AUDIOPHONICS PI-SPC V2 Power Management Module for Raspberry Pi
This power control module for Raspberry Pi allows you to cleanly turn your Raspberry Pi on and off like a family ATX PC. Once the monostable switch is turned on, your Linux distribution boots like any family computer.
4.4 / 5
Reference : 10912
15,90 €tax incl.
13,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
This module is supplied alone.
Audiophonics PI-SPC V2
Audiophonics PI-SPC V2 Module de contrôle alimentation type ATX pour Raspberry Pi
This power control module for Raspberry Pi allows you to cleanly turn your Raspberry Pi on and off like a family ATX PC. Once the monostable switch is turned on, your Linux distribution (Volumio, MoodeAudio, piCore...) boots like any family computer. Same for the shutdown function. A power LED output is available, to follow the evolution of the different stages of switching the Raspberry Pi on and off.
Features
1. Push button :
  • Raspberry Pi off: Pressing the push button starts the Raspberry Pi.
  • Raspberry Pi on: Pressing > 0.2s and < 4s turns off the Raspberry Pi after turning off the software solution in use.
  • Raspberry Pi on: One press > 4s for emergency stop. Immediate power off of the Raspberry Pi.
2. Power LED Status :
  • Off: Raspberry Pi off
  • Slow flashing: Raspberry Pi powered on, starting the software solution. Same for power off.
  • Fast blinking: Restart command sent from the software solution.
  • Fixed power on: Raspberry Pi powered on, software solution in use properly started and ready to use.
Schéma de câblage
Audiophonics PI-SPC V2 Module de contrôle d'alimentation type ATX pour Raspberry Pi
Product typeRaspberry Pi power management module
Module delivered flashed, ready for use
Power supplyEither by connection pins or by Micro USB
Fuse cavity for a fuse on a supply line
Fixation holes diameterØ2.5mm
Dimensions25x25mm
Pre-welded pins
CompatibilityRaspberry Pi 2 / 3 / B / B+ / 4 and other SBC
11 reviews
Works as designed, but...
Plus and play. Very good Addition for my Multimedia raspberry system (shutdown is quite fast, but boot process takes minutes)
I am using RaspBerry Pi 3B with 5inch touch LCD and HifiBerry DAC plus.
The issue: Since using the power control unit the operating system (volumio) alerts 'low power'. Disconnecting the power control unit changes this.
Obviously, this power control unit does not deliver enough power/unstable 5V.
Any idea in this?
Cheers
.:.lutz
This review has been posted for AUDIOPHONICS PI-SPC V2 Power Management Module for Raspberry Pi
Nickel
Fonctionne très bien. Installation sur pi 3 et volumio hyper simple. L'accessoire indispensable avec une carte pi. Un seul petit bémol: les barettes de connections ne sont pas très adaptés pour y souder des fils. Peut être vaudrait-il mieux ne rien souder et les mettre dans le sachet?
Useful addition
I use the spc v2 in conjunction with Audiophonics' i-sabre amp-dac hat on a Ri 4. Once I found the Audiophonics github page after digging through the forums, getting the scripts up and running on a vanilla Raspbian build was a breeze (a direct link to these scripts on the product page in addition to the Volumio/Moode tutorials wouldn't hurt) .
Perhaps its a failure of my own wiring, but I've noticed that after adding the module, my Pi no longer provides enough current to power an external hard drive on the USB 3 ports. This was not a problem before, when powering the Pi through the i-sabre amp-dac alone without the PI-SPC.
Indispensable
Produit très simple à mettre en oeuvre avec la carte AUDIOPHONICS I-SABRE AMP DAC ES9023 / Amplificateur Class D 2x30W TPA3118 pour Raspberry Pi
Le fonctionnement avec le plugin Volumio correspondant permet l'utilisation sans connaissance avec cette distribution, sinon j'ai aussi essayé avec les explications du forum très bien aussi.
Le petit plus appréciable, la led clignote pendant le démarrage du raspberry, et devient fixe une fois démarré.
Le service client est top!
Perfect
I have Audiphonics I-Sabre 9038Q2M DAC and everything works perfect. What is more it`s also comaptible with newest moOde. All scripts can be easily found in this link: https://github.com/audiophonics/Raspberry-pwr-management
This power control module for Raspberry Pi allows you to cleanly turn your Raspberry Pi on and off like a family ATX PC. Once the monostable switch...
