Frederic D.
Top !
Un adaptateur qui m'a permis d'éviter l'achat d'un cable secteur cher poyr mon lecteur réseau.livraison...
Frederic D.
Top !
Adaptateur qui m'a évité d'acheter un cable cher.
Livraison rapide ! Que du bon.
Thierry H.
upgradable
après échange* du NE5532 par un MUSE8920A [ pour que ce récepteur mérite vraiment son nom ;-) ] le résultat est très...
Customers reviews - There are 19147 reviews.
Werner S.
Good Dac an good Streamer wenn you find the right operation system
Well I had ordered the new Evo-Sabre as a complete kit at the beginning of February 2023 and it arrived within a week.
For the assembly it needs already some idea and also patience. Except for a wrong drill hole, which had no meaning, I could assemble everything well and also the first test was positive. The device looks good overall and makes a quality impression. Finally Audiophonics has a solution to switch the device on and off via a real hardware switch, including the Raspi, which is always running. The Dac itself is very quickly ready for operation and displays the sampling frequency, the selected input and the volume. The Raspi is accessible after about half a minute. Switching off or shutting down takes only a few seconds.
I took a lot of time with the choice of the operating system. First I tested the ready-made images offered by Audiophonics. The following comments are brief:
Volumio: makes at first a quite passable impression, but even after longer trying and reading in the forum, my embedded art covers could not be displayed correctly.
Moode: didn't work for me, especially the integration of my music collection didn't work and the cover images weren't displayed.
DietPi: altogether also not successful and only after much reading I got further so that at least the LMS server ran.
Then I downloaded the latest PiCorePlayer and from then on everything worked as I wanted. So this is the operating system of my choice. I could also set everything with a little reading up immediately and according to my ideas. After that, the LogitechMusicServer ran immediately and it was displayed, for example, all my cover images. I use for operation on the smartphone (Android) the Material Skin with the Kiwi Browser, which looks very good and also provides a lot of additional information about music and artists with the appropriate selection of plugins. I must say that I already knew and used the LMS before, so it was familiar to me again quickly.
The right display have not brought to run, but in the forum there is a script where it should be possible. I do not need the (right) display, because I see everything via the smartphone app.
Summary: overall a good device that I would buy again. The price is reasonable for me especially as a complete kit with Raspi. The converters are also very good and it sounds very nice in my very high quality system.
My request to the Audiophonics team would be to adapt the illustrated instructions to the current state and to give more instructions in a few places (e.g. installation of the display cover).
It was very good for me that I received several answers to my questions about details in advance (before I ordered the device). Thanks for that.
Jean C.
HIFIMAN ANANDA Stealth Audiophile Planar Magnetic Headphone High Senstivity 93dB Hifiman’s Ananda audiophile headphones are the result of many years of development. It is a lightweight model for unequalled comfort and equipped with ultra-thin ...
Clarté et polyvalence
Ce casque est assez imposant: oreillettes ovoïdes de 13 X 10 cm, 400 gr, arceau confortable. Le câble de +/- 1,30 m demandera une allonge pour se connecter à un ampli, mais est parfait pour se lier à un baladeur. La sensibilité de ce casque permet effectivement de le connecter sans problème à un (bon) baladeur, voire un smartphone.J'ai testé de nombreux genres: l'électronique de Bad guy (B Eilish), le sax de One Fine Day (J Harbeck 4tet), la trompette de Melody Nelson (D Zimmermann), le clavecin et le violon des Frères Francoeur (T. Langlois-J Taylor), la voix de Juste qq'un de bien (Enzo Enzo), l'orchestre symphonique du Concerto n° 2 de F Liszt (N. Arghamanyan), le tout avec bonheur. Le son est clair, ciselé. Sur certaines plages, les instruments se répartissent bien transversalement, mais également sur des plans différents, on se rapproche de l'écoute de SACD en 5.1. Les percussions de gros tambours sont bien rendues, les vibrations se limitant fatalement aux tympans. Le système ouvert, outre ses caractéristiques acoustiques, permet un port confortable, sans trop d'échauffement.
john p.
Part of my speaker cables
This cable combined with a pair of the thinner gauge solid core jantzens is one of the best cables I ever "assembled" .
john p.
