Rastislav K.
Nice
Marc A.
Un bon cable...
David m.
une super prise hifi
Customers reviews - There are 19554 reviews.
Zywno H.
IBASSO DX340 Digital Audio Player DAP Bluetooth 5.0 WiFi 32bit 768kHz DSD512 With the DX340, iBasso offers us a top-of-the-range digital music player incorporating the latest technological innovations in terms of FPGA and digital/analogue conversion,...
Perfect!
Fast delivery, wonderful DAP.
I strongly recommend!
Tiago R.
AUDIOPHONICS HC Trigger Home-Theater to HiFi system switcher 12V The Audiophonics HC is a home-theater trigger whose primary benefit is to save you the trouble of changing cable connections between your hi-fi system and your home-theater...
You miss a little detail
Just put a diode 1N4007 in the jack plug so you can use a jack spliter in your amp (hifi and avr)
Fredrik B.
AUDIOPHONICS HPA-DM750ET Power Amplifier Dual Mono Class D Purifi 1ET9040BA 2x750W 4 Ohm The Audiophonics HPA-DM750ET is a Class D power amplifier featuring dual mono architecture. Integrating two Purifi 1ET9040BA amplifier modules and two independent Hypex...
Fredrik
Very nice power amplifier for demanding speakers (low impedance / high current). This amplifier is driving my Magnepan speakers with ease, and with total control without coloration.
yann r.
Headphone Balanced Cable Jack 4.4mm to 2x Jack 3.5mm OCC Copper Silver Plated 1.5m This headphone cable features one balanced 4.4mm stereo jack connector and two balanced 3.5mm jack connectors. The cable uses two OCC copper conductors and two...
6 moi utilisation
ces un cable de tres grande quantité sonore. utilisez avec meze 109 pro une merveille. gain en profondeur détail clarté donc a acheter les yeux fermés
Michel V.
Musical et costaud !
Mon ancien lecteur CD (Arcam CD37) tient très bien le grave; et le Sabaj aussi. Le reste du spectre sonore est aussi bien musicalement restitué par le A20A.
Il y a 15 ou 25 ans, un ampli. de cette qualité valait plusieurs milliers de fr., etait plus volumineux et lourd ...
L'essai de rendu en BT est aussi très bon.
L'espace 3D est bien présent, mais un peu "compacté"; j'avais un ampli. à tubes en classe A OTL qui était plus aéré en 3D, mais beaucoup plus onéreux.
Je ne peux pas essayer sa polyvalence de connections, mais cela complète les bénéfices de cet appareil.
Vu ses petites dimensions, il faut être soigneux avec les petits commutateurs arrières.
Bref, une acquisition, que personne ne regrettera.
En plus, son esthétique est plaisante.
Bananes
VIBORG VR105G RCA Connectors Gold Plated OFC Copper Ø8mm (Set x4) Viborg VR105G RCA connectors enable the design of high-quality modulation cables, ensuring optimum transmission of the audio signal. The pure copper contacts, triple plated with...
Facile
Comme à son habitude, Viborg nous propose des prises RCA haut de gamme et facile à connecter avec vos cables préférés. Mais attention au diamètre de passage qui n’est pas de 8,5mm mais de 8mm.
À part ce petit bémol, c’est du tout bon.
Du Viborg tout simplement.
Frederic D.
Top !
Un adaptateur qui m'a permis d'éviter l'achat d'un cable secteur cher poyr mon lecteur réseau.livraison rapide.
Frederic D.
Top !
Adaptateur qui m'a évité d'acheter un cable cher.
Livraison rapide ! Que du bon.
Thierry H.
upgradable
après échange* du NE5532 par un MUSE8920A [ pour que ce récepteur mérite vraiment son nom ;-) ] le résultat est très convaincant !
* AOP au format SOP8 ! pas d'échange sans soudure comme avec les DIP8.......
Pavel V.
