Refurbished product - Grade S
New product, never used.
Switching Power Supply 1200W +/-76VDC +/-24VDC +/-15VDC
This Micro Audio SMPS600 switch mode power supply module can develop a power of 1200W. It can take in input a voltage ranging from 100-230VAC, selectable by jumper. The power supply has a main output of +/-76VDC, as well as a +/-15VDC 1.5A regulated output and a +/-24VDC unregulated output. A connector allows to connect a fan or a trigger.
| Specifications | |
| Product type | Switching power supply module |
| Input voltage | 100-230VAC |
| Output voltages | ±76VDC ±15VDC 1.5A regulated ±24VDC |
| Fan connector | Yes |
| External trigger connector | Yes |
| Power | 1200W |
