Arvydas V.
A
Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Anh J.
TONEWINNER AD-1PA+ Power Amplifier Class A Stereo 2x300W 8 Ohm Silver Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a...
Really a very rare winner; excellent in Class A.
This is a real rare winner. Secret tip. Excellent in Class A. Gets really hot, so i use a ventilator, very silent, to cool it down somewhat. Sound is very clear and clean. Sound picture is first row, but with big, huge and deep soundstage. Great resolution and magnificent transparancy. I play with very expensive devices, but this Tonewinner is worth the money and more. Review on Remusic is bull's eye review. The Tonewinner AD=1PA+ is really comparable with the viola symphony and worth the TAD loudspeakers. Sound is really very vivid and live like. Oncoloured. Deep Bass and no glare. Perfect voices. You can hear the effect of the 60 amperes and more than 200 damping factor. Total controle of speakers. I use BW 801 D4 and the Accuphase C-3900 and MCD 12000. Cumulus 3Tspeaker cables. The Tonewinner does not degrade these devices. Best kept secret.
Savvas P.
ATAUDIO POLARIS Power Cable Schuko IEC C15 Shielded Silver Plated OFC Copper 1.5m The ATAudio Polaris power cable is of exceptional quality and uses extremely pure conductors. Of the six insulated conductors in the Polaris, three are made of OFC 7N copper and...
Beau Cable
Bon rapport qualité / prix
Claude C.
fonctionne
fonctionne parfaitement . a voir dans le temps si les relais tiennent le coup .
Javier A.
Coolest CD player I’ve seen!!
If you’re into collecting CD’s then this is a must! I can’t stress how cool this CD player is, it’s aesthetically pleasing to look at, practical, and doesn’t feel cheap at all. At first I wasn’t too sure about ordering, but I decided to go for it and I’m so glad that I did. The packaging was great and shipping was insanely fast too, it arrived to the US in like 2 days after ordering. Honestly so worth it and one of my favorite purchases!
P v.
Amazing
This Q7 board is a worthwhile step-up compared to the already very capable Q3 + reclocker board. As previous described, more space, detail and musicality / timbre. Highly recommended
Jacek C.
Very good choise
Gustard R-26 - For now, after short tests, I can say that the sound quality improved in all aspects, after changing the vmv d1se, which is also a very good DAC in its class. Purchased with the latest firmware 1.42. The internal streamer works great, also on high resolution files and DSD up to DSD512. I haven't had a chance to test the DSD1024 yet. Earlier issues were fixed in the firmware. Also works great with HQ Player 5.0 after NAA update. I am very pleased with the purchase of the R-26. Audiophonic service and support excellent.
Elia M.
Regulated Linear Power Supply Module LT3045 LT3094 3x +/-15V This quality regulated linear power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of 3x ±15V on 3 pin XH2.54mm connectors. The...
Low ripple/noise psu
Very silent (ripple
Banana Plugs Gold Plated Lockable Ø9mm (The pair) These affordable banana plugs allow a quick and easy connection to the terminals of your speakers and amplifiers, while ensuring an optimized contact. The contacts are...
Magnifiques pour câble HP de forte section.
Achetées pour y brancher dedans mon câble HP Sommercable Elephant en 2x4mm2 soit 8mm2 de section.
C'est parfait, ça rentre facilement et il y a même de la marge jusqu'à 10mm2 de section de câble.
Le serrage par écartement de la fiche banane est simple et efficace, on ne risque pas de voir la prise se débrancher par accident.
Un tout petit reproche pour la route... j'aurais préféré des vis à clé Allen plutôt que des vis fendues pour un meilleur serrage.
Mais compte tenu du petit prix, c'est top.
Merci à Audiophonics pour la qualité des emballages et pour la rapidité de livraison !
Très bonne fiche à petit prix.
J'ai branché dessus le câble secteur Sommercable NYM-ST-J et cela convient parfaitement.
A l'autre extrémité, j'ai branché une prise mâle schuko Sommercable pour obtenir un très bon câble secteur.
Livraison super emballée et très rapide., top Audiophonics.
Vraiment rigide !!
J'avais lu que ce câble (marqué Général Cavi) est rigide.
Ayant coupé une longueur de 0,80 mètre puis placé une prise Schuko femelle Schurter et à l'autre extrémité une prise mâle Sommercable, le câble tient droit devant moi comme un bâton.
Vraiment rigide mais je peux quand même l'utiliser pour brancher mon ampli à lampes.
Constitué de 3 fils rigides monobrins de 2.5mm2 + un fil métallique supplémentaire plus fin et monobrin aussi (que j'ai branché avec le fil de terre) parcourent ce câble, il est effectivement blindé.