Banana Plugs Gold Plated Ø5mm (Pair) These affordable gold-plated banana plugs provide simple, effective connection to the terminal blocks on your speakers and amplifiers. The gold-plated contacts...
Good and tight plugs
Good and tight plugs, but despite my impression from the pictures, there is actually no grooving to put on a coloured rubber ring/distinguisher in the plastic shell and the outer diameter is smaller than the declared 14mm, so you can't use the 14mm silicon rings on them.
Pavel V.
AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home...
Excellent amplifier with a power-on issue
Excellent amplifier. The only serious issue: it can frequently trip sensitive circuit breakers on start-up. The NC252MP specification declares an inrush current of up to 75A and there is probably nothing to prevent all the three modules to start at the same time. I solved the problem by plugging the amplifier through an inrush current limiter: https://www.conrad.com/en/p/h-tronic-1114730-switch-on-current-limiter-scl-3680-ip20-2588901.html
Pavel V.
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz) that can be noticed from a 0.5-1m distance (or more) in silent environment (esp. from behind) ; the sound is different when the amp is off and when it is on (NC252M-based amps don't do this)
- if you plan to use the RCA inputs, expect sensitivity to ground-loops, esp. if you have a more complex sound system; if it includes a USB device (e.g. a DAC), you may need a proper USB isolator (a cheap one based on Adum3165 is just good enough)
- actually, I have been getting a slight humming sound from the RCA inputs all the time, until I connected the unbalanced source directly to the balanced input (shorting the SIG- to the ground pin); now it's finally completely silent!
- it is a pity that the XLR and RCA inputs cannot be switched remotely via some extension or upgrade; just some connector/header bypassing the mechanical switch would be very useful for a DIY implementation using relays; but considering my issues with the RCA inputs, it's probably better not using them at all anyway
Rob B.
NEOTECH NEP-3001G Power Cable Copper G-UPOCC Graphene 3x5.2mm² Ø16mm Neotech's NEP-3001G is a power cable incorporating 3 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both...
No brainer
Think this is one of the best cables for the money at the moment. Together with NEOTECH NC-P312G MKII Schuko + NEOTECH NC-P303II Connector IEC C13. It gave my NAD M23 a great boost. The graphene in the cable and the connectors will make the difference here I think. In my opinion it is not inferior to the Furutech dps-4.1. Highly recommended.
Luca C.
AUDIO-GD DI-25HE Digital Interface Amanero Accusilicon 32Bit 384kHz DSD512 The Audio-GD DI-25HE digital interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98MHz clocks. The circuit is designed to offer a plethora...
A highly recommended product!
Audiphonics is, as usual, a top website for purchasing high-quality products!
Immediate shipping!
Thanks and see you soon.
Enrico N.
INCREDIBILE!
Amplificatore veramente potente e con un suono decisamente soilfisticato! Pilota anche i sassi! Se usato in mono è addirittura spaventoso! Qualità sonica HI END!
Tutto questo a casa per 200 euro... Incredibile ma vero!
FRANCOIS D.
AUDIOPHONICS GREYHOUND Power Cable Schuko IEC C15 OCC / OFC Copper Shielded 3x2.5mm² 1.5m Hand-assembled in our workshops in France, the Audiophonics Greyhound Schuko to IEC C15 power cable offers an excellent solution for electrically connecting your HiFi equipment,...
Félicitations !
Une fois de plus un super produit ! Magnifique qualité de fabrication. Ce câble respire la robustesse et améliore grandement les performances de mon installation.
FRANCOIS D.
Bravo AUDIOPHONICS
Bravo à vous pour la conception de ce produit de très belle qualité !
Fabrice C.
J'ai acheté cet ampli dans l'espoir de mieux alimenter mes enceintes Magnepan MG1.6 QR actuellement sur un Denon PMA 2000.