MUNDORF MR10 non-inductive metal film Resistor 10W 10 Ohm Unlike conventional resistors, & film metal winding resistors have no residual inductance. Thus, in cases where impulse response is essential, in midrange frequencies for...
Why is this so?
I used them with poor results in speaker crossovers. The cheaper generic white ones sounded better to my ears. A bit strange isn't it? Now I am using the monacor attenuator with great results and convenience.
john p.
JANTZEN AUDIO WAX COIL 000-8165 Waxed Taped Coil 12AWG 2.5mH A true vintage treasure, this Jantzen reel is fashioned from 99.9998% pure Copper 12AWG tapes hardened with a polymolecular paraffin wax.
Seamless transition
Best inductors ever used in my horn speakers crossover. The most characteristic advantage of these woofer coils is a a really smooth transition between the woofer and the squawker.
john p.
JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 8.2µF Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a...
awesome caps
For many years i was convinced after testing various caps that pio caps was the only way to go for crossovers in horn loudspeakers. During a crossover modification , a wrong clumsy movement led to the destruction of the leads of an expensive pio cap. Replacing it was out of the question so I gave these jantzens a try and oh boy !!! These caps for the tweeter and midrange are really musical not so laid back as the pios but not as edgy as other boutique caps. Really impressed
john p.
QUALITY POT
I was testing some high db tweeters (107-110db) using some pots I had in hand but the sound was negatively affected. Soldering resistive L pads was out of the question - too much work - so I gave these attenuators a try and I am glad I did. I mounted them on the side of the tweeters baffle and I have full control on attenuation with very good sound!!!
Pierre J.
Extra.
Utilisés pour les placer sous une platine CD.
Une fois en place ils s'avère très souples, efficace pour supprimer les effets résonances et de ronflements.
Apportent par la même occasion un petit plus pour le rendu sonore, meilleur précision au niveau de médiums aigus.
Pierre J.
Parfait.
Patins très souple, pour ma part utiliser pour un ampli Hifi, très bien pour supprimer les ronflements et effets de résonance.
POPOVSCHI B.
MOGAMI W2330
Great quality cable! Very fast delivery! Thanks audiophonics!
manuel S.
Excellent rapport q/p
Ce streamer est excellent, très transparent, doté d’une large bande passante, le rendu est très fluide et toujours naturel, il est meilleur qu’un wattson digital que je possède aussi, c’est dire.
Testé en sortie coaxiale sur deux dac différents.
FOSI AUDIO BT30D PRO Class D 2.1 Amplifier 2xTPA3255 Bluetooth 5.0 2x125W+250W 4 Ohm The Fosi Audio DT30D Pro is a small, powerful and affordable Class D amplifier, ideal for the integration of a simple but powerful audio system. It embeds for that two TPA3255...
DECEPTION
J'ai comparé ce petit Fosi Audio BT30 D Pro à mon Aiyima A07 modifié et à ma surprise, le Fosi ne tient pas la comparaison. La définition est certes bonne mais les timbres sont un peu sommaires (sensible sur du piano) et l'image stereo pourrait être plus profonde et plus transparente. L'amélioration de ce Fosi Audio est quasi impossible car les AOP sont soudés sur la carte et non sur support, véritable erreur de la part du concepteur! Mon Aiyima monté avec AOP TLE2142 CP fait mieux sur tous les critères ci-avant énoncés.
Howard C.
Easy purchase, works with no hassle
Does what it says, just plug it in and it works. I have it connected to an optical cable to drive a set of Edifier S350DB speakers at the opposite side of the room, which support a 48khz signal. No problems.
Kęstutis S.
This replaced an IfI iPower 9V for my SOTM-200-Neo streamer. First of all - the make is solid and robust and gives an impression of reliability and safety. Secondly, the sound seems to have improved - the space enhanced, the bass more controlled, and the highs unvealed. Will buy a 12V version for my DAC when the finances allow :).
Kęstutis S.
Patrick R.
Très Prometteur!!
A la sortie du carton on ne peut que constater que c'est un très bel appareil et l'impression d'une écoute trop "contenue" disparait rapidement au bout de 3-4h sous sous tension. Un réel potentiel commence à poindre sur les timbres et la largeur de scène déjà impressionnante.
