DAYTON AUDIO XO2W-3.5K 2-Way Speaker Crossover Filter 3500Hz
The Dayton Audio XO2W-3.5K was designed using a second-order Linkwitz-Riley alignment (12 dB/octave). A unique feature of the low-pass section allows the use of 4- or 8-ohm woofers, which is perfect for building 2-way systems. The high-pass cutoff frequency is calibrated for an 8-ohm load. The power handling capacity of this filter is 300W.
Reference : 21320
33,90 €tax incl.
28,25 € tax excl.
Shipping date: 01-12-2026.
Dayton Audio XO2W-3.5K 2-Way Speaker Crossover Filter 3500Hz
Photo of the DAYTON AUDIO XO2W-3.5K crossover filter
The Dayton Audio XO2W-3.5K speaker crossover filter was designed using a second-order Linkwitz-Riley alignment (12dB/octave). Dayton Audio metallized polyester film capacitors are used in the high-pass and low-pass sections. 18-gauge inductors were used to keep DC resistance to a minimum. A unique feature of the low-pass section allows the use of 4 or 8-ohm woofers, which is perfect for building D'Appolito-type 2-way or multi-woofer systems. The high-pass cutoff frequency is calibrated for an 8-ohm load. All components are glued or secured to eliminate buzzing and vibration. The high-quality blue PC board uses a backplate for rigidity and eyelets for easy mounting. The power handling capacity of this filter is 300W.
Product type
Product type2-way crossover filter
Power rating300W
Cutoff frequency3500Hz
Terminal width5.2mm
Dimensions16.5 x 10.8 x 3.5cm
Weight453g
Package1x Dayton Audio XO2W-3.5K crossover filter
The Dayton Audio XO2W-3.5K was designed using a second-order Linkwitz-Riley alignment (12 dB/octave). A unique feature of the low-pass section...
