PANGEA RECORD DOCTOR VI Vinyl Cleaning Machine Black
The Pangea Record Doctor VI is the ideal tool to effectively clean your vinyl records to preserve them and promote better sound reproduction. The cleaning fluid is applied evenly to the surface of the record with a high quality nylon brush.
By buying this product you get 32 loyalty points
Reference : 15883
329,00 €tax incl.
274,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Pangea Record Doctor VI Machine de nettoyage pour vinyle
The Pangea Record Doctor VI is the ideal tool to effectively clean your vinyl records to preserve them and promote better sound reproduction. The cleaning fluid is applied evenly to the surface of the record with a high quality nylon brush. The easy-to-handle rotating nozzle protects the record label from moisture at the same time. After application, you can easily remove the dirt with the integrated vacuum function.
Technical specifications
Product typeVinyl cleaning machine
Dimensions315 x 178 x 220mm
Weight~ 4.5kg
ColorGloss black
Package1x Cleaning fluid
1x Nylon brush
1x Power cable 1.8m
1x PANGEA RECORD DOCTOR VI
The Pangea Record Doctor VI is the ideal tool to effectively clean your vinyl records to preserve them and promote better sound reproduction. The...
