LT1764 +/-15V 2x15V 5V
This versatile power supply module provides two 15V outputs or one +/-15V output depending on the wiring, as well as a 5V output. The voltage of each output is adjustable, from 5V to 20V for the former and from 3.3V to 5V for the latter. The module achieves low noise and ripple thanks to the use of LDO LT1764 regulators. The input is done on two 12V inputs and/or on one 9V input. The module also integrates a short-circuit protection at the output and a thermal protection.
For a dual 15V output, it is recommended to use a dual toroidal transformer with 12V outputs.
For a 5V output, it is recommended to use a toroidal transformer with 6V output to limit the voltage difference between input and output.
| Specifications | |
| Product type | Power supply board |
| Inputs | 2x 12V AC 1x 9V AC |
| Outputs | 2x 15V OR +/-15V DC (adjustable 5~20V) 1x 5V DC (adjustable 3.3~5V) |
| LDO Regulators | LT1764 |
| Protections | Short circuits Thermal protection |
| Max current | 2A |
| General | |
| Dimensions | 80 x 75mm |
| Mounting holes spacing | 73.5 x 68mm |
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 15.0 |
| Output voltage (V) | 5.0 |
| Output current (A) | 2.0 |
| Input voltage (V) | 12.0 |
| Input voltage (V) | 9.0 |
| Power Supply | Regulated Linear Power Supply |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Ludo B.
