This PS500 switching power supply module has been designed by Hypex specifically to power its Nilai500DIY amplifier modules. With its 600W power supply and +/-70V output, it can power one or two Nilai500DIY modules simultaneously. This power supply uses audiophile-grade components and a PFC (Power Factor Correction) for increased power density and reduced conductivity of EMI interference. Protected against overcurrents, the Hypex PS500 power supply is highly reliable. What's more, it is designed for universal use, accepting inputs from 100 to 240VAC (+/- 10%). As for the connectors, there are Molex connectors for the outputs used to power the amplifier module(s) such as the Nilai500DIY, as well as I/O and HBUS connectors for controlling the PS500 module and connecting third-party electronic components. The PS500 power supply is therefore an excellent choice for all DIY projects requiring a clean, powerful power supply.
| 1 | AC input |
| 2 | HBUS output PCB connector |
| 3 | +/-70VDC Molex output |
| 4 | +/-70VDC Molex output |
| 5 | I/O PCB connector |
| Specifications | |
| Product type | Switching mode power supply module |
| Input voltage arnge | 100-240VAC +/-10% Fuse: 250VAC 6.3A (Warning: the fuse is soldered to the printed circuit board and cannot be replaced.) |
| Main output voltages | 2x ±70V |
| Output power | 600W |
| Max. output power | 800W |
| Standby supply output | 5V 1A |
| Auxiliary supply output | ±18V / 200mA |
| Standby power | 0.2W |
| Idle power | 5.5W |
| General | |
| Dimensions | 100*170*47mm |
| Weight | Approx. 900g |
| Package | 1x Hypex PS500 module 2x Cable asm Z14A30L2 (30cm amplifier connection cable) 1x Cable asm Z12C30L1 (30cm auxiliaries’ cable) 1x Cable asm Z2B30L3 (30cm power input cable) 1x PS500 mounting set 1x PS500 manual |
| Input | PCB Connector |
| Output | Molex |
| Output voltage (V) | 70.0 |
| Output current (A) | 6.0 |
| Input voltage (V) | 250.0 |
| Input voltage (V) | 120.0 |
| Input voltage (V) | 130.0 |
| Input voltage (V) | 190.0 |
| Input voltage (V) | 150.0 |
| Input voltage (V) | 210.0 |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 100.0 |
| Input voltage (V) | 230.0 |
| Input voltage (V) | 90.0 |
| Input voltage (V) | 200.0 |
| Input voltage (V) | 220.0 |
| Power Supply | SMPS |
