ATOHM WT-5524-G Speaker Terminal Block Gold Plated 54x24mm (Unit)
The ATOHM WT-5524-G terminal block, like all the models offered by Atohm, is equipped with large-sized lead-free brass terminals with 24k gold plating. It accepts cables with large cross-sections, up to 6mm² and its body is made of reinforced ABS plastic.
Reference : 17017
5,50 €tax incl.
4,58 € tax excl.
Shipping date: 17-06-2026.
Atohm WT-5524-G
Atohm WT-5524-G Bornier Encastré pour Enceintes
The WT-5524-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts large cable cross-sections up to 6mm² and its panel is made of reinforced ABS plastic. A seal on the rear allows a reliable mounting on your speakers.
Atohm WT-5524-AG Bornier Encastré pour Enceintes, Plaqué Or
Product Speaker terminal block
Contacts materialLead-free Brass
Contacts platingGold 24k
Body materialReinforced ABS plastic
Banana plugs support
Total dimensions54x24mm
Package1x Speaker Terminal
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
tres satisfait
monter en remplacement des borniers pince des enceintes
La c est bien mieux, une légère amélioration du son
This review has been posted for ATOHM WT-5524-G Speaker Terminal Block Gold Plated 54x24mm (Unit)
The ATOHM WT-5524-G terminal block, like all the models offered by Atohm, is equipped with large-sized lead-free brass terminals with 24k gold...