Sinon pas de frayeur à avoir sur la notice vraiment très très succincte pour la partie Streamer de l'appareil. Ce dernier est vu 15s après démarrage par Roon et HQPlayer. Plutôt "user-friendly" donc mais à confirmer.
Je reposterai un avis d'ici qq jours sur le son et l'utilisation.
Laurent G.
Ont remplacé très avantageusement des câbles argent entre filtre et HP et compressions. Son à la fois plus riche et plus léger, moins crispé.
Erik T.
tube
je reviens sur mon questionnement sur le fonctionnement réel du tube : il fonctionne car il chauffe au bout d'un certain temps. Conclusion : il faut laisser chauffer l'appareil avnat de l'utiliser. La led rouge semble tout à fait inutile...
Erik T.
je modifie mon avis précédent sur le questionnement du fonctionnement réel du tube dans le Dynavox TPR-2. Le tube chauffe et donc est alimenté. Il me faudra encore du temps pour apprécier l'effet sur le son par rapport au tube d'origine mais il semble y avoir une amélioration.
Jean Paul G.
Équilibré
Pour un système secondaire c’était l’occasion d’essayer. Pas cher mais efficace. Connecté à une audiophonic PS24RA et à une Iec tout cuivre … Relié à un distributeur 4 prises audiophonic. Le son du système est plus équilibré, posé, plus dynamique, le côté un peu brouillon de l’ancienne belkin sur les masses orchestrale à disparu.
Sur du Pink Floyd la spacialisation a fait un bon. Le grave mieux tenu. RQP imbatable et ça marche. Surtout que le CD Teac et l’ampli teac (datant des années 1980) ont des câbles prisonniers. Je vais câbler un home studio avec. Pour moi le Résultat est probant. Neutre équilibré, Silence…pour un petit prix.
Mario C.
LT1028 Single OPA DIP8 (Unit) The LT1028 is a single OPA mounted on a DIP8 socket and therefore allows for easy installation. This high-speed operational amplifier offers high accuracy and low noise.
Etonnant
J'ai installé cet AOP sur une application pré phono RIAA MC . D'abord je les ai utilisés dans le premier étage avant le circuit RIAA et là déception, son filigrane mais maigre. Dans le deuxième étage couplés avec des OPA1611A en entrée c'est magnifique et ont détrôné des AOP discrets class A LKS chinois
Sandy G.
BLANKO Station de Soudure Réglable Numérique 48W
La qualité perçue est bonne, reste à voir à l'usage.
Bon fonctionnement constaté.
Sandy G.
ECC83 en "up-grading" sur LINE MAGNETICS 845
en remplacement pour améliorer la qualité de l'étage d'entrée de mon LINE MAGNETICS 845 IA, je suis assez satisfaitE du résultat.
Les paramètres mesurés sur mon montage de contrôle "maison" , sont conformes aux données constructeur. A l'écoute , je perçois une "image" sonore plus large, avec un meilleur placement des instruments dans l'espace. Il y a beaucoup de précision dans les détails, mais le médium n'est pas "surexposé" pour autant. Je suis contentE de mon achat, et mon mari aussi !
ELIGIO C.
Awesome amp. I was curious about class D amplifier. This is perfect in every area. Sound, construction and price. Nothing transistor sounds like at this price.
Eric L.
Un grand son
Capable de restituer avec beaucoup de fidélité la musique, sans vous faire les poches…
Il est associé au Pre-A préamplificateur classe A d’Audiophonics, un mariage qui tient toute ses promesses.
Eric L.
Se complète parfaitement avec l’ampli MPA-S125NC, justesse des timbres et transparence… ce que l’on demande à un bon préamplificateur.
Eric L.
IFI AUDIO UNO USB DAC Headphone Amplifier ES9219MQ 32bit 384kHz DSD256 MQA The iFi Audio Uno is a compact DAC and headphone amplifier that easily and efficiently enhances the sound quality of a standard digital source such as a smartphone, tablet or...
Exceptionnel
Un rapport qualité imbattable ! Musicalité sans aucune mesure avec le tarif.
François B.
Excellent DAC mais...
