OYAIDE ACROSS 900 V2 Interconnect Cable
The Oyaide ACROSS 900 V2 is a coaxial interconnect cable designed for low-noise analogue transmission in demanding environments. It relies on a 102SSC copper conductor combined with a C.I.S. structure incorporating an air layer, while adding a double shield to strengthen immunity to interference and stabilise electrical parameters across the full bandwidth.
Reference : 22193
59,91 €tax incl.
49,92 € tax excl.
Cable sold per metre
Oyaide ACROSS 900 V2 Shielded Unbalanced Interconnect Cable Copper 1mm² Ø9.7mm
Oyaide ACROSS 750 V2 : Front view
Intended for high-fidelity systems and complex installations, it combines a controlled coaxial geometry with low-dielectric-constant polyolefin insulation, preserving signal integrity even in the presence of external interference. This approach enables it to serve as a critical link within an audio chain, while maintaining the electrical and mechanical consistency required by the most sensitive configurations.
Oyaide ACROSS 900 V2: 102SSC Conductor
The ACROSS 900 V2 relies on the proprietary 102SSC conductor, drawn from primary copper conforming to JIS C1011 to eliminate any impurities associated with recycling, while a surface stripping process removes residual contaminants to promote uniform conduction. This approach is extended through drawing via natural diamond dies, refining the strand structure and improving their consistency, while maintaining a manufacturing tolerance of ±1µm that limits electrical variation. The whole, completed by a double annealing process reducing internal mechanical stress, achieves a conductivity of 102.3% IACS, ensuring stable and predictable signal transmission.
Oyaide ACROSS 750 V2 : Internal structure
Oyaide ACROSS 900 V2: 3E Structure
The patented 3E technology is based on the concentric combination of three distinct strand diameters, allowing the internal arrangement to be densified while reducing the gaps between conductors. This geometric organisation improves bundle cohesion and ensures a perfectly circular cross-section after twisting, promoting uniform contact with the insulation and limiting thickness irregularities. Beyond the mechanical precision, this homogeneous structure translates into more consistent electrical characteristics, contributing to greater signal stability across the full bandwidth.
Oyaide ACROSS 900 V2: C.I.S Structure and double shield
The cable adopts a C.I.S. (Cross-Insulated-Stabilizer) structure incorporating a cross insulation with an air layer, reducing parasitic capacitance while improving high-frequency stability through vibration dissipation ensured by the internal geometry rather than by damping materials. This approach extends into a coaxial architecture where the centre conductor is supported at discrete points, limiting interactions with the immediate signal environment.
Beyond this foundation, the ACROSS 900 V2 introduces a concentric double shield that reinforces electromagnetic isolation, more effectively containing external interference while stabilising the cable's overall impedance. This double layer also acts as an additional barrier against ground-borne disturbances and parasitic fields, resulting in cleaner transmission in electrically noisy environments or high-density equipment installations.
The assembly relies on a polyolefin dielectric with a low dielectric constant — approximately four times lower than PVC — limiting energy storage while maintaining effective conductor separation, ensuring stable and legible reproduction across the full audio spectrum.
Oyaide ACROSS 900 V2: Halogen-free insulation
The assembly is enclosed in a halogen-free polyethylene outer jacket, selected for its stable dielectric properties and low interaction with the signal, while contributing to the mechanical protection of the cable in both domestic and professional environments. This outer sheath maintains consistent electrical performance by limiting external influences, while its composition ensures controlled dissipation of thermal and mechanical stress.
Product typeSignal cable
Number of conductors1
Conductor cross-section1mm²
Conductor material102SSC copper
Insulation materialPolyolefin
ShieldDouble 102SSC copper braided sleeves
Outer jacket materialHalogen-free polypropylene
Cable diameter (nominal)Ø9.7mm
ColourBlack
Package contentsSold per metre
Diameter (mm)9.7
ShieldingYes
Section (mm²)1.00
Ground / ShieldingYes
OYAIDE ACROSS 900 V2 Shielded Unbalanced Interconnect Cable Copper 1mm² Ø9.7mm
The Oyaide ACROSS 900 V2 is a coaxial interconnect cable designed for low-noise analogue transmission in demanding environments. It relies on a...
