Luca C.
Panos M.
Its more my personal taste
Ludovic P.
Customers reviews - There are 19585 reviews.
mathieu s.
Perfection
Branché à une box en optique pour émettre le son à un casque Bluetooth JBL, la qualité est vraiment APTX HD avec plus de 10m d'émissions
Joris V.
gamechanger
As being a sound engineer and an audio enthusiast I was a bit scared when I placed the order and switching from DENON POA 6600A monoblocs to D-amps. I read a lot about them and made my research. Spent hours and hours reading and analysing data. Finally decided to go for the audiophonics MPA-M400ET set. Had to wait for a month, but what the heck. The audiophonics team gave me al the updates in this time and finally received my amps. Installed them and after an evening listening, I was so enthusiastic. It was like a totally new experience. My counterpoint tube preamp and my speakers, a DIY focal Utopia., who are hard to handle at 1,2 Ohm. They sounded so different, so clean, so spatial, it was like they were not there anymore. They disappeared in front of me. I listen to all kinds of music. I know quiet a few songs that are hard to handle for any combination of speaker/amps. And on a pretty fair volume the amps made it smooth listening. This is the amp for me that will always stay in my collection.
Thanks for the good service, the proper build and the switch to D-amps
Rémi D.
Etonnant
Etonnant je n'ai pas d'autre terme voilà un petit Préampli qui a tout d'un grand il remplace dans ma configuration un préampli qui coute 10 fois plus. Il est associé à un ampli de puissance en classe A de 2 fois 20 watts, musicalement il me plait beaucoup mais comment font-ils a ce prix !!! Un reproche les LED rouges derrière les tubes totalement inutiles voire gênantes comme celle du power (- 1 étoile). C'est dommage. Maintenant j'attends pour la fiabilité.
ADRIAN EMIL T.
Review CD-Payer Shanling EC3
The parcel arrived in good condition.
The CD player was in its original packaging and factory sealed.
It is a good product that is worth buying.
Pros: very good sound; compact size and well build; good-looking; top-loading mechanism wich, from my experience, is more reliable than tray-loading mechanism; the transparent cover is made from glass, not plastic; you can play usb memory sticks up to 2 TB, through Eddict Player app; remote control; with volume of the cd-player you can control the level of the signal of the RCA output so that active speakers can be connected (not available for digital outputs).
Cons: only 1 year warranty; the user manuals are too brief (eg: it is not specified that the volume of the cd-player must be set to 100 when you connect the amplifier to the RCA output of the cd-player, because otherwise the output signal is too low and cannot be heard in the amplifier. Therefore, I thought the cd-player was faulty.); the USB connector is mounted upside down, so the USB stick is upside down; Edict Player app sometimes crashes; the remote control has a small operating angle; you can`t play music from computer; no Wi-Fi.
ADRIAN EMIL T.
CD-player Shanling EC 3 review
ADRIAN EMIL T.
Cable review
Good quality cable.
ADRIAN EMIL T.
Cable review
Good cable, good quality
Emmanuel S.
TONEWINNER ETM-2 Omnidirectional Measurement Microphone for Home Theater Calibration The Tonewinner ETM-2 measuring microphone is designed to allow you, in association with certain Tonewinner home theater equipment, to automatically correct the acoustics of your...
Fait son taff...
...mais le jack n est pas du 6.35 comme indiqué dans la description technique mais du 3.5...comme sur les photos. Fonctionne aussi avec un AD-7200HD si l on a un adaptateur jack 3.5/6.35 .
Sinon article expédié rapiidement en emballages cartons bien calé par du papier. Merci Audiophonics
Slav A.
Excellent cable, true tonal balance, good separation and darkness.
Slav A.
One of the must have cable.
Eric L.
Élément trop négligé
Ce LPSU25 alimente mon dac smsl sanskrit mkll et mon lecteur réseau nuprime omnia, résultat une meilleure définition, de tout le spectre ….
