rayé, ca craque toute le 20 seconde, ca grésille, insuportable.
la reponse de gustard( good luck''
a fuir.
Frédéric P.
Connecteurs au top !
Pour le prix, il n'y a rien à redire...
Idéal pour les raccordements dans les endroits exigus.
J'ai utilisé ces connecteurs en association avec un câble Canare GS-6.
Thomas V.
Excellent pour le prix et facile à « upgrader »
J’essaie depuis quelques jour ce dac recommandé par ASR.
(Audiophonics propose aussi des « packages » intéressants avec l’amplificateur za3 de la même marque.)
Je le trouve très bon. Ma configuration est un peu « perchée » vu que je lui ai collé une très bonne alim 12 volts et super câble secteur + câble dc. Donc au final je ne suis plus du tout sur un dac à 180 euros.
Sans aller aussi loin on peut quand même profiter de l’entrée dc pour virer le petit bloc à découpage livré avec l’appareil.
Je ne sais pas ce que vaut cette ifi mais ça peut être intéressant
https://www.audiophonics.fr/fr/adaptateu...14433.html
Fosi propose aussi une manip relativement simple pour changer les aop de ses appareils. Apres le tube rolling on a donc du « op amp rolling ». On peut essayer des alternatives à quelques euros ou aller jusqu’au Sparkos à 85 euros, ce qui augmente fortement le coût de revient, particulièrement si on utilise le dac en symétrique (2 aop à changer).
On peut aussi trouver en ligne des aop « discrets » autour de 15 euros qui ont la cote. J’essaierai peut-être.
J’utilise simplement la sortie rca et je n’ai aucune frustration. C’est moins raffiné et détaillé que mon dac principal mais pour le prix c’est excellent. Bien mieux que le dac de mon petit lecteur de cd Teac 301 utilisé avec la même alimentation.
Erwan S.
FOSI AUDIO BOX X3 MM Phono Preamplifier with Tubes 2xJAN5725 Stereo Bluetooth 5.0 Black With its BOX X3 tube preamplifier, big brother to the BOX X2, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound...
Préamplification et réception bluetooth au top !
Acheté pour dynamiser un ampli vintage dont la partie préamplification phono n'était pas au top, je suis enthousiasmé du rendu ! Une très belle dynamique, l'évolution est flagrante ! Mon système audio a complètement changé avec ce petit boitier.
Petit bémol, le son parait tellement qualitatif que le rendu en est presque digital. Je vais tester d'autres lampes dans l'avenir pour trouver une texture de son plus chaleureuse.
Autre bonne surprise, la partie réception bluetooth est de haute volée ! Réactive à la connexion, le gain d'amplification est supérieur à d'autres boitiers essayés avec une amélioration de la dynamique.
Un de mes meilleurs achats audio
Erwan S.
Livré sans alimentation !
Effectivement c'est écrit en petit dans la description détaillée mais ce récepteur bluetooth est livré sans alimentation et ce n'est pas une alimentation USB C donc il faut l'alimentation spécifique 12V. Dommage
Dennis B.
JANTZEN AUDIO WAX COIL 000-8165 Waxed Taped Coil 12AWG 2.5mH A true vintage treasure, this Jantzen reel is fashioned from 99.9998% pure Copper 12AWG tapes hardened with a polymolecular paraffin wax.
Impressed with fast deliver, great product.
The sound is quite good, slightly better than the Jantzen 14awg wax paper foil inductor coils I have used a couple times in the past. I use these in Klipsch type B-2 crossovers along with Jantzen Superior Z caps-Jantzen Audio Power Cross-caps. After just a few hours break-in, better sound than the expected.
Andoni G.
Beutiful
Beutiful for made speaker and current cables
Andoni G.
Cheap and easy building
Cheap and easy building for basic speaker cable
Bernard C.
Ces fiches RCA sont parfaites autant par la qualité de fabrication que la facilité offerte pour la soudure et le réducteur pour les câbles de petit diamètre. Pas besoin de plus sauf peut-être pour des câbles très particuliers, argent ou autre.
Laurence M.
TOPPING PRE90 Balanced / Single-Ended Preamplifier NFCA Black Topping's Pre90 is a high-performance preamplifier based on a fully balanced circuit and high-performance NFCA modules. It also benefits from a high quality volume attenuator...
Topping Pre90
Un son épuré d’un grande transparence, très détaillé sans l’ombre d’un souffle.
Un excellent préampli allié aux deux excellents blocs mono Audiophonics MPA-M250NC.