Si vous avez la même idée, oubliez! Le grave est étriqué, il est dépourvu du beau "moelleux" procuré avec le Denon. Le haut médium est outrageusement mis en avant au point de rendre l'écoute très fatigante sur certains titres. Les timbres sont dénaturés dans cette gamme de fréquence. D'une manière générale, la musique est désincarnée. Après deux mois d'essais, il m'apparait que cet appareil se marie très mal avec les Magnepan.
J'ai donc décidé de le tester sur mes vielles enceintes Rogers LS7T qui fonctionnent très bien avec mon ampli Onkio A 8500 (2 X 100 watts), et là, ça a été la très bonne surprise! Je l'ai associé à un DAC pré-ampli Silkline Zuki I acquis récemment. Eh bien, mes Rogers n'ont jamais aussi bien sonné! Le grave est charpenté, moelleux et soyeux à souhaits. Les timbres sont justes et équilibrés, l'aigu à sa place sans excès. L'écoute, légèrement flatteuse est vivante et extrêmement agréable.
En conclusion, selon mon expérience, cet ampli est capable du meilleur comme du pire en fonction des enceintes qui lui sont raccordées... Le mariage avec des Magnepan est désastreux mais, au contraire, il fait merveille avec des Rogers...
bruno j.
J'ai longuement réfléchi avant l 'achat pour upgrader mon wiim pro plus ,foncé car cette alimentation vaut vraiment le coup .Un câble neotech nep 3003 G lui convient a merveille et MERCI a audiophonics de leur livraison rapide
rodrigue Y.
Connecteur RCA
Très bonne qualité de fabrication, donne une impression de robustesse au touché. Par contre il faut utiliser un câble avec le diamètre extérieur adapté pour que la tresse de masse soit en contact fiable avec la vis de blocage, ou dénuder sur une bonne longueur pour pouvoir enrouler soigneusement la tresse de masse autour de la gaine du câble de façon à augmenter le diamètre extérieur. J'ai utilisé un peu de soudure pour fixer la tresse enroulée. Pour mon deuxième câble,j'ai soudé la masse directement sur le connecteur côté intérieur. Si vous soudez côté extérieur impossible de refermer le connecteur, ou il faut une soudure d'1mm d’épaisseur. Ouais pas simple. Malgré tout, j’aime bien la solidité et l’aspect de ces connecteurs . Rodrigue
Franck M.
Franck M.
SHANLING Protective Leather Case for Onix Alpha XI1 Portable DAC This leather protective case from Shanling is specially designed for the Onix Alpha XI1 portable DAC. Aesthetically pleasing, it also provides effective protection for the...
excellentissime
petit dac très bien construit, tout en métal avec des boutons physique, design rétro magnifique et dac très performant, très puissant et le son est irréprochable, facile à utiliser, sur PC reconnu instantanément ainsi que sur smartphone ou il faut installer une application pour avoir plus d'options du contrôle du dac : application sur le store de Google ; Eddict Player. je recommande ce produit pour ceux qui ne veulent pas trop investir et avoir un dac d'excellente qualité utilisable partout .
Vincent B.
Bof
Le caoutchouc n est pas assemblé. C est une sorte de joint torique qui a du mal a resté a en place. Il aurait mieux value qu il ait une rainure et se clipse sur l alu.
Decu je m attendaia a autre chose
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo piano performances, where you can see the sound hanging in space, fading away without any blur.
The treble is never harsh, and the overall sound is truly flat and stress-free. Despite this, even the lowest frequencies are clearly separated and dynamic without being overbearing. For acoustic music, this is exactly the sound I was looking for.
However, one point requires attention.
This amplifier also supports RCA input via a switch. But since the Purifi module is designed for a fully balanced configuration, using RCA results in a severe degradation in sound quality. Specifically, issues such as smearing, distortion, and poor imaging become noticeable—to the point where (to exaggerate slightly) it starts to resemble a sub-€100 Chinese digital amp.