Merci à Audiophonics de nous proposer de tel matériel ☺️ à ce tarif.
Eric L.
Révélateur de potentiel
Je suis tellement conquis par la qualité du produit que j’ai commandé un deuxième pour la liaison pré ampli /ampli, le premier relis mon dac au pré ampli, tout semble plus naturelle, transparence et neutralité, la dynamique es t top…
Frank G.
ELFIDELITY AXF-106 Molex / SATA Computer Power Filter This Elfidelity AXF-106 module to be integrated into a computer is a real power filter that will allow the elements of your computer system to enjoy a clean electrical signal,...
Installed in the Roon Rock server between the PicoPsu power supply and the two SSD hard disks (250GB RoonCore and 4 TB music data storage). In my system, audibly more calm and balance.
Grégory O.
Bonjour, il s’agit d’un bon module d’alimentation. Un grand intérêt pour la possibilité de réglage du courant de sortie selon le besoin à l’usage. Un grand remerciement au SAV pour les échanges techniques. Cordialement,
eric l.
DD TC35C DAC AL5686 Male USB-C to Female Jack 3.5mm 32bit 384kHz This TC35C DD adapter for smartphone is composed of a male USB-C connector and a female 3.5mm jack. It also includes a Realtek AL5686 DAC for efficient conversion of...
pour le prix le son est tres bon tres ample et ne craque pas à fort volume et reconnu toute suite par mon smartphonr (samsung s9+).
eric l.
IKKO LOT Adapter DAC Male USB-C to Female Jack 3.5mm 16bit 48kHz This Ikko Lot adapter and DAC has a male USB-C connector and a female 3.5mm jack. It is ideal for connecting headphones to a smartphone that does not have a 3.5mm jack audio...
tres bon
fonctionne parfaitement ,le son est puissant et net
Steffen K.
TINYSINE AUDIO-B PLUS Bluetooth 4.2 Receiver Module aptX SMA If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver module is an excellent choice. It...
Is working fine, but not the advertised chip
The module seems to work fine, but the description is not correct. It says it has the CSRA64215 Bluetooth 4.2 chip, and the one I received had the QCC3008 Bluetooth 5.0 chip on it.
Mark H.
Mr h
Not really worth the message money with a pi would of been more acceptable there are better units out there
Davorin V.
Everything working as it should and board have output to switch ON or OFF some aditional board with relay on it - of course with remote controll :) Very usable. Motor works very slow but fast enough for me. With on Board LED Diode we see when you press ON/OFF Button on remote power is ON - LED IS SHINING and when you Controll Volume up or down LED IS BLINKING. Very satisfied ... Bravo
Davorin V.
AIYIMA T8 Tube Preamplifier 6N3 Headphone Amplifier MAX9722 DAC ES9018K2M Bluetooth 5.0 24bit 96kHz With the T8, Aiyima offers a versatile device that is a tube preamplifier, headphone amplifier and DAC at a very affordable price. Its preamplifier stage uses a 6N3 tube, which...
Sound and functionality very good fast delivery and good packed
Davorin V.
Aiyima A08 Pro
Very good sound and look. Very good packed and fast delivery.
1877PHONO EVANJEL MK2 3.5-RCA Jack 3.5mm to RCA Modulation Cable 1.5m A remarkable evolution of its predecessor, the EVANJEL MK2 distinguishes itself by a choice of high quality materials and particularly meticulous finishes.
bon rqp
Restitution équilibrée transparente et homogène , plus naturel et épanoui que le oyaide du même type vendu sur ce même site . Tout dépend ensuite de votre source .
Utilisé sur la sortie casque avec un câble phono evanjel ( mini jack vers rca ) connecté à un ampli smsl ( enceintes 3 voies bc acoustique niger ) . Son transparent sans agressivité , on distingue la scène sonore qui respecte les divers plan de positionnement des musiciens et chanteurs , son naturel . Etonnant vu le prix .
Tomas H.
Great!
