DOUK AUDIO VFD253-PRO VU Meter 4-Channel RCA Selector
The DOUK AUDIO VFD253-PRO is a 4-channel RCA analog audio selector and distributor featuring a 25 × 15-segment VFD display for real-time visualization of the music spectrum. It can operate in 1 input / 4 outputs mode to distribute a source to one or more outputs, or in 4 inputs / 1 output mode to easily select one of four audio sources, with illuminated buttons indicating the active channel.
Reference : 22456
119,00 €tax incl.
99,17 € tax excl.
Douk Audio VFD253-PRO 4-Channel RCA VU Meter Selector
The Douk Audio VFD253-PRO is a 4-channel RCA analog audio selector and distributor featuring a 25 × 15-segment VFD display for real-time visualization of the music spectrum. It can operate in 1 input / 4 outputs mode to distribute a source to one or more outputs, or in 4 inputs / 1 output mode to easily select one of four audio sources, with illuminated buttons indicating the active channel.
Its display offers 7 main modes with sub-modes, three spectrum ranges (LOW / MID / FULL), as well as brightness, gain, sensitivity, peak hold, and display response settings with Real Display and Smooth Display modes. The audio signal passes directly between the RCA inputs and outputs without processing by an operational amplifier, while transformer isolation separates the VFD display control circuit from the audio path to limit interference.
The VFD253-PRO also features a built-in microphone for sound detection, a clock display based on the RX8025T circuit with an advertised accuracy of ±1 minute per year, a remote control, settings memory after power-off, and an aluminum enclosure with a tempered glass front panel. It operates on DC 5V / ≥1A via a USB-C port.
Overview of the DOUK AUDIO VFD253-PRO
1Previous display mode
2Power / MIC/AUX switch
3Next display mode
4Channel selectors
51x I/O RCA
64x I/O RCA
7Microphone
8Microphone gain control
95V DC power via USB-C
10GND
Technical specifications
Product type4-Channel VU Meter Selector
Inputs4x RCA or 1x RCA I/O
MIC
Outputs4x RCA or 1x RCA I/O
Display typeVFD
Display resolution25 × 15
Displayed contentMusic spectrum / Clock
Display modes7 main display modes with sub-modes
Spectrum rangeLOW / MID / FULL
Display responseReal Display / Smooth Display
SettingsBrightness / Gain / Sensitivity / Peak hold
Clock ICRX8025T
Time accuracyLess than one minute per year
Power supply5V DC / ≥ 1 A via USB-C
Dimensions172 × 107 × 70mm
Weight650g
Package content1x Douk Audio VFD253-PRO
1x AC adapter
1x USB-C cable
1x Remote control
1x Screwdriver
Remote ControlYes
The DOUK AUDIO VFD253-PRO is a 4-channel RCA analog audio selector and distributor featuring a 25 × 15-segment VFD display for real-time...