Therefore, if your upstream equipment only has unbalanced RCA output, or a pseudo-XLR connection that only uses pin 2, simply using an adapter plug for conversion is not sufficient. The unbalanced-to-balanced conversion must be performed via active circuitry within the preamplifier!
Shigeo I.
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with older CD players or DACs that only have RCA outputs, an unbalanced-to-balanced conversion via electrical circuitry is necessary. In that regard, this device is essential for bringing out the full performance of the Purifi module and offers outstanding cost-performance.
The sound quality is warm, with the high frequencies extending naturally into the air range. The MUSES electronic volume control is also truly excellent!
However, for those who especially prefer a tight and direct sound, directly connecting a source device with built-in preamp functionality to the power amp via XLR may be more in line with their preferences.
Hans V.
Zeer fijn
Het is altijd afwachten met wat je krijgt....prijs/kwaliteitverhouding.
Maar ik vindt deze met deze pluggen zeer goed.
Het zilver geeft ook een mooi frisse geluidsbeeld.
Erg blij mee en zal.deze vaker bestellen mocht dit nodig zijn.
Ik ben tot deze pluggen gekomen omdat ze mooi kort zijn wat past in infinity kappa luidsprekers
Thierry C.
SHANLING ONIX ZENITH XST20 CD / SACD / MQA CD Transport Sanyo HD870 With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and high-performance components. In addition to a...
L'adresse du site Head Fi
Introducing ONIX Zenith XST20 - High-End SACD Transport with true DSD output | Page 10 | Headphone Reviews and Discussion - Head-Fi.org https://share.google/JOatlSESuj2O2cFiM
Thierry C.
Un drive à un doigt de la perfection
La construction est remarquable, massive et pourtant l'esthétique estraffinée, l'opération sans problème et le fonctionnement presque parfaitement silencieux même à faible distance.
La qualité sonore est exceptionnelle, avec une dynamique une ampleur de restitution de l'espace remarquable et l'apport du DSD parfaitement tangible en utilisant la sortie I2S.
Le seul défaut en l'état actuel du Firmware est que le Gapless ne l'est pas parfaitement
On suivra avec profit la résolution de ce défaut apparemment bien connu de la communauté sur le site Head Fi où intervient un staff de Shanling
Laurent G.
AUDIOPHONICS HPA-DM500NIL Power Amplifier Class D Dual Mono Nilai500DIY 2x500W 4 Ohm Hand-assembled in our workshop in France, the Audiophonics HPA-DM500NIL power amplifier is a high-performance Class D dual-mono model, based on the new Hypex Nilai500DIY...
Ampli nilai
Tenue de grave impressionnante , spatialisation excellente , rapport qualité prix incroyable fonctionne avec un ampli préamplificateur moonriver 404 référence sur des grosses enceintes elipson Legacy 3230
Joseph C.
VEZZOSO X36 Balanced DAC ES9039PRO HDMI I2S SPDIF USB XMOS AES 32bit 768kHz DSD512 This X36 DAC from Vezzoso is a high-fidelity DAC that incorporates quality components such as an XMOS XU216 USB interface, an ESS Technology ES9039PRO DAC chip and a Qualcomm...
Retour d’expérience
Retour d’expérience après dix jours d’utilisation. Malgré ses qualités de bande passante, je trouvais la sonorité « sèche « , une « trop grande «  séparation des instruments qui donnait la sensation d’écouter plusieurs chansons en même temps et un manque de fluidité..
J’ai vérifié la phase secteur et celle-ci était inversée. Après changement de la phase, le rendu c’est grandement amélioré sauf pour l’aspect fluidité. J’ai donc acquis une multiprise en aluminium schuko filtré. Cette dernière à résolu le soucis de fluidité :)
Pour résumer, ce dac est particulièrement sensible à la phase et qualité du secteur.
Jusqu’à présent tous mes précédents appareils n’ont révélé aucune différence sonore quand à la phase du secteur, c’est donc une première pour moi.
Cette vérification est de plus gratuite.
