ETI Bulletplug Special RCA Tellurium Copper Ø9.2mm (Set x4)
Reference : 6778
89,50 €tax incl.
74,58 € tax excl.
The ETI Bulletplug® RCA connectors offer unlike most of their competitors, even those marketed as high-end significantly increased conductivity.
The vast majority of RCA connectors are made from nickel, gilded brass or bronze / phosphorus alloys with a conductivity typically less than 28% IACS (International Annealed Copper Standard). By way of comparison, the high purity copper used in the vast majority of interconnecting cables has a conductivity rating of 100% IACS. Due to this low conductivity and the use of three disparate metals, the majority of standard RCAs, even expensive tend to decrease the performance of the components to which they connect.
The approachof ETI is radically different, the contact elements are machined in high-purity Copper Telurium (more than 90% IACS) or pure silver (106% IACS) so as to ensure maximum conductivity to 320%).
The contact point at one point of the mass also avoids eddy currents (href = "http://en.wikipedia.org/wiki/Eddy_current" target = "_ blank">Eddy Current).
Features:/ P>
  • Packing: 2 pairs
  • Contact Material: Copper Tellurium
  • 24 k gold plating directly applied to copper (no nickel, bronze or brass)
  • Connector Body Material: Aluminum
  • diammaximum acceptable cable length: 9.25 mm ( Reducers available separately )
  • Overall length: 37.5 mm
PDF Manufacturer
https://www.audiophonics.fr/images2/6776/6776_ETIBULLETPLUGCLASSIC_2.jpg
Detail of contact elements
[Img-10597-left-thickbox_default]
[Img-10598-left-thickbox_default]
Max cable diameter (mm)9.0
Mounting typeTo weld
ConnecticMale