Le son est clair, plus transparent qu'avec un câble secteur ordinaire.
Bon achat, je suis toujours ravi de la qualité de l'emballage et de la rapidité de livraison par Audiophonics.
Janne K.
Hey, it works!
Perfect for a headless Plexamp pi feeding a Genelec SAM system! :-)
The missing star is for lack of documentation and a little for lack of a suitable case. Stole the idea to use a low profile passive heatsink case from Geekworm and cannibalize their acrylic plate "case" for a hood and bits, Works, but the hat still remains pretty exposed.
What's actually needed to get it working: 'dtoverlay=hifiberry-digi'.
Can't figure out (with enough certainty, not going to guess) where/how to wire a coax S/PDIF output; Really should be documented here.
Ne pas hésiter à bien asperger le disque . J'ai rempli un pulvérisateur de ce nettoyant . Après séchage avec un deuxième chiffon prévu à cet effet les craquements reculent de façon significative .
Elom G.
Très bon DAC
Très bon dac et ampli casque. J'avais un radson earstudio dont j'étais déjà très content, mais avec ce Fiio K3, j'ai une meilleure résolution: le son est clair et limpide.
Seul bémol, j'imaginais la puissance de sortie plus importante sur le mini-jack 3,5 mm.
Bilan globale : je recommande !
Ioannis K.
Excellent for small components
Very good for small stuf.I am using them in my VMV D1SE DAC replacing the annoying factory spikes.It does the job.
Ioannis K.
Very good quality product
Used in my Unico hybrid integraded amplifier.I am enjoying the excellent sonic characteristics.Replaced the previous Mullard ones with very short life (unfortunatelly!).Not as brilliant as Mullards but very musical and pleasant with a lot of body in mids.I hope the will last more...
Laurent B.
DAYTON AUDIO IMM-6S Measurement Microphone for Smartphones and Tablets The Dayton Audio iMM-6S is a professional quality measurement and recording microphone designed to work with iDevices (iPad, iPhone, iPod) as well as Android and Microsoft...
Microphone de Mesure pour Smartphones
Microphone de qualité robuste et livré dans une boite métallique.
Claudio R.
Toute la HiFi dont j'ai raisonnablement besoin - filtrage USB recommandé +++
Cet avis va de pair avec quelques "conditions bonne-pratique" propre à mon utilisation de n'importe quel DAC USB ou interface audio USB : un bon câble USB qui isole bien les conducteurs pour données des conducteurs pour l'alimentation, et un filtre USB (dans ce cas un Pure Clock de chez Oehlbach) qui va permettre de réduire davantage le jitter en isolant le signal des données de celui du transport d'alimentation au niveau du port USB.
Sans le Pure Clock, ce petit DAC donne un son de qualité, agréable, bien meilleur que celui de votre chipset audio. Mais avec le Pure Clock d'Oehlbach, on passe à un autre niveau et on se rend compte de quoi il est vraiment capable : un son extrêmement bien contouré et précis, d'une fidélité que je ne m'attendais vraiment pas à écouter. J'ai été le premier surpris car j'ai surtout mis le filtre pour éviter les parasites et autres saletés éventuelles. Et en fait il a tout simplement révélé les véritables qualités de ce DAC qui offre bien plus de haute-fidélité que ce dont je pensais en tirer. Comme pour nous autres, êtres organiques : une alimentation saine pour des performances optimales.
Vincent P.
Petit mais costaud
Le plus petit dongle dual DAC avec contrôle du volume du marché (j'ai épluché des tonnes de pages produits) ! Si le form factor et le design sont excellents, le son n'est pas en reste, il drive parfaitement mes Sennheiser IE800 et se débrouille très bien avec mon Denon D9200.
Laurent B.
AUDIOPHONICS RASPDAC Kit DIY Streamer for Raspberry Pi 2 / 3 & DAC This RaspDAC kit contains the Aluminum case, button, display, HDMI extension, Micro SD extension cable and the necessary hardware to mount your DIY network drive. DAC and...
5 ans après
RAS tout marche si vous ne modifiez rien au niveau software (sur Volumio 2.619
nicolas m.
rapide
rapide et bon produit
Vincent D.
IBASSO DC03Pro Portable DAC Headphone Amplifier 2x CS43131 USB-C 32bit 384kHz DSD256 Silver With the DC03Pro, iBasso offers a portable DAC and headphone amplifier combo as compact as it is powerful. Thanks to an optimized design based on the use of quality components,...
bon
utilisation sur pc portable et iphone14 pro max .flac 16 et 24 bits bonne restitution sur HD 599 et ROG cetra II en attente d'évolution ...