Si cela peut aider les utilisateurs du dac
PSVANE KT88-TII MARK II Tubes HiFi Serie (Matched Quad) These high-end PSVane T-Series Mark II matched tubes offer exceptional performance. These tubes have a superb design quality and will easily find their place in your audio...
PSVane KT88-TII Mark II
I replaced the PSVane KT88-TII Mark II tubes with the original Cayin KT88 and it was immediately noticeable how the dynamics, depth, delivery, clean highs, dynamic bass, noticeable mids changed, the sound suddenly got a completely different dimension, the space also changed, beautiful 3D details, which I had rarely heard before. The tubes arrived beautifully packed in boxes with foam, against damage, excellently packaged. So we'll see when they burn out after about 250 hours, I assume the sound will get even better and it will be like a symphony of tone, which I will enjoy forever :) ... Thanks to Audiophonics for the fast delivery to the Czech Republic.
Eric v.
AUDIOPHONICS STEALTH XLR Interconnect Cable XLR-XLR OCC Copper 0.3m (Pair) The Audiophonics Stealth range offers a selection of particularly high-performance, affordable cables, hand-assembled in our workshops in France. The Audiophonics Stealth XLR...
Très bon cable neutre et des détails et avec les XLR au rapport qualité/prix imbattable
Eric v.
MORNSUN LOF550-20B36 SMPS Switching Mode Power Supply Module 550W 36V 15.3A PFC This LOF550-20B36 switching-mode power supply module delivers 36V and 15.3A for 550W of power. The module features high-quality components and is...
Très bonne alimentation utilisée sur bloc mono fosi , permet en 36v de faire baisser la température des petits amplis... assure une puissance constante vu sa conception , parfais!
Eric v.
NEOTECH CU-AG-20-20 Wiring Cable OCC Copper / OCC Silver PE Insulation 0.518mm² Neotech CU-AG cabling wire ensures perfect signal transmission, using conductors made of OCC copper alloy and 20% OCC silver for optimal conductivity. Each conductor is...
Bon cable
Cable très rigide ,pratique pour cablage interne modulation mais la gaine est vraiment médiocre , fond très vite dommage sur un cable de qualité et à ce prix !
Arnaud C.
IBASSO DX180 Digital Audio Player DAP 4x CS43131 Bluetooth 5.0 Android 13 Black The DX180 from iBasso is an audiophile DAP of excellent quality. It benefits from a meticulous design incorporating four CS43131 DAC chips, delivering faithful, accurate and...
IBASSO DX180
Il n'y a pas photo entre le DX180 et mon Redmi Note 10 Pro qui est pourtant certifié HiRes. Le son est clair, les graves sont présents, les médiums bien séparer et les aigus viennent agréablement agrémenter tous styles de musique. Les instruments sont bien placés et pour profiter d'une scène sonore élargie.
Pour l'instant je le teste avec mes IEM FH3.
Je recommande surtout avec une mémoire suffisamment grande pour y loger plus de 44h de musique dont la moitié en 192khz avec qobuz.
Hâte que le baladeur soit rodé et de les essayer avec mes FH19.
Kirsch p.
SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams...
Ne pas choisir la livraison par DPD
Audiophonics a été très réactif quant à la livraison mais DPD n'a pas respecté les délais nis mon colis il est arrivé dans un état abominable heureusement qu'il est bien protégé.
sinon le DAC et fantastique !
A H.
Great alternative for high end audio
I use this for my DSS mains conditioner with a Furutech cable and FI-e50 ( non-NCF) schuko on the other end. The powercon did not deteriorate the sound, it is clear, detailed but not very smooth in a high-end way. I guess this is due to the silver. But the Furutech rhodium will take care of the signal becoming smooth enough. Considering the price this powercon is a real steal.
A H.
Also with digital this is a great plug
My first c-004 was a big shock on my power amp. Stereo-image became very precise and clear, as if you listen to a master tape. What was lacking a bit was bass volume bit the increase in detail and realism… just incredible. I still wonder how this is possible with just an iec-plug.
