Max cable diameter (mm)
Material
Diameter (mm)
Color
Number of conductors
Insulation material
Thierry S.
Beau produit, massif et bien fini.
Pour les connecteurs il y a mieux mais beaucoup plus cher. Ceux-ci font très bien le taf...
Thierry S.
Câble monté sur caissons graves en 38cm et comme attendu résultat propre sans exagération ni manque.
On suis très bien une...
joffrey J.
Bon matériel
Fiches en cuivre pas chères. Faciles à monter. r.a.s.
Sleeves
Sleeves
  • Cotton Sleeves
    Cotton Sleeves
    Discover all our cotton sleeves, allowing an ideal finishing of your DIY cables, having at the same time a protective and aesthetic role.
  • Nylon Sleeves
    Nylon Sleeves
    Discover all our nylon sleeves, allowing an ideal finishing of your DIY cables, having at the same time a protective and aesthetic role.
  • Copper sleeves
    Copper sleeves
    Discover all our copper jackets, allowing an efficient shielding of your DIY cables, in order to limit significantly the impact of interferences on the signal.
  • PTFE Sleeves
    PTFE Sleeves
    Discover all our PTFE jackets, allowing an efficient insulation of your DIY cables, in order to limit significantly the impact of interferences on the signal.