Bonne finition général , néanmoins un jeu au niveau de usb-c !
Nicolas S.
Très bien !
Ampli compact par sa taille mais belle restitution sonore sur mes triangle antal 902. Son précis et transparent sur tous types de music ( jazz, chant, pop). Ecoute en flac uniquement pour le moment. Belle puissance en réserve et surprise! Graves profonds!!
et fermes . Borniers enceintes un peu petits.
Jose M.
Simple et efficace
Utilisé sur un vieux Denon PMA 280 afin de lui ajouter des entrées numériques, le résultat est excellent sur des Focal Chorus 726. Audiophonics toujours aussi bien en qualité de service et conseil.
Christian M.
Contre-pointes de très bonne qualité, bien finies et de très belle apparence, ce qui ne gâche rien. Je les utilise sous des enceintes (colonnes, 12kg) posées sur du marbre. Le déplacement des enceintes est très facile, sans ajouter de feutre ou quoi que ce soit et - pour l'instant du moins- le marbre n'est pas marqué par le glissement du métal. Je conseillerais volontiers ce produit..
THIERRY P.
TOPPING NX7 Portable Headphone NFCA Amplifier Balanced Black The Topping NX7 is a compact and powerful portable amplifier, offering a beautiful precision and richness of sound. It is equipped with a new NFCA amplifier circuit specifically...
Etonnant Nx7 !
Couplée avec le Dx170, vous prenez un gap sonore bluffant, la profondeur de scène et énorme, ainsi qu`une basse présente et bien texturée, la largeur de scène prend aussi de l`ampleur, le tout et magique ! Un achat de haute qualité.
THIERRY P.
Etonnant Nx7 !
Sur mon DX170 couplee avec le N
Joel G.
Passive Preamplifier converter RCA to XLR / XLR to RCA Silver This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two...
Very good for its price
This little box works great when used from balanced in to balanced out. When going from unbalanced in to balanced out, I experienced some quality loss, but only on certain loud numbers / passages. I guess it is not expected for a passive pre in this price range to be able to balance an unbalanced source. Unbalanced in to unbalanced out worked great too. The only case I didn’t try was balanced in to unbalanced out. As a curious person I opened my unit and saw that the potentiometer has printed C20K, I guess it is actually a 20K potentiometer? Anyway, it sounds great and the price is great
Rodolphe L.
Bon Ampli
Bon ampli avec des composants de qualité, qui marche bien, simple à mettre en œuvre. Cet ampli image très bien en stéréo, tout les instruments sont bien localisés. La bande passante est large, les basses sont rondes et bien tenues. Le médium-aigu ressemble à un son d'ampli à tube.
Ensuite affaire de gout, très subjectif j'aurais aimé un peu plus de texture, de matière sur les timbres pour que ce soit parfait, Je sais je suis exigeant. Cette remarque qui n'enlève rien à la qualité du produit qui est très bon.
Enrico R.
MAXWELL Supercapacitor 2.7V 325F This Maxwell supercapacitor provides significant energy storage for demanding applications. Supercapacitors are an ideal choice for applications requiring large amounts of...
Pay attention to soldering
Pay attention to the supercapacitor soldering because their mass need for a powerful soldering tool (at least 80 W, but i suggest also 100W) and a good practice skill. I also suggest a liquid flux for electronics.
Enrico R.
IAN CANADA UCCONDITIONER Ultra Capacitor Conditioner Board 5V The UcConditioner 5V is a ultra capacitor signal conditioner board operating with a 5V power supply. It will significantly improve the quality of your...
Pay close attention for supercapacitor soldering.
Very good product. It transforms the power supply at a higher quality level, with a better sound quality (if the audio circuit is equally audiograde). Pay attention to the supercapacitor soldeing because their mass joined to the large soldering area need for a powerful soldering tool (at least 80 W, but i suggest also 100W) and a good practice skill. I also suggest a liquid flux made for electronics.
Enrico R.
IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi Ian Canada's ShieldPi Pro is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO...
Excellent product
At this price this is a really excellent product, the effect on the sound is clearly perceptible. I put it on my Raspberry 3B between it and a R2R DAC and the result leads to an undeniable clarity improvement.
Rodolphe L.
Bon module
Très bon module. Très transparent, belle bande passante et amplificateur vivant. Ne pas hésiter à mettre une très belle alimentation pour en profiter pleinement.
Enrico R.
Good product
Good product, correct price. Fastening is really efficient and long-lasting.
Rodolphe L.