With a Furutech FI-50 schuko I got that bass volume back and changing the iec-inlet on my amp for a Furutech gold iec-inlet also made the highs more silky and the whole thing perfectly balanced and natural.
I bought a second c-004 for my streamer+server. Now the effect wasn’t that spectacular as with the power amp, but still the c-004 gave clearly more detail and is worth every penny. Here a Furutech FI-50 NCF schuko brought some more bass detail and smoother highs.
So, the c-004 is a real bargain when you can get around the “not that strong” points like less bass with a power amp.
My cables are green and blue Furutech. This all combines very well for a reasonable price. Only the Furutech FI-50 NCF seems a bit expensive, but also is the p-004.
Jean-Baptiste A.
Acheté pour découpler mes enceintes jmlab cobalt 826 installées sur dalle granit de 3cm d'épaisseur sur 1 dalle de liège de 1cm pour la liaison sur carrelage. Elles sont couplé avec les pointes audio bastion xspike plus. Elles s'associent parfaitement dans cette composition. Comparativement les soundcare me faisaient perdre énormément de dynamique sur les basses fréquences. A l'opposé les pointes et contre pointes d'origine me permettaient de récupérer du dynamisme au détriment d'un confort d'écoute très fatiguant avec des aigus très agressif. Bref, avec ce couple audio bastion, j'ai pu récupérer avec brio le meilleur des 2 solutions précédentes. Un grave dynamique avec beaucoup plus de profondeur. Une séparation des instruments intelligible, des médiums merveilleux et des aigus presque soyeux, jamais agressif même à fort volume ! Pour ma configuration, je pense que je ne pourrai pas trouver mieux.
Jean-Baptiste A.
AUDIO BASTION SPIKE X PLUS Spike Stainless Steel M8 (Set x4) These Audio Bastion Spike X PLUS spikes effectively dampen the vibrations generated by your audio system. They are made of 304 stainless steel, both robust and durable....
Acheté pour découpler mes enceintes jmlab cobalt 826 installées sur dalle granit de 3cm d'épaisseur sur 1 dalle de liège de 1cm pour la liaison sur carrelage. Elles sont couplé avec les Contrepointes audio bastion xpad plus2. Elles s'associent parfaitement dans cette composition. Comparativement les soundcare me faisaient perdre énormément de dynamique sur les basses fréquences. A l'opposé les pointes et contre pointes d'origine me permettaient de récupérer du dynamisme au détriment d'un confort d'écoute très fatiguant avec des aigus très agressif. Bref, avec ce couple audio bastion, j'ai pu récupérer avec brio le meilleur des 2 solutions précédentes. Un grave dynamique avec beaucoup plus de profondeur. Une séparation des instruments intelligible, des médiums merveilleux et des aigus presque soyeux, jamais agressif même à fort volume ! Pour ma configuration, je pense que je ne pourrai pas trouver mieux.
Johannes R.
Fosi Audio P4 Preamp
Très approprié à mon avis. J'ai équipé les monos V3 d'Audiophonics OPA1642. Parfait pour moi ! DAC est un Soekris 1221, antérieur à Lindemann Limetree Bride.
Patrice P.
MUSICIAN PEGASUS II Discrete Balanced R2R DAC 32bit 1536kHz DSD1024 Black The Musician Pegasus II presents itself as a magnificent and particularly powerful DAC, taking advantage of a neat R2R architecture. Integrating the best current technologies,...
Haute valeur musicale ajoutée
Après plus d'un mois d'écoute, ce DAC révèle sa vraie nature très musicale et analogique. Il est aussi très précis, transparent. et silencieux. la scène sonore est large et profonde. Un vrai régal pour l'oreille. Matériel audiophile !
Mon système : Eversolo DMAP A6, amplicateur Ma252 et enceintes Sonus Faber Sonetto III.