Je suis d'accord avec les autres avis posté avant le mien. Ce Dac est formidable pour le prix et même dans l'absolu ! J'ai l'impression d'avoir changé tout mon système. Ce que je viens d'écouter avec des CD lus par mon drive ATTOL DR 200 SE SIGNATURE relié en AES/EBU sur le SINGXER dépasse vraiment toutes mes attentes. C 'est une grosse claque que je viens de prendre en pleine figure et j'ai l'impression d'écouter un système vraiment très haut de gamme comme je n'en n'ai que très rarement entendu dans ma vie et je n'exagère pas. Je suis peut-être tombé par hasard sur l'accord parfait entre chacun de mes éléments. Autrement dit, je crois que j'ai eu le nez fin en choisissant ce DAC qui révèle enfin tout le potentiel de mon système. Je trouvais que la lecture de mes vinyles me procurais des résultats d'écoute bien supérieurs à ceux obtenus en lecture numérique avec mon ancien DAC AUDIO GD R2R 2 et je m'aperçois maintenant que c'était justement ce DAC qui était responsable de ce constat. En effet, l'AUDIO GD est très agressif dans le haut médium et dans l'aigü aussi bizarre que cela puisse paraître et ce quelque soit le réglage des jumpers (pas pratique du tout) NOS ou pas NOS. Soi-disant que les DAC R2R procure une restitution plus douces que les autres et bien en ce qui me concerne, c'est complètement faux. Peut-être que cela reste valable pour les DAC haut de gamme équipés de puces PCM 1704 je ne sais pas mais avec le R2R 2 c'est pas du tout ça. Impossible d'écouter quoi que ce soit à un niveau réaliste sans que cela me pète les tympans et que je n'éprouve le besoin de baisser le volume. Avec le SINGXER, c'est tout le contraire. Je mets un CD et j'augmente le volume une première fois, puis une seconde puis une troisième fois et ça le fait vraiment! Je n'en reviens pas moi même ! Inversement, en écoute à faible niveau j'entends des détails qui passaient totalement inaperçu avec l'AUDIO GD. Le son paraît totalement libéré. Les musiciens et les chanteurs me semblent présent dans la pièce, la scène sonore est large et profonde restituant parfaitement l'ambiance de l'endroit dans lequel la musique est jouée. Tout est juste. Les timbres, la dynamique, les extinctions de notes et l'absence de bruit de fond est impressionnante. Enfin bref, vous l'aurez compris, c'est sublime. Peut-être et sûrement que l'on peut obtenir encore quelque chose de meilleurs mais en ce qui me concerne je n'en n'éprouve pas le besoin et je suis comblé par ce que j'obtiens avec ce DAC dans mon système. Cependant, il y a un gros problème. Je n'arrive pas à faire fonctionner le pilote à télécharger recommandé par SINGXER. J'utilise le lecteur FOOBAR 2000 et je n'arrive pas à activer le pilote dans ce lecteur. C'est le pilote intégré dans le DAC qui fonctionne actuellement et qui s'est installé automatiquement lors du branchement du DAC sur mon système. Sur mon PC s'affiche comme sortie : Haut-parleurs (Singxer USB Audio 2.0). J'ai une icône qui est apparue en bas à droite dans la barre des râches avec la lettre T en blanc dans un carré rouge et lorsque je clique dessus la dernière version du pilote s'affiche : v5.50.0 mais me signale par l'écriture en gris clair que le pilote n'est pas actif. la résolution est en 44100 Hz - 24 Bits et les fichiers DSD ne sont pas lus par FOOBAR. La configuration requise pour le DSD est pourtant installée correctement puisque cela fonctionnait avec mon ancien DAC AUDIO GD et le pilote pour l'interface AMANERO. J'ai d'ailleurs supprimé ce pilote et tous ces composants avec Revo uninstal. Je me demande si je ne dois pas désactiver le pilote installé automatiquement. Toujours est-il que j'ai tout essayé ce que j'étais capable de faire pour faire fonctionner ce pilote et je n'y arrive pas. Je suis dégoûté. Pas de tutos en français sur YouTube ni ailleurs et je ne trouve personne qui parle du sujet dans les forums. J'appelle donc à l'aide. Si quelqu'un pouvait m'aider à régler ce gros problème ce serait sympa. Il serait souhaitable que j'entre en contact avec quelqu'un de ma région (Chalon Sur Saône) pour éventuellement travailler sur mon PC car ce n'est pas du tout évident de régler le problème par mail ou même par téléphone sauf si quelqu'un me guide en direct. Je ne sais pas si c'est le bon endroit pour demander de l'aide mais tant pis je tente le coup. Merci à celui ou celle qui pourra me venir en aide. Voici mes coordonnées : 06 46 38 44 06. fpawhite@laposte.net
François B.
