J'ai 3 modules TX/RX Bluetooth et celui ci fournit la meilleurs qualité audio et de loin. Un simple chargeur USB de tel est suffisant pour le faire fonctionner.
Aptx HD / CSR8675 / DAC PCM5102A 96kHz 24bit
This tiny Bluetooth 5.0 receiver is the ideal solution for integrating wireless connectivity in audio installations. It supports aptx HD standard and thus enables you to integrate the latest Lossless Bluetooth technology with minimal efforts and space.
The circuit carry its own reference chip PCM5102A to ensure a high-level digital / analog conversion. The sound benefits low distorsion (93dB THD), high dynamic range of 112dB and a Signal / Noise ratio of 112dB as well.
A Qualcomm chip CSR8675 is in charge of receiving the Bluetooth stream. The latter contributes significantly to the excellent audio quality through the Aptx HD support for lossless audio transmission.
Very easy to install, the device is powered by a USB-C port on the rear panel and offers a 3.5mm output jack on the front.
Caution : the power supply / power cable (USB-C to USB-A) are not included with this product
The receiver output stage uses an operational amplifier OPA1612. This model is particularly appreciated for its extremely low noise level with a distortion rate of 0.000015% at 1kHz and a spectral density of noise of 1.1VJHz.
Type | Bluetooth receiver |
Standard | Bluetooth 5.0 |
DAC chip | PCM5102A |
Bluetooth chip | CSR8675 |
Power Supply | DC 5V USB-C (not included) |
Norms | aptX, aptX Low Latency, aptX HD, MP3, AAC, SBC |
Dimensions | 63 x 67 x 20 mm |
Input | Bluetooth |
Output | Jack 3.5mm |
DAC / ADC Chip | PCM5102 |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Serge V.
BENOIT D.
