LHY AUDIO SFP-GE-T SFP RJ45 Module
New
The LHY Audio SFP-GE-T module adds a copper network link to a compatible SFP port, without the need for an optical connection. Compatible with all of the brand's network switches, it makes them easier to integrate into installations using standard RJ45 Ethernet cabling. On the RPI Pro, however, the RJ45 port and the SFP port must not be connected to the same local network at the same time.
Reference : 22668
29,00 €tax incl.
24,17 € tax excl.
LHY Audio SFP-GE-T SFP RJ45 Copper Module
Photo du LHY AUDIO SFP-GE-T SFP JR45 Copper Module
The SFP-GE-T module from LHY Audio adds a copper network link to a compatible SFP port, without the need for an optical connection. Compatible with all of the brand's network switches, it makes them easier to integrate into installations using standard RJ45 Ethernet cabling. On the RPI Pro, however, the RJ45 port and the SFP port must not be connected to the same local network at the same time.
Technical specifications
Product typeSFP module
ConnectorRJ45
PackageSold individually
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticFemale
ConnectorRJ45
LHY AUDIO SFP-GE-T SFP RJ45 Copper Module
The LHY Audio SFP-GE-T module adds a copper network link to a compatible SFP port, without the need for an optical connection. Compatible with all...