Je suis d'accord avec les autres avis posté avant le mien. Ce Dac est formidable pour le prix et même dans l'absolu ! J'ai l'impression d'avoir changé tout mon système. Ce que je viens d'écouter avec des CD lus par mon drive ATTOL DR 200 SE SIGNATURE relié en AES/EBU sur le SINGXER dépasse vraiment toutes mes attentes. C 'est une grosse claque que je viens de prendre en pleine figure et j'ai l'impression d'écouter un système vraiment très haut de gamme comme je n'en n'ai que très rarement entendu dans ma vie et je n'exagère pas. Je suis peut-être tombé par hasard sur l'accord parfait entre chacun de mes éléments. Autrement dit, je crois que j'ai eu le nez fin en choisissant ce DAC qui révèle enfin tout le potentiel de mon système. Je trouvais que la lecture de mes vinyles me procurais des résultats d'écoute bien supérieurs à ceux obtenus en lecture numérique avec mon ancien DAC AUDIO GD R2R 2 et je m'aperçois maintenant que c'était justement ce DAC qui était responsable de ce constat. En effet, l'AUDIO GD est très agressif dans le haut médium et dans l'aigü aussi bizarre que cela puisse paraître et ce quelque soit le réglage des jumpers (pas pratique du tout) NOS ou pas NOS. Soi-disant que les DAC R2R procure une restitution plus douces que les autres et bien en ce qui me concerne, c'est complètement faux. Peut-être que cela reste valable pour les DAC haut de gamme équipés de puces PCM 1704 je ne sais pas mais avec le R2R 2 c'est pas du tout ça. Impossible d'écouter quoi que ce soit à un niveau réaliste sans que cela me pète les tympans et que je n'éprouve le besoin de baisser le volume. Avec le SINGXER, c'est tout le contraire. Je mets un CD et j'augmente le volume une première fois, puis une seconde puis une troisième fois et ça le fait vraiment! Je n'en reviens pas moi même ! Inversement, en écoute à faible niveau j'entends des détails qui passaient totalement inaperçu avec l'AUDIO GD. Le son paraît totalement libéré. Les musiciens et les chanteurs me semblent présent dans la pièce, la scène sonore est large et profonde restituant parfaitement l'ambiance de l'endroit dans lequel la musique est jouée. Tout est juste. Les timbres, la dynamique, les extinctions de notes et l'absence de bruit de fond est impressionnante. Enfin bref, vous l'aurez compris, c'est sublime. Peut-être et sûrement que l'on peut obtenir encore quelque chose de meilleurs mais en ce qui me concerne je n'en n'éprouve pas le besoin et je suis comblé par ce que j'obtiens avec ce DAC dans mon système. Cependant, il y a un gros problème. Je n'arrive pas à faire fonctionner le pilote à télécharger recommandé par SINGXER. J'utilise le lecteur FOOBAR 2000 et je n'arrive pas à activer le pilote dans ce lecteur. C'est le pilote intégré dans le DAC qui fonctionne actuellement et qui s'est installé automatiquement lors du branchement du DAC sur mon système. Sur mon PC s'affiche comme sortie : Haut-parleurs (Singxer USB Audio 2.0). J'ai une icône qui est apparue en bas à droite dans la barre des tâches avec la lettre T en blanc dans un carré rouge et lorsque je clique dessus la dernière version du pilote s'affiche : v5.50.0 mais me signale par l'écriture en gris clair que le pilote n'est pas actif. la résolution est en 44100 Hz - 24 Bits et les fichiers DSD ne sont pas lus par FOOBAR. La configuration requise pour le DSD est pourtant installée correctement puisque cela fonctionnait avec mon ancien DAC AUDIO GD et le pilote pour l'interface AMANERO. J'ai d'ailleurs supprimé ce pilote et tous ces composants avec Revo uninstal. Je me demande si je ne dois pas désactiver le pilote installé automatiquement. Toujours est-il que j'ai tout essayé ce que j'étais capable de faire pour faire fonctionner ce pilote et je n'y arrive pas. Je suis dégoûté. Pas de tutos en français sur YouTube ni ailleurs et je ne trouve personne qui parle du sujet dans les forums. J'appelle donc à l'aide. Si quelqu'un pouvait m'aider à régler ce gros problème ce serait sympa. Il serait souhaitable que j'entre en contact avec quelqu'un de ma région (Chalon Sur Saône) pour éventuellement travailler sur mon PC car ce n'est pas du tout évident de régler le problème par mail ou même par téléphone sauf si quelqu'un me guide en direct. Je ne sais pas si c'est le bon endroit pour demander de l'aide mais tant pis je tente le coup. Merci à celui ou celle qui pourra me venir en aide. Voici mes coordonnées : 06 46 38 44 06. fpawhite@laposte.net
Michel P.