HYPEX SMPS1200A180 Switching Power Supply Module 1200W 2x46V The Hypex SMPS1200A180 is a high performance Class 2 switched mode power supply, originally designed for UcD / NCore amplifier modules. Capable of delivering 2x46VDC at 1500W,...
Bonnne alimentation
Utilisé pour alimenter des modules classe AB. Fait bien le job pour un poids très contenu.
Fabien M.
DAC multi plates-formes
Association avec un amplificateur HPA-S400ET ,cordons XLR,Focal aria 948.
Ce boîtier est vraiment plein de ressources au niveau connecteurs d'entrées et de sorties, il est très simple à utiliser via son écran tactile et possibilité de cast cet écran sur votre téléphone, un must pour le pilotage dans le canapé. Il prend en charge sans soucis Amazon music en 192khz mais pas pour spotify....
Le son est vraiment excellent, sans exagérer, précis et clair, on redecouvre ses flac.
Pour stocker les musiques j'ai installer un SSD de 512go qui me suffit amplement, l accès pour le transfert se fait simplement sur une adresse IP comme un lecteur réseau sous Windows. Les transferts en WiFi sont très rapides 900mb en 30sec.
L interface est rapide et sans soucis. Même sur le téléphone, quelques légers lags si le cast est activé mais rien de grave.
Bref que du bon à part sur un point pour moi, je voulais mettre un HDMI in et j'ai essayé avec un adaptateur sur l usb type c mais cela ne fonctionne pas... j'aurais aimé profiter de la bande passante HDMI pour récupérer le son de ma TV, si quelqu'un a une solution, je suis preneur
Fabien M.
Une performance audio inédite pour moi
Bonjour, après essais de plusieurs amplificateurs Technics,onkyo RZ900, yamaha, advance paris A10...j étais à la recherche de celui qui pourrait exploiter mes Focal aria 948, étant conseillé par un ami puis par Audiophonics (merci beaucoup pour vos réponses à toutes mes questions) je me suis lancé sur cet amplificateur et je redécouvre mes aria 948,des basses sèches et bien présentes, un aigu précis et un médium mieux spacialisé. Un amplificateur qui rempli a merveille tous mes critères
SOMMERCABLE Schuko Type E/F Power Connector 16A IP54 Ø13mm This robust and affordable Schuko power connector from Sommercable will allow you to design quality power cables at a low price. It accepts cable diameters up to 13mm and is...
Top du top !!
Une fois la vis inox retirée, la prise s'ouvre sans forcer.
On peut y visser 3 fils de grosse section (j'ai du power câble 4 mm2).
Le diamètre externe de mon câble est de 15 mm2 est ça rentre !!
Superbe prise secteur, c'est du Sommercable, c'est tout dire.
Belles fiches, un peu de bricolage...
Ces fiches sont superbes, j'ai pu y entrer 2 sections de 4 mm2 de mon Sommercable Elephant mais c'est juste pile poil pour 8 mm2.
Ne croyez pas les installer en 5 minutes, j'ai dû bricoler un peu.
Déjà la clé Allen n'est pas fournie, mon jeu de clés Allen n'a pas une clé aussi petite. J'ai dû utiliser un tournevis miniature de mon jeu de tournevis d'horloger. Jusque_là c'est bon, en enlevant le plus petit manchon le câble de 2x4mm2 rentre.
Petite déception, la vis du haut de la fourche tient le capuchon de la fourche mais pas le câble. C'est la vis du bas qui serre le câble mais directement en l'écrasant. J'ai dû rajouter une petite cale pour que la vis vienne presser la cale sur le câble et ne pas le mâchonner.
Sinon c'est très positif, la qualité de ces fourches est extra.
Ce n'est pas si courant de pouvoir entrer une section de 8mm2 dans une fiche !!
Je crois d'Audiophonics a un contrat de transport avec le super héros Flash, les livraisons se font toujours le surlendemain de ma commande, je n'en reviens pas !!
Yvon B.
Très bon appareil
La restitution du son est parfaite et supporte sans problème le 24/192 entre autre à partie de qobuz.
Thomas V.
TINYSINE TSA7800B Class D 2.1 Amplifier Board TPA3116D2 DSP Bluetooth aptX 2x50W + 1x100W The TinySine TSA7800B module is a 2.1 Class D amplifier, capable of delivering a power of 2x50W + 1x100W. It also embeds a Bluetooth 5.0 AudioB receiver, supporting the high...
Lieferung und Ablauf
Audiophonics ist ein Top Lieferant mit einem klasse Service und Kundenservice.
Hervorragende Preise und schnelle Lieferung.
Kann man nue empfehlen.
