DYNAVOX AMP-S III Audio Selector Switch for Speakers/Amplifiers Black
The Dynavox AMP-S III is a switch that allows you to quickly and easily switch between two pairs of speakers via an amplifier or to use two different amplifiers with a single pair of speakers. It features an all-aluminum housing with an 8mm thick front panel, while the switch is operated by a front-mounted lever. Thanks to its large speakers terminals and internal 4mm² conductors, the AMP-S III can accommodate speaker cables with large cross-sections and supports switching power of up to 600W per channel.
Reference : 21931
128,67 €tax incl.
107,22 € tax excl.
Dynavox AMP-S III Audio Selector Switch for Speakers / Amplifiers Black
Miniature du Dynavox AMP-S III
Schéma des deux configurations possible pour le Dynavox AMP-S III
Product typeSpeaker/Amplifier Switch
ConnectorsSpeaker terminals (compatible with screw terminals and banana plugs)
Max power per channel600W
Internal cable section4.4mm²
Dimensions190x70x215mm
Weight1.3kg
Package1x Dynavox AMP-S III
InputSpeaker terminals
OutputSpeaker terminal
DYNAVOX AMP-S III Audio Selector Switch for Speakers / Amplifiers Black
The Dynavox AMP-S III is a switch that allows you to quickly and easily switch between two pairs of speakers via an amplifier or to use two...
