SHANLING M1 Black DAP High Fidelity DAC AK4452 32bit/192kHz DSD
Reference : 11359
129,00 €tax incl.
107,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
shanling m1 DSDThe famous Shanling brand here unveils the DAP M1 Nomadic High Fidelity Walkman Bluetooth 4.0 APTX.
Designed around a sober and elegant design at the same time, its compactness brings in a pocket-sized audiophile sound.
Ideal for mobile listening, this full-fidelity player offers you the possibility to play virtually all PCM high-resolution audio files up to32bit 192kHzor DSD 64 and 128.
In addition, the analog part features an original ALPS potentiometer for increased reliability and sound fidelity.
This DAP uses a converter32bit AK4452192Khz latest generation as well as a high performance headphone output MAXA97220the result of which is a great musicality. Its very ergonomic design, its careful electronics makes it a successful product that represents an alternative to larger digital players.
Of course this player is alsoDAC OTG.
Features:/ Strong>
  • Screen: 2.35 "TFT (360x400)
  • Support DSD: Supported and converts to PCM by software channel
  • Bluetooth receiver: Version: 4.0 APT-X
  • DAC conversion component: AK4452
  • Amplification chipheadphone: MAX97220
  • Two-level gain (high / low)
  • Supported formats: APE, FLAC, ALAC, WMA, AAC, OGG, MP3, WAV, AIFF, DSF, DFF
  • Supported sampling frequencies: 44.1-192 kHz
  • Headphone output power: 35mW @ 32Ω
  • Bandwidth: 20Hz to 20kHz (-0.5dB)
  • Distortion: 0.006% (A-weighting, 500mV output)
  • S / N:> 105dB (A-weighting)
  • Dynamic capacity:> 105dB
  • Output Impedance: 0.1Ω
  • Channel separation> 70dB (1 kHz)
  • Jitter: 30ps (Typ)
  • Reference clock: 200 femtoseconds
  • Battery: 950mAH, 9-10 hours of operation (manufacturer data), 3-4 hours of charging
  • OS: Windows XP, 7, 8, 10 (32/64 bit), Mac OS X 10.7 or above
Connectors:
  • USB: Type-C
  • Headphone output: 3.5mm jack
  • Micro SD card reader: 1 TF (up to 200GB)
Dimensions and weight:
  • Width: 60 mm
  • Depth: 12.8 mm
  • Height: 50 mm
  • Weight: 60g
  • Black color
  • Comes with 3 screen protectors / USB-C cable to USB-C 15cm / USB-C cable to USB-B 15cm / USB-C cable angled to USB-C angled 15cm
Hi-Res Audio Certification Shanling M1
: Center; ">shanling m1 DSD
shanling m1 DSD
Casque Shanling M1
Casque audio Shanling M1
Casque Shanling M1
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipAK4452
Max sampling rate192kHz
lecteur de musique top et pas cher
Les +
- Super superbe.
- joli boitier
- application HiBy Musique au top et indispensable pour le contrôler à distance depuis le téléphone, ce qui enlève tous les problème d'ergonomie existant par le passé.
Les - :
Fragile, j'ai cassé la vitre arrière et pourtant ne l'ai jamais fait tomber. D'ailleurs si quelqu'un à une solution, je suis preneur, car elle s’effrite et laisse un trou béant.
This review has been posted for SHANLING M1 Black DAP High Fidelity DAC AK4452 32bit/192kHz DSD
