HIDIZS ST2 PRO NEBULA In-Ear Monitors Black
Hidizs ST2 Pro Nebula in-ear earphones are dynamic IEMs with a 10mm-diameter diaphragm for clear, detailed sound reproduction. An ES9218AC DAC chip integrated into the USB connector of their detachable cable supports up to PCM 32bit 384kHz and DSD128, enabling you to enjoy high-resolution files.
Reference : 20928
69,90 €tax incl.
58,25 € tax excl.
Hidizs ST2 Pro Nebula Dynamic IEM In-Ear Monitors Ø10mm USB-C 20Hz-40kHz Black
Photo of HIDIZS ST2 PRO NEBULA
Hidizs
 ST2 Pro Nebula in-ear monitors
 are dynamic IEMs with a 10mm-diameter diaphragm for clear, detailed sound reproduction. An ES9218AC DAC chip integrated into the USB connector of their detachable cable supports up to PCM 32bit 384kHz and DSD128, enabling you to enjoy high-resolution files. A microphone also supports calls. With a power rating of up to 70mW+70mW@32Ω the cable is capable of driving numerous 0.78mm CIEM IEMs. Versatile and high-performance, ST2 PRO NEBULA can even be used for gaming thanks to their 0 latency.
HIDIZS ST2 PRO NEBULA benefits
Hidizs ST2 Pro Nebula: 10mm dynamic driver
The ST2 Pro Nebula's dynamic driver, with its PU+PEEK composite cone, ensures faithful, detailed sound reproduction. This driver extends the high-frequency range, giving the ST2 Pro Nebula IEMs an extended frequency response from 20Hz-40kHz.
The HIDIZS ST2 PRO NEBULA driver
The HIDIZS ST2 PRO NEBULA DAC chip
Hidizs ST2 Pro Nebula: ES9218AC DAC chip
Inside the ST2A cable's USB connector is an ES9218AC DAC chip supporting high-resolution sampling rates up to PCM 32bit 384kHz and DSD128. This makes the ST2 PRO Nebula the perfect ally for enjoying the high resolution available on many audio streaming platforms. In addition, the cable being detachable and ensuring an output power of up to 2x70mW@32Ω offering the possibility of driving many other 0.78mm CIEM IEMs.
Hidizs ST2 Pro Nebula: An audiophile detachable cable
The TS2 Pro Nebula detachable cable is made of OFC copper for extremely reliable signal transmission.
The design of HIDIZS ST2 PRO NEBULA
Hidizs ST2 Pro Nebula: Precision tuning
Hidizs has chosen to target the H-2019 curve so that the ST2 Pro delivers powerful bass, rich midrange and moderately extended treble. The result is a balanced, pleasant sound.
HIDIZS ST2 PRO NEBULA tuning
Product typeIn-ear monitors (IEM)
DriverDynamic Ø10mm
DAC chipES9218AC
Body materialsResin + Aluminum alloy etching
Frequency response20Hz-40kHz
Sensitivity108dB
Impedance32 ohm
Microphone for phone calls
Detachable cable
IEM connectorsCIEM 0.78mm
Cable terminaisonUSB-C
Cable conductor materialCuivre OFC (4x260)
Cable length1.2m
ES9812AC DAC chip specification
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD128
MQA
Distorsion0.0012%
SNR118dB
DNR122dB
Channel separation63dB
Output powerUp to 2x70mW
Package1x Pair of Hidizs ST2 Pro Nebula in-ear monitors
1x USB-C to USB-A adapter
3x Pairs of eartips
1x Storage pouch
Impedance (Ω)32
Efficiency / Sensitivity (dB)108
WirelessNo
Cable terminationUSB-C
Phone call featureYes
Noise reductionNo
HIDIZS ST2 PRO NEBULA Dynamic IEM In-Ear Monitors Ø10mm USB-C 20Hz-40kHz Black
Hidizs ST2 Pro Nebula in-ear earphones are dynamic IEMs with a 10mm-diameter diaphragm for clear, detailed sound reproduction. An ES9218AC DAC chip...