Le rodage est un peu compliqué : au moins 250h pour qu'enfin la véritable signature sonore se stabilise. Pendant cette phase, on doute, on passe par des hauts et des bas... Puis, tout s'éclaire et là, c'est tout simplement magique.
Attention, ce DAC ne laisse rien passer. Toutes les liaisons (câbles) entre la box, la source, le DAC et l'ampli doivent être particulièrement soignées sinon on perd en précision et en fluidité.
Pour ma part il ne me reste plus qu'à changer ma source qui n'est plus au niveau de ce bijou ...
Je ne peux que recommander ce produit à tout ceux qui veulent approcher la sonorité "vinyle-like" avec de la précision, une dynamique franche, fluide et humaine.
philippe C.
FOSI AUDIO DC Power Noise Filter 12-55V 10A with DC jack doubler This Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power supply noise and protects your...
Dynamique
J'ai essayé ce filtre qui m'apporte du silence, de la dynamique, des détails et un médium plus naturel. C'est une bonne solution pour améliorer les alimentations "sales" qui pullulent sur le marché actuel de la hifi.
C'est bien, c'est peu coûteux et ça marche... sensiblement.
olivier P.
Déception !!…
Matière sans doute qualitative .. mais finition très moyenne un brin corrodée et mal ébavurée… on trouve mieux à 10 fois moins cher et en inox dans le commerce .. client audiophonics régulier et ravi de l’être mais très déçu sur cet achat …
Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many numerous amplifiers in the ASR ranking.
After a few days, the unit sounds even better.
Unfortunately, this amplifier requires 13-14 volts of input voltage to deliver its full power.
Most preamplifiers deliver up to 2-2.5 volts.
It is possible to adjust the gain on the bottom of the unit using the preamplifier itself.
Unfortunately, this somewhat degrades the excellent technical values ​​(Sinad from 137 dB to 128, etc.).
These are still excellent values, and I don't hear any sonic differences on my Nuvero 140.
Audiophonics specifies the following gain values:
Bypass: 11.5 dB
19 dB
25 dB
31 dB
33 dB
The following values ​​can be set on the device:
11.5 dB
19 dB
24 dB
28 dB
I love this amplifier. I've certainly owned over 10 select and well-tested amplifiers before.
The LPA-S600NCX is my favorite.
Plenty of stage, plenty of detail, and decent dynamics.
Theodoros R.
ORACLE II 01 Discrete Single OPA DIP8 (Unit) The Oracle II 01 single OPA represents a new generation of hybrid discrete operational amplifier, specifically designed for audio applications and offering excellent performance...
NICE OPAMP
VERY NICE OPAMP FOR THE MONEY!!
Charles S.
Bravo Xangsane
A ce prix les connecteurs XS-6001 AU sont imbattables .
Timbres dynamique aération et musicalité qui fait mieux même à 10 fois le prix !
Merci Audiophonics pour cette découverte , rare aujourd'hui .
Aurelijus S.
MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks...
Elevating FM Radio: Integrating Teac PD-301-X with Topping E70 Velvet & B200 for Audiophile Sound
I have a Teac PD-301-x FM tuner with excellent sound but only an analog RCA output from the FM Radio. So, to have its sound in my HiFi audio system, I added PocketADC into the chain, which looks like this now: Analog FM signal from Teac PD-301-X → PocketADC → SPDIF → Topping E70 Velvet (DAC) → Topping B200 (amplifier) → Dynaudio Emit 20 speakers. PocketADC is transparent, and now I can enjoy excellent FM Radio quality from my nice Teac tuner.
I selected 48 kHz as the sampling rate because the source signal is analog FM radio, which has a limited frequency range—typically up to around 15 kHz. A 48 kHz sampling rate comfortably captures the full audio bandwidth of FM broadcasts without unnecessary overhead. I did not see any heat from pocketADC. Also, I use a linear power supply, Keces P6, which also powers my Teac FM Radio component.