Easy to work with
Looks nice and feels professionaly made.
The fitment and how it locks in the socket is fantastic! No movement what so ever!
Great for large diametres of cable. I paired it up with Mogami W3104 - easy peasy!
If aluminum body is the best?
Well I suppose that´s up to how you like your system to sound.
This cable worked really great in my system and beat the crap out of a 30 times as expensive cable.
It´s not allways the price - it´s the performance...
Frederic H.
Très bien !
Une excellente alternative au Sommer Orbit 225 , plus vif et tout aussi bon sur les autres registres
En plus le prix est canon
Janne P.
VIABLUE UFO Vibration Absorbers Ø35mm Black (Set x4) Viablue UFO absorbers can be used to dampen harmful vibrations by placing themselves under your speakers or HiFi devices. Due to their optimal pressure on the lower surfaces of...
Works as it should
Neat, goodlooking feet that does it job. And price is not bad for quality.
Alain S.
Excellent couteau suisse de streaming
Moins cher que la concurrence et offrant nettement plus de possibilités (Chromecast, entrées analogiques, trigger, connecteur RJ45 etc ...)
Il est aussi nettement meilleur ...
Il m'arrive aussi d'utiliser l'Airplay ... le commentaire de "Jakub M" sur le sujet est incompréhensible ... mais les clients de la pomme ne sont pas vraiment des techniciens ...
Frédéric B.
Rapport Q/P excellent
De nombreuses revues et mesures existent sur le net. En résumé l'interface est géniale et le DAC mauvais selon ces avis. Pour ma part, je trouve l'interface en effet très pratique (ancien propriétaire d'un Lindemann DSD25) et le DAC tout à fait correct! C'est un peu "sec" mais avec une bonne séparation des instruments et des voix. Pour le prix, allez-y !
Amplifier Board Mono Class D TPA3255 1x 140W 4 Ohm This mono amplification module uses a TPA3255 amplification chip, allowing it to develop a substantial power of 1x250W under 4Ω (1% THD + N) while taking advantage of the...
Ampli de qualité
Très bon rapport qualité prix pour cet ampli qui peut fonctionner en large bande ou pour alimenter un caisson de grave. Le son est excellent, musical , aucun souffle. Il est utilisé dans une ancienne radio de 30 litres avec un HP de 93db et un tweeter, le niveau sonore atteint est plutôt élevé.
Laurent z.
Une des meilleures toutes marques confondues
Ça faisait un moment que je voulais essayer ce câble mais je ne suis plus aussi habile qu’avant pour des câbles aussi technique à monter. Et au miracle pour moi quand j’ai vu qu’audiophonics le proposait et je ne regrette rien. Ce câble est magnifiquement bien monté, les fiches XLR sont superbe, quand au son, c’est un mélange avec un parfait dosage entre transparence,définition, dynamique, aération et douceur. J’ai une dizaine de câbles ( ayant plusieurs enceintes et amplis) : siltech wireworld phono cardas furutech et j en passe , bref que des modèles reconnus, et bien ce neotech est celui qui a le plus de qualité rassemblées dans le même câble. Ce n’est pas pour faire de la lèche mais il n’y a que chez audiophonics qu’on peut trouver ce genre de pépite à ce tarif là . N’hésitez pas même sur un système HDG ( pour moi un ampli MBL qui ne pardonne rien) Encore merci de l’avoir proposé déjà monté….bluffant !!!
AUDIO-GD DI-20HE Digital Interface Amanero Accusilicon 32Bit / 384kHz The Audio-GD DI-20HE interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98M clocks. The circuit is designed to offer a plethora of options...
Excellent.
Commande passée le 21 février et reçue le 24.
Le DI20HE est exceptionnel. En USB en sortie d'un Roon Core.
Il sort en I2S sur un R27HE.
Pas encore rodé, mais déjà très bon. Les silences sont plus profonds, le scène sonore plus définie et un poil de matière en plus.
