NEUTRIK NC3MXX-14-BAG-D Male XLR Connector
New
The Neutrik NC3MXX-14-BAG-D is a 3-pin male XLR connector designed for cables with an outer diameter of 8 to 10 mm. This special version of the XX series combines a black metal housing with silver contacts and retains the features of the range, with a design suited to larger cross-section cables.
Reference : 22625
5,20 €tax incl.
4,33 € tax excl.
Neutrik NC3MXX-14-BAG-D Male XLR Connector Silver Ø10mm
NEUTRIK NC3FXX-14-BAG-D: Front view
The Neutrik NC3MXX-14-BAG-D is a 3-pin male XLR connector designed for cables with a diameter of 8 to 10mm (outer). This special version of the XX series combines a black metal housing with silver contacts and retains the features of the range, with a design suited to larger cross-section cables.
The specific cage of the female contact reduces contact resistance, while an integrated barrier limits solder wicking towards the connection area. Its reinforced metal latch, wider and easier to handle, makes connections easier; additional ground contacts improve electrical continuity between the connector and its shell. The clamp-type cable retention increases pull-out strength and simplifies assembly, while the polyurethane boot protects the cable against bending stress. Its rugged die-cast zinc shell completes this assembly intended for applications requiring a reliable and durable connector; colored rings and boots can also be used for identification.
NEUTRIK NC3FXX-14-BAG-D: Dimensions
Technical specifications
Product typeMale XLR connector
Mounting typeSolder
Max cable diameterØ10mm
Contacts materialSilver
Body materialZinc
Rated current16A
Rated voltage<50V
Contact resistance≤3mΩ
Insulation resistance>10GΩ
Dielectric strength1.5kVdc
Capacitance between contacts≤4pF
Lifespan> 1000 cycles
StandardIEC 61076-2-103
Operating temperature-30°C to +80°C
DimensionsØ20.3 x 69.6mm
PackageSold individually
Insulation materialNC
Max cable diameter (mm)10.0
Mounting typeTo weld
ConnecticMale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Silver
NEUTRIK NC3MXX-14-BAG-D Male XLR Connector Silver Ø10mm
The Neutrik NC3MXX-14-BAG-D is a 3-pin male XLR connector designed for cables with an outer diameter of 8 to 10 mm. This special version of the XX...