2éme avis
Très bon résultat sous une platine vinyle . J'ai découpé des carrés collés par paire sous chaque pieds de ma platine . Ecouté apaisée et plus propre . De plus collé sur une paroi de deux de mes meubles j'ai supprimé des résonnances dû à la salle d'écoute . A utiliser avec prudence car comme dans mon premier avis si vous en ajoutez de trop le son peut être étouffé.
efficace
Alimente un récepteur Bluetooth . Grosse différence avec l'alimentation d' origine qui délivrait un son plat . Cependant j' obtiens un petit plus en le remplaçant par une batterie . Bon achat toutefois.
PRE-TC10 review
I have posted a review of this recently bought product at ASR:
https://www.audiosciencereview.com/forum/index.php?threads/audiophonics-pre-tc10-preamp-with-tone-controls-review-and-measurements.44930/
The preamp function is good at affordable price, it is helpful especially in cases we use a record player or cassette recorder. However, there was a QC failure with this product, the negative voltage regulator LM337 did not work and sent -23V to the LME49720 negative supply pin. This, together with +14V positive supply (correct value) made total supply voltage of 37V and this exceeds datasheet absolute maximum value which is 36V. The op amps have survived and I have replaced the faulty LM337 for a new part. However, this should have been tested by the manufacturer.
Joel G.
So happy with this amp
After 3 months with this amp I am very very happy with my purchase. I have used it plugged to a DAC with volume control with only rca out, a passive preamp with xlr, an active preamp with both rca and xlr -it does great with all of them-. I tried all of the 3 gain settings and ended up with the medium gain which I think suits better my preamp, speakers and room. Great design Audiophonics, merci!
Elsa A.
Fiches banane à verouillage
Excellente fabrication , acceptent de forts diamètres de câble, verrouillage impeccable grâce au diamètre de bague extérieure important.
Roland S.
AUDIO-GD R-7HE 2021 MK2 Balanced DAC R2R FPGA I2S HDMI Amanero 32bit 384kHz DSD Accusilicon Audio-GD is developing its HE range, composed of its most top-of-the-range products. They benefit from the longest design and testing period since the brand's inception. This...
Finally sound to love
un-artificial, believable, strong and like real. I confirm Herb Reichert’s review at Stereophile. Many years of search without arriving for me. All this oversampling filters or dsd conversion which I studied: interesting but not satisfying in the end, since it never sounded really real. Now with this chinese monster dac baby, I always come back to NOS after playing with different oversampling settings (Hqplayer). And so it will stay. This dac must be have been developed by someone who loves to listen. Many, many thanks to this person(s)!
Still, the r7he mk2 needed some help to shine. In my case I added a singxer su-6 as a ddc, connected by I2S. Better now, but still it was not the sound I wanted. A sound-killing dryness was there. The singxer has a poor switching power supply and the claim is that for its super-capacitor it does not need a proper linear power supply. Simply wrong, at least in my case for this dac. Exchanging the standard PSU of the ddc by a linear PSU was the missing last piece in the puzzle. I guess, if you go with the ddc from audio-gd you get a direct goal. Et voila: my search ended, music is playing to happy ears :-)
Jani B.
energijaj@gmail.com
plug for the main starting point from the wall, top quality and power with a nice sound
Dominique V.
Contrepointes Aluminium
J'ai acheté ces contrepointes car c'était l'élément manquant pour mes pieds d'enceintes. Sur les photos elles sembles jolies, mais une fois installées c'est nickel. Elles finissent et embellissent parfaitement mon ensemble pieds / enceintes DYNAUDIO. Concernant le son, même si s'il est déjà très bon, je pense qu'il y aura encore une amélioration. De plus j'ai commandé des câbles Dynavox, que j'attends car rupture de stock, et là ce sera le TOP.
Merci à Audiophonics de proposer des produits de qualité à des prix adaptés à toutes les bourses.
BENOIT D.
Fait l'affaire !
Fonctionne parfaitement, le son est bon. Parfait pour le pour le prix.
P.S. à l'attention d'audiophonics : l'alimentation que vous préconisez sur votre site n'est pas adaptée au récepteur car ce dernier possède une entrée en USB C alors que l'alim. est encore avec l'usb première génération. Donc l'alimentation que j'ai reçue ne me sert à rien, dommage.
Miroslav T.
XH 2.54mm Female to Bare wires Cable 3 Poles 1 Connectors Gray 30cm 24AWG (Unit) This good quality shielded cable has a 2.54mm 3 pole XH connector and 3 bare wires (red, white, black). It will allow you to carry out simpler assemblies on your PCBs also...
nice product
I am very satid+sfied with this one