Dans ma configuration, c'est juste parfait. Si le rodage améliore encore le rendu, alors jusqu'où ça peu encore s'améliorer ?
Je ferais un autre compte rendu plus tard. Pour l'instant, j'écoute...
Jean-Pierre B.
TOPPING A30 PRO Headphone Amplifier NFCA Black The Topping A30 Pro is a high quality NFCA headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a...
Véritable 'pépite'...
Ce 'petit' Ampli-Casques est tout simplement sensationnel !
En effet, pour son prix modeste, et en dessous des 800 à 1000 eur, impossible de trouver un ampli capable de 'pousser' mon AKG 340 qui est monstrueusement gourmant en puissance avec ses 2 x 400 Ohms !
Non seulement il arrive à bien 'driver' l'ogre 340 mais en plus la qualité sonore est au Rendez-Vous ! (DAC à 2700 eur en amont tout de même !).
Donc, avec une bonne source vous aurez un grand plaisir d'écoute de TOUS types de casques (3 niveaux de gain) pour un budget abordable. Merci AUDIOPHONICS pour vos produits 'miracles' abordables.
Gyorgy H.
Déçu
J'ai voulu tenter de remplacer les JJecc83s sur mon ampli à lampes Synthesis. Après une dizaine d'heures de rodage les PsVane ne tiennent pas la comparaison. Manque de basses et de dynamique. Ça ne percutte pas. De même la richesse sonore souvent évoquée tourne plutôt au brouillon sur mon système : Dac Pegasus, enceintes tqwt Supravox. J'ai remis les Jj.
Gregory G.
VIBORG BP-604 (G) Binding Post Silver / Gold Plated 24K 5µ Pure Copper Ø4.5mm (Set x4) The BP-604 (G) from Viborg are excellent terminal blocks, ideal for high quality DIY mounting. Indeed, they integrate a pure copper conductor in order to offer an optimal...
Borniers Viborg
Je suis trés satisfait de mon achat. Ces borniers sont de trés bonne qualité, bien meilleurs que mes borniers dorigine triangle antal Ez. Serrage puissant, ouverture du son grâce à la bonne qualité des connecteurs. N'utilisant pas la double amplification ou le double câblage j'ai supprimé les borniers graves et réuni le cablage interne grave et aigu sur les borniers viborg avec les vis de serrage.
Moins de connections = moins de pertes, amélioration du son incontestable dans mon cas.
Serrage du câble sommercable sc-dual blue directement dans le bornier, il est parfaitement bloqué.
Miroslav T.
High level line level audio transformer
I tried to form a low level signal to power subwoofer crossover, but this dvice introduced strong hum and brum and was not useable at all. I guess it should be shieldes somehow as hum changed when I move a transformer but never dissapear.
Guillaume B.
TOPPING L30 II NFCA Headphone Amplifier Preamplifier Silver Topping unveils its L30 II, evolution of the very good L30 headphone amplifier and preamplifier. This new version is based on the architecture of the first model, while bringing...
Parfait sauf...
Arrivé rapidement et très bien emballé. Fonctionne parfaitement, et facile d'utilisation. Je suis malheureusement déçu par le bloc d'alimentation, qui fait 9cm de long par 5cm de large par 6cm de haut... Énorme et consomme aussi énormément pour une sortie 15v 1a, il consomme 6w au repos et je n'ai pas pu tester sa conso en charge. Pour comparaison mon chargeur téléphone consomme moins d'1w au repos et 3w en charge en sortie 15v 3a...
En fonctionnement l'ampli chauffe légèrement (normal pour un classeA) mais même après des heures d'utilisation, il est juste tiède au touché.
Et enfin le son ! Extrêmement propre, hyper réactif, puissant, pourrais sûrement détruire mon casque et pousse facilement aux maximum mes haut-parleurs, sans distorsion !
Guillaume B.
Parfait sauf...
