[GRADE B] AUDIOPHONICS AP300-S250NCX Power Amplifier NcoreX NCx252MP
-20%
Refurbished Product - Grade B
The Audiophonics AP300-S250NCX is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality.
Reduced price!
Reference : 22124
Refurbished
Limited special offer
549,00 €tax incl.
-20%
439,00 €tax incl.
365,84 € tax excl.
A few scratches on the acrylic panel (see last photo)
Audiophonics Workshop amplifiers range
Class D Stereo Power Amplifier NcoreX NCx252MP 2x250W 4 Ohm
AUDIOPHONICS AP300-S250NCX Class D Stereo Power Amplifier NcoreX NCx252MP 2x250W 4 Ohm
The Audiophonics AP300-S250NCX is a stereo amplifier based on an amplification module Hypex NcoreX NCx252MP. This solution is ideal for anyone who wants to have a large power reserve (2x250W @ 4Ω) without sacrificing sound reproduction quality. This amplifier block will be suitable for example to accompany demanding speakers, to sound large listening rooms or for studio applications requiring a large headroom without compromising the accuracy and richness of the audio message.
All components are integrated in a simple and robust 100% Aluminium housing with openings to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
Hypex NcoreX NCx252MP Amplification Board
The amplification circuit uses a module Hypex NcoreX NCx252MP. It is a versatile, high-performance Class D amplifier. It offers a very comfortable power of 2x150W at 8Ω while taking advantage of the high efficiency of Class D amplifiers.
Its main characteristics are its flat frequency response regardless of load impedance, its almost frequency-independent level of distortion and its ability to reject EMI interference. Its operation is based on a self-oscillating loop controlled by phase shift and taking into account feedback only at the speaker output.
This amplifier does not have a decoupling capacitor, so it lets the DC component of the signal through. Make sure your source has no DC component present at the output. The DC protection of the module switches on at 12VDC which is very permissive.
NCore Technology
NCore amplifiers are the first Class D amplifiers to approach the performance of operational amplifiers, but also to surpass them in terms of sound quality. As a result, they are able to deliver clear, rich, musical sound while remaining compact. This NCore technology combines the stability of the Hypex UcD series amplifiers with lower distortion and output impedance.
AUDIOPHONICS AP300-S250NC Class D Stereo Power Amplifier Ncore NC252MP 2x250W 4 Ohm
SMPS Power Supply
The NCx252MP module also integrates the amplification stage. This consists of a regulated half-bridge switching power supply (SMPS) with synchronous rectification on the main output rails. Compact, powerful and efficient, this power supply is particularly suitable for supplying a Class D amplifier cleanly.
In addition, to offer complete compatibility with the voltages delivered by the various electrical networks, the power supply is equipped with an automatic input voltage doubler. The NCx252MP module also has an overload protection system.
Connectivity
The AP300-S250NCX amplifier features a 2-pole stereo RCA input on gold-plated sockets, plus a 3-pole stereo XLR input for balanced signal processing. The XLR or RCA input source is selected via two switch buttons (right and left channel). The amplifier output is made on Elecaudio BP-209 24k gold-plated speaker terminals. They also accept banana plugs or spades for quick and easy connection. A 5-12V trigger connector in 3.5mm Jack format allows to control the automatic ignition of the amplifier when integrated in a compatible system. Finally, a bistable button is used to switch the unit on and off.
100% Aluminum Case and clean lines
The Hypex NCoreX NCx252MP amplifier is housed in a 100% black brushed aluminum case. The thick walls of this elegantly-finished case are highly resistant, providing the components with the protection they need. The natural conduction of aluminum, together with a carefully designed air flow, helps dissipate the heat generated by the module. In addition, the acrylic front panel is screen-printed with the Audiophonics logo, and the rear with the nomenclature of each input/output. Its compact size makes it easy to integrate into any audiophile installation, offering high performance in a small space.
Product typeAmplifier
ClassD
Number of channelStereo (2)
Max. power (@ 1kHz, THD=1%)2x150W @ 8Ω
2x250W @ 4Ω
2x180W @ 2Ω
Input1x Unbalanced Stereo RCA
1x Balanced Stereo XLR
OutputSpeaker terminals
Trigger5-12V
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5mΩ
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMax Power at 1.66V RMS
Supply voltage230V / 110V (automatic switch)
Case materialBrushed Aluminium
Total dimensions (WxDxH)300 x 248 x 62mm
Weight2080g
Package1x Audiophonics AP300-S250NC
1x Power cable
InputXLR
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)250.0
[GRADE B] AUDIOPHONICS AP300-S250NCX Class D Stereo Power Amplifier NcoreX NCx252MP 2x250W 4 Ohm
Refurbished Product - Grade B The Audiophonics AP300-S250NCX is a stereo amplifier based on an amplification...
