CONNEX SMPS300RS Switching Power Supply Module 300W 36V
The Connex SMPS300RS is a half-bridge resonant switched-mode power supply (SMPS) capable of delivering 300W continuous and up to 360W peak. It is configured for a 36V output voltage and also features an unregulated differential output of approx. ±18V at a maximum current of 500mA. The main output voltage is regulated and adjustable within a range of approx. 10% ±5%).
Reference : 22006
84,90 €tax incl.
70,75 € tax excl.
Connex SMPS300RS Switching Power Supply Module 300W 36V
Module d'alimentation à découpage Connex SMPS300RS
The main feature of this power supply is the absence of heat sinks for the power MOSFETs and rectifier diodes, due to the increased efficiency, up to 92%. What's more, the amount of EMI interference is much lower than that of any conventional power supply, and could be compared to a regulated linear power supply. Footprint and weight are also considerably reduced, enabling the SMPS300RS to be installed in a compact case. The SMPS300RS also features overcurrent protection that limits output current to around 110% to 120% of maximum power.
As the main output voltage of this power supply is regulated, it is suitable for Class AB and Class D/T amplifiers with a medium PSRR value. Target applications for this power supply module are Class D BTL output amplifiers.
Product typeSwitching power supply module
InputScrew terminals
OutputsPrincipale: cosses
Auxiliaire: borniers à vis
Input voltage120V (100-127V)
Main output voltageMin: 34V
Typ: 36V
Max: 38V
Aux output voltageMin: ±16V
Typ: ± 18V
Max: ±19V
Main output currentNominal: 8A
Peak: 9.5A
Aux output currentNominal: 0.25A
Peak: 0.5A
Zero load consumptionMin: 1.6W
Max: 1.8W
Efficiency at 50% load90.7%
Max output ripple31mV - 1A
86mV - 4A
Weight340g
Dimensions10 x 10 x 4cm
OutputPCB Connector
Output voltage (V)36.0
Output current (A)NC
Input voltage (V)120.0
Input voltage (V)100.0
Input voltage (V)115.0
Input voltage (V)110.0
Power SupplySMPS
The Connex SMPS300RS is a half-bridge resonant switched-mode power supply (SMPS) capable of delivering 300W continuous and up to 360W peak. It is...