Est arrivé très vite, bien emballé (mais il n'y avait plus le plastique de protection ?), Fonctionne parfaitement, facile d'utilisation même si j'aurais aimé pouvoir changer le volume autrement qu'avec la télécommande IR. Et il y a aussi l'histoire toirevdes filtre... Aucunes explications et impossible de les désactiver. Sinon le son est sublime, presque impossible d'entendre du bruit.
Eric E.
SMSL SU-6 DAC ES9038Q2M XMOS Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 Silver SMSL offers with the SU-6 a powerful and affordable DAC, benefiting from a careful design guaranteeing an accurate sound reproduction.
Bien, bien. Et bien.
J'ai deux Sanskrit mk2, fiables et sans failles, qui m'ont donné une belle confiance en la marque SMSL. Je viens d'acquérir le SU-6 et c'est encore mieux. Logique, je vais continuer à monter en gamme avec SMSL.
C'est hors-sujet mais je l'écris quand même : il y a eu un grand boum de la reproduction sonore autour des années 80, nous traversons un nouvel âge d'or. Vraiment.
Eric E.
Longueur...
Le câble fait en réalité un 1,2 mètre. Du coup je ne peux rien en faire. Mais c'est pas grave puisque le SAV Audiophonics est nickel.
Christophe M.
ben mazette
Reçu en cadeau en remplacement d'un Chromecast audio, en v'la une belle surprise. Facile d'installation, fonctionne parfaitement avec Qobuz en 192 et en plus est gapless, que demander de plus? Branché en optique sur un Rega Mydac, je n'arrive pas a aller me coucher tant je me fais plaisir à petit prix
Vincent D.
DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4...
Good subwoofer
I build it in a closed box with the recommended box size. The sub cut off is 120 hz in my setup. The bass is good and tight. The metal that holds the wire terminals bends easy. So support it when pushing in the terminals.
Vincent D.
DAYTON AUDIO DC28FT-8 Speaker Driver Dome Tweeter Silk 50W 8 Ohm 89dB 1300Hz - 20kHz Ø2.8cm This 28mm silk dome tweeter is strongly inspired by the prestigious Nordic solutions and provides a silky, pleasant sound and high capacity for detail. With a straight-line...
Very good cheap tweeter
Good tweeter for the money. The tweeter sounds nice and clear. 4 stars because the tweeter membrane is covered in some sticky stuff which dust will stick to. A dust cover is a must for this tweeter!
Vincent D.
Good quality
Good quality stands.
Guillaume B.
Bon streamer, fait ce que je lui demande à savoir lire ma bibliothèque musicale stockée sur HDD connecté à ma box. Raccordé en toslink à un DAC le son est pas mal mais pourrait être mieux. Vais devoir investir dans un câble optique de meilleure qualité que celui livré avec le Wiim et je verrai bien...
Patrick R.
Extra
Ce DAC qui embarque à la fois un streamer (utilisé dans mon cas avec Roon et/ou HQPlayer) est absolument fabuleux en terme de précision transparence et détails. La scène sonore est vaste. Il se dégage un certain naturel dans la restitution. Je pense que du fait de toutes ces qualités, il faut prendre soin à ce qu'on met pour accompagner cet appareil.
Le grave est massif ou autoritaire selon l'appréciation ou son système, mais très bien controlé toutefois.
Le fait de pouvoir se passer d'un streamer est vraiment très appréciable. Je pense qu'il doit falloir investir beaucoup pour aller plus loin que le streamer intégré.
Des petits moins qui sont à signaler et peuvent concerner certains:
- En mode LAN (streamer), l'UPnP présente semble t'il avec la dernière version du firmware (v1.4) des petits problèmes. Ce sera surement corrigé mais pas d'info claire de Gustard encore à ce jour.
- La documentation très très légère.
