Custom Toroidal Transformer - All Power
4.7 / 5
Reference : 3675
1,00 €tax incl.
0,83 € tax excl.
This is a personalised, tailor-made product for which cancellation, modification and retraction are not possible.
The dimensions displayed in the simulator correspond to simple transformers, with a primary winding and a secondary winding (low voltage 0–50 V).
For transformers with multiple windings (including some high-voltage windings) and equipped with electrostatic and magnetic shields, the dimensions will be larger.
For more complex transformers, we recommend that you contact us in advance so that we can provide you with the exact dimensions if needed.
Custom toroidal transformer
We offer a service of custom toroidal transformers built according to your needs. There is no minimum order quantity (you can ask for one piece only).
Custom transformers are available in three profiles (standard / low / high) with several types of optional supports.
Our toroidal transformers have a class IP00 protection, class B insulation. They are subjected to a 4kV flash test and comply with ISO9001 TUV CERT.
hi fi toroidal transformer custom specifications primary secondary
Audiophonics custom transformer toroidal electric AC converter hi-fi
Possibilities
Use the tool below to specify the characteristics of your custom toroidal transformer. Price is calculated automatically.
If your toroidal transformer has to meet special requirements or characteristics that lay beyond the capabilities of this calculator, please contact us to request a personalized quote.
Javascript must be enabled to use this tool
How to build your custom transformer :
  • Version 1.24 : Please update your cache (ctrl+F5) to access new options.
    You can now save your custom transformer template in a local file and load it for later use or edit
    - Use the "SAVE TEMPLATE" button to save the file.
    - Use the "CHOOSE FILE" button to load your file.
  • Write the primary voltage of your transformer in the "PRIMARY CIRCUIT" section.
  • Then, input the voltage and max intensity of your first secondary winding in the "SECONDARY CIRCUIT" section.
  • To add a new winding (primary or secondary) click the "NEW WINDING" button in the adequate section. A new line appears. Do not forget to specify the voltage and intensity that you need. "
  • You can remove a winding with the button "REMOVE WINDING". Please note that your transformer must have at least one primary winding and one secondary winding.
  • You can add intermediate cables to a secondary winding. It can be a midpoint (12-0-12V) or a free intermediate cable (0-3-5V). To do this, use the "EDIT" button on the corresponding secondary winding.
  • Caution : a winding cannot have a midpoint and free intermediate cables at the same time. You have to disable one to use the other.
  • Your custom transformer cannot have a unlimited number of cables. Leave the mouse cursor on any button that adds winding, midpoint or cable to know if you are close to those limitations.
  • Once satisfied with your coils, focus on the OPTIONS section. This section allows you to ask for an electrostatic screen, a magnetic screen and a thermal fuse. YOu can also specify the profile of your transformer and request a specific support. The choice of a support is optional and you can leave the default selection if your project does not require special mounting.
  • The "SUMMARY" section provide a summary of the windings values and all the options. Carefully check that the information is correct and complete : it is on this basis alone that your toroidal transformer will be built. If something is not writen here, it will not be a part of the transformer.
  • The Specifications section is given as an indication relative to the power and profile of your transformer. Please note that the proposed values ​​do not include the support and the number of windings which can significantly affect the dimensions & weight.. The more winding and cables, the less precise are those numbers.
  • If something is wrong with the template, the app lists what is wrong under the options section. Until the errors have been solved, it is neither possible to save the template nor to add the transformer to cart.
  • After verifying the summary, choose a quantity and press the add to cart button. Remember, once in the list, the transformer can not be changed. The only way to modify it is to go to your cart, remove the transformer and start again.
Primary voltage (V)N/A
Secondary voltage (V)N/A
Power (VA)N/A
Product customization
After saving your customized product, remember to add it to your cart.
Text
loader
* required fields
66 reviews
transfo sur mesure réalisé pour ampli a tubes vintage
réalisation parfaite pour une cabine leslie 147. l'ampli était alimenté en 220V ce qui à notre époque en 240V surchargeait les étages en courant continu.
Avec ce transfo les tensions obtenues sont excellentes entre 235V et 240V en entrée, d'autant que le transfo est réalisé avec trois primaires 230V , 240V et 250V.
produit idéal pour tout matériel vintage
remerciements à l'équipe d' Audiophonics pour ses conseils avisés
This review has been posted for Custom Toroidal Transformer - All Power
Transfos pour bloc mono
2 transfos sur mesure pour la fabrication de 2 blocs mono (double PP el84). Après contrôle, belle fabrication, tout est OK avec un encombrement un peu supérieur en diamètre (écran électrostatique ?), sans conséquence pour un projet diy. Livré 11 jours avant la date prescrite.
Je recommande vivement.
Au top
Devant remplacer un transformateur peu commun, celui livré respecte totalement les spécifications voulue.
impeccable
Conforme à ma spécification un peu complexe: 0-11-22-40V et un second enroulement 0-4V: le tout très bien repéré et dimensions conformes au configurateur.
Délai un peu long, mais c'est du sur-mesure.
Mon vieux transport CD Audio Note dont le torique vibrait un peu trop ces derniers temps est de nouveau bon pour le service.
Merci Audiophonics!
