50cm long pre-cut cable
Refurbished product - Grade S
Cable offcut with a length of 50cm
This OYAIDE Black Mamba V2 cable, sold by the meter, is the ideal cable for designing high-quality power cables. In fact, it's made from top-of-the-range materials and features a structure that enhances conductivity. Specially designed for audiophile applications, it features a precision 102SCC copper conductor, as well as an OFC copper drain and ground wire. A layer of polyolefin insulation and a layer of copper foil shielding covered by a halogen-free outer jacket complete the structure. The Black Mamba V2 conductor is made up of 45 wires, each 0.32mm thick and with a cross-section of 3.5mm², offering high-speed signal transmission with a voltage withstand of up to 300V at a maximum of 20A.
| Specifications | |
| Product type | Power cable |
| Conductor material | 102SCC copper |
| Cross section | 3.5mm² |
| Insulation | Polyolefin |
| Shielding | Copper foil |
| External sheath | Halogene free |
| External diameter | Ø11.8mm |
| General | |
| Color | Black |
| Length | 50cm |
| Diameter (mm) | 11.8 |
| Length (m) | 0.5 |
| Number of conductors | 1 |
| Insulation material | PVC |
| Shielding | Yes |
| Section (mm²) | 3.50 |
| Conductors Plating (Cable) | None |
| Refurbished Grade | Grade S |
| Ground / Shielding | Yes |