En comparaison avec un Tefnout de hifi câbles déjà très bon dans sa game de prix le viablue montre beaucoup plus de profondeur et de souplesse. C'est très défini mais sans côté insistant dans l'aigu du Tefnout. Pour finir les basses sont bien plus pleines et donnent beaucoup d'ampleur a la restitution. Je confirme les commentaires avec Patricia barber c'est somptueux.
fais le job
Restitution neutre et fidèle ; vu le prix aucune contestation possible .
4 étoiles
Ses points forts : un punch et une énergie accompagnés d' un suivi rythmique qui procure une écoute enjouée . Une scène sonore qui s'élargit laissant place aux musiciens . J'ai était obligé d'orienter mes panneaux magnepan MG 1.7 de façon moins concentré vers le point d'écoute .
Ses points faibles : La qualité du médium notamment sur l'entrée analogique rca est limitée ( à tendance à miauler légèrement) . On retrouve ce phénomène en Bluetooth et optique mais de façon moindre . Défaut acceptable vu le prix .
Conclusion : Ecoute un peu typée mais pas caricatural ; idéal pour une chaine secondaire . Toutefois je préfère dans la même catégorie de prix SMSL en vente sur ce même site plus fidèle musicalement mais plus sage dans sa restitution .
Bruno C.
EVERSOLO DAC-Z6 DAC 2x ES9068 XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA The EverSolo DAC-Z6 is a powerful DAC based on a neat technical structure. It embeds high-end components with notably two ESS ES9068AS digital/analog conversion chips and a XMOS...
PRELIMINAIRES
On va faire monter la température en douceur!
Le premier contact avec le produit est très positif et surprenant.
La présentation du conditionnement est vraiment premium.
Ok, rien à voir avec les qualités musicales du produit mais un constructeur qui pousse la présentation et l'emballage de son produit à ce niveau ne peut pas prendre le risque de livrer une "bouse" au final.
De toute façon l'impression positive initiale concernant l'emballage se poursuit avec la prise en main du produit.
Assemblage, matériaux utilisés, la qualité perçue est vraiment d'un très bon niveau.
Et le son dans tout çà? J'avais bien dit que c'était des préliminaires. Juste 3 heures d'écoute qui se finissent l'air un peu bête avec un large sourire sur les lèvres, la tête encore dans un nuage musical dont l'espace sonore a augmenté de volume en re définissant la localisation spatiale des différents interprètes. De la matière, de l'épaisseur mais avec beaucoup d'air entre les notes pas cet effet maigrelet et éthéré qu'on entend malheureusement trop souvent. Combien d'entre nous ,pourtant satisfaits de notre système, reconnaissent devoir pousser le volume pour avoir cette sensation de corps, de matière, d'épaisseur. Avec le Z6 c'est bien la première fois que toute ces qualités se retrouvent dès les premiers db. Et si l'envie vous prend de pousser le volume pas de crainte de tassement ni d'agressivité ou de fatigue.
Très belle excursion du registre grave à la fois tendu et nuancé et montée des aigus sans crispation et semblant monter très haut. Le médium sonne vrai et place les interprètes quasi dans votre pièces sans faire trop d'effort. Au final une belle exploration de la bande passante assez linéaire et neutre mais pas sans émotion ni musicalité.
Pour le moment ce qui m'embête le plus avec le Z6 c'est que j'avais l'intention de changer l'ampli mais il m'a enlevé cette envie en me donnant ce que j'attendais de mon système.
Adieu nouvel ampli mais bienvenue à la musique.
Merci Z6 et à Audiophonics qui comme d'habitude par leurs conseils et disponibilité ont fait mouche.
Je conclurai en rappelant que Le Z6 coute moins de 500€ et que tout jugement comporte une part de subjectivité.
Si vous avez compris ça alors oui produit hautement recommandé.
Salutations à toutes et tous.
Wissem B.
Topping g5
Excellent ampli dac. Peut conduire les intras les plus sensibles tout un casque du calibre du Sennheiser hd800s. Fonctionne mieux avec des intras full armatures équilibrées, ou à base de driver dynamique comme mes unique melody 3dt (triple DD)
