Refurbished product - Grade B
Impacts and/or scratches on the case.
FDA-8Ω 2x50W 24bit / 192kHz STA326 / AK4113 / CM6642
With its wide range of functionality and highly developed connectivity, the D802C Pro Audio at FX has all the assets to become a sound performance system the keystone.
The D802CPRO said amplifier is a "Full Digital" ie the S / PDIF signal is converted into I2s by AK4113, then directly amplified by a digital audio interface STA326. To do this, it has three digital inputs USB, S / PDIF coaxial and optical Toslink.
This team is also a stereo RCA auxiliary input and a USB audio jack supports OTG. We can connect him an Android smartphone.
Unlike its predecessor, the PRO model embeds a CSRA64215 chip. It is therefore compatible with the latest versions of the Bluetooth protocol and works with the 4.2 standard. Wireless connectivity thus gains in performance and speed.
This standard is also less energy, which means that use with a mobile reader (like eg smartphone) consume less battery while ensuring a stable and accurate digital stream.
The control chip / CM6642 conversion can work with resolutions up to 24 bit / 192kHz.
This chip natively supports decoding audio and has interesting specifications codecs for the general sound quality of the device (SNR and THD + N ≥100dB @ 1kHz ≤-85dB ≤0.005%
To facilitate installation, compatibility, and avoid wasting time on the software configuration, this amplifier requires no driver to operate. The USB input is automatically recognized by all devices. Including smartphones also benefit from OTG support.
This amplifier offers a neat control interface. There is a power-on button, a select button, a rotary volume control and a backlit control panel ..
For ease and comfort, it can also be controlled remotely via a remote control to a receiver I / R on the front.
Alternatively, the traditional interface is complete enough to let the onscreen user make their own settings with ease. It is even possible to specify an equalizer.
This amplifier emits a slight breath into the speakers during silent passages in the music. Although the phenomenon is very slight, it is still important to take into account when using desktop speakers with close listening.
| Specifications | |
| Type | Full Digital Amplifier |
| Power Output | 4Ω: 2x80W 8Ω: 2x50W |
| Supported sampling rates (max) | 24bit 192kHz |
| Inputs | Bluetooth, Auxiliary, Optical, Coaxial, USB |
| Output | Pregnant R + L |
| Impedance | 4-8Ω |
| THD | 0.09% (± 0.2dB) |
| SNR | 84dB |
| Interface control | Remote control / Control Panel |
| DC power supply | 32V 5A (supplied) |
| Color | Black |
| Weight | 1.25kg |
| Dimensions | 17.8x11.6x3.5 cm |
| Viewing | Digital display (OLED) - with sample rate |
| Frequency response | 18Hz - 22kHz |
| Clock | High accuracy |
| Remote Support | Yes (IR) - (supplied without its CR2032) |
| Audio / DSP controller | VIA VT 1630A |
| Input | RCA |
| Input | Optical |
| Input | SPDIF |
| Input | Bluetooth |
| Output | Speaker terminal |
| Color | Black |
| Color | Silver |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | STA326 |
| Power (W) | 50.0 |
| Refurbished Grade | Grade B |
