NEUTRIK NC5FD-TOP 5-Pole Female XLR Connector Chassis Mount
The Neutrik NC5FD-TOP is a female XLR chassis connector with 5 poles designed for front mounting on chassis, relying on a sealed TOP construction to ensure reliable operation in outdoor environments.
Reference : 22181
4,85 €tax incl.
4,04 € tax excl.
Neutrik NC5FD-TOP 5-Pole Female XLR Connector Chassis Mount Gold Plated
Thumbnail of the Neutrik NC5FD-TOP
KEY POINTS:
  • The airtight construction prevents air ingress, ensuring the internal integrity of the connector.
  • The IP65/IP67 rating protects against dust and water splashes, ensuring operation in outdoor conditions.
  • The design for demanding environments ensures mechanical robustness suitable for intensive use.
  • Flame-retardant materials (UL94 V0) limit flame propagation in case of incident.
  • The die-cast alloy body ensures rigidity and resistance to mechanical stress.
  • The front mounting facilitates access and maintenance.
Diagram showing the structure of the Neutrik NC5FD-TOP
Technical specifications
Product typeXLR connector
Connector5-pole female XLR
Contact materialBrass
Contact platingGold
Capacitance between contacts≤ 7pF
Contact resistance≤ 5mΩ
Dielectric strength1.5kVdc
Insulation resistance> 5GΩ
Rated current per contact7.5A
Rated voltage< 50V
Insertion/withdrawal force≤ 40N
Lifetime> 1000 cycles
StandardsUL94V0
IEC 60068-2-20
IP65 & IP67
Temperature range-30°C to +80°C
PackagingSold individually
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
Contacts number5
Max panel thickness (mm)N/A
ConnectorXLR
NEUTRIK NC5FD-TOP 5-Pole Female XLR Connector Chassis Mount Gold Plated
The Neutrik NC5FD-TOP is a female XLR chassis connector with 5 poles designed for front mounting on chassis, relying on a sealed TOP construction...
