IEAST OLIO Receiver WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz Black
With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it supports numerous transmission protocols such as DLNA, AirPlay 2, Spotify Connect, Tidal Connect, and can even be controlled through Amazon Alexa and Siri voice assistants.
Reference : 16062
79,00 €tax incl.
65,83 € tax excl.
iEast Olio
Receiver WiFi 2.4G/5G AirPlay 2 DLNA Bluetooth 5.0 24bit 192kHz Black
Récepteur WiFi 2.4G/5G AirPlay 2 DLNA Bluetooth 5.0 24bit 192kHz Noir
With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it supports numerous transmission protocols such as DLNA, AirPlay 2, Spotify Connect, Tidal Connect, and can even be controlled through Amazon Alexa and Siri voice assistants. Via the iEast app, it also allows you to enjoy the most popular streaming services such as Spotify, Deezer, Qobuz, Tidal, Amazon Music or many web radios via TuneIn. The Olio's output is on a common 3.5mm jack and Mini Toslink connector. It integrates a Burr Brown DAC chip allowing to perform the digital to analog conversion and supporting sampling rates up to 24bit 192kHz.
IEAST OLIO Récepteur WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz Noir
Many possibilities
Versatile, the IEST Olio allows you a multitude of installation configurations within your Hi-Fi system. With its optical/analog stereo output, you can connect it directly to active speakers, an amplifier or even a DAC to broadcast your audio source remotely.
Product typeWireless receiver
DAC ChipBurr Brown PCM5121
ConnectivityWiFi 2.4G/5G IEEE 802.11a/b/g/n/ac
Bluetooth 5.0
Outputs1x Jack 3.5mm / Optical (Toslink/Mini-Toslink) (shared output)
WWA SupportAlexa support
Supported sampling ratesPCM up to 24bit 192kHz
Supported transmission protocolsDLNA
AirPlay 2
Spotify Connect
Tidal Connect
Hi-Rescloud
QPlay
Supported streaming servicesSpotify
Deezer
Qobuz
Tidal
Amazon Music
Napster
Pandora
TuneIn
Supported audio formatsAPE, FLAC, MP3, WAV, AAC, AAC+, WMA, ALAC, AIFF
SNR108dB
Supply voltage5VDC 1A via USB-C
Dimensions54.25 x 54.25 x 13.45mm
Package1x iEast Olio
1x USB-C cable
1x Jack 3.5mm cable
InputWiFi
OutputJack 3.5mm
OutputOptical Toslink
OutputOptical Mini-Toslink
DAC / ADC ChipBurr Brown PCM5121
Max sampling rate192kHz
Transmission / Reception protocolWiFi
Transmission / Reception protocolDLNA
Transmission / Reception protocolAirPlay
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsTidal
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsTidal Connect
Supported Bluetooth codecsN/A
Cette minus boite qui fait tout est simplement incroyable
Je viens de recevoir mon iEAST OLIO (Alim Bloc 5V USB C iFi) que j'ai branché via Fibre Optique sur mon DAC SMSL M8A avec son alimentation séparée dédiée. Connecté sur mon abonnement QoBuz HiRes directement via le WiFi, le résultat est excellent pour un prix très contenu. L'application de pilotage IEAST intallée sur mon iPhone est très conviviale. Bravo!!!
Ce système qui me sert dans mon bureau est composé ensuite de l'interface Tube Musical Fidelity X10D refaite entièrement par Rock Grotto, un Pioneer A757 de mon adolescence, et une paire de Tannoy Devon de 1973 équipée du HPD 315alnico.
This review has been posted for IEAST OLIO Receiver WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz Black
With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it...