Très bel article pour le prix
Bouton en alu massif et vis de serrage, très beau produit à ce prix ! Et franchement pourrir les avis parce qu'il fait 32mm au lieu des 33 précédemment annoncés c'est carrément pathologique! Tout l'art de la conception c'est un minimum de souplesse face à l'imprévu.
JOSE DIEGO A.
Surpris par son son.
Ce fut une expérience agréable d'acheter sur audiophonics.fr pour la première fois. Mon avis dessus SMSL SU-9PRO Mon avis c'est un bon rapport qualité prix je l'ai connecté au Reavon UBR-X200 qu'il contient avec un DAC très musical comme le Burr-Brown PCM1690 de Texas Instruments,j'ai un autre DAC le Cambridge Audio DacMagic 200M connecté à d'autres lecteurs et aussi au Reavon,après presque trois semaines d'écoute branché avec de bons câbles d'alimentation, le SMSL SU-9 PRO ne colore pas le son, ayant une excellent dynamique, n'étant pas un DAC symétrique ou haut de gamme, il répond bien à toutes les fréquences, je vous conseille de l'acheter.
Erik T.
mis sur Dynavox TPR-2
Comme d'habitude, commande facile, livraison très rapide et super emballage pour ce produit fragile. Après, je me pose la question de la mise en fonction réelle de ce tube sur le préampli car aucune incandescence des filaments visible y compris après période de chauffe. (et une belle led rouge derrière la lampe mais n'en démontre pas le fonctionnement réel)
Erik T.
tube en fonction ?
Je suis satisfait du produit qui me permet d'écouter des vinyles sur une Denon DP-1200. J'ai changé le tube suite aux conseils d'autres acheteurs. Par contre j'ai une vraie question sur le fonctionnement de ce tube : on voit bien bien sûr la led rouge derrière le tube, mais si ce dernier est en fonction, ne doit-on pas voir les filaments en chauffe ? (une certaine incandescence ?). Or on ne voit rien de la sorte, les filaments restent gris. Je ne veux pas tester la température de la lampe avec la machine sous tension... Alors : tube en fonction ou tube déco ? (ce serait alors un comble de le changer...). Pourtant toutes les critiques sont élogieuses et de nombreux tweaks existent en Allemagne...
Serge V.
Pas de peine c'est du Jantzen !
Très bon produit. La fente permet d’absorber les vibrations et réduit les risques de desserrage. Bien sûr il faut serrer les vis selon les normes mécaniques pour ne pas risquer de déformations, le but n’étant pas d’incruster le câble dans le métal mais de le solidariser avec la fiche en assurant un très bon contact avec le câble, les borniers des HP et des Amplis. Jantzen audio est une société qui propose d’excellents produits, parmi les meilleurs condensateurs pour filtres passifs entre autres. Ses ingénieurs ne sont pas des débutants en la matière. Ils ont intérêt à ce que leurs produits restent dans le haut de gamme tout comme leurs condensateurs Superior Z-Cap ou Alumen Z-Cap ou leurs bobines à ruban ciré. Très satisfait de leur qualité, je recommande ces fiches bananes.
Istvan N.
Decent input switching device
The device itself is a very solidly built unit.
Giving only 4 stars because the following:
- the colored cable which connects the rotary switcher to the board has the tendency to break pretty easily. Some heat-shrink tubing would be nice over the connection points.
