Connector
Impedance (Ω)
Max cable diameter (mm)
Efficiency / Sensitivity (dB)
78 - 128
Lowest frequency (Hz)
0 - 2010
Highest frequency (Hz)
0 - 113000
Max sampling rate
Material
Power (W)
10 - 1000
Speaker type
Connectic
Length
0 m - 5 m
Section (mm²)
0 mm - 1 mm
Conductors material (Cable)
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
2 - 4
Input
Output
Mounting type
Remote Control
Transmission / Reception protocol
Streaming services
Color
Conductors Plating (Cable)
Number of loudspeakers
Insulation material
Shielding
Supported Bluetooth codecs
Wireless
Noise reduction
Phone call feature
Speakers and Headphones
YONATAN R.
JEAN-MARC M.
Sarisfait
Eliot C.
Clearly Audible Difference
Discover our range of headphones and speakers to accompany your HiFi system and offer you high quality listening.
  • Passive Speakers and Subwoofer
    We regularly offer you all our DIY setups and realizations, but we also have a range of HiFi speakers and passive subwoofers: bookshelves, satellites, or columns, selected by our experts to offer you a sound rendering that meets your expectations. All the parts of a HiFi installation are important, the speakers in particular, as well as the amplifier and the connections that will accompany them.
  • Active Speakers and Subwoofer
    Find in this category all our active speakers and subwoofers, including an amplifier module for a quick and easy installation.
  • Speaker Supports
    Speaker Supports
    Discover our range of speaker stands, allowing you to place, hold and cushion your speakers in a practical and efficient way.
  • Headphones
    Headphones
  • In-Ear Earphones
    In-Ear Earphones
    Here you'll find our selection of HiFi in-ear monitors. High-performance headphones capable of meeting every audiophile need and requirement. We strongly recommend pairing these earphones with a HiFi walkman of the same quality, i.e. one capable of processing high-fidelity music formats.
    Special conditions apply for a withdrawal on this type of product  => See our General Terms and Conditions.
  • Headphones & In-Ear Monitors Accessories
