Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
The SMPS300RS switching power supply is a very high performance model capable of developing a nominal power of 300 Watts in an extremely small footprint.
The Connex SMPS300RS is a half-bridge resonant switched-mode power supply (SMPS) capable of delivering 300W continuous and up to 360W peak. It is configured for a 36V output voltage and also features an unregulated differential output of approx. ±18V at a maximum current of 500mA. The main output voltage is regulated and adjustable within a range...
The SMPS600RXE switched mode power supply is a very high efficiency model capable of developing a nominal power of 600 Watts in an extremely small footprint.
The switching power supply SMPS800RE is a very high efficiency model capable of developing a nominal power of 800 Watts in an extremely small footprint. This power supply is capable of delivering 800W of continuous power and up to 1000W peak. It is available in several versions for dual output voltages from +/- 32V to +/- 72V. The main characteristic of...
The switching power supply SMPS800RS is a very high efficiency model capable of developing a nominal power of 800 Watts in an extremely small footprint. This power supply is capable of delivering 800W of continuous power and up to 1000W peak. The main characteristic of this power supply is the ratio between its compactness, its weight and the supplied...
This LLC switch mode power supply module has a main output delivering ±30V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A.
This LLC switch mode power supply module has a main output delivering ±40V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A.
This LLC switch mode power supply module has a main output delivering ±50V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±19V 0.5A.
This LLC switch mode power supply module has a main output delivering ±55V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±21V 0.5A.
This LLC switch mode power supply module has a main output delivering ±60V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A.
This LLC switch mode power supply module has a main output delivering ±70V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A.