- for the voltage regulator maybe use an LDO type (eg. KA78R05) or similar for better efficiency (less heat generated)
Istvan N.
Good speaker protection module
The module in general is OK, it does it's job as advertised.
However:
- make absolutely sure that the connected AC supply, when rectified and filtered provides at least 12V DC, otherwise the relays won't click. I've used a 9V AC transformer, and it was not sufficient.
- I had changed the filtering capacitor to a 25V unit. The provided 16V cap was very much on the edge from my point of view, and it would not live for very much long time, if run at the limit.
Istvan N.
Steel Shielding Cover for Toroidal Transformer 140x64mm This black steel cover allows you to hide a toroidal transformer while acting as shielding to considerably reduce harmful EMI disturbances. The internal dimensions of this cover...
Very nice cover
A very nice, massive cover for the toroidal transformer. It is powder coated.
pascal P.
OCTAVIO STREAM Streamer Bit-Perfect WiFi AirPlay 2 Bluetooth 24bit 192kHz Octavio offers with the Stream an improved version of its first streamer model. Extremely easy to use, it is designed to modernize an existing HiFi system by transforming it...
Correct
Il fait le job mais pas mieux que mon PC pour lire Qobuz. Pas d'entrée USB pour lire un disque dur ce qui oblige à lire sa bibliothèque via le Wifi, ce que toutes les configurations ne permettent pas. Pilotage via Android correct mais peut mieux faire.
Philippe V.
Encore plus satisfait
J'ai commandé le Mogami 2972 afin d'alimenter la section médium aigüe de mes en enceintes (fils reliés 2 par 2) en complément du w3103 pour les basses. Le resultat a été immédiatement très convainquant (en comparaison du w3103 seul) et qui s'améliorera probablement encore légèrement dans les jours à venir. Je suis vraiment très content d'avoir découvert le câble Mogami. La livraison en point relais en 24H. et très bien emballé. Audiophonics est toujours au top.
Robert K.
Quality product
I am very satisfied with the purchase. The module arrived fast,undamaged - well packaged (wrapped in cardboard and taped, wrapped in protective paper and placed in a larger cardboard box and taped again - excellent).
I am also surprised by the thorough and clean production, where quality components were used (among others Japanese ELNA-RC2, Panasonic-FC and Korean Lelon 105° capacitors).
I haven't tested the product yet, because I'm still waiting for the remaining components, but from what I've seen, I can report that I'm satisfied with the decision for Audiophonics. Greetings from Slovenia.
olivier C.
Vraiment surpris...
Je reçois le produit tard, pour n'embêter personne à debrancher la chaine hifi, je branche la Vilborg sur mon ampli à lampe Bogner, et la......grosse claque, plus de parasites, tout est limpide, plaisante à l'oreille, demain je teste sur la hifi et j'espère reprendre une claque....à suivre....
Delacour j.
Finition très propre.
Utilisée pour recouvrir une tresse de blindage sur le câble secteur d'un téléviseur.
Delacour j.
Pratique.
Utilisée pour finaliser le blindage d'un câble secteur.
Delacour j.
Conforme à la description.
Utilisée pour fabriquer un blindage sur un câble d'alimentation secteur d'un téléviseur.
Delacour j.
Un bon produit.
Solide, massif...très pratique pour serrer les câbles dénudés et quant dispositif de serrage de la gaine, il est exemplaire...
Anne b.
fourche cuivre plaqué or
fourche cuivre de tres bonne qualité utilisé sur ampli tuner technics on peu meme utlilisé les fiches bananes vraiment bien merci audiophonics
Un très bon rapport qualité prix ..résistance précise et transparente ..
Yves G.
Bon rapport Qualité/prix.
Simple et de qualité.
Montage connecteur Schuko Type E/F 250V 16A Ø8mm Noir à 2€.
Avec du câble OLFLEX 110CY 3x1,5mm² et un connecteur IEC C13 à 3€. Pour remplacer les fiches d'origines (en 0,75mm²) de mes deux amplis (Denon DRA800H et Cambridge CXA80) Fonctionne parfaitement.
Première commande depuis la Belgique et pas la dernière.
Yves G.
Bonne fiche et bon rapport Qualité/prix.
Yves G.
Bonne prise bon rapport Qualité/prix.
