Choisir son association avec l'IEC Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du...
These 35mm diameter white backlit meters are easy to mount and wire to an amplifier, giving your unit a beautiful vintage look. The meters are delivered with a remote controller and the necessary cables to make the connections. Moreover, this one integrates variable resistors, allowing to adjust the luminous intensity of the backlight of the vumeters as...
Here is a very elegant 3.12 "256x64 OLED screen with superb brightness and excellent readability. It is already mounted on its PCB with a soldered connector.
This small, compact and practical WiFi and Bluetooth receiver will allow you to transform a classic audio system into a real network player. It will allow you to easily stream your music from devices connected to your local network, while enjoying remote control thanks to the free ALink mobile application.
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications.
This WIMA MKP 10 capacitor has a good filter capacity and can be used for many applications. The quality of the design ensures a long service life even at high temperatures.
This WIMA MKP 10 capacitor has a good filtering capacity, allowing it to be used for many applications. It also benefits from a quality design that ensures a long service life, even at high temperatures.
This WIMA MKP 10 capacitor has good filtering capacity, making it suitable for a wide range of applications. It also benefits from a quality design ensuring a long service life, even at high temperatures.
These WIMA MKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 10%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications.
