FURUTECH FT-SWS-NCF PLUS (R) Power Plug Schuko Type F
The Furutech FT-SWS-NCF PLUS (R) is a Schuko wall socket that represents a direct evolution of the FT-SWS-NCF model, retaining its fundamental principles whilst enhancing its mechanical and electrical capabilities. It retains the architecture based on cryogenically treated and demagnetised α (Alpha) copper conductors, to which a non-magnetic rhodium plating has now been added, in order to stabilise conductivity and reduce contact impedance over time.
By buying this product you get 31 loyalty points
Reference : 21649
313,00 €tax incl.
260,83 € tax excl.
Shipping date: 24-11-2026.
Furutech FT-SWS-NCF PLUS (R) Power Plug Schuko Type F Pure Rhodium-Plated Copper 250VAC 16A
Furutech FT-SWS-NCF PLUS (R) : Front view
Designed for high-fidelity systems where the quality of the power supply determines the overall performance of the system, this ‘PLUS’ version further enhances the integration of NCF material and mechanical damping, thereby better mitigating the effects of vibrations and electrostatic charges. This approach enables it to enhance electrical continuity at the point of distribution, whilst maintaining consistent operational stability in demanding and evolving setups.
Furutech FT-SWS-NCF PLUS (R): Alpha Treatment
The two-stage α (Alpha) process developed by Furutech significantly improves the device’s performance. This treatment begins during the manufacturing process with the deep cryogenic freezing of all metal components. Using specific refrigerants, such as liquid nitrogen or helium, Furutech achieves temperatures ranging from -196°C to -250°C. The treated parts undergo a change in their molecular structure, thereby relieving internal stresses. The molecules bond more tightly together and the overall structure becomes more stable. This improves electrical conductivity and, consequently, the transfer of power and signals.
The second stage of the α (Alpha) treatment subjects these same parts to the patented ring demagnetisation process. Ordinary high-power magnets used for this purpose often increase magnetic effects and leave certain areas more magnetised than others. This patented process uses controlled attenuation to completely eliminate magnetisation, thereby achieving better performance, including in terms of conductivity.
Furutech FT-SWS-NCF PLUS (R) : NCF
Furutech FT-SWS-NCF PLUS (R): Nano Crystal² Formula (NCF)
Incorporated into a selection of Furutech products, NCF is based on a special crystalline material with two active properties. Firstly, NCF generates negative ions that eliminate static electricity. Secondly, it converts thermal energy into infrared radiation. Furutech combines this material with ceramic nanoparticles and carbon powder for their piezoelectric damping properties. Furutech thus achieves the optimal material for electrical and mechanical damping.
Furutech FT-SWS-NCF PLUS (R): New features in the Plus version
This development incorporates enhanced mechanical engineering based on a Zn-Mg alloy front plate combined with a redesigned carbon fibre, whilst an extended multi-layer damping architecture more effectively dissipates structural resonances, thereby limiting their propagation to the contact points. This approach is further enhanced by the integration of a hybrid carbon fibre/TPU coating, which absorbs residual micro-vibrations whilst stabilising the mechanical interface, resulting in more consistent contact under real-world conditions.
Beyond the structure itself, the optimisation of the internal supports enhances overall rigidity, whilst the new generation of FURUTECH’s pressure plate system increases the conductor contact area, reducing junction impedance and ensuring a secure connection. At the same time, the α (Alpha) copper conductors now feature a non-magnetic rhodium plating, combined with a non-magnetic stainless steel spring that maintains constant pressure, thereby ensuring a stable and consistent connection over the long term, particularly with Schuko plugs subjected to repeated insertion cycles.
Product typeSchuko plug
Connector typeType F
Maximum load250V 16A
Contact materialsPure α (alpha) copper
Contact platingRhodium
Compatible cable cross-section2.8mm² - 5.5mm²
MountingTo screw
Dimensions95 x 95 x 48mm
PackageSold by unit
Max cable diameter (mm)2.8
Mounting typeTo screw
ConnecticFemale
ConnectorType F (CEE 7/3 - CEE 7/4)
Rated current (A)16.0
FURUTECH FT-SWS-NCF PLUS (R) Power Plug Schuko Type F Pure Rhodium Plated Copper 250VAC 16A
The Furutech FT-SWS-NCF PLUS (R) is a Schuko wall socket that represents a direct evolution of the FT-SWS-NCF model, retaining its fundamental...
