MINIDSP UMIK-1 USB measurement Microphone
The Umik-1 is a low noise, omnidirectional USB measurement microphone that provides accurate results. The Umik-1 is a class 1 USB audio device, automatically recognized by all operating systems (Windows / Mac / Linux).
4.9 / 5
Reference : 8269
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 25-11-2026.
MiniDSP UMIK-1
Low Noise Omnidirectional USB Microphone
MiniDSP UMIK-1 Micro de mesure USB omnidirectionnel à faible bruit
The Umik-1 is a low noise, omnidirectional USB measurement microphone that provides accurate results. The Umik-1 is a class 1 USB audio device, automatically recognized by all operating systems (Windows / Mac / Linux). It is equipped with a unique calibration file based on the serial number. Combined with an acoustic measurement software, it is the ideal solution for a Plug & Play measurement system.
Product typeMeasuring microphone
Microphone typeElectret 6mm
DirectivityOmnidirectional
Frequency response20Hz - 20kHz ±1dB
Resolutions and sampling rates24bit ADC@44.1 ou 48kHz
Sound pressure133dB SPL @ 0dB, 1% THD, 1kHz
Noise level74dBFS
CompatibilityWindows
Mac
Linux
Connector systemUSB-C
Power supplyUSB 5V
Weight120g
Package1x MiniDSP Umik-1
1x USB Cable 2m
1x Mini tripod
Tips for getting started
Downloading the calibration file
Every Umik-1 comes with a unique calibration file. To download it, look for the 7-digit serial number on the body of the microphone.
  1. Enter the serial number in the form 700-XXXX on the MiniDSP website.
  2. In your browser, click on File > Save to save a '.txt' extension.
52 reviews
Bon produit - logistique à améliorer
Bon produit pour la calibration avec REW.
Réception après 8 jours (lent quand on à l'habitude d'Amazon)
Le suivi par la Poste et son sous-traitant DPD est particulièrement mauvais. Peu de mise à jour, plusieurs sites à consulter.
This review has been posted for MINIDSP UMIK-1 Low Noise Omnidirectional USB Microphone
Microphone for Dirac Measurement
The UMIK-1 is a well built measuring microphone you need to set up a Dirac system. It is well built and comes with a little stand and a connector-cable. The microphone works well and did everything it should during the measurement.
Positive:
Build quality
Performance
Negative:
Clamp of micro-holder to tight (hard to get micro in it.
Enclosed cable is USB-A to USB-C (pure USB-C would be more up to date)
A bit pricey for a one use item.
" La parole est aux ondes stationnaires ! "
Au départ je l'ai acheté par curiosité , afin de mettre une courbe sur l'acoustique de mon séjour. Simple à mettre en oeuvre avec le logiciel REW EQ , ce micro se révèle précieux pour celui qui cherche a optimiser les performances de son système audio. Cet appareil a mis le doigt sur des modes bien prononcés que tout déplacement du subwoofer ne parvenait à atténuer, et pas question d'installer des bass traps. Un Dspeaker antimode X2 a solutionné mon problème de façon très efficace.
Depuis, avec le Umik-1, Je me complais occasionnellement à débusquer à la demande les ondes stationnaires qui hantent les salons de
connaissances, telles des fantômes qui ponctionnent votre son .
l'appareil est robuste , pratique avec son pied. une rallonge usb A/ usbC de 3m munie d'un répéteur à ajouter au câble de 5m fourni sera conseillée si le point d'écoute est un peu éloigné de votre ampli hifi.
Super achat !
Pas de soucis
Super produit, intégration facile dans REW ou sur l'application Wiim. Envoi soigné et expédition plus rapide que les délais annoncés initialement.
UMIK 1
The microphone works great, there were no problems with the first setup. I have measured several applications in the last two days and I can say that I am very satisfied with the ease of measurement. I have checked the results with my B&K reference microphone, everything is within +/-0.5 decibels ............... This was a really great investment.
The Umik-1 is a low noise, omnidirectional USB measurement microphone that provides accurate results. The Umik-1 is a class 1 USB audio device,...
