DOUK AUDIO T12 Headphone Amplifier Preamplifier Line / MM/MC Phono
The DOUK AUDIO T12 is a tube MM/MC phono preamplifier with an integrated headphone amplifier, designed for use with a turntable or various analog sources. It integrates two 6J5B-Q tubes operating with an anode voltage of 120 VDC, providing a warmer analog sound while maintaining a low level of distortion.
Reference : 22458
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 17-11-2026.
DOUK AUDIO T12 Headphone Amplifier Preamplifier Line /  MM/MC Phono with 6J5B-Q Tube
DOUK AUDIO T12
The T12 features an RCA Line In input for connecting a CD player, DAC, streamer, or any other analog source, as well as a PHONO input compatible with MM and MC cartridges with RIAA equalization. Its two RCA outputs allow easy connection to two amplification systems or active speaker systems, while a 3.5mm Jack headphone output supports headphones from 32 to 200Ω and delivers up to 350mW.
The tone control provides bass and treble adjustment of ±10 dB, with center-detent sliders allowing the neutral position to be easily restored. The T12 features a signal-to-noise ratio of ≥78 dB and total harmonic distortion of < 0.002% on the RCA input, with a maximum input level of 1.5Vrms and a maximum output level of 8Vrms at 600Ω.
Its compact 147 × 91 × 78mm enclosure combines genuine walnut wood cladding, visible tubes, and retro-style controls. It operates from a DC 12 V ≥1 A power supply via a 5.5/2.1 mm connector and features a setting memory function when powered off.
DOUK AUDIO T12
DOUK AUDIO T12 Overview
16J5B-Q Tube
2Bass control
3Treble control
4Volume control
5LED indicators
6Output selector
7Power / Input selector
83.5mm Jack headphone output
92x RCA output
102x RCA input (AUX/PHONO)
11MM/MC selector
12GND
1312V DC power via 5.5/2.1 Jack
Technical specifications
Product typeHeadphone Amplifier / Phono Preamplifier
Tubes2x 6J5B-Q
Anode voltage120V DC
Inputs1x RCA
1x RCA Phono MM/MC
Outputs2x RCA
1x 3.5mm Jack headphone output
Frequency response20Hz–20kHz
SNR≥ 78dB (RCA In)
THD< 0.002% (RCA In)
Maximum input level1.5Vrms
Maximum output level8Vrms at 600Ω
Input impedanceMM: 47 kΩ
MC: 150 Ω
RCA line input: 50 kΩ
Output impedance10Ω
GainMM: 45 dB
MC: 58 dB
RCA line input: 10 dB
Tone adjustment range±10dB
Recommended headphone impedance32–200Ω
Headphone output powermax. 350mW
Power-off memory
Power supply12V DC ≥1 A (via 5.5 × 2.1mm Jack)
Dimensions147 × 91 × 78mm
Weight544g
Package content1x DOUK AUDIO T12
1x 12V DC power supply
1x Ground wire
InputPhono
OutputJack 3.5mm
ColorWood
ClassTube amp
The DOUK AUDIO T12 is a tube MM/MC phono preamplifier with an integrated headphone amplifier, designed for use with a turntable or various analog...
